[GRASS-SVN] r47113 - grass/trunk/raster/r.texture
svn_grass at osgeo.org
Thu Jul 14 09:01:53 EDT 2011
Author: mmetz
Date: 2011-07-14 06:01:53 -0700 (Thu, 14 Jul 2011)
New Revision: 47113
grass/trunk/raster/r.texture/main.c
scale input if needed
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c 2011-07-14 13:01:30 UTC (rev 47112)
+++ grass/trunk/raster/r.texture/main.c 2011-07-14 13:01:53 UTC (rev 47113)
@@ -54,11 +54,12 @@
int nrows, ncols;
int row, col, i, j;
CELL **data; /* Data structure containing image */
- CELL *cell_row;
+ DCELL *dcell_row;
+ struct FPRange range;
+ DCELL min, max, inscale;
FCELL measure; /* Containing measure done */
int t_measure, dist, size; /* dist = value of distance, size = s. of sliding window */
int infd, outfd;
- int verbose;
int a, c, corr, v, idm, sa, sv, se, e, dv, de, moc1, moc2, mcc;
RASTER_MAP_TYPE data_type, out_data_type;
struct GModule *module;
@@ -230,7 +231,7 @@
/* Load raster map. */
/* allocate the space for one row of cell map data *A* */
- cell_row = Rast_allocate_c_buf();
+ dcell_row = Rast_allocate_d_buf();
/* Allocate appropriate memory for the structure containing the image */
data = (int **)G_malloc(nrows * sizeof(int *));
@@ -238,17 +239,37 @@
data[i] = (int *)G_malloc(ncols * sizeof(int));
+ /* read input range */
+ Rast_init_fp_range(&range);
+ Rast_read_fp_range(name, "", &range);
+ Rast_get_fp_range_min_max(&range, &min, &max);
+ inscale = 0;
+ if (min < 0 || max > 255) {
+ inscale = 255. / (max - min);
+ /* input has 0 - 1 range */
+ else if (max <= 1.) {
/* Read in cell map values */
G_important_message(_("Reading raster map..."));
for (j = 0; j < nrows; j++) {
- Rast_get_row(infd, cell_row, j, CELL_TYPE);
- for (i = 0; i < ncols; i++)
- data[j][i] = (int)cell_row[i];
+ Rast_get_row(infd, dcell_row, j, DCELL_TYPE);
+ for (i = 0; i < ncols; i++) {
+ if (Rast_is_d_null_value(&(dcell_row[i])))
+ data[j][i] = -1;
+ else if (inscale) {
+ data[j][i] = (CELL)((dcell_row[i] - min) * inscale);
+ else
+ data[j][i] = (CELL)dcell_row[i];
/* close input cell map and release the row buffer */
Rast_close(infd);
- G_free(cell_row);
+ G_free(dcell_row);
/* Now raster map is into memory. */
@@ -288,9 +309,13 @@
out_data_type);
*result = '\0';
+ strcpy(mapname, filename);
+ strcat(mapname, suffixes[t_measure]);
+ G_important_message(_("Calculating measure #%d <%s> (56 measures available)"),
+ (t_measure + 1), mapname);
for (row = 0; row < nrows - (size - 1); row++) {
- if (verbose)
- G_percent(row, nrows, 2);
+ G_percent(row, nrows, 2);
/*process the data */
for (col = 0; col < ncols - (size - 1); col++) {
@@ -340,10 +365,6 @@
Rast_put_row(outfd, outrast, out_data_type);
Rast_close(outfd);
- strcpy(mapname, filename);
- strcat(mapname, suffixes[t_measure]);
- G_important_message(_("Calculated measure #%d <%s> (56 measures available)"),
- (t_measure + 1), mapname);
Rast_short_history(mapname, "raster", &history);
Rast_command_history(&history);
