[GRASS-SVN] r47030 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 6 16:33:48 EDT 2011
Author: annakrat
Date: 2011-07-06 13:33:48 -0700 (Wed, 06 Jul 2011)
New Revision: 47030
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
wxNviz: fixed small bugs in volume page gui
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-07-06 16:07:31 UTC (rev 47029)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-07-06 20:33:48 UTC (rev 47030)
@@ -2388,7 +2388,7 @@
else:
value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
- useMap = False
+ useMap = False
else:
useMap = None
@@ -2410,7 +2410,7 @@
if attrb == 'topo':
list = self.FindWindowById(self.win['volume']['isosurfs'])
sel = list.GetSelection()
- list.SetString(sel, "%s %s" % (_("Level"), str(value)))
+ list.SetString(sel, "%s %.1f" % (_("Level"), value))
list.Check(sel)
# update properties
@@ -2896,6 +2896,9 @@
def OnVolumeIsosurfMap(self, event):
"""!Set surface attribute"""
+ if self.vetoGSelectEvt:
+ self.vetoGSelectEvt = False
+ return
self.SetMapObjAttrb(nvizType = 'volume', winId = event.GetId())
def OnVolumeIsosurfCheck(self, event):
@@ -2909,7 +2912,17 @@
isosurfId = event.GetSelection()
if list.IsChecked(index):
- self._display.SetIsosurfaceTransp(id, isosurfId, False, "0")
+ if 'transp' in data['isosurface'][isosurfId] and\
+ data['isosurface'][isosurfId]['transp']['map'] is not None:
+ if data['isosurface'][isosurfId]['transp']['map']:
+ map = True
+ value = data['isosurface'][isosurfId]['transp']['value']
+ elif data['isosurface'][isosurfId]['transp']['map'] is not None:
+ map = False
+ self._display.SetIsosurfaceTransp(id, isosurfId, map, value)
+ else:
+ self._display.SetIsosurfaceTransp(id, isosurfId, False, "0")
else:
# disable -> make transparent
self._display.SetIsosurfaceTransp(id, isosurfId, False, "255")
@@ -2972,6 +2985,7 @@
isosurfData[attrb] = {}
win = self.FindWindowById(self.win['volume'][attrb]['const'])
isosurfData[attrb]['value'] = win.GetValue()
+ isosurfData[attrb]['map'] = None
else:
uwin = self.FindWindowById(self.win['volume'][attrb]['use'])
sel = uwin.GetSelection()
@@ -3003,6 +3017,7 @@
# update buttons
self.UpdateIsosurfButtons(list)
+ self.UpdateVolumeIsosurfPage(layer, isosurfData)
if self.mapDisplay.statusbarWin['render'].IsChecked():
self.mapWindow.Refresh(False)
@@ -3600,13 +3615,14 @@
# check required first
if attrb == 'color':
if layer and layer.type == '3d-raster':
+ self.vetoGSelectEvt = True
self.FindWindowById(self.win['volume'][attrb]['map']).SetValue(layer.name)
else:
self.FindWindowById(self.win['volume'][attrb]['map']).SetValue('')
self.SetMapObjUseMap(nvizType = 'volume',
attrb = attrb, map = True) # -> map
- continue
+ #continue
# skip empty attributes
if attrb not in data:
@@ -3622,15 +3638,28 @@
self.FindWindowById(self.win['volume'][attrb]['const']).SetColour(color)
else:
if data[attrb]['map']:
win = self.FindWindowById(self.win['volume'][attrb]['map'])
win.SetValue(value)
else:
- win = self.FindWindowById(self.win['volume'][attrb]['const'])
- win.SetValue(float(value))
+ if value:
+ win = self.FindWindowById(self.win['volume'][attrb]['const'])
+ win.SetValue(float(value))
attrb = attrb, map = data[attrb]['map'])
+ ret = gcmd.RunCommand('r3.info', read = True, flags = 'r', map = layer.name)
+ if ret:
+ range = []
+ for value in ret.strip('\n').split('\n'):
+ range.append(value.split('=')[1])
+ topo = self.FindWindowById(self.win['volume']['topo']['const'])
+ if fs:
+ topo.SetRange(min_val = float(range[0]), max_val = float(range[1]))
+ else:
+ topo.SetRange(minVal = int(range[0]), maxVal = int(range[1]))
def SetPage(self, name):
"""!Get named page"""
if name == 'view':
