[GRASS-SVN] r47048 - grass/trunk/gui/wxpython/gui_modules
    svn_grass at osgeo.org
    Thu Jul  7 12:05:40 EDT 2011
Author: annakrat
Date: 2011-07-07 09:05:40 -0700 (Thu, 07 Jul 2011)
New Revision: 47048
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxNviz: volumes: fixed loading when re-checking layer, added positioning
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-07 12:21:52 UTC (rev 47047)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-07 16:05:40 UTC (rev 47048)
@@ -650,11 +650,11 @@
         @param nvizType nviz data type (surface, points, vector)
         if nvizType != 'constant':
-            type = self.tree.GetPyData(item)[0]['maplayer'].type
+            mapType = self.tree.GetPyData(item)[0]['maplayer'].type
             # reference to original layer properties (can be None)
             data = self.tree.GetPyData(item)[0]['nviz']
         else:
-            type = nvizType
+            mapType = nvizType
             data = self.constants[item]
         if not data:
@@ -663,56 +663,60 @@
                 self.tree.GetPyData(item)[0]['nviz'] = {}
-            if type ==  'raster':
+            if mapType ==  'raster':
                 # reset to default properties
                 data[nvizType] = self.nvizDefault.SetSurfaceDefaultProp()
-            elif type ==  'vector':
+            elif mapType ==  'vector':
                 # reset to default properties (lines/points)
                 data['vector'] = self.nvizDefault.SetVectorDefaultProp()
                 self.SetVectorFromCmd(item, data['vector'])
                 self.SetVectorSurface(data['vector']['points'])
                 self.SetVectorSurface(data['vector']['lines'])
-            elif type ==  '3d-raster':
+            elif mapType ==  '3d-raster':
                 data[nvizType] = self.nvizDefault.SetVolumeDefaultProp()
-            elif type == 'constant':
+            elif mapType == 'constant':
                 data['constant'] = self.nvizDefault.SetConstantDefaultProp()
         else:
             # complete data (use default values), not sure if this is necessary
                 if not data['surface']:
                     data['surface'] = self.nvizDefault.SetSurfaceDefaultProp()
-            if type ==  'vector':
+            if mapType ==  'vector':
                 if not data['vector']['lines']:
                     self.nvizDefault.SetVectorLinesDefaultProp(data['vector']['lines'])
                 if not data['vector']['points']:
-                    self.nvizDefault.SetVectorPointsDefaultProp(data['vector']['points'])
+                    self.nvizDefault.SetVectorPointsDefaultProp(data['vector']['points'])
             # set updates
             for sec in data.keys():
                 for sec1 in data[sec].keys():
                     if sec1 == 'position':
                         data[sec][sec1]['update'] = None
                         continue
-                    for sec2 in data[sec][sec1].keys():
-                        if sec2 !=  'all':
-                            data[sec][sec1][sec2]['update'] = None
+                    if type(data[sec][sec1]) == type({}):
+                        for sec2 in data[sec][sec1].keys():
+                            if sec2 !=  'all':
+                                data[sec][sec1][sec2]['update'] = None
+                    elif type(data[sec][sec1]) == type([]):
+                        for i in range(len(data[sec][sec1])):
+                            for sec2 in data[sec][sec1][i].keys():
+                                data[sec][sec1][i][sec2]['update'] = None
             event = wxUpdateProperties(data = data)
             wx.PostEvent(self, event)
         # set id
         if id > 0:
-            if type in ('raster', '3d-raster'):
+            if mapType in ('raster', '3d-raster'):
                data[nvizType]['object'] = { 'id' : id,
                                             'init' : False }
                 data['vector'][nvizType]['object'] = { 'id' : id,
                                                        'init' : False }
                                              'init' : False }
@@ -880,12 +884,19 @@
         self.layers.remove(item)
         # update tools window
-        if hasattr(self.lmgr, "nviz") and \
-                layer.type ==  'raster':
+        if hasattr(self.lmgr, "nviz"):
             toolWin = self.lmgr.nviz
-            win = toolWin.FindWindowById( \
-                toolWin.win['vector']['lines']['surface'])
-            win.SetItems(self.GetLayerNames(layer.type))
+            if layer.type ==  'raster':
+                win = toolWin.FindWindowById(toolWin.win['vector']['lines']['surface'])
+                win.SetItems(self.GetLayerNames(layer.type))
+                win = toolWin.FindWindowById(toolWin.win['surface']['map'])
+                win.SetValue('')
+            if layer.type ==  '3d-raster':
+                win = toolWin.FindWindowById(toolWin.win['volume']['map'])
+                win.SetValue('')
+            if layer.type ==  'vector':
+                win = toolWin.FindWindowById(toolWin.win['vector']['map'])
+                win.SetValue('')
     def LoadVector(self, item, points = None):
         """!Load 2D or 3D vector map overlay
@@ -1176,6 +1187,7 @@
         isosurfId = 0
         for isosurf in data['isosurface']:
+            self._display.AddIsosurface(id, 0, isosurf_id = isosurfId)
             for attrb in ('topo', 'color', 'mask',
                           'transp', 'shine'):
                 if attrb not in isosurf or \
@@ -1187,7 +1199,7 @@
                 if map is None: # unset
                     # only optional attributes
                     if attrb == 'topo' :
-                         self._display.SetIsosurfaceTopo(id, isosurfId, map, str(value))
+                        self._display.SetIsosurfaceTopo(id, isosurfId, map, str(value))
                     elif attrb ==  'mask':
                         # TODO: invert mask
                         # TODO: broken in NVIZ
@@ -1210,7 +1222,14 @@
                         self._display.SetIsosurfaceShine(id, isosurfId, map, str(value))
                 isosurf[attrb].pop('update')
             isosurfId +=  1
+        # position
+        if 'update' in data['position']:
+            x = data['position']['x']
+            y = data['position']['y']
+            z = data['position']['z']
+            self._display.SetVolumePosition(id, x, y, z)
+            data['position'].pop('update')
     def UpdateVectorProperties(self, id, data, type):
         """!Update vector layer properties
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-07-07 12:21:52 UTC (rev 47047)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-07-07 16:05:40 UTC (rev 47048)
@@ -551,6 +551,7 @@
         all.Bind(wx.EVT_BUTTON, self.OnSurfaceModeAll)
         gridSizer.Add(item = all, flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
                       pos = (3, 4))
+        self.win['surface']['all'] = all.GetId()
         # resolution coarse
         gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
@@ -704,7 +705,7 @@
         # position
         self._createControl(panel, data = self.win['surface'], name = 'position',
                             range = (-10000, 10000),
-                            bind = (self.OnSurfacePosition, self.OnSurfacePositionChanged, self.OnSurfacePosition))
+                            bind = (self.OnSurfacePosition, self.OnSurfacePositionChanged, self.OnSurfacePositionText))
         axis = wx.Choice (parent = panel, id = wx.ID_ANY, size = (75, -1),
                           choices = ["X",
@@ -714,6 +715,7 @@
         reset = wx.Button(panel, id = wx.ID_ANY, label = _("Reset"))
         reset.SetToolTipString(_("Reset to default position"))
         reset.Bind(wx.EVT_BUTTON, self.OnResetSurfacePosition)
+        self.win['surface']['position']['reset'] = reset.GetId()
         self.win['surface']['position']['axis'] = axis.GetId()
         axis.SetSelection(0)
@@ -1291,13 +1293,13 @@
                             label = " %s " % (_("Draw")))
         boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
         gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
-        gridSizer.AddGrowableCol(4)
+##        gridSizer.AddGrowableCol(4)
         # mode
                                          label = _("Mode:")),
                       pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
-        mode = wx.Choice (parent = panel, id = wx.ID_ANY, size = (150, -1),
+        mode = wx.Choice (parent = panel, id = wx.ID_ANY, size = (-1, -1),
                           choices = [_("isosurfaces"),
                                      _("slides")])
         mode.SetSelection(0)
@@ -1506,6 +1508,50 @@
                       flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
                       border = 3)
+        # position
+        self.win['volume']['position'] = {}
+        box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
+                            label = " %s " % (_("Position")))
+        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.GridBagSizer(vgap = 3, hgap = 3)
+        gridSizer.AddGrowableCol(3)
+        # position
+        self._createControl(panel, data = self.win['volume'], name = 'position',
+                            range = (-10000, 10000),
+                            bind = (self.OnVolumePosition, self.OnVolumePositionChanged, self.OnVolumePositionText))
+        axis = wx.Choice (parent = panel, id = wx.ID_ANY, size = (75, -1),
+                          choices = ["X",
+                                     "Y",
+                                     "Z"])
+        reset = wx.Button(panel, id = wx.ID_ANY, label = _("Reset"))
+        reset.SetToolTipString(_("Reset to default position"))
+        reset.Bind(wx.EVT_BUTTON, self.OnResetVolumePosition)
+        self.win['volume']['position']['reset'] = reset.GetId()
+        self.win['volume']['position']['axis'] = axis.GetId()
+        axis.SetSelection(0)
+        axis.Bind(wx.EVT_CHOICE, self.OnVolumeAxis)
+        pslide = self.FindWindowById(self.win['volume']['position']['slider'])
+        ptext = self.FindWindowById(self.win['volume']['position']['text'])
+        ptext.SetValue('0')
+        gridSizer.Add(item = axis, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+        gridSizer.Add(item = pslide, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 1))
+        gridSizer.Add(item = ptext, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 2))
+        gridSizer.Add(item = reset, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, pos = (0, 3))
+        boxSizer.Add(item = gridSizer, proportion = 1,
+                  flag = wx.ALL | wx.EXPAND, border = 3)
+        pageSizer.Add(item = boxSizer, proportion = 1,
+                      flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+                      border = 3)
         panel.SetSizer(pageSizer)
         panel.Fit()
@@ -2194,6 +2240,8 @@
         for win in self.win['surface']['position'].itervalues():
             if win == self.win['surface']['position']['axis']:
                 self.FindWindowById(win).SetSelection(0)
+            elif win == self.win['surface']['position']['reset']:
+                continue
             else:
                 self.FindWindowById(win).SetValue(0)
@@ -2566,7 +2614,8 @@
         self.AdjustSliderRange(slider = slider, value = value)
-            if win == self.win['surface']['position']['axis']:
+            if win in (self.win['surface']['position']['axis'],
+                       self.win['surface']['position']['reset']):
                 continue
             else:
                 self.FindWindowById(win).SetValue(value)
@@ -2601,6 +2650,11 @@
         self.mapWindow.render['quick'] = False
         self.mapWindow.Refresh(False)
+    def OnSurfacePositionText(self, event):
+        """!Surface position changed by textctrl"""
+        self.OnSurfacePosition(event)
+        self.OnSurfacePositionChanged(None)
     def UpdateVectorShow(self, vecType, enabled):
         """!Enable/disable lines/points widgets
@@ -3140,6 +3194,101 @@
         event.Skip()
+    def OnVolumePositionChanged(self, event):
+        """!Volume position changed"""
+        self.mapWindow.render['quick'] = False
+        self.mapWindow.Refresh(False)
+    def OnVolumePosition(self, event):
+        """!Volume position"""
+        winName = self.__GetWindowName(self.win['volume'], event.GetId())
+        if not winName:
+            return
+        axis = self.FindWindowById(self.win['volume']['position']['axis']).GetSelection()
+        value = self.FindWindowById(event.GetId()).GetValue()
+        slider = self.FindWindowById(self.win['volume'][winName]['slider'])
+        self.AdjustSliderRange(slider = slider, value = value)
+        for win in self.win['volume']['position'].itervalues():
+            if win in (self.win['volume']['position']['axis'],
+                       self.win['volume']['position']['reset']):
+                continue
+            else:
+                self.FindWindowById(win).SetValue(value)
+        data = self.GetLayerData('volume')
+        id = data['volume']['object']['id']
+        x, y, z = self._display.GetVolumePosition(id)
+        if axis == 0: # x
+            x = value
+        elif axis == 1: # y
+            y = value
+        else: # z
+            z = value
+        data['volume']['position']['x'] = x
+        data['volume']['position']['y'] = y
+        data['volume']['position']['z'] = z
+        data['volume']['position']['update'] = None
+        # update properties
+        event = wxUpdateProperties(data = data)
+        wx.PostEvent(self.mapWindow, event)
+        self.mapWindow.render['quick'] = True
+        if self.mapDisplay.statusbarWin['render'].IsChecked():
+    def OnVolumeAxis(self, event):
+        """!Volume position, axis changed"""
+        slider = self.FindWindowById(self.win['volume']['position']['slider'])
+        text = self.FindWindowById(self.win['volume']['position']['text'])
+        if axis == 0: # x
+            slider.SetValue(x)
+            text.SetValue(x)
+            slider.SetValue(y)
+            text.SetValue(y)
+        else: # z
+            slider.SetValue(z)
+            text.SetValue(z)
+    def OnVolumePositionText(self, event):
+        """!Volume position changed by textctrl"""
+        self.OnVolumePosition(event)
+        self.OnVolumePositionChanged(None)
+    def OnResetVolumePosition(self, event):
+        """!Reset position of volume"""
+            if win == self.win['volume']['position']['axis']:
+                self.FindWindowById(win).SetSelection(0)
+            elif win == self.win['volume']['position']['reset']:
+                continue
+            else:
+                self.FindWindowById(win).SetValue(0)
+        data['volume']['position']['x'] = 0
+        data['volume']['position']['y'] = 0
+        data['volume']['position']['z'] = 0
     def OnCPlaneSelection(self, event):
         """!Cutting plane selected"""
         plane = self.FindWindowById(self.win['cplane']['planes']).GetStringSelection()
@@ -3307,7 +3456,7 @@
                     self.UpdateVectorPage(layer, data['vector'])
                 elif pageId == 'volume':
                     layer = self.mapWindow.GetLayerByName(name, mapType = '3d-raster')
-                    self.UpdateVectorPage(layer, data['vector'])
+                    self.UpdateVolumePage(layer, data['volume'])
         elif pageId == 'light':
             zval = self.mapWindow.light['position']['z']
             bval = self.mapWindow.light['bright']
@@ -3635,7 +3784,14 @@
             self.UpdateVolumeIsosurfPage(layer, data['isosurface'][0])
         else:
             self.UpdateVolumeIsosurfPage(layer, data['attribute'])
+        # position
+        if 'x' in data['position']:
+            xval = data['position']['x']
+            self.FindWindowById(self.win['volume']['position']['axis']).SetSelection(0)
+            for control in ('slider','text'):
+                    self.FindWindowById(self.win['volume']['position'][control]).SetValue(xval)
     def UpdateVolumeIsosurfPage(self, layer, data):
         """!Update dialog -- isosurface attributes"""
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-07-07 12:21:52 UTC (rev 47047)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-07-07 16:05:40 UTC (rev 47048)
@@ -949,7 +949,7 @@
         return 1
-    def AddIsosurface(self, id, level):
+    def AddIsosurface(self, id, level, isosurf_id = None):
         """!Add new isosurface
         @param id volume id
@@ -961,6 +961,11 @@
         if not GVL_vol_exists(id):
             return -1
+        if isosurf_id is not None:
+            num = GVL_isosurf_num_isosurfs(id)
+            if num < 0 or isosurf_id != num:
+                return -1
         if GVL_isosurf_add(id) < 0:
             return -1
@@ -1280,6 +1285,45 @@
         return 1
+    def GetVolumePosition(self, id):
+        """!Get volume position
+        @param id volume id
+        @return x,y,z
+        @return zero-length vector on error
+        if not GVL_vol_exists(id):
+            return []
+        x, y, z = c_float(), c_float(), c_float()
+        GVL_get_trans(id, byref(x), byref(y), byref(z))
+        Debug.msg(3, "Nviz::GetVolumePosition(): id=%d, x=%f, y=%f, z=%f",
+                  id, x.value, y.value, z.value)
+        return [x.value, y.value, z.value]
+    def SetVolumePosition(self, id, x, y, z):
+        """!Set volume position
+        @param x,y,z translation values
+        @return 1 on success
+        @return -1 volume not found
+        @return -2 setting position failed
+            return -1
+        Debug.msg(3, "Nviz::SetVolumePosition(): id=%d, x=%f, y=%f, z=%f",
+                  id, x, y, z)
+        GVL_set_trans(id, x, y, z)
+        return 1
     def GetCPlaneCurrent(self):
         return Nviz_get_current_cplane(self.data)
