[GRASS-SVN] r47040 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Jul 7 04:56:17 EDT 2011
Author: mmetz
Date: 2011-07-07 01:56:17 -0700 (Thu, 07 Jul 2011)
New Revision: 47040
grass/trunk/lib/vector/Vlib/box.c
avoid compiler warnings in Vlib
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c 2011-07-07 08:55:49 UTC (rev 47039)
+++ grass/trunk/lib/vector/Vlib/box.c 2011-07-07 08:56:17 UTC (rev 47040)
@@ -192,7 +192,6 @@
\brief Get bounding box of given feature
@@ -205,12 +204,12 @@
int Vect_get_line_box(const struct Map_info *Map, int line, struct bound_box * Box)
- const struct Plus_head *Plus;
+ struct Plus_head *Plus;
struct P_line *Line;
static struct line_pnts *Points = NULL;
static struct boxlist *list = NULL;
- Plus = &(Map->plus);
+ Plus = (struct Plus_head *)&(Map->plus);
Line = Plus->Line[line];
if (Line == NULL) { /* dead */
@@ -278,6 +277,7 @@
return 1;
\brief Get bounding box of area
@@ -290,7 +290,7 @@
int Vect_get_area_box(const struct Map_info *Map, int area, struct bound_box * Box)
struct P_area *Area;
struct P_node *Node;
@@ -298,7 +298,7 @@
struct bound_box bbox;
struct P_topo_b *topo;
Area = Plus->Area[area];
if (Area == NULL) { /* dead */
@@ -357,7 +357,7 @@
int Vect_get_isle_box(const struct Map_info *Map, int isle, struct bound_box * Box)
struct P_isle *Isle;
@@ -365,7 +365,7 @@
Isle = Plus->Isle[isle];
if (Isle == NULL) { /* dead */
