[GRASS-SVN] r47015 - grass/trunk/lib/vector/Vlib
Wed Jul 6 08:07:29 EDT 2011
Author: mmetz
Date: 2011-07-06 05:07:29 -0700 (Wed, 06 Jul 2011)
New Revision: 47015
   grass/trunk/lib/vector/Vlib/area.c
   grass/trunk/lib/vector/Vlib/find.c
   grass/trunk/lib/vector/Vlib/poly.c
sync Vect_point_in_area() to the other Vect_point_in_*() functions
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c	2011-07-06 12:05:06 UTC (rev 47014)
+++ grass/trunk/lib/vector/Vlib/area.c	2011-07-06 12:07:29 UTC (rev 47015)
@@ -339,20 +339,20 @@
    \return 1 if point is in area
    \return 0 if not
-int Vect_point_in_area(const struct Map_info *Map, int area, double x, double y)
+int Vect_point_in_area(double x, double y, const struct Map_info *Map,
+                       int area, struct bound_box box)
     int i, isle;
     const struct Plus_head *Plus;
     struct P_area *Area;
+    struct bound_box ibox;
     int poly;
-    struct bound_box box;
     Plus = &(Map->plus);
     Area = Plus->Area[area];
     if (Area == NULL)
 	return 0;
-    Vect_get_area_box(Map, area, &box);
     poly = Vect_point_in_area_outer_ring(x, y, Map, area, box);
     if (poly == 0)
 	return 0;		/* includes area boundary (poly == 2), OK? */
@@ -360,8 +360,8 @@
     /* check if in islands */
     for (i = 0; i < Area->n_isles; i++) {
 	isle = Area->isles[i];
-	Vect_get_isle_box(Map, isle, &box);
-	poly = Vect_point_in_island(x, y, Map, isle, box);
+	Vect_get_isle_box(Map, isle, &ibox);
+	poly = Vect_point_in_island(x, y, Map, isle, ibox);
 	if (poly >= 1)
 	    return 0;		/* excludes island boundary (poly == 2), OK? */
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c	2011-07-06 12:05:06 UTC (rev 47014)
+++ grass/trunk/lib/vector/Vlib/find.c	2011-07-06 12:07:29 UTC (rev 47015)
@@ -28,6 +28,7 @@
 typedef struct {
     int i;
     double size;
+    struct bound_box box;
 } BOX_SIZE;
 static int sort_by_size(const void *a, const void *b)
@@ -299,6 +300,7 @@
     for (i = 0; i < List->n_values; i++) {
 	size_list[i].i = List->id[i];
 	box = List->box[i];
+	size_list[i].box = List->box[i];
 	size_list[i].size = (box.N - box.S) * (box.E - box.W);
@@ -314,7 +316,7 @@
 	area = size_list[i].i;
-	ret = Vect_point_in_area(Map, area, x, y);
+	ret = Vect_point_in_area(x, y, Map, area, size_list[i].box);
 	G_debug(3, "    area = %d Vect_point_in_area() = %d", area, ret);
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c	2011-07-06 12:05:06 UTC (rev 47014)
+++ grass/trunk/lib/vector/Vlib/poly.c	2011-07-06 12:07:29 UTC (rev 47015)
@@ -695,6 +695,7 @@
     int n_intersects, inter;
     int i, line;
     static struct line_pnts *Points;
+    struct bound_box lbox;
     struct P_line *Line;
@@ -715,16 +716,24 @@
 	return 0;
     n_intersects = 0;
     for (i = 0; i < Area->n_lines; i++) {
 	line = abs(Area->lines[i]);
 	G_debug(3, "  line[%d] = %d", i, line);
 	Line = Plus->Line[line];
+	/* this is slow, but the fastest of all alternatives */
+	Vect_get_line_box(Map, line, &lbox);
+	/* slower as long as the spatial index is in memory: */
+	Vect_read_line(Map, Points, NULL, line);
+	Vect_line_box(Points, &lbox);
-	Vect_get_line_box(Map, line, &box);
 	/* dont check lines that obviously do not intersect with test ray */
-	if ((box.N < Y) || (box.S > Y) || (box.E < X))
+	if ((lbox.N < Y) || (lbox.S > Y) || (lbox.E < X))
 	    continue;
@@ -763,6 +772,7 @@
     int i, line;
     struct P_isle *Isle;
@@ -786,10 +796,17 @@
 	    continue;
