[GRASS-SVN] r47091 -
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
svn_grass at osgeo.org
Sun Jul 10 15:55:00 EDT 2011
Author: madi
Date: 2011-07-10 12:55:00 -0700 (Sun, 10 Jul 2011)
New Revision: 47091
Added:
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
panel network extraction
Added: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py 2011-07-10 19:55:00 UTC (rev 47091)
@@ -0,0 +1,182 @@
+#!/usr/bin/python
+# -*- coding: utf-8 -*-
+import wx
+import gselect
+# First panel # Network extraction
+class TabPanelOne(wx.Panel):
+ def __init__(self, parent):
+ wx.Panel.__init__(self, parent, id = wx.ID_ANY)
+ self.parent = parent
+ # define the panel for select maps
+ self.panel = wx.Panel(self)
+ # create the layout
+ self._layout()
+ def _layout(self):
+ # create the grid for gselect
+ select = wx.GridBagSizer(20, 5)
+ #---------Input maps---------
+ # Ask user for digital elevation model
+ text1 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Elevation map (required)")
+ select.Add(item = text1, flag = wx.LEFT, pos = (1,0), span = wx.DefaultSpan, border = 0)
+ # Add the box for choosing the map
+ select1 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
+ type = 'rast', multiple = False)
+ select.Add(item = select1, pos = (2,0), span = wx.DefaultSpan)
+ # binder
+ select1.Bind(wx.EVT_TEXT, self.OnSelect)
+ # Ask user for Flow accumulation
+ text2 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT/OUTPUT : Flow accumulation (required)")
+ select.Add(item = text2, flag = wx.LEFT, pos = (3,0), span = wx.DefaultSpan)
+ # Flow accum can be either existent or to be calculated
+ # Check box
+ hbox1 = wx.BoxSizer(wx.HORIZONTAL)
+ cb1 = wx.CheckBox(parent = self.panel, label='Create by MFD algorithm')
+ hbox1.Add(item = cb1, flag = wx.LEFT, border=10)
+ cb2 = wx.CheckBox(parent = self.panel, label='Create by SFD algorithm')
+ hbox1.Add(item = cb2, flag = wx.LEFT, border=10)
+ cb3 = wx.CheckBox(parent = self.panel, label='Custom (select existing map)')
+ hbox1.Add(item = cb3, flag = wx.LEFT, border=10)
+ select.Add(item = hbox1, pos = (4,0))
+ # Check box binder
+ # Box to insert name of new acc map (to be created)
+ txtOne = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
+ select.Add(item = txtOne, flag = wx.LEFT | wx.EXPAND , pos = (5,0), span = wx.DefaultSpan)
+ select2 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
+ select.Add(item = select2, pos = (6,0), span = wx.DefaultSpan)
+ # binder
+ select2.Bind(wx.EVT_TEXT, self.OnSelect)
+ # Ask user for Mask
+ text3 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Mask (optional)")
+ select.Add(item = text3, flag = wx.LEFT, pos = (7,0), span = wx.DefaultSpan)
+ select3 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
+ select.Add(item = select3, pos = (8,0), span = wx.DefaultSpan)
+ # binder
+ select3.Bind(wx.EVT_TEXT, self.OnSelect)
+ # Ask user for threshold
+ text4 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Threshold (required)")
+ select.Add(item = text4, flag = wx.LEFT, pos = (9,0), span = wx.DefaultSpan)
+ # Box to insert threshold
+ txtTwo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
+ select.Add(item = txtTwo, flag = wx.LEFT, pos = (10,0), span = wx.DefaultSpan)
+ #---------Output maps---------
+ # Flow direction map
+ text5 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Flow direction map (required)")
+ select.Add(item = text5, flag = wx.LEFT | wx.EXPAND, pos = (11,0), span = wx.DefaultSpan)
+ # Box to insert name of new flow dir map (to be created)
+ txtThr = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
+ select.Add(item = txtThr, flag = wx.LEFT | wx.EXPAND , pos = (12,0), span = wx.DefaultSpan)
+ # Streams map
+ text6 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Streams (required)")
+ select.Add(item = text6, flag = wx.LEFT | wx.EXPAND, pos = (13,0), span = wx.DefaultSpan)
+ # Box to insert name of new streams map (to be created)
+ txtFou = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
+ select.Add(item = txtFou, flag = wx.LEFT | wx.EXPAND , pos = (14,0), span = wx.DefaultSpan)
+ # Network map
+ text7 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Network (required)")
+ select.Add(item = text7, flag = wx.LEFT | wx.EXPAND, pos = (15,0), span = wx.DefaultSpan)
+ txtFiv = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
+ select.Add(item = txtFiv, flag = wx.LEFT | wx.EXPAND , pos = (16,0), span = wx.DefaultSpan)
+ self.panel.SetSizer(select)
+ btnPanel = wx.Panel(self)
+ #-------------Buttons-------------
+ self.createButtonBar(btnPanel)
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ sizer.Add(self.panel, 1, wx.EXPAND)
+ sizer.Add(btnPanel, 0, wx.EXPAND)
+ self.SetSizer(sizer)
+ def OnSelect(self, event):
+ """!Gets raster map or function selection and send it to
+ insertion method
+ item = event.GetString()
+ self._addSomething(item)
+ def buttonData(self):
+ return (("Update Preview", self.OnPreview),
+ ("Run Analysis", self.OnRun))
+ def createButtonBar(self, panel, yPos = 0):
+ xPos = 0
+ for eachLabel, eachHandler in self.buttonData():
+ pos = (xPos, yPos)
+ button = self.buildOneButton(panel, eachLabel, eachHandler, pos)
+ xPos += button.GetSize().width
+ def buildOneButton(self, parent, label, handler, pos = (0,0)):
+ button = wx.Button(parent, wx.ID_ANY, label, pos)
+ self.Bind(wx.EVT_BUTTON, handler, button)
+ return button
+ def OnPreview(self, event):
+ pass
+ def OnRun(self, event):
+ pass
