[GRASS-SVN] r47069 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sat Jul 9 08:59:10 EDT 2011
Author: martinl
Date: 2011-07-09 05:59:10 -0700 (Sat, 09 Jul 2011)
New Revision: 47069
grass/trunk/display/d.vect/main.c
d.vect: call G_get_set_window() after D_open_driver() to read GRASS_REGION
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2011-07-09 12:35:00 UTC (rev 47068)
+++ grass/trunk/display/d.vect/main.c 2011-07-09 12:59:10 UTC (rev 47069)
@@ -374,12 +374,12 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- G_get_set_window(&window);
if (D_open_driver() != 0)
G_fatal_error(_("No graphics device selected. "
"Use d.mon to select graphics device."));
+ G_get_set_window(&window);
/* Read map options */
/* Check min/max region */
