[GRASS-SVN] r47119 - grass/branches/develbranch_6/locale/po
Fri Jul 15 03:36:50 EDT 2011
Author: lucadelu
Date: 2011-07-15 00:36:50 -0700 (Fri, 15 Jul 2011)
New Revision: 47119
   grass/branches/develbranch_6/locale/po/grassmods_it.po
update italian grassmods messages
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-07-15 07:36:19 UTC (rev 47118)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-07-15 07:36:50 UTC (rev 47119)
@@ -14,13 +14,13 @@
 "Project-Id-Version: grassmods_it\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-06-09 20:20+0200\n"
-"PO-Revision-Date: 2008-03-26 17:32+0100\n"
-"Last-Translator: Marco Curreli <marcocurreli at tiscali it>\n"
+"PO-Revision-Date: 2011-07-15 07:22+0100\n"
+"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
+"Language: it\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: it\n"
 "X-Generator: KBabel 1.11.4\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
@@ -46,7 +46,7 @@
 #: ../raster3d/r3.out.ascii/main.c:98 ../raster/r.transect/main.c:85
 #: ../raster/r.what/main.c:117
 msgid "Char string to represent no data cell"
-msgstr ""
+msgstr "Stringa per rappresentare celle senza valore"
 #: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
 #: ../raster/r.out.arc/main.c:89
@@ -90,9 +90,7 @@
 #: ../raster3d/r3.in.ascii/main.c:90
 #, fuzzy
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Stringa rappresentante la cella con valore NULL (usare 'none' se non ci sono "
-"valori null)"
+msgstr "Stringa rappresentante la cella con valore NULL (usare 'none' se non ci sono valori null)"
 #: ../raster3d/r3.in.ascii/main.c:174
 #, c-format
@@ -101,13 +99,11 @@
 #: ../raster3d/r3.in.ascii/main.c:190
 msgid "End of file reached while still loading data."
-msgstr ""
-"Raggiunta la fine del file mentre è ancora in corso il caricamento dei dati."
+msgstr "Raggiunta la fine del file mentre è ancora in corso il caricamento dei dati."
 #: ../raster3d/r3.in.ascii/main.c:209
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:240 ../raster3d/r3.in.v5d/main.c:193
@@ -116,8 +112,7 @@
 #: ../raster3d/r3.in.ascii/main.c:242
 msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr ""
-"Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+msgstr "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
 #: ../raster3d/r3.in.ascii/main.c:274
 #, fuzzy
@@ -162,7 +157,7 @@
 #: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
 msgid "Could not write raster row"
-msgstr ""
+msgstr "Non è possibile scrivere la riga del raster"
 #: ../raster3d/r3.cross.rast/main.c:270 ../raster3d/r3.to.rast/main.c:215
 #: ../raster3d/r3.gwflow/main.c:184 ../raster3d/r3.mkdspf/main.c:75
@@ -172,9 +167,7 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:272
-msgid ""
-"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
-"map"
+msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:284 ../raster3d/r3.to.rast/main.c:228
@@ -185,10 +178,8 @@
 #: ../raster3d/r3.cross.rast/main.c:298 ../raster/r.to.rast3elev/main.c:462
 #: ../raster/r.to.rast3/main.c:222
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
-msgstr ""
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
+msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni g3d per aggiustare la regione 2D"
 #: ../raster3d/r3.cross.rast/main.c:318 ../raster3d/r3.to.rast/main.c:243
 #: ../raster3d/r3.to.rast/main.c:284 ../raster3d/r3.out.vtk/main.c:209
@@ -249,10 +240,8 @@
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input G3D map for the 2d output maps, "
-"independent of the current region settings"
-msgstr ""
+msgid "Use the same resolution as the input G3D map for the 2d output maps, independent of the current region settings"
+msgstr "Utilizza la stessa risoluzione della map G3D di input per la mappa output 2D, indipendentemente dalle impostazioni attuali della region"
 #: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
 #, fuzzy
@@ -305,13 +294,11 @@
 #: ../raster3d/r3.to.rast/main.c:225
 #, c-format
 msgid "Open 3d raster map <%s>"
-msgstr ""
+msgstr "Apri raster 3D <%s>"
 #: ../raster3d/r3.to.rast/main.c:267
-msgid ""
-"The 2d and 3d region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
+msgid "The 2d and 3d region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "La regione 2D e 3D hanno impostazioni differenti. Sarà usata le impostazioni 2D per aggiustare la parte 2D della regione 3D."
 #: ../raster3d/r3.to.rast/main.c:299 ../raster3d/r3.out.v5d/main.c:202
 #: ../raster/r.gwflow/main.c:347 ../raster/r.li/r.li.daemon/list.c:49
@@ -346,7 +333,7 @@
 #: ../vector/v.net.components/main.c:127
 #: ../imagery/i.smap/bouman/multialloc.c:115 ../imagery/i.ask/popup.c:174
 msgid "Out of memory"
-msgstr ""
+msgstr "Fuori memoria massima"
 #: ../raster3d/r3.to.rast/main.c:304
 #, fuzzy, c-format
@@ -356,7 +343,7 @@
 #: ../raster3d/r3.to.rast/main.c:310
 #, c-format
 msgid "Raster map %i Filename: %s"
-msgstr ""
+msgstr "Mappa raster %i Nome del file: %s"
 #: ../raster3d/r3.to.rast/main.c:313
 #, fuzzy, c-format
@@ -406,9 +393,7 @@
 msgstr "Fornire tre mappe vettoriali g3d [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:178
-msgid ""
-"No g3d data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No g3d data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:198
@@ -449,10 +434,8 @@
 msgstr "dp deve essere fra 0 e 20"
 #: ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2d and 3d region settings are different. The g3d settings are used to "
-msgstr ""
+msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
 #: ../raster3d/r3.out.vtk/main.c:488
 #, fuzzy
@@ -466,13 +449,11 @@
 #: ../raster3d/r3.out.vtk/main.c:545
 msgid "Error closing 3d raster map, the VTK file may be incomplete."
-msgstr ""
-"Errore nella chiusura della mappa g3d, il file VTK potrebbe essere "
-"incompleto."
+msgstr "Errore nella chiusura della mappa g3d, il file VTK potrebbe essere incompleto."
 #: ../raster3d/r3.out.vtk/main.c:560 ../raster/r.out.vtk/main.c:393
 msgid "Error closing VTK-ASCII file"
-msgstr ""
+msgstr "Errore chiudendo il file VTK-ASCII"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:39
 msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
@@ -498,7 +479,7 @@
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "G3D map(s) to be converted to VTK-ASCII data format"
-msgstr ""
+msgstr "Mappa/e G3D da convertire nel formato VTK-ASCII"
 #: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
 #, fuzzy
@@ -508,12 +489,11 @@
 #: ../raster3d/r3.out.vtk/parameters.c:41
 #, fuzzy
 msgid "Float value to represent no data cell/points"
-msgstr ""
-"Valori a virgola mobile per rappresentare le celle/punti prive di valori"
+msgstr "Valori a virgola mobile per rappresentare le celle/punti prive di valori"
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
+msgstr "Crea VTK pointdata invece di VTK celldata (celldata è di default)"
 #: ../raster3d/r3.out.vtk/parameters.c:56
 #, fuzzy
@@ -526,14 +506,11 @@
 msgstr "mappa raster 2D della superficie inferiore"
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:92
@@ -553,7 +530,7 @@
 #: ../raster3d/r3.out.vtk/parameters.c:117
 msgid "Use g3d mask (if exists) with input maps"
-msgstr ""
+msgstr "Utilizza maschera G3D (se esiste) con le mappe di input"
 #: ../raster3d/r3.out.vtk/parameters.c:122
 msgid "Scale factor effects the origin"
@@ -583,12 +560,8 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:334
 #, fuzzy, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"vrite_vtk_data: Scrittura in corso di Celldata %s con %i righe e %i colonne, "
-"profondità %i nel vtk-ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "vrite_vtk_data: Scrittura in corso di Celldata %s con %i righe e %i colonne, profondità %i nel vtk-ascii file"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:392
 msgid "write_vtk_rgb_data: writing rgb data"
@@ -597,8 +570,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:429
 #: ../raster3d/r3.out.vtk/writeVTKData.c:462
 msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
+msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:492
 msgid "write_vtk_vector_data: writing vector data"
@@ -637,9 +609,7 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:118
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
+msgid "The piezometric head result of the numerical calculation will be written to this map"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:125
@@ -655,14 +625,11 @@
 msgstr "Usa una mask G3D (se esiste)"
 #: ../raster3d/r3.gwflow/main.c:142
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:185
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:202 ../raster/r.gwflow/main.c:242
@@ -692,12 +659,8 @@
 msgstr "Errore nella chiusura del file g3d"
 #: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crea un file display da un file grid3 in base ai livelli di soglia "
-"specificati."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crea un file display da un file grid3 in base ai livelli di soglia specificati."
 #: ../raster3d/r3.mkdspf/main.c:85
 msgid "Name of an existing 3d raster map"
@@ -775,11 +738,11 @@
 #: ../raster3d/r3.stats/main.c:569
 msgid "Generates volume statistics for raster3d maps."
-msgstr ""
+msgstr "Genera statistiche sul volume per raster 3D"
 #: ../raster3d/r3.stats/main.c:580
 msgid "Number of sub-ranges to collect stats from"
-msgstr ""
+msgstr "Numero di sottoinsiemi dai quali ottenere le statistiche"
 #: ../raster3d/r3.stats/main.c:586
 msgid "Calculate statistics based on equal value groups"
@@ -787,7 +750,7 @@
 #: ../raster3d/r3.stats/main.c:606
 msgid "The number of subranges has to be equal or greater than 1"
-msgstr ""
+msgstr "Il numero dei sottoinsiemi dev'essere uguale o maggiore di 1"
 #: ../raster3d/r3.stats/main.c:611 ../raster/r.univar2/r3.univar_main.c:151
 #: ../raster/r.univar2/r3.univar_main.c:193
@@ -797,7 +760,7 @@
 #: ../raster3d/r3.stats/main.c:665
 msgid "Sort non-null values"
-msgstr ""
+msgstr "Ordina valori non nulli"
 #: ../raster3d/base/r3.null.main.c:58
 msgid "3d raster map for which to modify null values"
@@ -879,9 +842,7 @@
 #: ../raster3d/base/r3.info.main.c:113
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Stampa esclusivamente il timestamp (giorno.mese.anno ora.minuti.secondi) di "
-"un raster 3D"
+msgstr "Stampa esclusivamente il timestamp (giorno.mese.anno ora.minuti.secondi) di un raster 3D"
 #: ../raster3d/base/r3.info.main.c:121
 #: ../raster/r.out.gridatb/check_ready.c:12 ../raster/r.median/main.c:75
@@ -1003,7 +964,7 @@
 #: ../raster3d/base/r3.info.main.c:321 ../raster3d/base/r3.info.main.c:334
 #: ../raster/r.info/main.c:307 ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
-msgstr ""
+msgstr "Non è possibile alloccare memoria per la stringa"
 #: ../raster3d/base/r3.info.main.c:404
 #, fuzzy
@@ -1036,7 +997,7 @@
 #: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:260
 #, c-format
 msgid "%s: illegal value spec"
-msgstr ""
+msgstr "%s: valore illegale"
 #: ../raster3d/base/r3.mask.main.c:44
 msgid "3d raster map with reference values"
@@ -1151,7 +1112,7 @@
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
 msgid "raster, export"
-msgstr ""
+msgstr "raster, esportazione"
 #: ../raster/r.out.bin/main.c:280
 #, fuzzy
@@ -1171,8 +1132,7 @@
 #: ../raster/r.out.bin/main.c:296
 #, fuzzy
 msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-"Nome della mappa binaria di output (usare out=- per lo standard output)"
+msgstr "Nome della mappa binaria di output (usare out=- per lo standard output)"
 #: ../raster/r.out.bin/main.c:303
 msgid "Value to write out for null"
@@ -1227,25 +1187,24 @@
 #: ../raster/r.out.bin/main.c:394
 msgid "Floating-point output requires bytes=4 or bytes=8"
-msgstr ""
+msgstr "L'outpu floating-point richiede byte=4 o byte=8"
 #: ../raster/r.out.bin/main.c:398
 msgid "Integer output doesn't support bytes=8 in this build"
-msgstr ""
+msgstr "L'output intero non supporta byte=8 in questa costruzione"
 #: ../raster/r.out.bin/main.c:412
 msgid "GMT grid doesn't support 64-bit integers"
-msgstr ""
+msgstr "Griglia GMT non supporta interi 64-bit"
 #: ../raster/r.out.bin/main.c:418
 msgid "Creating BIL support files..."
-msgstr ""
+msgstr "Sto creando file di supporto BILL..."
 #: ../raster/r.out.bin/main.c:435
 #, fuzzy, c-format
 msgid "Exporting raster as floating values (bytes=%d)"
-msgstr ""
-"Esportazione in corso del raster come valori a virgola mobile (bytes=%d)"
+msgstr "Esportazione in corso del raster come valori a virgola mobile (bytes=%d)"
 #: ../raster/r.out.bin/main.c:437
 msgid "Writing GMT float format ID=1"
@@ -1288,12 +1247,12 @@
 #: ../raster/r.out.bin/main.c:450
 #, c-format
 msgid "r=%d"
-msgstr ""
+msgstr "r=%d"
 #: ../raster/r.out.bin/main.c:451
 #, c-format
 msgid "c=%d"
-msgstr ""
+msgstr "c=%d"
 #: ../raster/r.out.gridatb/main.c:46
 msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
@@ -1317,11 +1276,11 @@
 #: ../raster/r.out.gridatb/file_io.c:41 ../raster/r.in.gridatb/file_io.c:36
 msgid "Rows changed"
-msgstr ""
+msgstr "Righe cambiate"
 #: ../raster/r.out.gridatb/file_io.c:44 ../raster/r.in.gridatb/file_io.c:39
 msgid "Cols changed"
-msgstr ""
+msgstr "Colonne cambiate"
 #: ../raster/r.median/main.c:46 ../raster/r.surf.gauss/main.c:46
 #: ../raster/r.stats/main.c:103 ../raster/r.average/main.c:51
@@ -1335,12 +1294,10 @@
 #: ../raster/r.neighbors/main.c:108 ../raster/r.quantile/main.c:254
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
 msgid "raster, statistics"
-msgstr ""
+msgstr "raster, statistiche"
 #: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.median/main.c:54
@@ -1391,7 +1348,7 @@
 #: ../raster/r.median/main.c:79
 #, c-format
 msgid "Base map and output map <%s> must be different"
-msgstr ""
+msgstr "La mappa di origine <%s> e quella di output devono essere differenti"
 #: ../raster/r.median/main.c:82
 #, fuzzy, c-format
@@ -1409,13 +1366,8 @@
 msgstr "raster, proiezione, trasformazione"
 #: ../raster/r.his/main.c:65
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Genera mappe raster separate per le componenti rosso, verde e blu combinando "
-"i valori di tonalità (hue), intensità (intensity), e saturazione "
-"(saturation) (HIS) di mappe raster di input definite dall’utente."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Genera mappe raster separate per le componenti rosso, verde e blu combinando i valori di tonalità (hue), intensità (intensity), e saturazione (saturation) (HIS) di mappe raster di input definite dall’utente."
 #: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
 msgid "Name of layer to be used for HUE"
@@ -1560,12 +1512,8 @@
 #: ../raster/r.out.tiff/r.out.tiff.c:144 ../raster/r.in.mat/main.c:125
 #: ../display/d.mon/pgms/release.c:36 ../display/d.vect/main.c:411
 #: ../visualization/nviz/src/nviz_init.c:34
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--"
-"verbose'."
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--verbose'."
 #: ../raster/r.out.mat/main.c:115 ../raster/r.out.pov/main.c:186
 #: ../raster/r.out.png/r.out.png.c:233 ../raster/r.colors.out/main.c:101
@@ -1606,12 +1554,12 @@
 #: ../raster/r.out.mat/main.c:202 ../raster/r.in.mat/main.c:419
 #, c-format
 msgid "nsres=%f"
-msgstr ""
+msgstr "nsres=%f"
 #: ../raster/r.out.mat/main.c:203 ../raster/r.in.mat/main.c:420
 #, c-format
 msgid "ewres=%f"
-msgstr ""
+msgstr "ewres=%f"
 #: ../raster/r.out.mat/main.c:204 ../raster/r.in.mat/main.c:421
 #, fuzzy, c-format
@@ -1634,16 +1582,15 @@
 #: ../raster/r.out.mat/main.c:282
 msgid "Exporting raster as double FP values"
-msgstr ""
-"Esportazione del raster come valori a virgola mobile con precisione doppia"
+msgstr "Esportazione del raster come valori a virgola mobile con precisione doppia"
 #: ../raster/r.out.mat/main.c:325
 msgid "Reading in map ... "
-msgstr ""
+msgstr "Sto leggendo la mappa di input..."
 #: ../raster/r.out.mat/main.c:339
 msgid "Writing out map..."
-msgstr ""
+msgstr "Sto scrivendo la mappa di output..."
 #: ../raster/r.out.mat/main.c:399
 #, fuzzy, c-format
@@ -1656,7 +1603,7 @@
 #: ../raster/r.in.arc/main.c:59
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
 msgid "raster, import"
-msgstr ""
+msgstr "raster, importazione"
 #: ../raster/r.in.poly/main.c:31
 msgid "Creates raster maps from ASCII polygon/line/point data files."
@@ -1705,7 +1652,7 @@
 #: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:528
 #, c-format
 msgid "Pass #%d (of %d) ..."
-msgstr ""
+msgstr "Passato #%d (di %d) ..."
 #: ../raster/r.in.poly/poly2rast.c:78 ../raster/r.carve/raster.c:32
 #: ../vector/v.to.rast/vect2rast.c:182
@@ -1720,9 +1667,7 @@
 #: ../raster/r.contour/main.c:92
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Produce una mappa vettoriale di curve di livello in base a parametri "
-"specificati a partire da una mappa raster."
+msgstr "Produce una mappa vettoriale di curve di livello in base a parametri specificati a partire da una mappa raster."
 #: ../raster/r.contour/main.c:104
 msgid "List of contour levels"
@@ -1761,17 +1706,12 @@
 msgstr ""
 #: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
-"I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro "
-"posto usare '--quiet'."
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro posto usare '--quiet'."
 #: ../raster/r.contour/main.c:152
 msgid "Neither \"levels\" nor \"step\" parameter specified."
-msgstr ""
-"Non è stato specificato né il parametro \"levels\" né il parametro \"step\""
+msgstr "Non è stato specificato né il parametro \"levels\" né il parametro \"step\""
 #: ../raster/r.contour/main.c:165 ../raster/r.stats/main.c:315
 #: ../raster/r.recode/read_rules.c:19
@@ -1995,12 +1935,11 @@
 #: ../raster/r.describe/main.c:59 ../raster/r.support/front/front.c:54
 #: ../raster/r.info/main.c:69 ../raster/r.region/main.c:54
 msgid "raster, metadata"
-msgstr ""
+msgstr "raster, metadati"
 #: ../raster/r.describe/main.c:61
 msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Stampa una lista concisa dei valori delle categorie trovate nel raster."
+msgstr "Stampa una lista concisa dei valori delle categorie trovate nel raster."
 #: ../raster/r.describe/main.c:72 ../raster/r.stats/main.c:127
 msgid "String representing no data cell value"
@@ -2028,8 +1967,7 @@
 #: ../raster/r.describe/main.c:102
 msgid "Read fp map as integer"
-msgstr ""
-"Legge la mappa di valori a virgola mobile (fp) come mappa di valori interi"
+msgstr "Legge la mappa di valori a virgola mobile (fp) come mappa di valori interi"
 #: ../raster/r.describe/main.c:115 ../raster/r.out.png/r.out.png.c:159
 #: ../raster/r.rescale.eq/main.c:107 ../raster/r.compress/main.c:90
@@ -2043,12 +1981,8 @@
 #: ../raster/r.distance/parse.c:72 ../raster/r.carve/main.c:127
 #: ../raster/r.neighbors/main.c:292 ../vector/v.qcount/main.c:117
 #: ../vector/v.mkgrid/main.c:141
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Il flag '-q' è superato e in futuro verrà rimosso. Al suo posto usare '--"
-"quiet'."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "Il flag '-q' è superato e in futuro verrà rimosso. Al suo posto usare '--quiet'."
 #: ../raster/r.describe/main.c:126
 #, c-format
@@ -2073,10 +2007,7 @@
 msgstr ""
 #: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
 msgstr ""
 #: ../raster/r.le/r.le.setup/sample.c:1050
@@ -2085,9 +2016,7 @@
 msgstr "Impossibile leggere il vettore"
 #: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
 msgstr ""
 #: ../raster/r.le/r.le.setup/main.c:67
@@ -2101,24 +2030,17 @@
 msgstr "Mappa vettoriale da sovrapporre"
 #: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Calcola attributo, dimensione della patch, estensione dell'area centrale "
-"(interna), forma, dimensione frattale e misure di perimetro per insiemi di "
-"patch in un paesaggio"
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Calcola attributo, dimensione della patch, estensione dell'area centrale (interna), forma, dimensione frattale e misure di perimetro per insiemi di patch in un paesaggio"
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
 msgstr ""
 #: ../raster/r.mfilter.fp/main.c:58 ../raster/r.mfilter/main.c:51
 #: ../raster/r.bitpattern/main.c:62
 msgid "raster, map algebra"
-msgstr ""
+msgstr "raster, map algebra"
 #: ../raster/r.mfilter.fp/main.c:59
 msgid "Raster map matrix filter."
@@ -2131,7 +2053,7 @@
 #: ../raster/r.mfilter.fp/main.c:78 ../raster/r.mfilter/main.c:71
 msgid "Number of times to repeat the filter"
-msgstr ""
+msgstr "Numero di volte da ripetere il filtro"
 #: ../raster/r.mfilter.fp/main.c:84 ../raster/r.mfilter/main.c:78
 msgid "Output raster map title"
@@ -2155,9 +2077,7 @@
 #: ../raster/r.mfilter.fp/main.c:109 ../raster/r.mfilter/main.c:104
 #: ../raster/r.out.ppm/main.c:81 ../raster/r.kappa/main.c:133
-msgid ""
-"quiet' instead"
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
 msgstr ""
 #: ../raster/r.mfilter.fp/main.c:138 ../raster/r.mfilter/main.c:133
@@ -2263,13 +2183,10 @@
 #: ../raster/r.out.ascii/main.c:78
 #, fuzzy
 msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
-"Nome in output di una mappa ASCII grid (usare out=- per lo standard output)"
+msgstr "Nome in output di una mappa ASCII grid (usare out=- per lo standard output)"
 #: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:100
@@ -2294,15 +2211,15 @@
 #: ../raster/r.out.ascii/main.c:131
 msgid "Failed to interpret width as an integer"
-msgstr ""
+msgstr "Interpretazione della larghezza come intero fallita"
 #: ../raster/r.out.ascii/main.c:137
 msgid "Both -s and -h doesn't make sense"
-msgstr ""
+msgstr "Sia -s che -h non hanno senso"
 #: ../raster/r.out.ascii/main.c:140
 msgid "Use -M or -s, not both"
-msgstr ""
+msgstr "Usare -M o -s, non entrambi"
 #: ../raster/r.out.ascii/main.c:172 ../raster/r.out.ppm3/main.c:149
 #: ../raster/r.profile/main.c:157 ../raster/r.out.arc/main.c:142
@@ -2322,13 +2239,10 @@
 #: ../raster/r.out.ascii/main.c:197
 #, c-format
 msgid "Read failed at row %d"
-msgstr ""
+msgstr "Lettura fallita alla riga %d"
 #: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:55
@@ -2338,7 +2252,7 @@
 #: ../raster/r.surf.gauss/main.c:59
 msgid "Distribution mean"
-msgstr ""
+msgstr "Distribuzione media"
 #: ../raster/r.surf.gauss/main.c:65
 #, fuzzy
@@ -2367,7 +2281,7 @@
 #: ../raster/r.out.png/r.out.png.c:128
 msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
+msgstr "(0 = nessuna, 1 = più veloce, 9 = migliore)"
 #: ../raster/r.out.png/r.out.png.c:140
 msgid "Make NULL cells transparent"
@@ -2395,7 +2309,7 @@
 #: ../raster/r.out.png/r.out.png.c:298 ../raster/r.univar2/r.univar_main.c:183
 #, c-format
 msgid "Raster <%s> type mismatch"
-msgstr ""
+msgstr "La tipologia del raster <%s> non combacia"
 #: ../raster/r.out.png/r.out.png.c:324 ../raster/r.surf.idw/main.c:690
 #: ../raster/r.proj/readcell.c:27 ../raster/r.mapcalc/map.c:234
@@ -2432,11 +2346,7 @@
 msgstr "raster, superficie di costo, costi cumulativi"
 #: ../raster/r.walk/main.c:179
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
 msgstr ""
 #: ../raster/r.walk/main.c:191
@@ -2446,7 +2356,7 @@
 #: ../raster/r.walk/main.c:199
 msgid "Name of input raster map containing friction costs"
-msgstr ""
+msgstr "Nome del raster di input contenente i costi di frizione"
 #: ../raster/r.walk/main.c:206
 msgid "Name of raster map to contain results"
@@ -2479,9 +2389,7 @@
 #: ../raster/r.walk/main.c:260 ../raster/r.cost/main.c:201
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono "
-"esclusi."
+msgstr "Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono esclusi."
 #: ../raster/r.walk/main.c:268 ../raster/r.cost/main.c:210
 #: ../raster/r.in.xyz/main.c:235
@@ -2494,7 +2402,7 @@
 #: ../raster/r.walk/main.c:287
 msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
+msgstr "Coefficienti per i parametri a,b,c,d per la formula dell'energia di cammino"
 #: ../raster/r.walk/main.c:296
 msgid "Lambda coefficients for combining walking energy and friction cost"
@@ -2503,9 +2411,7 @@
 #: ../raster/r.walk/main.c:305
 #, fuzzy
 msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Il fattore pendenza determina il costo di viaggio in termini di energia in "
-"relazione al dislivello"
+msgstr "Il fattore pendenza determina il costo di viaggio in termini di energia in relazione al dislivello"
 #: ../raster/r.walk/main.c:310 ../raster/r.cost/main.c:215
 msgid "Use the 'Knight's move'; slower, but more accurate"
@@ -2533,28 +2439,28 @@
 #: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:306
 #, c-format
 msgid "Inappropriate percent memory: %d"
-msgstr ""
+msgstr "Percentuale di memoria inappropriata: %d"
 #: ../raster/r.walk/main.c:377
 #, c-format
 msgid "Missing required value: got %d instead of 4"
-msgstr ""
+msgstr "Mancano valori richiesti: ottenuti %d invece di 4"
 #: ../raster/r.walk/main.c:381
 #, c-format
 msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
-msgstr ""
+msgstr "I costi di cammino sono a=%lf b=%lf c=%lf d=%lf"
 #: ../raster/r.walk/main.c:386 ../raster/r.walk/main.c:394
 #: ../raster/r.walk/main.c:401
 #, c-format
 msgid "Missing required value: %d"
-msgstr ""
+msgstr "Valore richiesto mancante: %d"
 #: ../raster/r.walk/main.c:389
 #, c-format
 msgid "Lambda is %lf"
-msgstr ""
+msgstr "Lambda è %lf"
 #: ../raster/r.walk/main.c:397
 #, fuzzy, c-format
@@ -2564,15 +2470,15 @@
 #: ../raster/r.walk/main.c:404
 #, c-format
 msgid "Nseg is %d"
-msgstr ""
+msgstr "Nseg è %d"
 #: ../raster/r.walk/main.c:410
 msgid "Null cells excluded from cost evaluation."
-msgstr ""
+msgstr "Le celle nulle sono escluse dal calcolo del costo"
 #: ../raster/r.walk/main.c:414
 msgid "Input null cell will be retained into output map"
-msgstr ""
+msgstr "Le celle nulle di input saranno ritornate nella mappa di output"
 #: ../raster/r.walk/main.c:426
 #, fuzzy, c-format
@@ -2587,9 +2493,7 @@
 #: ../raster/r.walk/main.c:512
 #, fuzzy
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Attenzione: assegnazione di costi negativi alle celle vuote. I valori nulli "
-"vengono esclusi."
+msgstr "Attenzione: assegnazione di costi negativi alle celle vuote. I valori nulli vengono esclusi."
 #: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
 #, fuzzy, c-format
@@ -2598,19 +2502,19 @@
 #: ../raster/r.walk/main.c:591
 msgid "Map with different projection"
-msgstr ""
+msgstr "Mappa con proiezione differente"
 #: ../raster/r.walk/main.c:603
 msgid "DTM_Source map is: Integer cell type"
-msgstr ""
+msgstr "La mappa DTM_Source è: celle intere"
 #: ../raster/r.walk/main.c:606
 msgid "DTM_Source map is: Floating point (float) cell type"
-msgstr ""
+msgstr "La mappa DTM_Source è: celle floating point (float)"
 #: ../raster/r.walk/main.c:609
 msgid "DTM_Source map is: Floating point (double) cell type"
-msgstr ""
+msgstr "La mappa DTM_Source è: celle floating point (double)"
 #: ../raster/r.walk/main.c:612 ../raster/r.walk/main.c:627
 #: ../raster/r.walk/main.c:664
@@ -2620,15 +2524,15 @@
 #: ../raster/r.walk/main.c:618
 msgid "COST_Source map is: Integer cell type"
-msgstr ""
+msgstr "La mappa COST_Source è: celle intere"
 #: ../raster/r.walk/main.c:621
 msgid "COST_Source map is: Floating point (float) cell type"
-msgstr ""
+msgstr "La mappa COST_Source è: celle floating point (float)"
 #: ../raster/r.walk/main.c:624
 msgid "COST_Source map is: Floating point (double) cell type"
-msgstr ""
+msgstr "La mappa COST_Source è: celle floating point (double)"
 #: ../raster/r.walk/main.c:655
 #, fuzzy
@@ -2637,14 +2541,11 @@
 #: ../raster/r.walk/main.c:658
 msgid "Output map is: Floating point (float) cell type"
-msgstr ""
-"La mappa di output è: cella di tipo con valori a virgola mobile (float)"
+msgstr "La mappa di output è: cella di tipo con valori a virgola mobile (float)"
 #: ../raster/r.walk/main.c:661
 msgid "Output map is: Floating point (double) cell type"
-msgstr ""
-"La mappa di output è: cella di tipo con valori a virgola mobile con "
-"precisione doppia (double)"
+msgstr "La mappa di output è: cella di tipo con valori a virgola mobile con precisione doppia (double)"
 #: ../raster/r.walk/main.c:666
 #, c-format
@@ -2696,7 +2597,7 @@
 #: ../raster/r.walk/main.c:852
 msgid "Initializing output "
-msgstr ""
+msgstr "Inizializzando l'output"
 #: ../raster/r.walk/main.c:860 ../raster/r.walk/main.c:889
 #, fuzzy
@@ -2711,15 +2612,12 @@
 #: ../raster/r.walk/main.c:917
 #, fuzzy, c-format
 msgid "Raster output map <%s> not found (no start_points given)"
-msgstr ""
-"Mappa raster di output <%s> non trovata (nessun punto di partenza definito)"
+msgstr "Mappa raster di output <%s> non trovata (nessun punto di partenza definito)"
 #: ../raster/r.walk/main.c:932
 #, c-format
 msgid "Memory allocation error on reading start points from raster map %s"
-msgstr ""
-"Errore nell'allocazione della memoria nel leggere i punti di partenza dalla "
-"mappa raster %s"
+msgstr "Errore nell'allocazione della memoria nel leggere i punti di partenza dalla mappa raster %s"
 #: ../raster/r.walk/main.c:935
 #, fuzzy, c-format
@@ -2757,18 +2655,24 @@
 "Integer cell type.\n"
 "Writing..."
 msgstr ""
+"Celle intere.\n"
+"Sto scrivendo..."
 #: ../raster/r.walk/main.c:1543
 msgid ""
 "Float cell type.\n"
 "Writing..."
 msgstr ""
+"Celle float.\n"
+"Sto scrivendo..."
 #: ../raster/r.walk/main.c:1578
 msgid ""
 "Double cell type.\n"
 "Writing..."
 msgstr ""
+"Celle double.\n"
+"Sto scrivendo..."
 #: ../raster/r.walk/main.c:1613 ../raster/r.cost/main.c:1117
 #, fuzzy, c-format
@@ -2805,14 +2709,7 @@
 msgstr "Radiazione solare e modello di irraggiamento"
 #: ../raster/r.sun2/main.c:232 ../raster/r.sun/main.c:178
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun2/main.c:246 ../raster/r.sun/main.c:208
@@ -2844,37 +2741,27 @@
 #: ../raster/r.horizon/main.c:269 ../raster/r.horizon/main.c:277
 #: ../raster/r.horizon/main.c:285 ../raster/r.horizon/main.c:293
 msgid "Input_options"
-msgstr ""
+msgstr "Opzioni di input"
 #: ../raster/r.sun2/main.c:255 ../raster/r.sun/main.c:217
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Nome della mappa delle esposizioni (esposizione del terreno o azimuth del "
-"pannello solare) [gradi decimali]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Nome della mappa delle esposizioni (esposizione del terreno o azimuth del pannello solare) [gradi decimali]"
 #: ../raster/r.sun2/main.c:264
 msgid "A single value of the orientation (aspect), 270 is south"
 msgstr "Un singolo valore dell'angolo di esposizione, il sud è 270"
 #: ../raster/r.sun2/main.c:273 ../raster/r.sun/main.c:227
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Nome dela mappa di input delle pendenze (pendenza del terreno o inclinazione "
-"del pannello solare) [gradi decimali]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Nome dela mappa di input delle pendenze (pendenza del terreno o inclinazione del pannello solare) [gradi decimali]"
 #: ../raster/r.sun2/main.c:281
 msgid "A single value of inclination (slope)"
 msgstr "Un sngolo valore di inclinazione (pendenza)"
 #: ../raster/r.sun2/main.c:290 ../raster/r.sun/main.c:236
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Nome della mappa raster di input dei coefficienti di torbidità di Linke [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Nome della mappa raster di input dei coefficienti di torbidità di Linke [-]"
 #: ../raster/r.sun2/main.c:300 ../raster/r.sun/main.c:247
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -2940,15 +2827,11 @@
 #: ../vector/v.vol.rst/main.c:398 ../vector/v.vol.rst/main.c:407
 #: ../vector/v.vol.rst/main.c:416 ../vector/v.vol.rst/main.c:425
 msgid "Output_options"
-msgstr ""
+msgstr "Opzioni di output"
 #: ../raster/r.sun2/main.c:391 ../raster/r.sun/main.c:322
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione diretta, istantanea [W.m-2] "
-"(modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione diretta, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun2/main.c:400 ../raster/r.sun/main.c:331
 #, fuzzy
@@ -2956,28 +2839,16 @@
 msgstr "Mappa raster di output del tempo di insolazione [h] (solo modalità 2)"
 #: ../raster/r.sun2/main.c:409 ../raster/r.sun/main.c:340
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione diffusa, istantanea [W.m-2] "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione diffusa, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun2/main.c:418 ../raster/r.sun/main.c:349
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione riflessa, istantanea [W.m-2] "
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione riflessa, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun2/main.c:427
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione globale (totale), istantanea [W.m-2] "
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione globale (totale), istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun2/main.c:434 ../raster/r.sun/main.c:356
 msgid "No. of day of the year (1-365)"
@@ -3018,7 +2889,7 @@
 #: ../raster/r.sun2/main.c:511 ../raster/r.sun/main.c:384
 msgid "Incorporate the shadowing effect of terrain"
-msgstr ""
+msgstr "Incorpora l'effetto delle ombre del terreno"
 #: ../raster/r.sun2/main.c:516
 msgid "Use the low-memory version of the program"
@@ -3060,18 +2931,15 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:612
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Se si utilizza l'opzione horizon bisogna anche impostare il parametro 'horizonstep'"
 #: ../raster/r.sun2/main.c:618
 msgid "Time and insol_time are incompatible options"
 msgstr "Time e insol_time sono opzioni incompatibili"
 #: ../raster/r.sun2/main.c:620
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun2/main.c:625 ../raster/r.sun/main.c:424
@@ -3087,9 +2955,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:685
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun2/main.c:730 ../general/g.region/printwindow.c:247
@@ -3103,7 +2969,7 @@
 #: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
 #: ../display/d.where/main.c:96
 msgid "Can't get projection units of current location"
-msgstr ""
+msgstr "Non è possibile ottenere le unità  della proiezione della location attuale"
 #: ../raster/r.sun2/main.c:738 ../raster/r.sun/main.c:481
 #: ../raster/r.horizon/main.c:481 ../general/g.region/printwindow.c:253
@@ -3111,14 +2977,14 @@
 #: ../display/d.grid/plot.c:341 ../display/d.where/main.c:99
 #: ../ps/ps.map/do_geogrid.c:271
 msgid "Can't get projection key values of current location"
-msgstr ""
+msgstr "Non è possibile ottenere le chiavi valori della proiezione della location attuale"
 #: ../raster/r.sun2/main.c:748 ../raster/r.sun/main.c:491
 #: ../raster/r.horizon/main.c:491 ../display/d.grid/plot.c:348
 #: ../display/d.grid/plot.c:375 ../display/d.where/main.c:106
 #: ../display/d.where/main.c:132 ../ps/ps.map/do_geogrid.c:277
 msgid "Unable to set up lat/long projection parameters"
-msgstr ""
+msgstr "Impossibile impostare i parametri della proiezione lat/long"
 #: ../raster/r.sun2/main.c:752
 msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
@@ -3162,9 +3028,7 @@
 #: ../raster/r.in.gdal/main.c:113
 msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Nome della location da cui leggere la proiezione per la trasformazione dei "
-"GPG"
+msgstr "Nome della location da cui leggere la proiezione per la trasformazione dei GPG"
 #: ../raster/r.in.gdal/main.c:121 ../raster/r.external/main.c:537
 #: ../imagery/i.landsat.toar/main.c:86 ../imagery/i.landsat.toar/main.c:102
@@ -3223,7 +3087,7 @@
 #: ../raster/r.in.gdal/main.c:146
 msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr ""
+msgstr "Forza le mappe Lat/Lon per ricadere nelle coordinate geografiche (90N,S; 180E,W)"
 #: ../raster/r.in.gdal/main.c:151
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:11
@@ -3232,15 +3096,15 @@
 #: ../raster/r.in.gdal/main.c:172
 msgid "You have to specify a target location different from output location"
-msgstr ""
+msgstr "Bisogna specificare una location d'origine differente da quella di output"
 #: ../raster/r.in.gdal/main.c:176
 msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr ""
+msgstr "La flag '-l' funziona solo in location Lat/Lon"
 #: ../raster/r.in.gdal/main.c:194
 msgid "Available GDAL Drivers:"
-msgstr ""
+msgstr "Driver GDAL disponibili:"
 #: ../raster/r.in.gdal/main.c:215 ../raster/r.proj/main.c:264
 #: ../raster/r.out.gdal/main.c:230 ../raster/r.proj.seg/main.c:301
@@ -3261,32 +3125,20 @@
 msgstr "Mappa raster <%s> già esistente. Sarà sovrascritta"
 #: ../raster/r.in.gdal/main.c:246
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "La rettifica polinomiale usata in i.rectify non lavora bene con dati NOAA/AVHRR. Prova usando gdalwarp con la rettifica spline piana. (-tps)"
 #: ../raster/r.in.gdal/main.c:262 ../raster/r.external/main.c:202
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Il raster di input è ruotato - non può essere importato. Si può utilizzare 'gdalwarp' per trasformare la mappa col Nord in alto"
 #: ../raster/r.in.gdal/main.c:304
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:324
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Non si è in grado di convertire la proiezione della mappa di input nel "
-"formato di GRASS; impossibile creare una nuova location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Non si è in grado di convertire la proiezione della mappa di input nel formato di GRASS; impossibile creare una nuova location."
 #: ../raster/r.in.gdal/main.c:330
 #, c-format
@@ -3294,9 +3146,7 @@
 msgstr "Location <%s> creata"
 #: ../raster/r.in.gdal/main.c:337 ../raster/r.external/main.c:83
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:353 ../raster/r.external/main.c:99
@@ -3310,8 +3160,7 @@
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"La proiezione del dataset sembra non corrispondere a quella della location "
-"corrente.\n"
+"La proiezione del dataset sembra non corrispondere a quella della location corrente.\n"
 "\n"
 #: ../raster/r.in.gdal/main.c:369 ../raster/r.external/main.c:112
@@ -3331,27 +3180,19 @@
 #: ../raster/r.in.gdal/main.c:429
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Si può usare il flag -o perché r.in.gdal tralasci questa verifica e utilizzi "
-"la definizione della location per il dataset.\n"
+"Si può usare il flag -o perché r.in.gdal tralasci questa verifica e utilizzi la definizione della location per il dataset.\n"
 #: ../raster/r.in.gdal/main.c:432 ../raster/r.external/main.c:175
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Si prenda in considerazione di generare una nuova location dal dataset di "
-"input usando il parametro location\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Si prenda in considerazione di generare una nuova location dal dataset di input usando il parametro location\n"
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.external/main.c:180
 #: ../vector/v.in.ogr/main.c:592
 msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"La proiezione del dataset di input e della location corrente sembrano "
-"corrispondere"
+msgstr "La proiezione del dataset di input e della location corrente sembrano corrispondere"
 #: ../raster/r.in.gdal/main.c:443 ../raster/r.external/main.c:614
 #, fuzzy
@@ -3380,17 +3221,17 @@
 #: ../raster/r.in.gdal/main.c:561
 #, c-format
 msgid "* Input projection for GCP table: %s"
-msgstr ""
+msgstr "* Proiezione di input per la tabella GCP: %s"
 #: ../raster/r.in.gdal/main.c:563
 #, c-format
 msgid "* Output projection for GCP table: %s"
-msgstr ""
+msgstr "* Proiezione dell'output per la tabella GCP: %s "
 #: ../raster/r.in.gdal/main.c:580
 #, c-format
 msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr ""
+msgstr "Errore in pj_do_proj (non è possibile riproiettare GCP %i)"
 #: ../raster/r.in.gdal/main.c:639
 msgid "Unable to translate projection key values of input GCPs"
@@ -3399,13 +3240,11 @@
 #: ../raster/r.in.gdal/main.c:655
 #, fuzzy
 msgid "Unable to get projection info of target location"
-msgstr ""
-"Impossibile ottenere informazioni sulla proiezione della location definita "
-"dal parametro target"
+msgstr "Impossibile ottenere informazioni sulla proiezione della location definita dal parametro target"
 #: ../raster/r.in.gdal/main.c:657
 msgid "Unable to get projection units of target location"
-msgstr ""
+msgstr "Impossibile ottene le unità della proiezione della location d'origine"
 #: ../raster/r.in.gdal/main.c:659
 msgid "Unable to get projection key values of target location"
@@ -3433,16 +3272,12 @@
 #: ../raster/r.in.gdal/main.c:932
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr ""
-"Impostazione della tavola dei colori per il grigio per <%s>  (8 bit, intera "
-"gamma)"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s>  (8 bit, intera gamma)"
 #: ../raster/r.in.gdal/main.c:945
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (16bit, image range)"
-msgstr ""
-"Impostazione della tavola dei colori per il grigio per <%s> (16 bit, gamma "
-"dell'immagine)"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s> (16 bit, gamma dell'immagine)"
 #: ../raster/r.in.gdal/main.c:956 ../raster/r.circle/dist.c:155
 #: ../raster/r.surf.fractal/main.c:39 ../raster/r.recode/main.c:110
@@ -3521,8 +3356,7 @@
 #: ../raster/r.in.bin/main.c:260
 msgid "Get region info from GMT style header"
-msgstr ""
-"Recupera le informazioni sulla regione da una intestazione in stile GMT"
+msgstr "Recupera le informazioni sulla regione da una intestazione in stile GMT"
 #: ../raster/r.in.bin/main.c:261 ../raster/r.in.bin/main.c:301
 #: ../raster/r.in.bin/main.c:309 ../raster/r.in.bin/main.c:317
@@ -3581,24 +3415,24 @@
 #: ../raster/r.in.bin/main.c:385
 #, c-format
 msgid "-f incompatible with bytes=%d; must be 4 or 8"
-msgstr ""
+msgstr "-f incompatibile con bytes=%d, devono essere 4 o 8"
 #: ../raster/r.in.bin/main.c:393
 #, c-format
 msgid "-d incompatible with bytes=%d; must be 8"
-msgstr ""
+msgstr "-d incompatibile con bytes=%d; deve essere 8"
 #: ../raster/r.in.bin/main.c:400
 msgid "bytes= required for integer data"
-msgstr ""
+msgstr "bytes= richiesto per dati interi"
 #: ../raster/r.in.bin/main.c:404
 msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
+msgstr "Input intero non supporta size=8 in questa costruzione"
 #: ../raster/r.in.bin/main.c:408
 msgid "bytes= must be 1, 2, 4 or 8"
-msgstr ""
+msgstr "bytes= devono essere 1, 2, 4 o 8"
 #: ../raster/r.in.bin/main.c:421
 #, fuzzy
@@ -3607,7 +3441,7 @@
 #: ../raster/r.in.bin/main.c:426
 msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr ""
+msgstr "O tutti o nessuno di north=, south=, east= e west= devono essere passati"
 #: ../raster/r.in.bin/main.c:433 ../display/d.grid/main.c:201
 #, c-format
@@ -3636,13 +3470,8 @@
 #: ../raster/r.in.bin/main.c:464
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"Le risoluzioni Est-Ovest (ewres: %f) e Nord-Sud (nwres: %f) differiscono in "
-"modo significativo. I parametri east= and west= sono stati definiti "
-"correttamente?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "Le risoluzioni Est-Ovest (ewres: %f) e Nord-Sud (nwres: %f) differiscono in modo significativo. I parametri east= and west= sono stati definiti correttamente?"
 #: ../raster/r.in.bin/main.c:487
 #, fuzzy
@@ -3659,9 +3488,7 @@
 msgstr "raster, ricampionamento"
 #: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
@@ -3704,9 +3531,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:131
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
 msgstr ""
 #: ../raster/r.drain/main.c:139
@@ -3718,7 +3543,7 @@
 #: ../raster/r.cost/main.c:153 ../raster/r.cost/main.c:165
 #: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:224
 msgid "Start"
-msgstr ""
+msgstr "Inizio"
 #: ../raster/r.drain/main.c:145
 #, fuzzy
@@ -3738,9 +3563,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -3752,9 +3575,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:184
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:191
@@ -3798,7 +3619,7 @@
 #: ../raster/r.drain/main.c:227
 msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
+msgstr "Specificare solo uno dei flag -c, -a e -n"
 #: ../raster/r.drain/main.c:250
 msgid "Metrics allocation"
@@ -3870,9 +3691,7 @@
 #: ../raster/r.drain/main.c:316
 #, fuzzy, c-format
 msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"La mappa vettoriale di partenza <%s> non contiene punti nella regione "
-"corrente"
+msgstr "La mappa vettoriale di partenza <%s> non contiene punti nella regione corrente"
 #: ../raster/r.drain/main.c:322
 #, fuzzy
@@ -3908,7 +3727,7 @@
 #: ../raster/r.support/front/check.c:29
 #, c-format
 msgid "Update the statistics (histogram, range) for [%s]? "
-msgstr ""
+msgstr "Aggiorna le statistiche (istogramma, range) per [%s]?"
 #: ../raster/r.support/front/check.c:35
 #, c-format
@@ -3916,6 +3735,8 @@
 "\n"
 "  Updating statistics for [%s]"
 msgstr ""
+"\n"
+"  Aggiornando le statistiche per [%s]"
 #: ../raster/r.support/front/check.c:77
 #, c-format
@@ -3923,6 +3744,8 @@
 "   Updating the number of categories for [%s]\n"
 "\n"
 msgstr ""
+"   Aggiornando il numero di categorie per [%s]\n"
+"\n"
 #: ../raster/r.support/front/front.c:55
 msgid "Allows creation and/or modification of raster map layer support files."
@@ -3997,6 +3820,8 @@
 "\n"
 "NOTE: [%s] is a reclass of [%s in %s]"
 msgstr ""
+"\n"
+"NOTE: [%s] è una riclassificazione di [%s in %s]"
 #: ../raster/r.support/front/front.c:264
 msgid "Canceling from edit header."
@@ -4005,12 +3830,12 @@
 #: ../raster/r.support/front/front.c:271
 #, c-format
 msgid "Edit the category file for [%s]? "
-msgstr ""
+msgstr "Modificare il file delle categorie per [%s]?"
 #: ../raster/r.support/front/front.c:281
 #, c-format
 msgid "Create/Update the color table for [%s]? "
-msgstr ""
+msgstr "Crea/Aggiorna la tabella dei colori per [%s]?"
 #: ../raster/r.support/front/front.c:292
 #, fuzzy, c-format
@@ -4030,24 +3855,25 @@
 #, c-format
 msgid ""
 "\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
 msgstr ""
+"\n"
+"Vuoi creare/rimuovere il file dei nulli per [%s] così quei valori null saranno considerati dati validi?"
 #: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
-msgstr ""
+msgstr "[%s] è una riclassificazione di un'altra mappa. Sto uscendo."
 #: ../raster/r.support/front/front.c:329
 #, c-format
 msgid "Writing new null file for [%s]... "
-msgstr ""
+msgstr "Sto scrivendo un nuovo file null per [%s]..."
 #: ../raster/r.support/front/front.c:334
 #, c-format
 msgid "Error writing null row [%d]."
-msgstr ""
+msgstr "Errore scrivendo una riga nulla [%d]."
 #: ../raster/r.support/front/front.c:346
 #, c-format
@@ -4056,11 +3882,14 @@
 "Do you want to delete the null file for [%s]\n"
 "(all zero cells will then be considered no data)? "
 msgstr ""
+"\n"
+"Vuoi eliminare il file dei null per [%s]\n"
+"(tutte le celle zero saranno considerate no data)?"
 #: ../raster/r.support/front/front.c:360
 #, c-format
 msgid "Removing null file for [%s]...\n"
-msgstr ""
+msgstr "Sto rimuovendo file dei nulli per [%s]...\n"
 #: ../raster/r.support/front/front.c:367 ../display/d.what.vect/main.c:172
 msgid "Done."
@@ -4069,7 +3898,7 @@
 #: ../raster/r.support/modhead/ask_format.c:24
 #, c-format
 msgid "Please enter the following information for [%s]:"
-msgstr ""
+msgstr "Inserire le seguenti informazioni per [%s]:"
 #: ../raster/r.support/modhead/ask_format.c:29
 #, fuzzy
@@ -4088,12 +3917,12 @@
 #: ../raster/r.support/modhead/ask_format.c:33
 msgid "        Floating point map"
-msgstr ""
+msgstr "        Mappa floating point"
 #: ../raster/r.support/modhead/ask_format.c:51
 #, c-format
 msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
+msgstr "righe * colonne * bytes per cella devone essere gli stessi della dimensione del file (%lu)"
 #: ../raster/r.support/modhead/ask_format.c:55
 msgid "If you need help figuring them out, just hit ESC"
@@ -4101,21 +3930,21 @@
 #: ../raster/r.support/modhead/ask_format.c:76
 msgid "** Negative values not allowed!"
-msgstr ""
+msgstr "** Valori negativi non permessi!"
 #: ../raster/r.support/modhead/ask_format.c:79
 msgid "** Positive values only please!"
-msgstr ""
+msgstr "** Solo valori positivi"
 #: ../raster/r.support/modhead/modhead.c:70
 #, c-format
 msgid "Edit header for [%s]\n"
-msgstr ""
+msgstr "Modifica l'intestazione per [%s]\n"
 #: ../raster/r.support/modhead/modhead.c:73
 #, c-format
 msgid "[%s] cannot be found!"
-msgstr ""
+msgstr "[%s] non può essere trovato"
 #: ../raster/r.support/modhead/modhead.c:76
 msgid "For what layer shall the header file be edited? "
@@ -4124,12 +3953,12 @@
 #: ../raster/r.support/modhead/modhead.c:86
 #, c-format
 msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-msgstr ""
+msgstr "[%s] è una riclassificazione di [%s] - non è possibile editare l'intestazione! Eseguire supporto su [%s]"
 #: ../raster/r.support/modhead/modhead.c:90
 #, c-format
 msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr ""
+msgstr "[%s] è una riclassificazione di [%s in %s] - l'intestazione non può essere editata!"
 #: ../raster/r.support/modhead/modhead.c:96
 #, fuzzy, c-format
@@ -4149,7 +3978,7 @@
 #: ../raster/r.support/modhead/modhead.c:191
 #, c-format
 msgid "cellhd compression: %d\n"
-msgstr ""
+msgstr "compressione delle celle: %d\n"
 #: ../raster/r.support/modhead/modhead.c:192
 #, c-format
@@ -4164,11 +3993,11 @@
 #: ../raster/r.support/modhead/modhead.c:201
 #, c-format
 msgid "[%s] appears to be compressed. Is it? "
-msgstr ""
+msgstr "[%s] sembra essere compressa. È così?"
 #: ../raster/r.support/modhead/modhead.c:207
 msgid "Please indicate the type of compression:\n"
-msgstr ""
+msgstr "Indicare la tipologia di compressione:\n"
 #: ../raster/r.support/modhead/modhead.c:208
 msgid "  1. Pre 3.0 compression\n"
@@ -4181,11 +4010,11 @@
 #: ../raster/r.support/modhead/modhead.c:245
 #, c-format
 msgid "The header for [%s] says the file is not compressed. "
-msgstr ""
+msgstr "L'intestazione per [%s] dice the il file non è compresso"
 #: ../raster/r.support/modhead/modhead.c:247
 msgid "The file appears to be compressed.\n"
-msgstr ""
+msgstr "Il file appare essere compresso.\n"
 #: ../raster/r.support/modhead/modhead.c:248
 #: ../raster/r.support/modhead/modhead.c:257
@@ -4195,17 +4024,15 @@
 #: ../raster/r.support/modhead/modhead.c:254
 #, c-format
 msgid "The header for [%s] says the file is compressed. "
-msgstr ""
+msgstr "L'intestazione per [%s] dice che il file è compresso"
 #: ../raster/r.support/modhead/modhead.c:256
 msgid "The file does NOT appear to be compressed.\n"
-msgstr ""
+msgstr "Il file non sembra essere compresso.\n"
 #: ../raster/r.support/modhead/modhead.c:271
 #, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
 msgstr ""
 #: ../raster/r.support/modhead/modhead.c:303
@@ -4216,17 +4043,19 @@
 #: ../raster/r.support/modhead/modhead.c:305
 #, c-format
 msgid "Header for raster map [%s] updated."
-msgstr ""
+msgstr "Intestazione per il raster [%s] aggiornato."
 #: ../raster/r.support/modhead/hitreturn.c:12
 msgid ""
 "\n"
 "hit RETURN to continue -->"
 msgstr ""
+"\n"
+"Premere INVIO per continuare -->"
 #: ../raster/r.support/modcolr/modcolr.c:38
 msgid "Which raster map needs a color table"
-msgstr ""
+msgstr "Quale raster necessita una tabella dei colori"
 #: ../raster/r.support/modcolr/modcolr.c:53
 #, fuzzy, c-format
@@ -4235,7 +4064,7 @@
 #: ../raster/r.support/modhist/modhist.c:38
 msgid "Which raster map needs an updated history? "
-msgstr ""
+msgstr "Quale raster necessita un'aggiornamento della storia?"
 #: ../raster/r.support/modhist/modhist.c:46
 #, fuzzy, c-format
@@ -4245,20 +4074,20 @@
 #: ../raster/r.support/modhist/modhist.c:51
 #, c-format
 msgid "History file for [%s] updated."
-msgstr ""
+msgstr "File della storia per [%s] aggiornato."
 #: ../raster/r.support/modhist/modhist.c:53
 #, c-format
 msgid "History file for [%s] not updated."
-msgstr ""
+msgstr "File della storia per [%s] non aggiornato."
 #: ../raster/r.support/modcats/modcats.c:46
 msgid "Which vector map needs updated categories?"
-msgstr ""
+msgstr "Quale vettoriale necessità un aggiornamento delle categorie?"
 #: ../raster/r.support/modcats/modcats.c:49
 msgid "Which raster map needs updated categories?"
-msgstr ""
+msgstr "Quale raster necessità un aggiornamento delle categorie?"
 #: ../raster/r.support/modcats/modcats.c:53
 #: ../raster/r.support/modcats/modcats.c:62
@@ -4280,7 +4109,7 @@
 #: ../raster/r.lake/main.c:79
 #, c-format
 msgid "Failed writing output raster map row %d"
-msgstr ""
+msgstr "Scrittura del raster di output fallita alla riga %d"
 #: ../raster/r.lake/main.c:149
 msgid "Fills lake from seed at given level."
@@ -4339,9 +4168,7 @@
 msgstr "G_malloc: memoria esaurita"
 #: ../raster/r.lake/main.c:291
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:374
@@ -4371,7 +4198,7 @@
 #: ../raster/r.surf.idw/main.c:69 ../raster/r.surf.idw2/main.c:60
 #: ../raster/r.surf.contour/main.c:52
 msgid "raster, interpolation"
-msgstr ""
+msgstr "raster, interpolazione"
 #: ../raster/r.surf.idw/main.c:71
 msgid "Surface interpolation utility for raster map."
@@ -4384,7 +4211,7 @@
 #: ../raster/r.surf.idw/main.c:86
 msgid "Output is the interpolation error"
-msgstr ""
+msgstr "Output sono gli errori dell'interpolazione "
 #: ../raster/r.surf.idw/main.c:92
 #, fuzzy, c-format
@@ -4411,7 +4238,7 @@
 #: ../raster/r.colors.out/main.c:63
 msgid "raster, export, color table"
-msgstr ""
+msgstr "raster, esportazione, tabella dei colori"
 #: ../raster/r.colors.out/main.c:65
 #, fuzzy
@@ -4466,31 +4293,31 @@
 #: ../raster/r.stats/main.c:146
 msgid "Print averaged values instead of intervals"
-msgstr ""
+msgstr "Visualizza valori medi invece degli intervalli"
 #: ../raster/r.stats/main.c:151
 msgid "Print area totals"
-msgstr ""
+msgstr "Visualizza area totale"
 #: ../raster/r.stats/main.c:156
 msgid "Print cell counts"
-msgstr ""
+msgstr "Visualizza il numero di celle"
 #: ../raster/r.stats/main.c:162
 msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
+msgstr "Visualizza le percentuali approssimative (il totale potrebbe non essere 100%)"
 #: ../raster/r.stats/main.c:167
 msgid "Print category labels"
-msgstr ""
+msgstr "Visualizza le etichette delle categorie"
 #: ../raster/r.stats/main.c:172
 msgid "Print grid coordinates (east and north)"
-msgstr ""
+msgstr "Visualizza le coordinate della griglia (est e nord)"
 #: ../raster/r.stats/main.c:177
 msgid "Print x and y (column and row)"
-msgstr ""
+msgstr "Visualizza x e y (colonna e riga)"
 #: ../raster/r.stats/main.c:182
 msgid "Print raw indexes of fp ranges (fp maps only)"
@@ -4528,23 +4355,17 @@
 #: ../raster/r.stats/main.c:284
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "Il raster <%s> sta venendo letto come mappa intera! Flag '-%c' e/o '%s' saranno ignorate"
 #: ../raster/r.stats/main.c:301
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Categorie per il raster <%s> sono mancanti o non hanno etichette esplicite. Si sta usando %s=%d."
 #: ../raster/r.stats/main.c:308
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/main.c:342
@@ -4688,15 +4509,11 @@
 msgstr "time e insol_time sono opzioni incompatibili"
 #: ../raster/r.sun/main.c:419
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:474 ../raster/r.horizon/main.c:473
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
 msgstr ""
 #: ../raster/r.sun/main.c:529
@@ -4813,8 +4630,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:381
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:46
@@ -4832,13 +4648,11 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:76
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:86
@@ -4854,8 +4668,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:129
@@ -5000,12 +4813,8 @@
 #: ../raster/r.slope.aspect/main.c:154
 #, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Genera raster della pendenza, esposizione, curvature e le derivate parziali "
-"da un raster con valori dell'elevazione."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione."
 #: ../raster/r.slope.aspect/main.c:156
 msgid "Aspect is calculated counterclockwise from east."
@@ -5053,35 +4862,27 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
 #, fuzzy
 msgid "Name for output second order partial derivative dxx raster map"
-msgstr ""
-"Nome della mappa raster di output della derivata parziale di secondo ordine "
-"dxx"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxx"
 #: ../raster/r.slope.aspect/main.c:230
 #, fuzzy
 msgid "Name for output second order partial derivative dyy raster map"
-msgstr ""
-"dyy"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dyy"
 #: ../raster/r.slope.aspect/main.c:237
 #, fuzzy
 msgid "Name for output second order partial derivative dxy raster map"
-msgstr ""
-"dxy"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxy"
 #: ../raster/r.slope.aspect/main.c:243
 msgid "Multiplicative factor to convert elevation units to meters"
@@ -5107,9 +4908,7 @@
 #: ../raster/r.slope.aspect/main.c:348
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
-"s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:378
@@ -5189,19 +4988,12 @@
 msgstr "Mappa raster Dxy <%s> completata"
 #: ../raster/r.cost/main.c:130
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Crea una mappa raster che mostra il costo cumulativo per muoversi tra "
-"diverse località geografiche su una mappa raster di input i cui valori di "
-"categoria delle celle rappresentano dei costi"
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crea una mappa raster che mostra il costo cumulativo per muoversi tra diverse località geografiche su una mappa raster di input i cui valori di categoria delle celle rappresentano dei costi"
 #: ../raster/r.cost/main.c:137
 msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-"Nome della mappa raster che contiene la griglia con le informazioni del costo"
+msgstr "Nome della mappa raster che contiene la griglia con le informazioni del costo"
 #: ../raster/r.cost/main.c:152
 #, fuzzy
@@ -5334,16 +5126,12 @@
 #: ../raster/r.bilinear/main.c:44
 msgid "Bilinear interpolation utility for raster map layers."
-msgstr ""
+msgstr "Strumento per l'interpolazione bilineare per layer raster."
 #: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
 #, fuzzy
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
-msgstr ""
-"Specifica un valore di input da assegnare ai poli nord e/o sud per le "
-"griglie di longitudine-latitudine"
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+msgstr "Specifica un valore di input da assegnare ai poli nord e/o sud per le griglie di longitudine-latitudine"
 #: ../raster/r.bilinear/main.c:67
 #, fuzzy
@@ -5400,11 +5188,11 @@
 #: ../raster/r.resample/main.c:65
 msgid "Name of an input layer"
-msgstr ""
+msgstr "Nome del layer di input"
 #: ../raster/r.resample/main.c:72
 msgid "Name of an output layer"
-msgstr ""
+msgstr "Nome del layer di output"
 #: ../raster/r.resample/main.c:137 ../raster/r.resamp.rst/main.c:527
 #: ../vector/v.surf.rst/main.c:622 ../vector/v.surf.rst/main.c:773
@@ -5417,14 +5205,12 @@
 msgstr "Creazione di una nuovo file delle categorie in corso..."
 #: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:62
 msgid "Name of raster maps to be patched together"
-msgstr ""
+msgstr "Nome dei raster da unire insieme"
 #: ../raster/r.patch/main.c:65
 msgid "Name for resultant raster map"
@@ -5432,7 +5218,7 @@
 #: ../raster/r.patch/main.c:77
 msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
+msgstr "Utilizzare zero (0) per trasparenza invece di NULL"
 #: ../raster/r.patch/main.c:102
 #, fuzzy
@@ -5455,12 +5241,8 @@
 #: ../raster/simwe/r.sim.sediment/main.c:113
 #, fuzzy
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il "
-"metodo path sampling (SIMWE)"
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il metodo path sampling (SIMWE)"
 #: ../raster/simwe/r.sim.sediment/main.c:121
 #, fuzzy
@@ -5609,7 +5391,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:323
 #: ../raster/simwe/r.sim.water/main.c:440
 msgid "More than 100 files are going to be created !!!!!"
-msgstr ""
+msgstr "Più di 100 file stanno per essere creati !!!!!"
 #: ../raster/simwe/r.sim.sediment/main.c:329
 #: ../raster/simwe/r.sim.water/main.c:446
@@ -5647,9 +5429,7 @@
 #: ../raster/simwe/r.sim.water/main.c:120
 #, fuzzy
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Simulazione del ruscellamento superficiale usando il metodo path sampling "
-"(SIMWE)"
+msgstr "Simulazione del ruscellamento superficiale usando il metodo path sampling (SIMWE)"
 #: ../raster/simwe/r.sim.water/main.c:138
 #, fuzzy
@@ -5669,9 +5449,7 @@
 #: ../raster/simwe/r.sim.water/main.c:163
 #, fuzzy
 msgid "Runoff infiltration rate unique value [mm/hr]"
-msgstr ""
-"Un singolo valore  della velocità di infiltrazione del deflusso superficiale "
-"[mm/h]"
+msgstr "Un singolo valore  della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #: ../raster/simwe/r.sim.water/main.c:177
 msgid "Mannings n unique value"
@@ -5729,9 +5507,7 @@
 #: ../raster/simwe/simlib/input.c:409
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/simwe/simlib/input.c:541
@@ -5870,12 +5646,8 @@
 msgstr "Creazione della mappa raste 3D"
 #: ../raster/r.out.ppm/main.c:56
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
-"della region corrente"
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel della region corrente"
 #: ../raster/r.out.ppm/main.c:64
 #, fuzzy
@@ -5907,12 +5679,8 @@
 msgstr "File <%s> creato"
 #: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
-"pixel della region corrente"
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del pixel della region corrente"
 #: ../raster/r.out.ppm3/main.c:65 ../raster/r.composite/main.c:88
 #, c-format
@@ -5938,8 +5706,7 @@
 #: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:60
@@ -5961,22 +5728,19 @@
 #: ../raster/r.random/main.c:51 ../raster/r.surf.random/main.c:44
 msgid "raster, random"
-msgstr ""
+msgstr "raster, random"
 #: ../raster/r.random/main.c:53
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
 #: ../raster/r.random/main.c:69
 msgid "The number of points to allocate"
-msgstr ""
+msgstr "Numero di punti da allocare"
 #: ../raster/r.random/main.c:81
 msgid "Generate points also for NULL category"
-msgstr ""
+msgstr "Generare punti anche per categorie NULL"
 #: ../raster/r.random/main.c:86
 msgid "Report information about input raster and exit"
@@ -5984,11 +5748,11 @@
 #: ../raster/r.random/main.c:90
 msgid "Generate vector points as 3D points"
-msgstr ""
+msgstr "Generare punti vettoriali come punti 3D"
 #: ../raster/r.random/main.c:94 ../vector/v.in.ascii/in.c:161
 msgid "Do not build topology in points mode"
-msgstr ""
+msgstr "Non creare topologia per i punti"
 #: ../raster/r.random/main.c:95 ../vector/v.out.ascii/out.c:67
 #: ../vector/v.out.ascii/out.c:77 ../vector/v.out.ascii/out.c:84
@@ -6008,7 +5772,7 @@
 #: ../raster/r.random/main.c:142
 #, c-format
 msgid "Note: one (or both) of %s and %s must be specified"
-msgstr ""
+msgstr "Nota: uno (o entrambi) di %s e %s dev'essere specificato"
 #: ../raster/r.random/main.c:160
 #, fuzzy, c-format
@@ -6061,8 +5825,7 @@
 #: ../raster/r.random/random.c:110
 #, fuzzy, c-format
 msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr ""
-"Scrittura della mappa raster <%s> e della mappa vettoriale <%s> in corso ..."
+msgstr "Scrittura della mappa raster <%s> e della mappa vettoriale <%s> in corso ..."
 #: ../raster/r.random/random.c:113
 #, fuzzy, c-format
@@ -6082,8 +5845,7 @@
 #: ../raster/r.random/random.c:135
 #, fuzzy, c-format
 msgid "Cannot read raster row [%d] from cover raster map <%s>"
-msgstr ""
-"Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
+msgstr "Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
 #: ../raster/r.random/random.c:194 ../vector/v.net.distance/main.c:256
 #: ../vector/v.net.allpairs/main.c:228 ../vector/v.net.timetable/main.c:134
@@ -6097,7 +5859,7 @@
 #: ../raster/r.random/random.c:246
 #, c-format
 msgid "Only [%ld] random points created"
-msgstr ""
+msgstr "Solo [%ld] punti casuali creati"
 #: ../raster/r.los/main.c:82
 #, fuzzy
@@ -6129,17 +5891,16 @@
 #: ../raster/r.los/main.c:123
 msgid "Consider earth curvature (current ellipsoid)"
-msgstr ""
+msgstr "Considera la curva terreste (elissoide attuale)"
 #: ../raster/r.los/main.c:150
 msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
+msgstr "Il supporto per Lat/Long non è (ancora) implementato per questo modulo."
 #: ../raster/r.los/main.c:155
 #, fuzzy
 msgid "Specified observer coordinate is outside current region bounds."
-msgstr ""
-"L'osservatore specificato è al di fuori dei limiti della regione corrente"
+msgstr "L'osservatore specificato è al di fuori dei limiti della regione corrente"
 #: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
 #: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:428
@@ -6152,15 +5913,13 @@
 msgstr ""
 #: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Problemi nell'ottenere i parametri dell'ellisoide, si sta usando la sfera (6370997.0)"
 #: ../raster/r.los/main.c:250
 #, fuzzy, c-format
 msgid "Using maximum distance from the viewing point (meters): %f"
-msgstr ""
-"Si sta utilizzando la distanza massima dal punto di osservazione (metri): %f"
+msgstr "Si sta utilizzando la distanza massima dal punto di osservazione (metri): %f"
 #: ../raster/r.los/main.c:380 ../raster/r.buffer/write_map.c:78
 #: ../raster/r.proj/main.c:445 ../raster/r.texture/main.c:356
@@ -6178,16 +5937,11 @@
 msgstr "raster, buffer"
 #: ../raster/wildfire/r.spread/main.c:103
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:116
@@ -6218,19 +5972,15 @@
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:177
@@ -6291,8 +6041,7 @@
 #: ../raster/wildfire/r.ros/main.c:439
 #, fuzzy, c-format
 msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-msgstr ""
-"La mappa raster <%s> esiste già nel mapset <%>, selezionare un altro nome"
+msgstr "La mappa raster <%s> esiste già nel mapset <%>, selezionare un altro nome"
 #: ../raster/wildfire/r.spread/main.c:463
 #, fuzzy
@@ -6300,12 +6049,8 @@
 msgstr "Lettura dell'input in corso ..."
 #: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Traccia ricorsivamente il percorso di minor costo partendo dalle celle da "
-"cui il costo complessivo è stato determinato."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Traccia ricorsivamente il percorso di minor costo partendo dalle celle da cui il costo complessivo è stato determinato."
 #: ../raster/wildfire/r.spreadpath/main.c:83
 msgid "Name of raster map containing back-path easting information"
@@ -6324,11 +6069,7 @@
 msgstr ""
 #: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
 msgstr ""
 #: ../raster/wildfire/r.ros/main.c:224
@@ -6357,23 +6098,23 @@
 #: ../raster/wildfire/r.ros/main.c:267
 msgid "Name of raster map containing wind DIRECTIONs (degree)"
-msgstr ""
+msgstr "Nome del raster contenente le DIREZIONI del vento (gradi)"
 #: ../raster/wildfire/r.ros/main.c:274
 msgid "Name of raster map containing SLOPE (degree)"
-msgstr ""
+msgstr "Nome del raster contenente PENDENZA (gradi)"
 #: ../raster/wildfire/r.ros/main.c:281
 msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
+msgstr "Nome del raster contentente ESPOSIZIONE (gradi, antiorario da EST)"
 #: ../raster/wildfire/r.ros/main.c:288
 msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr ""
+msgstr "Nome del raster contenente ELEVAZIONE (m) (richiesto w/ -s)"
 #: ../raster/wildfire/r.ros/main.c:296
 msgid "Name of raster map to contain results (several new layers)"
-msgstr ""
+msgstr "Nome del raster contenente i risultati (diversi layers nuovi)"
 #: ../raster/wildfire/r.ros/main.c:305
 msgid "Also produce maximum SPOTTING distance"
@@ -6466,16 +6207,13 @@
 msgstr "raster"
 #: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:50
 #, fuzzy, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"La location Lat/Long non è supportata da %s. Prima riproiettare la mappa."
+msgstr "La location Lat/Long non è supportata da %s. Prima riproiettare la mappa."
 #: ../raster/r.gwflow/main.c:215
 msgid "Please provide river_head, river_leak and river_bed maps"
@@ -6501,7 +6239,7 @@
 #: ../raster/r.gwflow/main.c:379
 #, c-format
 msgid "Maximum difference between this and last increment: %g"
-msgstr ""
+msgstr "Differenza massima tra questo e l'ultimo incremento: %g"
 #: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
 #: ../raster/r.profile/input.c:59
@@ -6520,7 +6258,7 @@
 #: ../raster/r.profile/main.c:66
 msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
+msgstr "Nome del file di output (utilizzare output=- per stampare a monitor)"
 #: ../raster/r.profile/main.c:74
 #, fuzzy
@@ -6529,11 +6267,11 @@
 #: ../raster/r.profile/main.c:81
 msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
+msgstr "Risoluzione lungo profilo (default = risoluzione della regione attuale)"
 #: ../raster/r.profile/main.c:88
 msgid "Character to represent no data cell"
-msgstr ""
+msgstr "Carattere per rappresentare celle no data"
 #: ../raster/r.profile/main.c:92
 msgid "Interactively select End-Points"
@@ -6631,12 +6369,8 @@
 #: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Crea un raster mostrando una zona di buffer intorno alle celle che "
-"contengono valori non nulli."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crea un raster mostrando una zona di buffer intorno alle celle che contengono valori non nulli."
 #: ../raster/r.buffer/main.c:83
 msgid "Distance zone(s)"
@@ -6648,8 +6382,7 @@
 #: ../raster/r.buffer/main.c:96
 msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-"Ignora le celle con valore zero (0) invece di ignorare quelle con valore NULL"
+msgstr "Ignora le celle con valore zero (0) invece di ignorare quelle con valore NULL"
 #: ../raster/r.buffer/main.c:149
 msgid "Parse distances error"
@@ -6691,9 +6424,7 @@
 msgstr "raster, serie"
 #: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:149
@@ -6711,7 +6442,7 @@
 #: ../raster/r.series/main.c:176
 msgid "Ignore values outside this range"
-msgstr ""
+msgstr "Ignora valori fuori questo range"
 #: ../raster/r.series/main.c:180 ../raster/r.resamp.stats/main.c:277
 msgid "Propagate NULLs"
@@ -6725,22 +6456,15 @@
 #: ../raster/r.series/main.c:228
 msgid "output= and method= must have the same number of values"
-msgstr ""
+msgstr "output= e method= devono avere lo stesso numero di valori"
 #: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trova la media dei valori in una mappa di copertura all'interno di aree che "
-"hanno lo stesso valore di categoria in una mappa di base definita "
-"dall'utente."
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trova la media dei valori in una mappa di copertura all'interno di aree che hanno lo stesso valore di categoria in una mappa di base definita dall'utente."
 #: ../raster/r.average/main.c:66 ../raster/r.statistics/main.c:73
 msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-"Esegue i calcoli sui valori estratti dalle etichette di categoria della "
-"mappa di copertura"
+msgstr "Esegue i calcoli sui valori estratti dalle etichette di categoria della mappa di copertura"
 #: ../raster/r.average/main.c:82 ../raster/r.grow2/main.c:212
 #, fuzzy, c-format
@@ -6764,19 +6488,18 @@
 msgstr "Programma per la generazione di superfici"
 #: ../raster/r.surf.idw2/main.c:80
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/long non sono supportati da r.surf.idw2. Utilizzare invece r.surf.idw!"
 #: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:141
 #, c-format
 msgid "%s=%s - illegal number of interpolation points"
-msgstr ""
+msgstr "%s=%s - numero di punti per l'interpolazione non accettabile "
 #: ../raster/r.surf.idw2/main.c:96
 #, c-format
 msgid "%s: no data points found"
-msgstr ""
+msgstr "%s: nessun punto trovato"
 #: ../raster/r.surf.idw2/main.c:114
 #, fuzzy, c-format
@@ -6823,8 +6546,7 @@
 msgstr "Nome di una mappa raster contenente una superfice di altezze"
 #: ../raster/r.watershed/front/main.c:88
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:94
@@ -6867,8 +6589,7 @@
 #: ../raster/r.watershed/front/main.c:129
 #, fuzzy
-msgid ""
-"Name for output raster map useful for visual display of results (DEPRECATED)"
+msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
 msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
 #: ../raster/r.watershed/front/main.c:135
@@ -6909,7 +6630,7 @@
 #: ../raster/r.watershed/front/main.c:179
 msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
+msgstr "Memoria massima da utilizzare con la flag -m (in MB)"
 #: ../raster/r.watershed/front/main.c:183
 msgid "Enable MFD flow (default is SFD (D8))"
@@ -6928,9 +6649,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:197
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:202
@@ -7037,21 +6756,13 @@
 #, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 "\n"
 "USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
 msgstr ""
 #: ../raster/r.watershed/ram/do_astar.c:26
@@ -7112,8 +6823,7 @@
 msgstr ""
 #: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
 msgstr ""
 #: ../raster/r.watershed/shed/main.c:41
@@ -7123,7 +6833,7 @@
 #: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
 #, c-format
 msgid "<<%s>> command line failed"
-msgstr ""
+msgstr "<<%s>> comando fallito"
 #: ../raster/r.watershed/shed/main.c:72
 #, fuzzy
@@ -7214,18 +6924,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
@@ -7237,8 +6944,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -7249,14 +6955,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -7265,18 +6968,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -7289,18 +6989,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -7406,8 +7103,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -7426,9 +7122,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -7470,8 +7164,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -7485,8 +7178,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -7494,8 +7186,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/basin_maps.c:12
@@ -7705,12 +7396,8 @@
 msgstr "Calcolo della superficie %d (di %d) in corso..."
 #: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Output una matrice della covarianza/correlazione per un raster specificato "
-"dall'utente."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Output una matrice della covarianza/correlazione per un raster specificato dall'utente."
 #: ../raster/r.covar/main.c:62
 msgid "Print correlation matrix"
@@ -7723,7 +7410,7 @@
 #: ../raster/r.covar/main.c:129
 msgid "No non-null values"
-msgstr ""
+msgstr "Nessun valore non-null "
 #: ../raster/r.rescale/main.c:52
 msgid "Rescales the range of category values in a raster map layer."
@@ -7856,13 +7543,13 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:149
 #, c-format
 msgid "<%s=%s> unknown %s"
-msgstr ""
+msgstr "<%s=%s> sconosciuto %s"
 #: ../raster/r.proj/main.c:217 ../raster/r.proj.seg/main.c:247
 #: ../vector/v.proj/main.c:132
 #, c-format
 msgid "option <%s>: <%s> exists."
-msgstr ""
+msgstr "option <%s>:<%s> esiste."
 #: ../raster/r.proj/main.c:222 ../raster/r.proj.seg/main.c:253
 #: ../vector/v.proj/main.c:149
@@ -7872,22 +7559,17 @@
 #: ../raster/r.proj/main.c:228 ../raster/r.proj.seg/main.c:265
 #, fuzzy
 msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Impossibile ottenere informazioni sulla proiezione per la mappa raster di "
-"output"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:231 ../raster/r.proj.seg/main.c:268
 #, fuzzy
 msgid "Unable to get projection units of output raster map"
-msgstr ""
-"Impossibile ottenere le unità della proiezione per la mappa raster di output"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:234 ../raster/r.proj.seg/main.c:271
 #, fuzzy
 msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Impossibile ottenere i valori chiave della proiezione per la mappa raster di "
-"output"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:243 ../raster/r.proj.seg/main.c:280
 #, fuzzy, c-format
@@ -7908,22 +7590,17 @@
 #: ../raster/r.proj/main.c:275 ../raster/r.proj.seg/main.c:312
 #, fuzzy
 msgid "Unable to get projection info of input map"
-msgstr ""
-"input"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di input"
 #: ../raster/r.proj/main.c:278 ../raster/r.proj.seg/main.c:315
 #, fuzzy
 msgid "Unable to get projection units of input map"
-msgstr ""
-"Impossibile ottenere le unità della proiezione per la mappa raster di input"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di input"
 #: ../raster/r.proj/main.c:281 ../raster/r.proj.seg/main.c:318
 #, fuzzy
 msgid "Unable to get projection key values of input map"
-msgstr ""
-"intput"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di intput"
 #: ../raster/r.proj/main.c:296 ../raster/r.proj.seg/main.c:332
 msgid "Unable to work with unprojected data (xy location)"
@@ -7931,7 +7608,7 @@
 #: ../raster/r.proj/main.c:370 ../raster/r.proj.seg/main.c:440
 msgid "Input:"
-msgstr ""
+msgstr "Input:"
 #: ../raster/r.proj/main.c:371 ../raster/r.proj/main.c:382
 #: ../raster/r.proj.seg/main.c:441 ../raster/r.proj.seg/main.c:452
@@ -8072,9 +7749,7 @@
 msgstr "Impossibile creare i file temporanei"
 #: ../raster/r.fill.dir/main.c:86
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:90
@@ -8178,9 +7853,7 @@
 msgstr "Impossibile scrivere la tavola dei colori per %s"
 #: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:86
@@ -8222,10 +7895,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:158
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:169
@@ -8457,12 +8127,8 @@
 msgstr "raster, statistica, riclassificazione"
 #: ../raster/r.clump/main.c:51
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Ricategorizza i dati in una mappa raster raggruppando celle che formano aree "
-"fisicamente distinte in categorie singole."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Ricategorizza i dati in una mappa raster raggruppando celle che formano aree fisicamente distinte in categorie singole."
 #: ../raster/r.clump/main.c:63
 msgid "Title, in quotes"
@@ -8489,12 +8155,8 @@
 msgstr "Scrittura della riga %d della mappa raster non riuscita"
 #: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del "
-"pixel definita della regione corrente"
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del pixel definita della regione corrente"
 #: ../raster/r.out.tiff/r.out.tiff.c:111
 #, fuzzy
@@ -8534,15 +8196,11 @@
 #: ../raster/r.out.tiff/r.out.tiff.c:177
 #, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
 msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
 msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:198
@@ -8572,18 +8230,13 @@
 msgstr "raster, importazione, LIDAR"
 #: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Crea un raster da un assemblaggio di molte coordinate usando statistiche "
-"univariate"
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Crea un raster da un assemblaggio di molte coordinate usando statistiche univariate"
 #: ../raster/r.in.xyz/main.c:165
 #, fuzzy
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-"File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
+msgstr "File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
 #: ../raster/r.in.xyz/main.c:173
 msgid "Statistic to use for raster values"
@@ -8623,9 +8276,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:256
@@ -8667,8 +8318,7 @@
 msgstr "Impossibile aprire il file di input <%s>"
 #: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:483
@@ -8684,8 +8334,7 @@
 #: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
@@ -8828,16 +8477,12 @@
 msgstr ""
 #: ../raster/r.texture/h_measure.c:84
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
 msgstr ""
 #: ../raster/r.texture/h_measure.c:88
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/h_measure.c:927
@@ -8846,9 +8491,7 @@
 msgstr ""
 #: ../raster/r.surf.random/main.c:46
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.random/main.c:53
@@ -8910,9 +8553,7 @@
 msgstr ""
 #: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
 msgstr ""
 #: ../raster/r.colors/main.c:175
@@ -8946,8 +8587,7 @@
 #: ../raster/r.colors/main.c:205
 #, fuzzy
 msgid "Path to rules file (\"-\" to read rules from stdin)"
-msgstr ""
-"Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
+msgstr "Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
 #: ../raster/r.colors/main.c:210
 #, fuzzy
@@ -8996,25 +8636,16 @@
 msgstr "Nessuna mappa raster specificata"
 #: ../raster/r.colors/main.c:280
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
-"Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o "
-"\"rules\"!"
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
 #: ../raster/r.colors/main.c:283
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
-msgstr ""
-"La modalità interattiva è incompatibile con le opzioni \"color\", \"rules\" "
-"e \"raster\""
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+msgstr "La modalità interattiva è incompatibile con le opzioni \"color\", \"rules\" e \"raster\""
 #: ../raster/r.colors/main.c:290
 msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-msgstr ""
-"Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
+msgstr "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
 #: ../raster/r.colors/main.c:301
 msgid "-g and -a flags are mutually exclusive"
@@ -9037,22 +8668,16 @@
 #: ../raster/r.colors/main.c:345
 #, fuzzy
 msgid "Color table 'random' is not supported for floating point raster map"
-msgstr ""
-"La tavola dei colori 'random' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:350
 #, fuzzy
 msgid "Color table 'grey.eq' is not supported for floating point raster map"
-msgstr ""
-"La tavola dei colori 'grey.eq' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:357
 msgid "Color table 'grey.log' is not supported for floating point raster map"
-msgstr ""
-"La tavola dei colori 'grey.log' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'grey.log' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:370
 #, fuzzy, c-format
@@ -9140,9 +8765,7 @@
 #: ../raster/r.colors/stats.c:79
 msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-"Non è possibile usare lo scaling logaritmico se il campo di variazione "
-"include lo zero"
+msgstr "Non è possibile usare lo scaling logaritmico se il campo di variazione include lo zero"
 #: ../raster/r.statistics/main.c:44
 msgid "Calculates category or object oriented statistics."
@@ -9222,14 +8845,11 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:34
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:40
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:57
@@ -9246,8 +8866,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.cwed/cwed.c:46
@@ -9272,8 +8891,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:33
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.simpson/simpson.c:39
@@ -9545,9 +9163,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:210
@@ -9571,9 +9187,7 @@
 #: ../raster/r.out.gdal/main.c:267
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:272
@@ -9601,23 +9215,17 @@
 #: ../raster/r.out.gdal/main.c:435
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:446
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:454
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:463 ../raster/r.out.gdal/main.c:506
@@ -9638,8 +9246,7 @@
 #: ../raster/r.out.gdal/main.c:492
 #, fuzzy, c-format
 msgid "Checking options for raster map <%s> (band %d)..."
-msgstr ""
-"Controllo delle opzioni per la mappa raster <%s> (banda %d) in corso..."
+msgstr "Controllo delle opzioni per la mappa raster <%s> (banda %d) in corso..."
 #: ../raster/r.out.gdal/main.c:533
 #, fuzzy
@@ -9728,10 +9335,7 @@
 #: ../raster/r.out.gdal/main.c:746 ../raster/r.out.gdal/main.c:759
 #: ../raster/r.out.gdal/main.c:774
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:749
@@ -9747,10 +9351,7 @@
 #: ../raster/r.out.gdal/main.c:788
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:791
@@ -9765,32 +9366,22 @@
 #: ../raster/r.out.gdal/export_band.c:188
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:193
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:203
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:210
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:256
@@ -9848,9 +9439,7 @@
 #: ../raster/r.null/null.c:117
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/null.c:123
@@ -9886,8 +9475,7 @@
 #: ../raster/r.null/null.c:169
 #, fuzzy, c-format
 msgid "Writing new null file for raster map <%s>..."
-msgstr ""
-"Scrittura del nuovo file di valori nulli per la mappa raster <%s> in corso..."
+msgstr "Scrittura del nuovo file di valori nulli per la mappa raster <%s> in corso..."
 #: ../raster/r.null/null.c:176
 #, c-format
@@ -9902,8 +9490,7 @@
 #: ../raster/r.null/null.c:188
 #, fuzzy, c-format
 msgid "Removing null file for raster map <%s>..."
-msgstr ""
-"Rimozione in corso del file di valori nulli per la mappa raster <%s>..."
+msgstr "Rimozione in corso del file di valori nulli per la mappa raster <%s>..."
 #: ../raster/r.null/null.c:258
 #, c-format
@@ -10222,14 +9809,11 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:116
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:117
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:131
@@ -10335,22 +9919,16 @@
 msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
 #, fuzzy, c-format
 msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-"Calcolo della posizione del sole in corso... (utilizzando solpos(V. %s) da "
-"NREL)"
+msgstr "Calcolo della posizione del sole in corso... (utilizzando solpos(V. %s) da NREL)"
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:397
@@ -10491,24 +10069,18 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98
 #, fuzzy
 msgid "Unable to get projection info of current location"
-msgstr ""
-"Non è possibile ottenere informazioni sulla proiezione della location "
-"corrente"
+msgstr "Non è possibile ottenere informazioni sulla proiezione della location corrente"
 #: ../raster/r.sunmask/g_solposition.c:101
 msgid "Unable to get projection units of current location"
@@ -10527,9 +10099,7 @@
 #: ../general/g.region/printwindow.c:684 ../general/g.region/printwindow.c:692
 #: ../general/g.region/printwindow.c:700
 msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr ""
-"Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di "
-"proiezione in input)"
+msgstr "Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di proiezione in input)"
 #: ../raster/r.random.surface/main.c:43
 msgid "raster, random, surface"
@@ -10715,9 +10285,7 @@
 #: ../raster/r.thin/thin_lines.c:176
 msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Assotigliamento non completato, considera di incrementare il parametro "
-"'iterations'"
+msgstr "Assotigliamento non completato, considera di incrementare il parametro 'iterations'"
 #: ../raster/r.reclass/main.c:49
 #, fuzzy
@@ -10731,12 +10299,8 @@
 #: ../raster/r.reclass/main.c:52
 #, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crea un nuovo layer dove i valori della categoria sono basati sulla "
-"riclassificazione delle categorie esistenti in un altro raster"
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crea un nuovo layer dove i valori della categoria sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #: ../raster/r.reclass/main.c:57
 msgid "Raster map to be reclassified"
@@ -10763,8 +10327,7 @@
 #: ../raster/r.reclass/main.c:105
 #, fuzzy, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Inserire regola/e, \"end\" quando finito, \"help\" in caso di necessità.\n"
+msgstr "Inserire regola/e, \"end\" quando finito, \"help\" in caso di necessità.\n"
 #: ../raster/r.reclass/main.c:107
 #, fuzzy, c-format
@@ -10911,9 +10474,7 @@
 msgstr "Attributi"
 #: ../raster/r.to.vect/main.c:79
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
 msgstr ""
 #: ../raster/r.to.vect/main.c:86
@@ -10931,9 +10492,7 @@
 msgstr "il flag z è supportato solo per i punti"
 #: ../raster/r.to.vect/main.c:123
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:194 ../vector/v.in.sites/main.c:170
@@ -11021,12 +10580,8 @@
 #: ../raster/r.cats/main.c:53
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Gestisce i valori delle categorie e le etichette associate con un raster "
-"specificato dall'utente"
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Gestisce i valori delle categorie e le etichette associate con un raster specificato dall'utente"
 #: ../raster/r.cats/main.c:66
 #, fuzzy
@@ -11040,14 +10595,11 @@
 #: ../raster/r.cats/main.c:84
 #, fuzzy
 msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"File contenente le regole per le etichette di categoria (oppure \"-\" per "
-"leggere dallo stdin)"
+msgstr "File contenente le regole per le etichette di categoria (oppure \"-\" per leggere dallo stdin)"
 #: ../raster/r.cats/main.c:91
 msgid "Default label or format string for dynamic labeling"
-msgstr ""
-"Etichetta predefinita o stringa del formato per l'etichettatura dinamica"
+msgstr "Etichetta predefinita o stringa del formato per l'etichettatura dinamica"
 #: ../raster/r.cats/main.c:93
 msgid "Used when no explicit label exists for the category"
@@ -11074,14 +10626,11 @@
 #: ../raster/r.cats/main.c:252
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s> in <%s>"
-msgstr ""
-"Impossibile leggere il file delle categorie della mappa raster <%s> in <%s>"
+msgstr "Impossibile leggere il file delle categorie della mappa raster <%s> in <%s>"
 #: ../raster/r.cats/main.c:268
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"La mappa è con valori a virgola mobile! La lista delle categorie verrà "
-"ignorata, si sta usando la lista di valori"
+msgstr "La mappa è con valori a virgola mobile! La lista delle categorie verrà ignorata, si sta usando la lista di valori"
 #: ../raster/r.cats/main.c:285
 msgid "vals argument is required for floating point map!"
@@ -11103,9 +10652,7 @@
 msgstr "Lettura di <%s> in <%s>"
 #: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:75
@@ -11171,11 +10718,8 @@
 msgstr ""
 #: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
-msgstr ""
-"Questo programma di utilità consente di confrontare le coincidenze di due "
-"tematismi raster\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
+msgstr "Questo programma di utilità consente di confrontare le coincidenze di due tematismi raster\n"
 #: ../raster/r.coin/inter.c:52
 msgid "The report can be made in one of 8 units."
@@ -11183,8 +10727,7 @@
 #: ../raster/r.coin/inter.c:53
 msgid "Please choose a unit by entering one of the following letter codes:"
-msgstr ""
-"Scegliere un'unità di misura immettendo uno dei seguenti codici letterali:"
+msgstr "Scegliere un'unità di misura immettendo uno dei seguenti codici letterali:"
 #: ../raster/r.coin/inter.c:55
 msgid "     'c': cells"
@@ -11245,10 +10788,8 @@
 #: ../raster/r.coin/inter.c:117
 #, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-msgstr ""
-"Si vuol stampare questo rapporto (richiede il comando Unix lpr (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr "Si vuol stampare questo rapporto (richiede il comando Unix lpr (y/n) [n] "
 #: ../raster/r.coin/inter.c:126
 #, c-format
@@ -11259,18 +10800,12 @@
 #: ../raster/r.coin/inter.c:142
 #, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
-msgstr ""
-"Si vuole generare questo rapporto con una diversa unità di misurà? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgstr "Si vuole generare questo rapporto con una diversa unità di misurà? (y/n) [y] "
 #: ../raster/r.coin/main.c:68
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Riporta in forma tabellare le reciproche occorrenze (coincidenze) delle "
-"categorie di due tematismi raster."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Riporta in forma tabellare le reciproche occorrenze (coincidenze) delle categorie di due tematismi raster."
 #: ../raster/r.coin/main.c:76
 #, fuzzy
@@ -11288,13 +10823,8 @@
 msgstr "Unità di misura"
 #: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(celle), p(percentuale), x(percentuale di categoria [colonna]), y"
-"(percentuale di categoria [riga]), a(acri), h(ettari), k(chilometri "
-"quadrati), m(miglia quadrate)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(celle), p(percentuale), x(percentuale di categoria [colonna]), y(percentuale di categoria [riga]), a(acri), h(ettari), k(chilometri quadrati), m(miglia quadrate)"
 #: ../raster/r.coin/main.c:98
 msgid "Wide report, 132 columns (default: 80)"
@@ -11331,9 +10861,7 @@
 msgstr "Preparazione del rapporto in corso ..."
 #: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
 msgstr ""
 #: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:117
@@ -11445,14 +10973,7 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:183
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation:  1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction.  The input for this is the angle (in "
-"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:236
@@ -11460,33 +10981,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:252
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:260
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:268
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:276
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:284
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:292
@@ -11580,8 +11091,7 @@
 #: ../raster/r.external/main.c:172
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
 msgstr ""
 #: ../raster/r.external/main.c:300
@@ -11697,8 +11207,7 @@
 msgstr ""
 #: ../raster/r.proj.seg/main.c:222
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj.seg/main.c:255
@@ -11787,8 +11296,7 @@
 #: ../raster/r.recode/read_rules.c:31
 #, fuzzy, c-format
 msgid "Data range of raster map <%s> is %s to %s (entire map)"
-msgstr ""
-"L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
+msgstr "L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
 #: ../raster/r.recode/read_rules.c:36
 #, fuzzy, c-format
@@ -11803,8 +11311,7 @@
 #: ../raster/r.recode/read_rules.c:44
 #, fuzzy, c-format
 msgid "Integer data range of raster mao <%s> is %d to %d"
-msgstr ""
-"L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
+msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
 #: ../raster/r.recode/read_rules.c:63
 #, fuzzy
@@ -11847,12 +11354,8 @@
 msgstr "Valore del raster"
 #: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un "
-"vettoriale contenendo i centroidi calcolati di questi gruppi"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un vettoriale contenendo i centroidi calcolati di questi gruppi"
 #: ../raster/r.volume/main.c:69
 msgid "Existing raster map representing data that will be summed within clumps"
@@ -11940,8 +11443,7 @@
 msgstr "Elaborazione delle linee in corso ..."
 #: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.carve/main.c:78
@@ -11949,9 +11451,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:79
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:84
@@ -12003,9 +11503,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:58
@@ -12058,12 +11556,8 @@
 #: ../raster/r.report/parse.c:46
 #, fuzzy
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi;miglia;me;metri;k;chilometri;a;acri;h;ettari;c;conteggio delle celle;p;"
-"percentuale di copertura"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi;miglia;me;metri;k;chilometri;a;acri;h;ettari;c;conteggio delle celle;p;percentuale di copertura"
 #: ../raster/r.report/parse.c:56
 msgid "Character representing no data cell value"
@@ -12142,8 +11636,7 @@
 msgstr ""
 #: ../raster/r.composite/main.c:74
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Combina raster rosso, verde e blu in un singolo raster"
 #: ../raster/r.composite/main.c:100
@@ -12236,9 +11729,7 @@
 msgstr ""
 #: ../raster/r.flow/calc.c:414
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
 msgstr ""
 #: ../raster/r.flow/calc.c:453
@@ -12291,9 +11782,7 @@
 msgstr ""
 #: ../raster/r.flow/calc.c:536
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/io.c:68
@@ -12439,10 +11928,8 @@
 #: ../raster/r.in.ascii/main.c:74
 #, fuzzy
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"File raster ASCII da importare. Se non è dato legge dallo standard input"
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "File raster ASCII da importare. Se non è dato legge dallo standard input"
 #: ../raster/r.in.ascii/main.c:92 ../raster/r.in.arc/main.c:94
 #, fuzzy
@@ -12508,9 +11995,7 @@
 #: ../raster/r.in.ascii/gethead.c:40
 msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-"errore nella lettura della dimensione della riga e della colonna dal file "
-"Surfer grid"
+msgstr "errore nella lettura della dimensione della riga e della colonna dal file Surfer grid"
 #: ../raster/r.in.ascii/gethead.c:46
 msgid "error reading the X range from the Surfer grid file"
@@ -12609,8 +12094,7 @@
 #: ../raster/r.what/main.c:143
 msgid "Output integer category values, not cell values"
-msgstr ""
-"Visualizzare i valori delle categorie integer e non i valori delle celle"
+msgstr "Visualizzare i valori delle categorie integer e non i valori delle celle"
 #: ../raster/r.what/main.c:147
 msgid "Turn on cache reporting"
@@ -12665,15 +12149,11 @@
 #: ../raster/r.topidx/main.c:39
 #, fuzzy
 msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
+msgstr "Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
 #: ../raster/r.topidx/file_io.c:32
 #, c-format
-msgid ""
-"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
-"%.2f]! Needs to be at least identical or the current region resolution lower "
-"than the input map resolution"
+msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
 msgstr ""
 #: ../raster/r.topidx/file_io.c:90
@@ -12713,8 +12193,7 @@
 msgstr ""
 #: ../raster/r.univar2/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
 #: ../raster/r.univar2/r.univar_main.c:274
@@ -12729,11 +12208,8 @@
 #: ../raster/r.univar2/r3.univar_main.c:106
 #, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
 #: ../raster/r.regression.line/main.c:44
 #, fuzzy
@@ -12749,9 +12225,7 @@
 msgstr ""
 #: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.regression.line/main.c:63 ../general/g.region/main.c:147
@@ -13018,9 +12492,7 @@
 msgstr "Estrae parametri del terreno da un DEM."
 #: ../raster/r.param.scale/interface.c:56
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:74
@@ -13061,11 +12533,8 @@
 msgstr ""
 #: ../raster/r.in.arc/main.c:61
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster (binario)"
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster (binario)"
 #: ../raster/r.in.arc/main.c:69
 #, fuzzy
@@ -13111,10 +12580,7 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:133
@@ -13279,10 +12745,7 @@
 msgstr ""
 #: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
 msgstr ""
 #: ../general/manage/cmd/copy.c:58
@@ -13337,16 +12800,13 @@
 msgstr "%s file da rimuovere"
 #: ../general/manage/cmd/list.c:43 ../general/g.mlist/main.c:67
-msgid ""
-"Lists available GRASS data base files of the user-specified data type to "
-"standard output."
+msgid "Lists available GRASS data base files of the user-specified data type to standard output."
 msgstr ""
 #: ../general/manage/cmd/list.c:72 ../general/g.mlist/main.c:121
 #, fuzzy
 msgid "Mapset to list (default: current search path)"
-msgstr ""
-"Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
+msgstr "Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
 #: ../general/manage/cmd/list.c:76 ../general/g.mlist/main.c:147
 #, fuzzy
@@ -13490,25 +12950,16 @@
 #: ../general/g.proj/input.c:250
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Lettura del file %s avvenuta con successo, ma non contiene alcuna "
-"informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna "
-"proiezione)'"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Lettura del file %s avvenuta con successo, ma non contiene alcuna informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna proiezione)'"
 #: ../general/g.proj/main.c:54 ../general/g.setproj/main.c:78
 msgid "general, projection"
 msgstr ""
 #: ../general/g.proj/main.c:56
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"Converte le descrizioni del sistema di coordinate (es. informazioni sulla "
-"proiezione) utilizzando diversi formati (incluso quello di GRASS)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "Converte le descrizioni del sistema di coordinate (es. informazioni sulla proiezione) utilizzando diversi formati (incluso quello di GRASS)."
 #: ../general/g.proj/main.c:59
 #, fuzzy
@@ -13521,8 +12972,7 @@
 #: ../general/g.proj/main.c:71
 msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Verifica le informazioni sul datum e stampa i parametri di trasformazione"
+msgstr "Verifica le informazioni sul datum e stampa i parametri di trasformazione"
 #: ../general/g.proj/main.c:77
 msgid "Print projection information in PROJ.4 format"
@@ -13537,22 +12987,17 @@
 msgstr "Usa formato in stile ESRI (solo per il formato WKT)"
 #: ../general/g.proj/main.c:94
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e "
-"PROJ4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e PROJ4)"
 #: ../general/g.proj/main.c:103
 msgid "Georeferenced data file to read projection information from"
-msgstr ""
-"File di dati georeferenziati dai quali leggere le informazioni di proiezione"
+msgstr "File di dati georeferenziati dai quali leggere le informazioni di proiezione"
 #: ../general/g.proj/main.c:112
 #, fuzzy
 msgid "ASCII file containing a WKT projection description (- for stdin)"
-msgstr ""
-"File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
+msgstr "File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
 #: ../general/g.proj/main.c:121
 msgid "PROJ.4 projection description (- for stdin)"
@@ -13576,9 +13021,7 @@
 msgstr ""
 #: ../general/g.proj/main.c:145
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:150 ../general/g.proj/main.c:159
@@ -13587,12 +13030,8 @@
 msgstr "Crea/Modifica"
 #: ../general/g.proj/main.c:151
-msgid ""
-"Create new projection files (modifies current location unless 'location' "
-"option specified)"
-msgstr ""
-"Crea un nuovo file contenente le informazioni sulla proiezione (modifica la "
-"location attuale a meno che l'opzione 'location' venga specificata)"
+msgid "Create new projection files (modifies current location unless 'location' option specified)"
+msgstr "Crea un nuovo file contenente le informazioni sulla proiezione (modifica la location attuale a meno che l'opzione 'location' venga specificata)"
 #: ../general/g.proj/main.c:160
 #, fuzzy
@@ -13606,8 +13045,7 @@
 #: ../general/g.proj/main.c:183
 #, fuzzy, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Solo una delle seguenti opzioni: '%s', '%s' o '%s' può essere specificata"
+msgstr "Solo una delle seguenti opzioni: '%s', '%s' o '%s' può essere specificata"
 #: ../general/g.proj/main.c:210
 msgid "Projection files missing"
@@ -13639,12 +13077,8 @@
 #: ../general/g.proj/output.c:174
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection. (Current mapset is %s)"
-msgstr ""
-"Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione "
-"corrente della localtion. (Il mapset corrente è %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+msgstr "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione corrente della localtion. (Il mapset corrente è %s)"
 #: ../general/g.proj/output.c:190
 #, c-format
@@ -13670,10 +13104,7 @@
 msgstr "Errore durante la scrittura di PROJ_UNITS"
 #: ../general/g.proj/output.c:243
-msgid ""
-"N.B. The default region was updated to the new projection, but if you have "
-"multiple mapsets g.region -d should be run in each to update the region from "
-"the default."
+msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
 msgstr ""
 #: ../general/g.proj/output.c:247
@@ -13780,8 +13211,7 @@
 msgstr ""
 #: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:37
@@ -13900,8 +13330,7 @@
 #: ../general/g.setproj/main.c:216
 #, fuzzy
 msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-"Si vuole cambiare il datum (o i parametri di trasformazione del datum)?"
+msgstr "Si vuole cambiare il datum (o i parametri di trasformazione del datum)?"
 #: ../general/g.setproj/main.c:224
 #, fuzzy
@@ -13954,10 +13383,7 @@
 msgstr "Le informazioni sulla zona UTM non sono state aggiornate"
 #: ../general/g.setproj/main.c:455
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:460
@@ -14096,11 +13522,7 @@
 msgstr ""
 #: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
 #: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
@@ -14115,8 +13537,7 @@
 #: ../general/g.transform/main.c:359
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"File contenente le coordinate da trasformare (\"-\" per leggere dallo stdin)"
+msgstr "File contenente le coordinate da trasformare (\"-\" per leggere dallo stdin)"
 #: ../general/g.transform/main.c:360
 msgid "Local x,y coordinates to target east,north"
@@ -14145,8 +13566,7 @@
 msgstr "Cambia il mapset corrente."
 #: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:57
@@ -14160,11 +13580,8 @@
 #: ../general/g.mapset/main.c:75
 #, fuzzy
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
-msgstr ""
-"Directory dei dati GIS (percorso intero della directory dove la nuova "
-"location è situata)"
+msgid "GIS data directory (full path to the directory where the new location is)"
+msgstr "Directory dei dati GIS (percorso intero della directory dove la nuova location è situata)"
 #: ../general/g.mapset/main.c:80
 #, fuzzy
@@ -14208,9 +13625,7 @@
 #: ../general/g.mapset/main.c:179
 #, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
 msgstr ""
 #: ../general/g.mapset/main.c:183
@@ -14266,9 +13681,7 @@
 msgstr "Modifica il percorso di ricerca corrente dell'utente"
 #: ../general/g.mapsets/main.c:61
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:69
@@ -14284,14 +13697,12 @@
 #: ../general/g.mapsets/main.c:78
 #, fuzzy
 msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr ""
-"Nome di uno o più mapset esistenti da aggiungere al percorso di ricerca"
+msgstr "Nome di uno o più mapset esistenti da aggiungere al percorso di ricerca"
 #: ../general/g.mapsets/main.c:87
 #, fuzzy
 msgid "Name(s) of existing mapset(s) to remove from search path"
-msgstr ""
-"Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
+msgstr "Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
 #: ../general/g.mapsets/main.c:91
 #: ../locale/scriptstrings/m.proj_to_translate.c:7
@@ -14537,8 +13948,7 @@
 #: ../general/g.region/main.c:93
 #, fuzzy
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Stampa la regione corrente in lat/long usando ellissoide/datum corrente"
+msgstr "Stampa la regione corrente in lat/long usando ellissoide/datum corrente"
 #: ../general/g.region/main.c:99
 #, fuzzy
@@ -14569,9 +13979,7 @@
 msgstr ""
 #: ../general/g.region/main.c:130
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:136
@@ -14585,12 +13993,8 @@
 #: ../general/g.region/main.c:153
 #, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Allinea la regione alla risoluzione (predefinito = allinea ai margini, "
-"funziona solo per la risoluzione 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Allinea la regione alla risoluzione (predefinito = allinea ai margini, funziona solo per la risoluzione 2D)"
 #: ../general/g.region/main.c:159
 msgid "Do not update the current region"
@@ -14608,9 +14012,7 @@
 #: ../general/g.region/main.c:186
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Imposta la regione in modo che corrisponda a questa mappa raster (sia valori "
-"2D che 3D)"
+msgstr "Imposta la regione in modo che corrisponda a questa mappa raster (sia valori 2D che 3D)"
 #: ../general/g.region/main.c:253
 msgid "Value for the top edge"
@@ -14666,8 +14068,7 @@
 #: ../general/g.region/main.c:361
 #, fuzzy
 msgid "Save current region settings in named region file"
-msgstr ""
-"Salva le impostazioni della regione corrente in un file di regione con nome"
+msgstr "Salva le impostazioni della regione corrente in un file di regione con nome"
 #: ../general/g.region/main.c:508
 #, fuzzy, c-format
@@ -14701,9 +14102,7 @@
 #: ../general/g.region/main.c:857
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"Non è possibile cambiare la regione predefintia. Il mapset corrente non è "
-"<PERMANENT>"
+msgstr "Non è possibile cambiare la regione predefintia. Il mapset corrente non è <PERMANENT>"
 #: ../general/g.region/main.c:874
 #, fuzzy, c-format
@@ -14736,18 +14135,12 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Output WGS84 impossible a causa dell'assenza di parametri di trasformazione "
-"del datum. Prova ad eseguire g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Output WGS84 impossible a causa dell'assenza di parametri di trasformazione del datum. Prova ad eseguire g.setproj."
 #: ../general/g.region/printwindow.c:783
 msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -14767,10 +14160,7 @@
 msgstr ""
 #: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS "
-"Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
-"command line interface only"
+msgid "wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:54
@@ -14820,15 +14210,12 @@
 #: ../general/g.findfile/main.c:79
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
-"s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../display/d.profile/main.c:61
-#, fuzzy
 msgid "display, raster, profile"
-msgstr "raster, serie"
+msgstr ""
 #: ../display/d.profile/main.c:63
 msgid "Interactive profile plotting utility with optional output."
@@ -14949,12 +14336,8 @@
 msgstr ""
 #: ../display/d.font/main.c:48 ../display/d.font.freetype/main.c:61
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-"nel monitor grafico dell'utente."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
 #: ../display/d.font/main.c:56
 msgid "Choose new current font"
@@ -14991,8 +14374,7 @@
 #: ../display/d.font/main.c:126
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:110 ../display/d.rast.edit/main.c:59
@@ -15004,9 +14386,7 @@
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:121
@@ -15041,8 +14421,7 @@
 #: ../display/d.rast.arrow/arrow.c:177
 #, fuzzy
 msgid "Raster map containing values used for arrow length"
-msgstr ""
-"Mappa raster che contiene i valori utilizzati per la lunghezza della freccia"
+msgstr "Mappa raster che contiene i valori utilizzati per la lunghezza della freccia"
 #: ../display/d.rast.arrow/arrow.c:184
 msgid "Scale factor for arrows (magnitude map)"
@@ -15128,9 +14507,7 @@
 msgstr ""
 #: ../display/d.text.new/main.c:144 ../display/d.text/main.c:68
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text.new/main.c:150 ../display/d.text.freetype/main.c:146
@@ -15149,18 +14526,14 @@
 #: ../display/d.text.new/main.c:175
 #, fuzzy
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Colore per lo sfondo del testo, o un colore GRASS standard o una tripletta R:"
-"G:B"
+msgstr "Colore per lo sfondo del testo, o un colore GRASS standard o una tripletta R:G:B"
 #: ../display/d.text.new/main.c:184 ../display/d.text/main.c:94
 msgid "The screen line number on which text will begin to be drawn"
 msgstr ""
 #: ../display/d.text.new/main.c:192 ../display/d.text/main.c:103
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text.new/main.c:200 ../display/d.text.freetype/main.c:209
@@ -15256,9 +14629,7 @@
 msgstr " Destro:  Esce\n"
 #: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:61
@@ -15378,9 +14749,7 @@
 msgid ""
 "WGS84 grid output not possible as this location does not contain\n"
 "datum transformation parameters. Try running g.setproj."
-msgstr ""
-"del datum in questa location. Provare ad eseguire g.setproj."
+msgstr "Output WGS84 impossible a causa dell'assenza di parametri di trasformazione del datum in questa location. Provare ad eseguire g.setproj."
 #: ../display/d.grid/plot.c:534
 msgid "Error in pj_do_proj1"
@@ -15489,9 +14858,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
 msgstr ""
 #: ../display/d.erase/main.c:52 ../display/d.rgb/main.c:65
@@ -15514,9 +14881,7 @@
 msgstr "Unità della distanza"
 #: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.geodesic/main.c:56 ../display/d.path/main.c:66
@@ -15558,8 +14923,7 @@
 msgstr "mostra"
 #: ../display/d.menu/main.c:68
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.menu/main.c:77
@@ -15640,14 +15004,11 @@
 msgstr "Imposta la versione di FreeType"
 #: ../display/d.ask/main.c:36
-#, fuzzy
 msgid "display, map management"
-msgstr "Nessun mappa raster rimossa"
+msgstr ""
 #: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
 msgstr ""
 #: ../display/d.ask/main.c:46
@@ -15827,9 +15188,8 @@
 msgstr "Non è possibile uilizzare la finestra corrente"
 #: ../display/d.info/main.c:34 ../display/d.save/main.c:79
-#, fuzzy
 msgid "display, metadata"
-msgstr "mostra"
+msgstr ""
 #: ../display/d.info/main.c:36
 msgid "Display information about the active display monitor"
@@ -15860,9 +15220,7 @@
 msgstr "Mostra numero di colori"
 #: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
@@ -15887,8 +15245,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:134
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:144
@@ -15984,8 +15341,7 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:65
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:82
@@ -16066,9 +15422,7 @@
 msgstr ""
 #: ../display/d.rgb/main.c:56
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:61 ../display/d.rast/main.c:88
@@ -16086,14 +15440,11 @@
 msgstr "Errore nella lettura della riga dei dati"
 #: ../display/d.where/main.c:42
-#, fuzzy
 msgid "display, position, querying"
-msgstr "raster, buffer"
+msgstr ""
 #: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.where/main.c:49
@@ -16109,9 +15460,7 @@
 msgstr ""
 #: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:69
@@ -16133,27 +15482,19 @@
 msgstr ""
 #: ../display/d.rhumbline/main.c:47
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
 msgstr ""
 #: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
 msgstr ""
 #: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
 msgstr ""
 #: ../display/d.barscale/main.c:57
@@ -16186,9 +15527,7 @@
 msgstr "Disegna solo la barra della scala"
 #: ../display/d.barscale/main.c:98
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is top-left of "
-"frame)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
 msgstr ""
 #: ../display/d.barscale/main.c:106
@@ -16206,14 +15545,11 @@
 msgstr ""
 #: ../display/d.measure/main.c:49
-#, fuzzy
 msgid "display, geometry"
-msgstr "mostra"
+msgstr ""
 #: ../display/d.measure/main.c:51
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.measure/main.c:57
@@ -16237,9 +15573,7 @@
 msgstr ""
 #: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
 msgstr ""
 #: ../display/d.text.freetype/main.c:154
@@ -16334,9 +15668,7 @@
 msgstr "Si sta effettuando la trasformazione logaritmica"
 #: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:95
@@ -16367,10 +15699,7 @@
 msgstr "Errore nella lettura dei dati di saturazione"
 #: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.rast/main.c:89
@@ -16408,9 +15737,7 @@
 msgstr "Stai cliccando fuori la mappa"
 #: ../display/d.thematic.area/main.c:80
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.thematic.area/main.c:90
@@ -16427,9 +15754,7 @@
 msgstr "Algoritmo da usare per la classificazione"
 #: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
 msgstr ""
 #: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
@@ -16494,10 +15819,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:160
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
 msgstr ""
 #: ../display/d.thematic.area/main.c:168
@@ -16505,9 +15827,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:179
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.thematic.area/main.c:183
@@ -16522,8 +15842,7 @@
 #: ../display/d.thematic.area/main.c:218
 #, fuzzy, c-format
 msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: Si deve creare la topologia sulla mappa vettoriale. Eseguire v.build"
+msgstr "%s: Si deve creare la topologia sulla mappa vettoriale. Eseguire v.build"
 #: ../display/d.thematic.area/main.c:225
 #, fuzzy
@@ -16578,9 +15897,7 @@
 msgstr "Colore sconosciuto: [%s]"
 #: ../display/d.thematic.area/main.c:329
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.thematic.area/main.c:366
@@ -16605,11 +15922,8 @@
 #: ../display/d.thematic.area/main.c:409 ../display/d.vect/main.c:660
 #, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Il box di confine della mappa è al di fuori della regione in uso, non verrà "
-"visualizzato nulla."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Il box di confine della mappa è al di fuori della regione in uso, non verrà visualizzato nulla."
 #: ../display/d.thematic.area/main.c:458
 #, fuzzy, c-format
@@ -16652,9 +15966,7 @@
 #: ../display/d.thematic.area/plot1.c:217 ../display/d.vect/area.c:79
 #: ../display/d.vect/plot1.c:226
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:235 ../display/d.vect/area.c:98
@@ -16678,9 +15990,7 @@
 #: ../display/d.thematic.area/plot1.c:366
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring [%"
-"s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:373
@@ -16691,8 +16001,7 @@
 #: ../display/d.thematic.area/plot1.c:441 ../display/d.vect/area.c:345
 #: ../display/d.vect/plot1.c:537
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.save/main.c:81
@@ -16704,15 +16013,11 @@
 msgstr ""
 #: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
 msgstr ""
 #: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
 msgstr ""
 #: ../display/d.save/main.c:143
@@ -16744,8 +16049,7 @@
 #: ../display/d.colortable/main.c:68
 #, fuzzy
 msgid "Name of raster map whose color table is to be displayed"
-msgstr ""
-"Nome della mappa raster la cui tavola dei colori dev'essere visualizzata"
+msgstr "Nome della mappa raster la cui tavola dei colori dev'essere visualizzata"
 #: ../display/d.colortable/main.c:76
 msgid "Color of lines separating the colors of the color table"
@@ -16765,16 +16069,12 @@
 #: ../display/d.colortable/main.c:118
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:132
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:141
@@ -16835,9 +16135,7 @@
 msgstr "Aggiorna statistiche per un raster"
 #: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:77
@@ -16883,9 +16181,7 @@
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:115
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:119
@@ -16952,8 +16248,7 @@
 msgstr ""
 #: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:58
@@ -16987,14 +16282,11 @@
 msgstr "Nessun nome di mappa assegnato"
 #: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:71
@@ -17144,14 +16436,11 @@
 msgstr ""
 #: ../display/d.paint.labels/main.c:46
-#, fuzzy
 msgid "display, paint labels"
-msgstr "Unità della distanza"
+msgstr ""
 #: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.paint.labels/main.c:54
@@ -17178,15 +16467,11 @@
 #: ../display/d.paint.labels/main.c:102 ../display/d.vect/main.c:431
 msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"La dimensione della regione è inferiore rispetto al valore di minreg, non "
-"verrà visualizzato nulla."
+msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla."
 #: ../display/d.paint.labels/main.c:111 ../display/d.vect/main.c:440
 msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla."
 #: ../display/d.paint.labels/main.c:121 ../vector/v.lrs/v.lrs.label/main.c:299
 #, fuzzy, c-format
@@ -17199,9 +16484,7 @@
 msgstr "Errore: %s\n"
 #: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.vect/main.c:85
@@ -17417,8 +16700,7 @@
 #: ../display/d.rast/main.c:74
 #, fuzzy
 msgid "List of values to be displayed (FP maps)"
-msgstr ""
-"Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
+msgstr "Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
 #: ../display/d.rast/main.c:83
 msgid "Background color (for null)"
@@ -17446,12 +16728,8 @@
 #: ../display/d.rast.num/number.c:86
 #, fuzzy
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"Sovrappone i valori di categoria delle celle su un tematismo raster "
-"visualizzato sul monitor grafico"
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Sovrappone i valori di categoria delle celle su un tematismo raster visualizzato sul monitor grafico"
 #: ../display/d.rast.num/number.c:99
 msgid "Color for drawing grid, or \"none\""
@@ -17487,8 +16765,7 @@
 #: ../display/d.rast.num/number.c:210
 msgid ""
 "\n"
-"Your current window setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
 msgstr ""
 #: ../display/d.rast.num/number.c:216
@@ -17584,9 +16861,7 @@
 msgstr ""
 #: ../display/d.nviz/main.c:538
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../display/d.zoom/main.c:57
@@ -17595,9 +16870,7 @@
 msgstr "mostra"
 #: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
 msgstr ""
 #: ../display/d.zoom/main.c:100
@@ -17704,9 +16977,7 @@
 #: ../display/d.zoom/zoom.c:42
 #, c-format
 msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor "
-"grafico\n"
+msgstr "Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor grafico\n"
 #: ../display/d.zoom/pan.c:18
 #, c-format
@@ -17733,11 +17004,7 @@
 msgstr "Visualizza"
 #: ../display/d.vect/main.c:136
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
 msgstr ""
 #: ../display/d.vect/main.c:151
@@ -17879,22 +17146,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:329
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:337
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:349
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
 msgstr ""
 #: ../display/d.vect/main.c:365
@@ -17902,9 +17162,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:371
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:378
@@ -17912,9 +17170,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:383
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
 msgstr ""
 #: ../display/d.vect/main.c:388
@@ -17922,9 +17178,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:455
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:486
@@ -17967,8 +17221,7 @@
 #: ../display/d.vect/area.c:278
 #, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect/area.c:284
@@ -18014,9 +17267,7 @@
 #: ../display/d.vect/plot1.c:461
 #, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
 msgstr ""
 #: ../display/d.vect/plot1.c:469
@@ -18026,8 +17277,7 @@
 #: ../display/d.vect/plot1.c:591
 #, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
 msgstr ""
 #: ../display/d.vect/plot1.c:679
@@ -18070,9 +17320,7 @@
 msgstr "Mappa raster da leggere"
 #: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
 msgstr ""
 #: ../vector/v.sample/main.c:119
@@ -18180,8 +17428,7 @@
 msgstr "Indicatore di valore nullo"
 #: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:93 ../db/base/select.c:242
@@ -18196,9 +17443,7 @@
 #: ../vector/v.db.select/main.c:141
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:176
@@ -18231,12 +17476,8 @@
 msgstr "Assegna sottoreti per i centri più vicini (direzione dal centro)."
 #: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
-msgstr ""
-"Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del "
-"nodo centrale vengono utilizzati nel calcolo"
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+msgstr "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del nodo centrale vengono utilizzati nel calcolo"
 #: ../vector/v.net.alloc/main.c:92 ../vector/v.net.iso/main.c:99
 #: ../vector/v.net.salesman/main.c:132
@@ -18253,12 +17494,8 @@
 msgstr "Colonna costo per i nodi (numero)"
 #: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, "
-"il layer per queste categorie è dato dall'opzione nlayer"
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, il layer per queste categorie è dato dall'opzione nlayer"
 #: ../vector/v.net.alloc/main.c:186
 #, c-format
@@ -18303,12 +17540,7 @@
 msgstr "Operazione da eseguire"
 #: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/main.c:97
@@ -18362,8 +17594,7 @@
 #: ../vector/v.clean/main.c:281 ../vector/v.category/main.c:555
 #, fuzzy
 msgid "Failed to copy attribute table to output map"
-msgstr ""
-"Copiatura della tabella degli attributi sulla mappa di output non riuscita"
+msgstr "Copiatura della tabella degli attributi sulla mappa di output non riuscita"
 #: ../vector/v.net/nodes.c:85
 #, c-format
@@ -18518,9 +17749,7 @@
 #: ../vector/v.to.db/update.c:32 ../vector/v.to.db/query.c:83
 #, fuzzy, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Connessione al database non definita per il layer %d. Usare prima v.db."
-"connect"
+msgstr "Connessione al database non definita per il layer %d. Usare prima v.db.connect"
 #: ../vector/v.to.db/update.c:82
 msgid "Updating database..."
@@ -18544,8 +17773,7 @@
 #: ../vector/v.to.db/parse.c:38
 #, fuzzy
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Per coor sono validi point/centroid, per length sono validi line/boundary"
+msgstr "Per coor sono validi point/centroid, per length sono validi line/boundary"
 #: ../vector/v.to.db/parse.c:42
 #, fuzzy
@@ -18569,8 +17797,7 @@
 #: ../vector/v.to.db/parse.c:87
 #, fuzzy
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
 msgstr ""
 "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)\n"
 "(miglia, piedi, metri, chilometri, acri, ettari, radianti, gradi)"
@@ -18643,9 +17870,7 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many (%"
-"d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:145
@@ -18675,9 +17900,7 @@
 #: ../vector/v.to.db/report.c:197
 #, fuzzy, c-format
 msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d categorie lette dalla mappa vettoriale mancano nella selezione dalla "
-"tabella"
+msgstr "%d categorie lette dalla mappa vettoriale mancano nella selezione dalla tabella"
 #: ../vector/v.to.db/report.c:199
 #, fuzzy, c-format
@@ -18747,9 +17970,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:96
 #: ../vector/lidar/v.lidar.edgedetection/main.c:86
 #: ../vector/lidar/v.lidar.correction/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/lidar/v.outlier/main.c:92
@@ -18807,9 +18028,7 @@
 #: ../vector/lidar/v.lidar.correction/main.c:229
 #, fuzzy, c-format
 msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"Non è stata definita nessuna connessione al database per il driver <%s>. "
-"Eseguire db.connect."
+msgstr "Non è stata definita nessuna connessione al database per il driver <%s>. Eseguire db.connect."
 #: ../vector/lidar/v.outlier/main.c:174
 #: ../vector/lidar/v.surf.bspline/main.c:213
@@ -18901,13 +18120,10 @@
 #: ../vector/lidar/v.surf.bspline/main.c:85
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
+msgstr "Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
 #: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:104
@@ -18939,8 +18155,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:159
 #, fuzzy
 msgid "Attribute table column with values to interpolate (if layer>0)"
-msgstr ""
-"Colonna della tabella degli attributi coi valori da interpolare (se layer>0)"
+msgstr "Colonna della tabella degli attributi coi valori da interpolare (se layer>0)"
 #: ../vector/lidar/v.surf.bspline/main.c:172
 msgid "Choose either vector or raster output, not both"
@@ -18974,9 +18189,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:285
 #, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:307
@@ -19001,14 +18214,10 @@
 #: ../vector/lidar/v.surf.bspline/main.c:369
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-"Interpolazione: Creazione della tabella: Non è stato possibile creare la "
-"tabella <%s>."
+msgstr "Interpolazione: Creazione della tabella: Non è stato possibile creare la tabella <%s>."
 #: ../vector/lidar/v.surf.bspline/main.c:392
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:590
@@ -19036,9 +18245,7 @@
 msgstr "%d punti letti nella regione"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:90
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:119
@@ -19053,8 +18260,7 @@
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:151
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:169
@@ -19079,15 +18285,12 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:306
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:308
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:316
@@ -19214,9 +18417,7 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:86
@@ -19267,9 +18468,7 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:85
@@ -19365,9 +18564,7 @@
 msgstr "Problemi nel caricamento dei valori di categoria"
 #: ../vector/v.generalize/main.c:76
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
 msgstr ""
 #: ../vector/v.generalize/main.c:77
@@ -19375,16 +18572,7 @@
 msgstr "Generalizzazione vettoriale"
 #: ../vector/v.generalize/main.c:95
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
 msgstr ""
 #: ../vector/v.generalize/main.c:109
@@ -19475,8 +18663,7 @@
 #: ../vector/v.generalize/main.c:490
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:493
@@ -19547,9 +18734,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
 msgstr ""
 #: ../vector/v.build/main.c:84 ../vector/v.support/main.c:129
@@ -19624,9 +18809,7 @@
 msgstr "Opzionalmente cambia il tipo di input predefinito"
 #: ../vector/v.in.ogr/main.c:164
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:175
@@ -19638,9 +18821,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:191
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:198
@@ -19714,15 +18895,11 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:482
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:494
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:524
@@ -19737,9 +18914,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:587
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:610
@@ -19764,9 +18939,7 @@
 #: ../vector/v.in.ogr/main.c:752
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:764
@@ -19867,10 +19040,7 @@
 #: ../vector/v.in.ogr/main.c:1140
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1150
@@ -19914,9 +19084,7 @@
 msgstr "Aree senza categoria: %G (%d aree)"
 #: ../vector/v.in.ogr/main.c:1208
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:193
@@ -19961,9 +19129,7 @@
 msgstr ""
 #: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
 msgstr ""
 #: ../vector/v.to.rast3/main.c:59
@@ -20000,12 +19166,8 @@
 msgstr ""
 #: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa "
-"contenento solo gli oggetti selezionati."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa contenento solo gli oggetti selezionati."
 #: ../vector/v.extract/main.c:98
 msgid "Dissolve common boundaries (default is no)"
@@ -20026,8 +19188,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:122
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
 msgstr ""
 #: ../vector/v.extract/main.c:136
@@ -20056,9 +19217,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
 msgstr ""
 #: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
@@ -20096,9 +19255,7 @@
 msgstr "%d categrie caricate dalla tabella <%s>"
 #: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:319
@@ -20107,16 +19264,12 @@
 #: ../vector/v.extract/main.c:323
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:346
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:383
@@ -20143,8 +19296,7 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:54
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr "Crea un nuovo vettoriale (punti) da una tabella contenente coordinate"
 #: ../vector/v.in.db/main.c:58
@@ -20181,8 +19333,7 @@
 #: ../vector/v.in.db/main.c:130
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:138 ../vector/v.transform/trans_digit.c:101
@@ -20230,16 +19381,11 @@
 msgstr "N"
 #: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
 msgstr ""
 #: ../vector/v.net.iso/main.c:122
@@ -20286,13 +19432,10 @@
 #: ../vector/v.net.salesman/main.c:105
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
+msgstr "Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
 #: ../vector/v.net.salesman/main.c:107
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:125
@@ -20341,10 +19484,7 @@
 msgstr "Distribuzione della perturbazione"
 #: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:106
@@ -20403,15 +19543,11 @@
 msgstr "N"
 #: ../vector/v.net.distance/main.c:61
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:64
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this realtion are uploaded to the attribute table."
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:73
@@ -20470,12 +19606,8 @@
 msgstr "Impossibile assegnare i privilegi sulla tabella <%s>"
 #: ../vector/v.distance/main.c:117
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel "
-"vettoriale 'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel vettoriale 'from'."
 #: ../vector/v.distance/main.c:121
 #, fuzzy
@@ -20510,9 +19642,7 @@
 #: ../vector/v.distance/main.c:156
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Nome di una mappa vettoriale di output contenente le linee che collegano gli "
-"elementi più vicini"
+msgstr "Nome di una mappa vettoriale di output contenente le linee che collegano gli elementi più vicini"
 #: ../vector/v.distance/main.c:164
 #, fuzzy
@@ -20529,20 +19659,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:182
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
-"the nearest point on 'to' feature;to_along;distance between points/centroids "
-"in 'from' map and the linear feature's start point in 'to' map, along this "
-"linear feature;to_angle;angle between the linear feature in 'to' map and the "
-"positive x axis, at the location of point/centroid in 'from' map, "
-"counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;"
-"attribute of nearest feature given by to_column option"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of the nearest point on 'to' feature;to_along;distance between points/centroids in 'from' map and the linear feature's start point in 'to' map, along this linear feature;to_angle;angle between the linear feature in 'to' map and the positive x axis, at the location of point/centroid in 'from' map, counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;attribute of nearest feature given by to_column option"
 msgstr ""
 #: ../vector/v.distance/main.c:200
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:201
@@ -20570,9 +19691,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:225
-msgid ""
-"The output is written to stdout but may be uploaded to a new table created "
-"by this module. From categories are may be multiple."
+msgid "The output is written to stdout but may be uploaded to a new table created by this module. From categories are may be multiple."
 msgstr ""
 #: ../vector/v.distance/main.c:276
@@ -20592,9 +19711,7 @@
 #: ../vector/v.distance/main.c:302
 #, fuzzy, c-format
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"La mappa vettoriale <%s> non è nel mapset dell'utente e non può essere "
-"aggiornata"
+msgstr "La mappa vettoriale <%s> non è nel mapset dell'utente e non può essere aggiornata"
 #: ../vector/v.distance/main.c:373 ../vector/v.distance/main.c:407
 #: ../vector/v.out.ascii/b2a.c:252 ../vector/v.reclass/main.c:137
@@ -20751,8 +19868,7 @@
 #: ../vector/v.random/main.c:100
 #, fuzzy
 msgid "Minimum z height (needs -z flag or column name)"
-msgstr ""
-"Minimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
+msgstr "Minimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:102 ../vector/v.random/main.c:111
 #: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
@@ -20763,18 +19879,14 @@
 #: ../vector/v.random/main.c:109
 #, fuzzy
 msgid "Maximum z height (needs -z flag or column name)"
-msgstr ""
-"Massimo valore di altezza z (necessita del parametro -z o del nome di "
-"colonna)"
+msgstr "Massimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:119
 msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
 msgstr ""
 #: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
 msgstr ""
 #: ../vector/v.random/main.c:132
@@ -20806,9 +19918,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:264
@@ -20853,8 +19963,7 @@
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:187
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:1061
@@ -20992,9 +20101,7 @@
 #: ../vector/v.label.sa/main.c:103 ../vector/v.label/main.c:79
 #, fuzzy
 msgid "Name of attribute column to be used for labels"
-msgstr ""
-"Nome della colonna della tabella degli attributi da utilizzare per le "
-"etichette"
+msgstr "Nome della colonna della tabella degli attributi da utilizzare per le etichette"
 #: ../vector/v.label.sa/main.c:107 ../vector/v.label/main.c:68
 msgid "Name for new paint-label file"
@@ -21039,9 +20146,7 @@
 msgstr "Spessore del bordo (solo per l'output di ps.map)"
 #: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
 msgstr ""
 #: ../vector/v.label.sa/labels.c:74
@@ -21085,8 +20190,7 @@
 #: ../vector/v.label.sa/labels.c:229
 #, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
 msgstr ""
 #: ../vector/v.label.sa/labels.c:287
@@ -21240,9 +20344,7 @@
 #: ../vector/v.in.dxf/write_vect.c:230
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"Impossibile aggiungere il collegamento al database per la mappa vettoriale <%"
-"s>"
+msgstr "Impossibile aggiungere il collegamento al database per la mappa vettoriale <%s>"
 #: ../vector/v.in.dxf/read_dxf.c:57
 msgid "end of file while looking for HEADER"
@@ -21364,9 +20466,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:65
@@ -21456,8 +20556,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:130
 #, fuzzy
 msgid "Output vector map where oriented lines are written"
-msgstr ""
-"Nome della mappa vettoriale di output dove sono scritte le linee orientate"
+msgstr "Nome della mappa vettoriale di output dove sono scritte le linee orientate"
 #: ../vector/v.lrs/v.lrs.create/main.c:135
 #, fuzzy
@@ -21482,8 +20581,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:179
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:188
@@ -21612,14 +20710,12 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:862
 #, fuzzy
 msgid "Building topology for output (out_lines) map..."
-msgstr ""
-"Costruzione della topologia per la mappa di output (out_lines) in corso..."
+msgstr "Costruzione della topologia per la mappa di output (out_lines) in corso..."
 #: ../vector/v.lrs/v.lrs.create/main.c:868
 #, fuzzy
 msgid "Building topology for error (err) map..."
-msgstr ""
-"Costruzione della topologia per la mappa degli errori (err) in corso..."
+msgstr "Costruzione della topologia per la mappa degli errori (err) in corso..."
 #: ../vector/v.lrs/v.lrs.label/main.c:103
 msgid "Create stationing from input lines, and linear reference system"
@@ -21641,14 +20737,12 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:160
 #, fuzzy
 msgid "Offset label in label x-direction in map units"
-msgstr ""
-"Offset delle etichette nella direzione x dell'etichetta in unità di mappa"
+msgstr "Offset delle etichette nella direzione x dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:167
 #, fuzzy
 msgid "Offset label in label y-direction in map units"
-msgstr ""
-"Offset delle etichette nella direzione y dell'etichetta in unità di mappa"
+msgstr "Offset delle etichette nella direzione y dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:173 ../vector/v.label/main.c:114
 msgid "Reference position"
@@ -21695,12 +20789,8 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti "
-"sono letti dallo stdin o da file"
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti sono letti dallo stdin o da file"
 #: ../vector/v.lrs/v.lrs.segment/main.c:80
 msgid "Output vector map where segments will be written"
@@ -21822,19 +20912,13 @@
 msgstr ""
 #: ../vector/v.reclass/main.c:65
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Cambia i valori delle categorie per un esistente vettoriale secondo "
-"risultati di interrogazioni SQL o valori di una colonna della tabella degli "
-"attributi"
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Cambia i valori delle categorie per un esistente vettoriale secondo risultati di interrogazioni SQL o valori di una colonna della tabella degli attributi"
 #: ../vector/v.reclass/main.c:82
 #, fuzzy
 msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"Il nome della colonna i cui valori devono essere usati come nuove categorie"
+msgstr "Il nome della colonna i cui valori devono essere usati come nuove categorie"
 #: ../vector/v.reclass/main.c:83
 msgid "The source for the new key column must be type integer or string"
@@ -21931,9 +21015,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:107
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:111
@@ -21981,9 +21063,7 @@
 msgstr "Metodo sconosciuto"
 #: ../vector/v.kernel/main.c:167
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
 msgstr ""
 #: ../vector/v.kernel/main.c:174
@@ -21992,23 +21072,15 @@
 msgstr "Funzioni note:"
 #: ../vector/v.kernel/main.c:182
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa "
-"come massimo (sperimentale)"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa come massimo (sperimentale)"
 #: ../vector/v.kernel/main.c:187
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà "
-"creata)"
+msgstr "Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà creata)"
 #: ../vector/v.kernel/main.c:192
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:197
@@ -22026,15 +21098,11 @@
 msgstr "Proiezione sconosciuta"
 #: ../vector/v.kernel/main.c:238
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:242
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:279
@@ -22049,12 +21117,8 @@
 #: ../vector/v.kernel/main.c:334
 #, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Scegli automaticamente i parametri di smoothing (deviazione standard), il "
-"massimo valore possibile della deviazione standard è stato posto pari a %f"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Scegli automaticamente i parametri di smoothing (deviazione standard), il massimo valore possibile della deviazione standard è stato posto pari a %f"
 #: ../vector/v.kernel/main.c:341
 #, c-format
@@ -22073,12 +21137,8 @@
 #: ../vector/v.kernel/main.c:359
 #, fuzzy, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Le distanze tra tutti i punti sono oltre %e (4 * deviazione standard), "
-"impossibile calcolare il valore ottimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Le distanze tra tutti i punti sono oltre %e (4 * deviazione standard), impossibile calcolare il valore ottimale."
 #: ../vector/v.kernel/main.c:370
 #, c-format
@@ -22092,8 +21152,7 @@
 "Writing output vector map using smooth parameter=%f."
 msgstr ""
 "\n"
-"Sto scrivendo il file vettoriale in output usando il parametro di smoothing=%"
-"f."
+"Sto scrivendo il file vettoriale in output usando il parametro di smoothing=%f."
 #: ../vector/v.kernel/main.c:399 ../vector/v.kernel/main.c:506
 #, c-format
@@ -22131,9 +21190,7 @@
 msgstr "Converte in uno dei formati vettoriali supportati da OGR"
 #: ../vector/v.out.ogr/main.c:106
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:114
@@ -22179,21 +21236,17 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:171
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:176
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
+msgstr "Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
 #: ../vector/v.out.ogr/main.c:181
 #, fuzzy
 msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
 #: ../vector/v.out.ogr/main.c:186
 msgid "Export lines as polygons"
@@ -22216,102 +21269,79 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:326
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:331
 #, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:336
 #, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:342
 #, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:348
 #, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:353
 #, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:357
 #, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:363
 #, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:368
 #, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:374
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
+msgid "No points found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:383
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:393
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:402
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:412
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:421
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:430
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:439
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:450
@@ -22345,16 +21375,12 @@
 #: ../vector/v.out.ogr/main.c:583
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:590
 #, c-format
-msgid ""
-"'lco') to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:603
@@ -22516,8 +21542,7 @@
 #: ../vector/v.hull/main.c:286
 #, fuzzy
 msgid "Use all vector points (do not limit to current region)"
-msgstr ""
-"Utilizza tutti i punti vettoriali (non solo quelli nella regione corrente)"
+msgstr "Utilizza tutti i punti vettoriali (non solo quelli nella regione corrente)"
 #: ../vector/v.hull/main.c:291
 msgid "Create a 'flat' 2D hull even if the input is 3D points"
@@ -22586,9 +21611,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a G3D grid volume using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:237
@@ -22726,8 +21749,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:126
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.net.timetable/main.c:218
@@ -22811,14 +21833,11 @@
 msgstr "Crea un nuovo vettoriale contenendo altri vettoriali."
 #: ../vector/v.patch/main.c:80
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:89
@@ -23009,8 +22028,7 @@
 #: ../vector/v.kcv/main.c:174
 #, fuzzy, c-format
 msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
-"Impossibile ottenere informazioni sul layer per la mappa vettoriale <%s>"
+msgstr "Impossibile ottenere informazioni sul layer per la mappa vettoriale <%s>"
 #: ../vector/v.kcv/main.c:198
 #, c-format
@@ -23063,8 +22081,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -23074,19 +22091,15 @@
 #: ../vector/v.support/main.c:188
 #, fuzzy, c-format
 msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-"Non è possibile aprire il file della cronologia per la mappa vettoriale <%s>"
+msgstr "Non è possibile aprire il file della cronologia per la mappa vettoriale <%s>"
 #: ../vector/v.select/main.c:52
 msgid "vector, spatial query"
 msgstr ""
 #: ../vector/v.select/main.c:54
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Elementi selezionati di un vettoriale (A) con gli elementi di un altro "
-"vettoriale (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Elementi selezionati di un vettoriale (A) con gli elementi di un altro vettoriale (B)."
 #: ../vector/v.select/main.c:87
 #, fuzzy
@@ -23179,10 +22192,7 @@
 msgstr "L'operatore definisce la relazione fra elementi richiesta"
 #: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:53
@@ -23190,15 +22200,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
 msgstr ""
 #: ../vector/v.select/args.c:75
@@ -23215,11 +22217,8 @@
 msgstr ""
 #: ../vector/v.buffer2/main.c:151 ../vector/v.buffer/main.c:153
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere "
-"centroide)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere centroide)."
 #: ../vector/v.buffer2/main.c:169
 msgid "Buffer distance along major axis in map units"
@@ -23250,15 +22249,11 @@
 #: ../vector/v.buffer2/main.c:208 ../vector/v.parallel/main.c:64
 #: ../vector/v.buffer/main.c:200
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer2/main.c:224
-msgid ""
-"This is an alias to the distance option. It is retained for backwards "
-"compatibility"
+msgid "This is an alias to the distance option. It is retained for backwards compatibility"
 msgstr ""
 #: ../vector/v.buffer2/main.c:226 ../vector/v.buffer/main.c:175
@@ -23278,10 +22273,7 @@
 msgstr ""
 #: ../vector/v.buffer2/main.c:250
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
 msgstr ""
 #: ../vector/v.buffer2/main.c:261
@@ -23289,9 +22281,7 @@
 msgstr ""
 #: ../vector/v.buffer2/main.c:264
-msgid ""
-"The buffer option has been replaced by the distance option and will be "
-"removed in future."
+msgid "The buffer option has been replaced by the distance option and will be removed in future."
 msgstr ""
 #: ../vector/v.buffer2/main.c:267
@@ -23319,9 +22309,7 @@
 msgstr "Non è possibile selezionare dati dalla tabella <%s>"
 #: ../vector/v.buffer2/main.c:379 ../vector/v.buffer/main.c:292
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer2/main.c:394
@@ -23409,11 +22397,8 @@
 msgstr "N"
 #: ../vector/v.voronoi/vo_main.c:119
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
 #: ../vector/v.voronoi/vo_main.c:134
 msgid "Output tessellation as a graph (lines), not areas"
@@ -23436,12 +22421,8 @@
 msgstr "Non posso copiare la tabella"
 #: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crea una triangolazione Delaunay da un vettoriale contenente punti o "
-"centroidi."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crea una triangolazione Delaunay da un vettoriale contenente punti o centroidi."
 #: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
 #, fuzzy
@@ -23471,9 +22452,7 @@
 msgstr "Crea albero di Streiner per la rete e i punti scelti"
 #: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:369
@@ -23509,8 +22488,7 @@
 #: ../vector/v.net.steiner/main.c:527
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:532
@@ -23710,12 +22688,8 @@
 msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Esegue una trasformazione affine (shift, riscalare e ruotare, o GPCs) su una "
-"mappa vettoriale"
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Esegue una trasformazione affine (shift, riscalare e ruotare, o GPCs) su una mappa vettoriale"
 #: ../vector/v.transform/main.c:80
 msgid "Suppress display of residuals or other information"
@@ -23743,9 +22717,7 @@
 msgstr "Stampa la matrice di trasformazione sullo stdout"
 #: ../vector/v.transform/main.c:102
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
 msgstr ""
 #: ../vector/v.transform/main.c:115
@@ -23753,9 +22725,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:116
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
 msgstr ""
 #: ../vector/v.transform/main.c:127
@@ -23804,19 +22774,13 @@
 #: ../vector/v.transform/main.c:212
 #, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
 msgstr ""
 #: ../vector/v.transform/main.c:217
 #, fuzzy, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--"
-"quiet'"
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--quiet'"
 #: ../vector/v.transform/main.c:223
 #, c-format
@@ -23824,9 +22788,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:228
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
 msgstr ""
 #: ../vector/v.transform/main.c:242
@@ -23868,17 +22830,13 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:123
 #, fuzzy
 msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Nessun numero di categoria definito. Si stanno usando i parametri di "
-"trasformazione predefiniti"
+msgstr "Nessun numero di categoria definito. Si stanno usando i parametri di trasformazione predefiniti"
 #: ../vector/v.transform/creat_trans.c:69
 #, c-format
@@ -23926,18 +22884,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:98
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:103
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:114
@@ -24027,10 +22978,7 @@
 msgstr ""
 #: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:193
@@ -24073,10 +23021,7 @@
 msgstr ""
 #: ../vector/v.build.polylines/main.c:121
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
 msgstr ""
 #: ../vector/v.build.polylines/main.c:212
@@ -24183,9 +23128,7 @@
 msgstr ""
 #: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
 msgstr ""
 #: ../vector/v.convert/read.c:185
@@ -24439,8 +23382,7 @@
 msgstr "Trova il percorso più breve in una rete vettoriale."
 #: ../vector/v.net.path/main.c:65
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:92
@@ -24448,10 +23390,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.net.path/main.c:106
@@ -24471,8 +23410,7 @@
 #: ../vector/v.net.path/path.c:205
 #, c-format
 msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"Il punto con categoria [%d] non è raggiungibile dal punto con categoria [%d]"
+msgstr "Il punto con categoria [%d] non è raggiungibile dal punto con categoria [%d]"
 #: ../vector/v.net.path/path.c:262
 #, c-format
@@ -24495,12 +23433,8 @@
 msgstr ""
 #: ../vector/v.univar/main.c:73
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Calcola statistiche univariate per gli attributi. Varianza e deviazione "
-"standard è calcolate solo per punti se specificato."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcola statistiche univariate per gli attributi. Varianza e deviazione standard è calcolate solo per punti se specificato."
 #: ../vector/v.univar/main.c:86
 msgid "Column name"
@@ -24520,16 +23454,13 @@
 "\t(%s)"
 #: ../vector/v.univar/main.c:145
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:150
 #, fuzzy
 msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Le statistiche estese attualmente sono supportate solo per punti/centroidi"
+msgstr "Le statistiche estese attualmente sono supportate solo per punti/centroidi"
 #: ../vector/v.univar/main.c:187
 #, fuzzy, c-format
@@ -24571,9 +23502,7 @@
 #: ../vector/v.label/main.c:138
 msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Spazio tra le lettere per le etichette disposte lungo la linea (in unità "
-"della mappa)"
+msgstr "Spazio tra le lettere per le etichette disposte lungo la linea (in unità della mappa)"
 #: ../vector/v.label/main.c:145
 msgid "Label size (in points)"
@@ -24589,11 +23518,8 @@
 msgstr ""
 #: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"Dimensione e spaziatura variano significativamente e possono fornire un "
-"output insoddisfacente!"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "Dimensione e spaziatura variano significativamente e possono fornire un output insoddisfacente!"
 #: ../vector/v.label/main.c:260
 msgid "Too many parameters for <reference>"
@@ -24614,9 +23540,8 @@
 msgstr ""
 #: ../vector/v.delaunay2/main.c:152
-#, fuzzy
 msgid "Writing edges..."
-msgstr "Sto disegnando ..."
+msgstr ""
 #: ../vector/v.delaunay2/main.c:162
 #, fuzzy
@@ -24659,18 +23584,13 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:61
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
 msgstr ""
 #: ../vector/v.to.rast/main.c:70
 #, fuzzy
 msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Nome della colonna per il parametro 'attr' (il tipo di dato dev'essere "
-"numerico)"
+msgstr "Nome della colonna per il parametro 'attr' (il tipo di dato dev'essere numerico)"
 #: ../vector/v.to.rast/main.c:76
 msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -24964,8 +23884,7 @@
 #: ../vector/v.in.ascii/in.c:56
 #, fuzzy
 msgid "ASCII file to be imported, if not given reads from standard input"
-msgstr ""
-"File ASCII da importare, se non viene fornito legge dallo standard input"
+msgstr "File ASCII da importare, se non viene fornito legge dallo standard input"
 #: ../vector/v.in.ascii/in.c:67
 msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
@@ -24990,9 +23909,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:93
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
@@ -25019,9 +23936,7 @@
 msgstr "Nome della colonna usata come categoria (points mode)"
 #: ../vector/v.in.ascii/in.c:137
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:146
@@ -25090,13 +24005,11 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:271
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:276
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:282
@@ -25121,8 +24034,7 @@
 #: ../vector/v.in.ascii/in.c:417
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:445
@@ -25165,15 +24077,12 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.external/main.c:58
-#, fuzzy
 msgid "vector, external, import"
-msgstr "raster, ricampionamento"
+msgstr ""
 #: ../vector/v.external/main.c:60
 msgid "Creates a new vector as a read-only link to OGR layer."
@@ -25212,28 +24121,11 @@
 msgstr ""
 #: ../vector/v.clean/main.c:66
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed "
-"attachement of centroid), first and last segment of the boundary is never "
-"changed;rmarea;remove small areas, the longest boundary with adjacent area "
-"is removed;rmline;remove all lines or boundaries of zero length, threshold "
-"is ignored;rmsa;remove small angles between lines at nodes"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove small a
 reas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
 msgstr ""
 #: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
 msgstr ""
 #: ../vector/v.clean/main.c:100
@@ -25420,12 +24312,8 @@
 msgstr "Linee / confini rimossi: %d"
 #: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolazione della superficie da un vettore puntuale con peso inverso "
-"delle distanze al quadrato IDW"
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolazione della superficie da un vettore puntuale con peso inverso delle distanze al quadrato IDW"
 #: ../vector/v.surf.idw/main.c:95
 msgid "If set to 0, z coordinates are used (3D vector only)"
@@ -25445,8 +24333,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:127
@@ -25454,9 +24341,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:128
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:147
@@ -25470,8 +24355,7 @@
 #: ../vector/v.surf.idw/main.c:267
 #, fuzzy, c-format
 msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
-msgstr ""
-"Interpolazione della mappa raster <%s> in corso (%d righe, %d colonne)..."
+msgstr "Interpolazione della mappa raster <%s> in corso (%d righe, %d colonne)..."
 #: ../vector/v.surf.idw/read_sites.c:102
 #, fuzzy, c-format
@@ -25492,15 +24376,12 @@
 msgstr ""
 #: ../vector/v.parallel/main.c:76 ../vector/v.parallel2/main.c:84
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
 msgstr ""
 #: ../vector/v.buffer/main.c:151
-#, fuzzy
 msgid "vector, geometry, buffer"
-msgstr "N"
+msgstr ""
 #: ../vector/v.buffer/main.c:169
 #, fuzzy
@@ -25555,12 +24436,8 @@
 msgstr ""
 #: ../vector/v.edit/main.c:56
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Modifica un vettore, permette aggiunte, eliminzione e modifica degli "
-"elementi del vettore selezionato"
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Modifica un vettore, permette aggiunte, eliminzione e modifica degli elementi del vettore selezionato"
 #: ../vector/v.edit/main.c:65
 #, fuzzy, c-format
@@ -25573,9 +24450,7 @@
 #: ../vector/v.edit/main.c:153
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:168
@@ -25594,9 +24469,7 @@
 #: ../vector/v.edit/main.c:228
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:266
@@ -25663,9 +24536,7 @@
 #: ../vector/v.edit/main.c:346
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:356
@@ -25707,19 +24578,7 @@
 msgstr "Strumenti"
 #: ../vector/v.edit/args.c:55
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
 msgstr ""
 #: ../vector/v.edit/args.c:100
@@ -25767,9 +24626,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:170
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
 msgstr ""
 #: ../vector/v.edit/args.c:178
@@ -25778,15 +24635,11 @@
 msgstr "Nome della mappa/e vettoriale di sfondo"
 #: ../vector/v.edit/args.c:185
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:187
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
 msgstr ""
 #: ../vector/v.edit/args.c:195
@@ -25905,8 +24758,7 @@
 #: ../vector/v.info/main.c:199 ../vector/v.db.connect/main.c:161
 #, fuzzy, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La connessione al database per la mappa <%s> non è definita nel file DB"
+msgstr "La connessione al database per la mappa <%s> non è definita nel file DB"
 #: ../vector/v.info/main.c:205
 #, c-format
@@ -26096,12 +24948,7 @@
 msgstr "Azione da eseguire"
 #: ../vector/v.category/main.c:86
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/'"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:102
@@ -26122,14 +24969,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:137
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:155
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:164
@@ -26214,10 +25058,7 @@
 msgstr "%d elementi modificati."
 #: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:192
@@ -26273,9 +25114,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:300
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:323
@@ -26283,8 +25122,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:367
@@ -26299,23 +25137,18 @@
 #: ../vector/v.surf.rst/main.c:418 ../vector/v.surf.rst/main.c:423
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"Il nome della mappa vettoriale di output  <%s> non è un nome di mappa valido"
+msgstr "Il nome della mappa vettoriale di output  <%s> non è un nome di mappa valido"
 #: ../vector/v.surf.rst/main.c:436
 msgid "You are not outputting any raster or vector maps"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:462
@@ -26479,8 +25312,7 @@
 #: ../vector/v.digit/main.c:157
 #, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
 msgstr ""
 #: ../vector/v.digit/zoom.c:26
@@ -26503,9 +25335,8 @@
 msgstr ""
 #: ../vector/v.digit/zoom.c:157
-#, fuzzy
 msgid "Pan"
-msgstr "%s Sposta\n"
+msgstr ""
 #: ../vector/v.digit/zoom.c:158
 #, fuzzy
@@ -26515,7 +25346,7 @@
 #: ../vector/v.digit/zoom.c:247
 #, fuzzy, c-format
 msgid "Cannot find window '%s'"
-msgstr "Non riesco ad impostare user/password"
+msgstr "Impossibile inserire una nuova regola: %s"
 #: ../vector/v.digit/var.c:80 ../vector/v.digit/var.c:101
 #: ../vector/v.digit/var.c:122
@@ -26531,7 +25362,7 @@
 #: ../vector/v.digit/var.c:164
 #, fuzzy, c-format
 msgid "Cannot get code of variable %s"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Non riesco a mostrare i database:\n"
 #: ../vector/v.digit/var.c:184
 #, fuzzy, c-format
@@ -26547,7 +25378,7 @@
 #: ../vector/v.digit/centre.c:56
 #, fuzzy
 msgid "Select tool"
-msgstr "Tipo di grafico"
+msgstr "Selezionee"
 #: ../vector/v.digit/centre.c:178
 msgid "Region restored to original extent."
@@ -26556,23 +25387,23 @@
 #: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
 #, fuzzy, c-format
 msgid "Cannot open driver %s"
-msgstr "Non riesco ad eseguire il driver '%s'"
+msgstr "Impossibile aprire %s"
 #: ../vector/v.digit/c_face.c:189 ../vector/v.digit/c_face.c:251
 #, fuzzy, c-format
 msgid "Cannot open database %s"
-msgstr "Non posso scrivere i collegamenti del database"
 #: ../vector/v.digit/c_face.c:242
 #, fuzzy
 msgid "Cannot open driver "
 #: ../vector/v.digit/c_face.c:252 ../vector/v.digit/attr.c:137
 #: ../vector/v.digit/attr.c:650
-#, c-format
+#, fuzzy, c-format
 msgid "Cannot open database %s by driver %s"
-msgstr "Non riesco ad aprire il database %s col driver %s"
+msgstr "Non è possibile aprire il database <%s> col driver <%s>"
 #: ../vector/v.digit/c_face.c:270
 #, fuzzy
@@ -26595,41 +25426,38 @@
 msgstr "Permessi non sufficienti per accedere alla tabella %s"
 #: ../vector/v.digit/c_face.c:312
-msgid ""
-"Cannot add database link to vector, link for given field probably already "
-"exists."
+msgid "Cannot add database link to vector, link for given field probably already exists."
 msgstr ""
 #: ../vector/v.digit/generate.c:77
 #, fuzzy
 msgid "Cannot open driver"
 #: ../vector/v.digit/generate.c:78
 #, fuzzy, c-format
 msgid "Cannot open driver '%s'<BR>"
+msgstr "Impossibile aprire il file del filtro '%s'"
 #: ../vector/v.digit/generate.c:89
 #, fuzzy
 msgid "Cannot open database"
 #: ../vector/v.digit/generate.c:91
 #, fuzzy, c-format
 msgid "Cannot open database '%s' by driver '%s'<BR>"
 #: ../vector/v.digit/generate.c:106
 #, fuzzy
 msgid "Cannot open select cursor"
+msgstr "Impossibile aprire il cursore selezionato: '%s'"
 #: ../vector/v.digit/generate.c:110
-#, fuzzy, c-format
-msgid ""
-"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+#, c-format
+msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgstr ""
 #: ../vector/v.digit/generate.c:121
 #, fuzzy
@@ -26639,7 +25467,7 @@
 #: ../vector/v.digit/generate.c:130
 #, fuzzy
 msgid "No database record"
-msgstr "nome database"
+msgstr "Driver del database:"
 #: ../vector/v.digit/generate.c:223
 #, c-format
@@ -26692,54 +25520,49 @@
 msgstr "Nessun monitor selezionato"
 #: ../vector/v.digit/vertex.c:199
-#, fuzzy
 msgid "Remove vertex:"
-msgstr "Vertici rimossi"
+msgstr ""
 #: ../vector/v.digit/vertex.c:200 ../vector/v.digit/vertex.c:220
 #: ../vector/v.digit/vertex.c:325
-#, fuzzy
 msgid "Select vertex"
+msgstr ""
 #: ../vector/v.digit/vertex.c:372
 msgid "Add vertex:"
 msgstr ""
 #: ../vector/v.digit/vertex.c:471
-#, fuzzy
 msgid "New vertex"
-msgstr "Nome di un file vettoriale in output"
+msgstr ""
 #: ../vector/v.digit/vertex.c:569
-#, fuzzy
 msgid "Move vertex:"
+msgstr ""
 #: ../vector/v.digit/vertex.c:633 ../vector/v.digit/line.c:671
 #, fuzzy
 msgid "New location"
-msgstr "locazione del database"
 #: ../vector/v.digit/form.c:97
-#, fuzzy
 msgid "db connection was not set by form\n"
-msgstr "Connessione al database non definita\n"
+msgstr ""
 #: ../vector/v.digit/form.c:108
 #, fuzzy
 msgid "Cannot open driver\n"
 #: ../vector/v.digit/form.c:120
 #, fuzzy
 msgid "Cannot open database\n"
 #: ../vector/v.digit/form.c:133
 #, fuzzy
 msgid "Cannot describe table\n"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Non posso copiare la tabella"
 #: ../vector/v.digit/form.c:162
 #, fuzzy
@@ -26842,7 +25665,7 @@
 #: ../vector/v.digit/attr.c:145 ../vector/v.digit/attr.c:659
 #, fuzzy, c-format
 msgid "Cannot select record from table %s"
-msgstr "Non riesco a selezionare dati dalla tabella"
+msgstr "Non è possibile selezionare i record dalla tabella <%s>"
 #: ../vector/v.digit/attr.c:191
 #, fuzzy
@@ -26909,7 +25732,7 @@
 #: ../vector/v.digit/attr.c:571
 #, fuzzy, c-format
 msgid "Line %d"
-msgstr "Linea: %d\n"
+msgstr "Spessore di linea"
 #: ../vector/v.digit/attr.c:577
 #, fuzzy
@@ -26918,9 +25741,7 @@
 #: ../vector/v.digit/attr.c:668
 #, c-format
-msgid ""
-"There are no more features with category %d (layer %d) in the map, but there "
-"is record in the table. Delete this record?"
+msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
 msgstr ""
 #: ../vector/v.digit/attr.c:680
@@ -26933,9 +25754,7 @@
 msgstr ""
 #: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:127
@@ -26991,9 +25810,7 @@
 #: ../vector/v.db.connect/main.c:52
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Visualizza/imposta la connessione per una mappa vettoriale alla tabella "
-"degli attributi"
+msgstr "Visualizza/imposta la connessione per una mappa vettoriale alla tabella degli attributi"
 #: ../vector/v.db.connect/main.c:72
 #, fuzzy
@@ -27008,15 +25825,12 @@
 #: ../vector/v.db.connect/main.c:85
 #, fuzzy
 msgid "Print all map connection parameters and exit"
-msgstr ""
-"Stampa tutti i parametri di connessione al database della mappa ed esce"
+msgstr "Stampa tutti i parametri di connessione al database della mappa ed esce"
 #: ../vector/v.db.connect/main.c:90
 #, fuzzy
 msgid "Print all map connection parameters and exit in shell script style"
-msgstr ""
-"Stampa tutti i parametri di connessione della mappa ed esce in stile script "
-"per la shell"
+msgstr "Stampa tutti i parametri di connessione della mappa ed esce in stile script per la shell"
 #: ../vector/v.db.connect/main.c:93
 msgid "Format: layer[/layer name] table key database driver"
@@ -27028,8 +25842,7 @@
 #: ../vector/v.db.connect/main.c:108
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
+msgstr "Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
 #: ../vector/v.db.connect/main.c:115
 #, fuzzy
@@ -27038,14 +25851,12 @@
 #: ../vector/v.db.connect/main.c:120
 msgid "Delete connection for certain layer (not the table)"
-msgstr ""
-"Cancella la connessione al database di alcuni layer (ma non la tabella)"
+msgstr "Cancella la connessione al database di alcuni layer (ma non la tabella)"
 #: ../vector/v.db.connect/main.c:153
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
-msgstr ""
-"Impossibile modificare la mappa vettoriale che si trova in un altro mapset"
+msgstr "Impossibile modificare la mappa vettoriale che si trova in un altro mapset"
 #: ../vector/v.db.connect/main.c:170
 #, c-format
@@ -27054,8 +25865,7 @@
 #: ../vector/v.db.connect/main.c:198
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:261
@@ -27070,24 +25880,16 @@
 #: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o "
-"sovrascritta dai moduli GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o sovrascritta dai moduli GRASS"
 #: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Permessi selezionati concessi alla tabella"
 #: ../vector/v.db.connect/main.c:346
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Per definire una nuova connessione, devi specificare i seguenti parametri: "
-"driver, database, tabella [, chiave [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Per definire una nuova connessione, devi specificare i seguenti parametri: driver, database, tabella [, chiave [, layer]]"
 #: ../vector/v.out.pov/main.c:207
 #, c-format
@@ -27152,8 +25954,7 @@
 msgstr ""
 #: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
+msgid "No features drapped. Check Your computational region and input raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:48
@@ -27166,14 +25967,11 @@
 #: ../vector/v.what.rast/main.c:82
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un raster nella tabella degli attributi di un vettoriale "
-"puntuale"
+msgstr "Carica valori di un raster nella tabella degli attributi di un vettoriale puntuale"
 #: ../vector/v.what.rast/main.c:87
 msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Nome della mappa vettoriale di punti della quale editare la tabella attributi"
+msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #: ../vector/v.what.rast/main.c:91
 #, fuzzy
@@ -27190,9 +25988,7 @@
 #: ../vector/v.what.rast/main.c:164
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Il raster è di tipo float mentre la colonna è di tipo integer, attenzione "
-"alla possibile perdita di dati!"
+msgstr "Il raster è di tipo float mentre la colonna è di tipo integer, attenzione alla possibile perdita di dati!"
 #: ../vector/v.what.rast/main.c:244
 #, fuzzy, c-format
@@ -27207,8 +26003,7 @@
 #: ../vector/v.what.rast/main.c:302
 #, c-format
 msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-"Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
+msgstr "Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
 #: ../vector/v.what.rast/main.c:367
 #, c-format
@@ -27380,9 +26175,7 @@
 msgstr "N"
 #: ../misc/m.cogo/main.c:226
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:228
@@ -27550,9 +26343,7 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:50
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in a 3D space."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in a 3D space."
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:128
@@ -27829,8 +26620,7 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:603
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:607
@@ -28006,8 +26796,7 @@
 #: ../doc/vector/v.example/main.c:209
 #, fuzzy, c-format
 msgid "Unable to copy attribute table to vector map <%s>"
-msgstr ""
-"Impossibile copiare la tabella degli attributi nella mappa vettoriale <%s>"
+msgstr "Impossibile copiare la tabella degli attributi nella mappa vettoriale <%s>"
 #: ../ps/ps.map/ps_vlines.c:54 ../ps/ps.map/ps_vpoints.c:70
 #: ../ps/ps.map/ps_vareas.c:162
@@ -28054,9 +26843,7 @@
 #: ../ps/ps.map/main.c:88
 #, fuzzy
 msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra "
-"destra alto basso[margine])"
+msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
 #: ../ps/ps.map/main.c:89 ../ps/ps.map/main.c:101
 msgid "Utility"
@@ -28067,9 +26854,7 @@
 msgstr "Crea file EPS (Encapsulated PostScript) invece di PostScript"
 #: ../ps/ps.map/main.c:100
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:104
@@ -28088,8 +26873,7 @@
 #: ../ps/ps.map/main.c:119
 msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-msgstr ""
-"Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
+msgstr "Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
 #: ../ps/ps.map/main.c:126
 #, fuzzy
@@ -28103,10 +26887,7 @@
 #: ../ps/ps.map/main.c:208
 #, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
 msgstr ""
 #: ../ps/ps.map/main.c:222
@@ -28166,9 +26947,7 @@
 #: ../ps/ps.map/r_vpoints.c:243
 #, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
 msgstr ""
 #: ../ps/ps.map/r_group.c:29
@@ -28194,8 +26973,7 @@
 #: ../ps/ps.map/ps_fclrtbl.c:63
 #, fuzzy
 msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Una tabella colori a virgola mobile deve contenere un intervallo di valori"
+msgstr "Una tabella colori a virgola mobile deve contenere un intervallo di valori"
 #: ../ps/ps.map/ps_fclrtbl.c:68 ../ps/ps.map/ps_clrtbl.c:43
 msgid "Unable to read colors for colorbar"
@@ -28204,16 +26982,12 @@
 #: ../ps/ps.map/ps_fclrtbl.c:91 ../ps/ps.map/ps_fclrtbl.c:96
 #: ../ps/ps.map/ps_clrtbl.c:68
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Posizione y della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione y della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/ps_fclrtbl.c:102 ../ps/ps.map/ps_fclrtbl.c:107
 #: ../ps/ps.map/ps_clrtbl.c:74
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Posizione x della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione x della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/catval.c:64
 msgid "Column type not supported (must be string)"
@@ -28237,10 +27011,7 @@
 msgstr "Lettura della mappa raster nel gruppo <%s> in corso ..."
 #: ../ps/ps.map/ps_clrtbl.c:53
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/scale.c:136
@@ -28332,7 +27103,7 @@
 #: ../ps/ps.map/eps.c:18
 #, fuzzy, c-format
 msgid "Can't open eps file <%s>"
+msgstr "Impossibile aprire il file delle regole <%s>"
 #: ../ps/ps.map/eps.c:37
 #, fuzzy, c-format
@@ -28361,7 +27132,7 @@
 #: ../ps/ps.map/r_plt.c:157
 #, fuzzy
 msgid "Can't open eps file"
 #: ../db/drivers/postgres/fetch.c:172
 msgid "Cannot recognize boolean value"
@@ -28379,30 +27150,18 @@
 #: ../db/drivers/postgres/describe.c:116
 #, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni "
-"dati possono essere corrotti"
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/postgres/describe.c:120
 #, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni "
-"dati possono essere persi"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/postgres/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 "
-"(false), 1 (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 (false), 1 (true)"
 #: ../db/drivers/postgres/parse.c:55 ../db/drivers/mysql/parse.c:71
 msgid "'user' in database definition is not supported, use db.login"
@@ -28410,8 +27169,7 @@
 #: ../db/drivers/postgres/parse.c:59 ../db/drivers/mysql/parse.c:75
 msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'password' non è supportata nella definizione del database, usa db.login"
+msgstr "'password' non è supportata nella definizione del database, usa db.login"
 #: ../db/drivers/postgres/parse.c:63
 msgid "Unknown option in database definition for PostgreSQL: "
@@ -28461,12 +27219,8 @@
 #: ../db/drivers/mysql/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"colonna '%s' : il tipo BIGINT è archiviata come integer (4 byte) alcuni dati "
-"possono essere corrotti"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : il tipo BIGINT è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/mysql/parse.c:60
 msgid "Wrong port number in MySQL database definition: "
@@ -28515,12 +27269,8 @@
 #: ../db/drivers/ogr/describe.c:157
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come "
-"varchar(250) alcuni dati possono essere persi"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/sqlite/describe.c:159
 #, fuzzy, c-format
@@ -28573,12 +27323,8 @@
 #: ../db/base/copy.c:37
 #, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Può essere utilizzata sia l'opzione 'from_table' (in opzione con 'where') "
-"che 'select', ma non contemporaneamente."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Può essere utilizzata sia l'opzione 'from_table' (in opzione con 'where') che 'select', ma non contemporaneamente."
 #: ../db/base/copy.c:43
 msgid "Input driver name"
@@ -28607,8 +27353,7 @@
 #: ../db/base/copy.c:84
 #, fuzzy
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Istruzione select completa (solo se from_table a where non sono utilizzati)"
+msgstr "Istruzione select completa (solo se from_table a where non sono utilizzati)"
 #: ../db/base/copy.c:85
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -28637,8 +27382,7 @@
 #: ../db/base/connect.c:47
 msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
+msgstr "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
 #: ../db/base/connect.c:51
 msgid "Print current connection parameters and exit"
@@ -28655,18 +27399,13 @@
 #: ../db/base/connect.c:75
 #, fuzzy
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"Non utilizzare questa opzione se lo schema non è supportato dal driver/"
-"database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Non utilizzare questa opzione se lo schema non è supportato dal driver/database server"
 #: ../db/base/connect.c:85
 #, fuzzy
 msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Gruppo utenti predefinito del database al quale è assegnato il privilegio "
-"select"
+msgstr "Gruppo utenti predefinito del database al quale è assegnato il privilegio select"
 #: ../db/base/connect.c:121
 msgid "Database connection not defined. Run db.connect."
@@ -28692,8 +27431,7 @@
 #: ../db/base/describe.c:104
 #, fuzzy
 msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"Mostra soltanto i nomi delle colonne invece che la completa descrizione"
+msgstr "Mostra soltanto i nomi delle colonne invece che la completa descrizione"
 #: ../db/base/describe.c:109
 msgid "Print table structure"
@@ -28853,9 +27591,7 @@
 msgstr "La password è stata archiviata nel file"
 #: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
 msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:3
@@ -28879,8 +27615,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:2
@@ -28915,12 +27650,8 @@
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
 #, fuzzy
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset "
-"corrente nel formato corrente"
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset corrente nel formato corrente"
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 msgid "run non-interactively"
@@ -28936,8 +27667,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
+msgid "Creation option to the output format driver. Multiple options may be listed"
 msgstr ""
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
@@ -28968,9 +27698,7 @@
 msgstr "Nome della mappa vettoriale di output"
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:2
@@ -29062,9 +27790,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:17
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:19
@@ -29073,8 +27799,7 @@
 msgstr "Nessuna mappa in input specificata"
 #: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
+msgid "Script style output in CSV format respecting the field separator settings"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:23
@@ -29116,9 +27841,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:8
 #, fuzzy
 msgid "Width and height of output image (overrides resolution setting)"
-msgstr ""
-"Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni "
-"della risoluzione)"
+msgstr "Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni della risoluzione)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:10
 #, fuzzy
@@ -29167,8 +27890,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:26
@@ -29185,8 +27907,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:31
 msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr ""
-"Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
+msgstr "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:33
 msgid "Do not crop away margins"
@@ -29194,18 +27915,14 @@
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Prova il driver del database, il database deve esistere e impostato "
-"utilizzando db.connect"
+msgstr "Prova il driver del database, il database deve esistere e impostato utilizzando db.connect"
 #: ../locale/scriptstrings/db.test_to_translate.c:3
 msgid "Test name"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:2
@@ -29221,8 +27938,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
@@ -29259,8 +27975,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
@@ -29286,38 +28001,31 @@
 msgstr "Sensore SPOT"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-#, fuzzy
 msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "Nome della mappa raster di input (green: tm2 | qbird_green | spot1)"
+msgstr "Nome del raster di input (green: tm2 | qbird_green | spot1)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-#, fuzzy
 msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-msgstr "Nome della mappa raster di input (NIR: tm4 | qbird_nir | spot2)"
+msgstr "Nome del raster di input (NIR: tm4 | qbird_nir | spot2)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
-#, fuzzy
 msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-msgstr "Nome della mappa raster di input (MIR; tm5 | qbird_red | spot3)"
+msgstr "Nome del raster di input (MIR; tm5 | qbird_red | spot3)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
-#, fuzzy
 msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "Nome della mappa raster di input (etmpan | qbird_pan | spotpan)"
+msgstr "Nome del raster di input (etmpan | qbird_pan | spotpan)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
-#, fuzzy
 msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "Nome del prefisso per la mappa raster di output (e.g. 'brov')"
+msgstr "Prefisso per il raster di output (e.g. 'brov')"
 #: ../locale/scriptstrings/g.extension_to_translate.c:1
 msgid "Tool to maintain GRASS extensions in local GRASS installation."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -29325,7 +28033,6 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:4
-#, fuzzy
 msgid "Name of extension to install/remove"
 msgstr "Nome dell'estensione da installare/rimuovere"
@@ -29338,7 +28045,6 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:8
-#, fuzzy
 msgid "List available modules in the GRASS Addons SVN repository"
 msgstr "Elenca i moduli disponibili nel repository SVN Addons di GRASS "
@@ -29363,9 +28069,8 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:4
 #: ../locale/scriptstrings/d.correlate_to_translate.c:5
 #: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#, fuzzy
 msgid "raster input map"
-msgstr "mappa raster in input"
+msgstr "Raster in input"
 #: ../locale/scriptstrings/d.correlate_to_translate.c:7
 msgid "Draw a trend line"
@@ -29416,12 +28121,8 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Riclassifica un raster maggiore o minore della dimensione di un'area "
-"specificata dall'utente (in ettaari)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Riclassifica un raster maggiore o minore della dimensione di un'area specificata dall'utente (in ettaari)."
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
 msgid "raster, statistics, aggregation"
@@ -29437,14 +28138,11 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
 msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un vettoriale nella tabella degli attributi di un "
-"vettoriale puntuale"
+msgstr "Carica valori di un vettoriale nella tabella degli attributi di un vettoriale puntuale"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#, fuzzy
 msgid "Vector map to modify"
-msgstr "Mappa vettoriale da modificare"
+msgstr "Vettoriale da modificare"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:4
 msgid "Layer in the vector to be modified"
@@ -29455,7 +28153,6 @@
 msgstr "Colonna da aggiornare con il risultato della query"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#, fuzzy
 msgid "Vector map to be queried"
 msgstr "Mappa vettoriale da interrogare"
@@ -29464,7 +28161,6 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#, fuzzy
 msgid "Column to be queried"
 msgstr "Colonna da interrogare"
@@ -29493,9 +28189,8 @@
 msgstr "Riporta le statistiche delle geometrie per i vettoriali"
 #: ../locale/scriptstrings/v.report_to_translate.c:2
-#, fuzzy
 msgid "vector, report, statistics"
-msgstr "N"
+msgstr "vettoriale, reportistica, statistiche"
 #: ../locale/scriptstrings/v.report_to_translate.c:3
 msgid "Reverse sort the result"
@@ -29506,7 +28201,6 @@
 msgstr ""
 #: ../locale/scriptstrings/v.report_to_translate.c:7
-#, fuzzy
 msgid "Value to calculate"
 msgstr "Valore da calcolare"
@@ -29515,11 +28209,8 @@
 msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permette di aggiornare una colonna nella tabella degli attributi connessa a "
-"una mappa vettoriale"
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Permette di aggiornare una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:3
 msgid "Vector map to edit the attribute table for"
@@ -29530,29 +28221,22 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
-#, fuzzy
 msgid "Column to update"
 msgstr "Colonna da aggiornare"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
+msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
 msgid "Column to query"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
 msgstr ""
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-#, fuzzy
 msgid "Displays a raster map and its legend on a graphics window"
 msgstr "Visualizza una mappa raster e la sua legenda in una finestra grafica"
@@ -29561,17 +28245,14 @@
 msgstr ""
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#, fuzzy
 msgid "Name of raster map to display"
-msgstr "Nome della mappa raster da mostrare"
+msgstr "Nome della mappa raster da visualizzare"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-#, fuzzy
 msgid "Number of lines to appear in the legend"
 msgstr "Numero di righe che devono apparire nella legenda"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#, fuzzy
 msgid "Name of raster map to generate legend from"
 msgstr "Nome della mappa raster da cui generare la legenda"
@@ -29601,9 +28282,7 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
@@ -29613,7 +28292,6 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#, fuzzy
 msgid "Name of data table"
 msgstr "Nome della tabella dei dati"
@@ -29629,9 +28307,8 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#, fuzzy
 msgid "Database driver"
-msgstr "Driver del database:"
+msgstr "Driver del database"
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:13
@@ -29661,8 +28338,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
 msgstr ""
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
@@ -29674,11 +28350,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Rinomina una colonna nella tabella degli attributi connessa a una mappa "
-"vettoriale"
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Rinomina una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
 msgid "Vector map for which to rename attribute column"
@@ -29693,9 +28366,8 @@
 msgstr "Vecchio e nuovo nome della colonna (vecchio,nuovo)"
 #: ../locale/scriptstrings/r.mask_to_translate.c:1
-#, fuzzy
 msgid "Creates a MASK for limiting raster operation."
-msgstr "Crea una MASK per limitare le operazioni raster"
+msgstr ""
 #: ../locale/scriptstrings/r.mask_to_translate.c:2
 msgid "raster, mask"
@@ -29725,10 +28397,8 @@
 msgstr ""
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
 msgid "vector, export, GPS"
@@ -29743,34 +28413,26 @@
 msgstr ""
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:5
-#, fuzzy
 msgid "Export as tracks"
 msgstr "Esporta come tracce"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
-#, fuzzy
 msgid "Feature type(s)"
 msgstr "Tipo/i di elemento"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
-#, fuzzy
 msgid "Name for output file or GPS device"
 msgstr "Nome del file in output o del dispositivo GPS"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
-#, fuzzy
 msgid "GpsBabel supported output format"
 msgstr "Formato di output supportato da GpsBabel"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Una singola mappa vettoriale può essere connessa a più tabelle di un "
-"database. Questo numero determina quale tabella viene utilizzata."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Una singola mappa vettoriale può essere connessa a più tabelle di un database. Questo numero determina quale tabella viene utilizzata."
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
@@ -29786,35 +28448,27 @@
 msgstr "Riconnette i vettoriali a un nuovo database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#, fuzzy
 msgid "Name of old database"
 msgstr "Nome del vecchio database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-#, fuzzy
 msgid "Name of new database"
 msgstr "Nome del nuovo database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-#, fuzzy
 msgid "Old schema"
 msgstr "Vecchio schema"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-#, fuzzy
 msgid "New schema"
 msgstr "Nuovo schema"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
@@ -29831,14 +28485,11 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:2
@@ -29846,12 +28497,10 @@
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:4
-#, fuzzy
 msgid "Name of column containing numeric data"
 msgstr "Nome della colonna contenente dati numerici"
 #: ../locale/scriptstrings/v.colors_to_translate.c:5
-#, fuzzy
 msgid "Layer number of data column"
 msgstr "Numero del layer della colonna dei dati"
@@ -29868,7 +28517,6 @@
 msgstr "Nome della mappa raster da cui copiare la tavola dei colori"
 #: ../locale/scriptstrings/v.colors_to_translate.c:13
-#, fuzzy
 msgid "Path to rules file"
 msgstr "Percorso del file di regole"
@@ -29881,7 +28529,6 @@
 msgstr "Esporta tabella degli attributi in diversi formati"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#, fuzzy
 msgid "GRASS table name"
 msgstr "Nome tabella di GRASS"
@@ -29890,15 +28537,13 @@
 msgstr "Tabella da esportare o stringa di connessione al Database"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
 msgid "Table format"
 msgstr "Formato della tabella"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-#, fuzzy
 msgid "Name for output table"
-msgstr "Nome del file in output"
+msgstr "Nome della di output"
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:1
 msgid "Import ASCII x,y[,z] coordinates as a series of lines."
@@ -29909,7 +28554,6 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-#, fuzzy
 msgid "Name of input file (or \"-\" to read from stdin)"
 msgstr "Nome del file di input (o \"-\" per leggere dallo stdin)"
@@ -29926,7 +28570,6 @@
 msgstr ""
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:1
-#, fuzzy
 msgid "Slide show of GRASS raster/vector maps."
 msgstr "Slide show delle mappe raster e vettoriali."
@@ -29935,9 +28578,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:3
-#, fuzzy
 msgid "Show vector maps rather than raster maps"
-msgstr "Mostra le mappe vettoriali piuttosto che quelle raster"
+msgstr "Mostra i vettoriali piuttosto che i raster"
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:4
 msgid "Map prefix. Specify character(s) to view selected maps only"
@@ -29960,11 +28602,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
@@ -30095,9 +28734,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
-#, fuzzy
 msgid "Displays thematic vector map"
-msgstr "Mostra mappa vettoriale tematica"
+msgstr "Visualizza mappa vettoriale tematica"
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
 msgid "display, vector, thematic, legend"
@@ -30147,7 +28785,6 @@
 msgstr "Icona di punti vettoriali per dati puntiformi"
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-#, fuzzy
 msgid "Icon size for point data"
 msgstr "Dimensione dell'icona per dati puntiformi"
@@ -30193,7 +28830,6 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-#, fuzzy
 msgid "Must be expressed as R:G:B triplet"
 msgstr "Dev'essere espresso come tripletta R:G:B"
@@ -30256,9 +28892,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
 msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:2
@@ -30271,13 +28905,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Calcola statistiche univariate da un raster basandosi su poligoni vettoriali "
-"e carica le statistiche in una nuova colonna della tabella degli attributi."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Calcola statistiche univariate da un raster basandosi su poligoni vettoriali e carica le statistiche in una nuova colonna della tabella degli attributi."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
 msgid "vector, raster, statistics"
@@ -30292,9 +28921,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid ""
-"number determines which table to use"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
@@ -30302,7 +28929,6 @@
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#, fuzzy
 msgid "Column prefix for new attribute columns"
 msgstr "Prefisso di colonna per la nuova colonna della tabella degli attributi"
@@ -30319,9 +28945,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.m_to_translate.c:2
-#, fuzzy
 msgid "Name of .dmrc settings file"
-msgstr "Nome di un file MAT-File(v4) esistente"
+msgstr "Nome del file di impostazioni .dmrc"
 #: ../locale/scriptstrings/gis.m_to_translate.c:1
 msgid "GIS manager for GRASS"
@@ -30340,16 +28965,12 @@
 msgstr ""
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:5
-#, fuzzy
 msgid "Name of the column"
 msgstr "Nome della colonna"
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Esporta un raster in un file di testo come valori x,y,z basato sui centri "
-"delle celle"
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Esporta un raster in un file di testo come valori x,y,z basato sui centri delle celle"
 #: ../locale/scriptstrings/d.resize_to_translate.c:1
 msgid "Resizes active display monitor"
@@ -30364,12 +28985,10 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-#, fuzzy
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importa mappe vettoriali Mapgen o Matlab-ASCII in GRASS"
+msgstr "Importa vettoriali Mapgen o Matlab-ASCII in GRASS"
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#, fuzzy
 msgid "Input map is in Matlab format"
 msgstr "La mappa di input è nel formato di Matlab"
@@ -30378,15 +28997,12 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-#, fuzzy
 msgid "Name of input file in Mapgen/Matlab format"
 msgstr "Nome di un file di input in formato Mapgen/Matlab"
 #: ../locale/scriptstrings/v.build.all_to_translate.c:1
-#, fuzzy
 msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Ricostruisce la topologia in tutte le mappe vettoriali nel mapset corrente"
+msgstr "Ricostruisce la topologia in tutti i vettoriali nel mapset corrente."
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
 msgid "calculates univariate statistics from a GRASS raster map"
@@ -30445,7 +29061,6 @@
 #: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
-#, fuzzy
 msgid "Do not overwrite existing map"
 msgstr "Non sovrascrive la mappa esistente"
@@ -30518,12 +29133,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:1
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati "
-"scaricati da un GPS in un vettore"
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati scaricati da un GPS in un vettore"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
 msgid "Import waypoints"
@@ -30542,21 +29153,16 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
-#, fuzzy
 msgid "Device or file used to import data"
 msgstr "Dispositivo o file utilizzato per l'importazione dei dati"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
 msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
+msgstr "Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato "
-"WGS84 Lat/Lon"
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato WGS84 Lat/Lon"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 msgid "Downloads and imports data from WMS servers."
@@ -30579,7 +29185,6 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:38
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:49
-#, fuzzy
 msgid "Request"
 msgstr "Interrogazione"
@@ -30699,10 +29304,8 @@
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
+msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr "Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
 msgid "raster, elevation, interpolation"
@@ -30713,8 +29316,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
+msgid "Output raster map with nulls filled by interpolation from surrounding values"
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
@@ -30726,21 +29328,16 @@
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Dissolve i confini tra aree adiacenti che condividono categorie o attributi "
-"comuni."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Dissolve i confini tra aree adiacenti che condividono categorie o attributi comuni."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:2
 msgid "vector, area, dissolve"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
 msgid "Layer number. If -1, all layers are extracted."
-msgstr "Numero di layer. Se -1, tutti i layer sono estratti"
+msgstr "Numero di layer. Se -1, tutti i layer sono estratti."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:7
 msgid "Name of column used to dissolve common boundaries"
@@ -30799,25 +29396,20 @@
 msgstr "Modo esperto (inserisci un set di espressioni r3.mapcalc)"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-#, fuzzy
 msgid "Removes existing attribute table of a vector map."
-msgstr "Rimuove la tabella degli attributi esistente di una mappa vettoriale"
+msgstr "Rimuove la tabella degli attributi esistente di una mappa vettoriale."
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
 msgid "Force removal (required for actual deletion of table)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#, fuzzy
 msgid "Vector map from which to remove attribute table"
 msgstr "Mappa vettoriale dalla quale rimuovere la tabella degli attributi"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-#, fuzzy
 msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"Nome della tabella degli attributi esistente (predefinito: nome della mappa "
-"vettoriale"
+msgstr "Nome della tabella degli attributi esistente (predefinito: nome della mappa vettoriale)"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
 msgid "Layer from which to drop linked attribute table"
@@ -30868,70 +29460,54 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-#, fuzzy
 msgid "raster input map (LANDSAT channel 1)"
-msgstr "mappa raster di input (LANDSAT canale 1)"
+msgstr "raster di input (LANDSAT canale 1)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-#, fuzzy
 msgid "raster input map (LANDSAT channel 2)"
-msgstr "mappa raster di input (LANDSAT canale 2)"
+msgstr "raster di input (LANDSAT canale 2)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-#, fuzzy
 msgid "raster input map (LANDSAT channel 3)"
-msgstr "mappa raster di input (LANDSAT canale 3)"
+msgstr "raster di input (LANDSAT canale 3)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-#, fuzzy
 msgid "raster input map (LANDSAT channel 4)"
-msgstr "mappa raster di input (LANDSAT canale 4)"
+msgstr "raster di input (LANDSAT canale 4)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-#, fuzzy
 msgid "raster input map (LANDSAT channel 5)"
-msgstr "mappa raster di input (LANDSAT canale 5)"
+msgstr "raster di input (LANDSAT canale 5)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-#, fuzzy
 msgid "raster input map (LANDSAT channel 7)"
-msgstr "mappa raster di input (LANDSAT canale 7)"
+msgstr "raster di input (LANDSAT canale 7)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:12
 msgid "raster output TC maps prefix"
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#, fuzzy
 msgid "Vector map for which to add new attribute table"
-msgstr ""
-"Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
+msgstr "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#, fuzzy
 msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nome della nuova tabella degli attributi (predefinito: nome della mappa "
-"vettoriale)"
+msgstr "Nome della nuova tabella degli attributi (predefinito: nome della mappa vettoriale)"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
 msgid "Layer where to add new attribute table"
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-#, fuzzy
 msgid "Import GetFeature from WFS"
 msgstr "Importa GetFeature da WFS"
@@ -30945,8 +29521,7 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
 msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
+msgstr "Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
 #, fuzzy
@@ -30974,17 +29549,14 @@
 msgstr ""
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
 msgstr ""
 #: ../locale/scriptstrings/d.out.png_to_translate.c:1
 msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"Salva il monitor attivo visualizzato in un file PNG nella directory home"
+msgstr "Salva il monitor attivo visualizzato in un file PNG nella directory home"
 #: ../locale/scriptstrings/d.out.png_to_translate.c:3
-#, fuzzy
 msgid "Name of PNG file"
 msgstr "Nome del file PNG"
@@ -31029,7 +29601,6 @@
 msgstr ""
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-#, fuzzy
 msgid "raster, landscape structure analysis"
 msgstr "raster, analisi della struttura del paesaggio"
@@ -31050,7 +29621,6 @@
 msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
 msgid "Name of aspect raster map"
 msgstr "Nome della mappa raster delle esposizioni"
@@ -31063,23 +29633,19 @@
 msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-#, fuzzy
 msgid "Minimum size of each cell"
 msgstr "Dimensione minima di ogni cella"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-#, fuzzy
 msgid "Maximum number of rows to load"
-msgstr "Numero massimo di righe da caaricare"
+msgstr "Numero massimo di righe da caricare"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-#, fuzzy
 msgid "Maximum number of columns to load"
 msgstr "Numero massimo di colonne da caricare"
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
@@ -31108,7 +29674,6 @@
 msgstr ""
 #: ../locale/scriptstrings/d.polar_to_translate.c:5
-#, fuzzy
 msgid "Name of optional EPS output file"
 msgstr "Nome del file EPS opzionale di output"
@@ -31129,12 +29694,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Aggiunge una o più colonne alla tabella degli attributi connessa ad una "
-"mappa vettoriale"
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Aggiunge una o più colonne alla tabella degli attributi connessa ad una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
 msgid "Name of vector map for which to edit attribute table"
@@ -31149,13 +29710,10 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:1
-#, fuzzy
 msgid "Moves displayed maps to another monitor"
 msgstr "Sposta le mappe visualizzate su un altro monitor"
@@ -31172,14 +29730,12 @@
 msgstr ""
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:6
-#, fuzzy
 msgid "Target monitor"
 msgstr "Monitor di destinazione"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:7
-#, fuzzy
 msgid "Source monitor"
-msgstr "Monitori di origine"
+msgstr "Monitor di origine"
 #: ../sites/s.out.ascii/main.c:47 ../sites/s.in.ascii/main.c:50
 msgid "sites"
@@ -31190,12 +29746,10 @@
 msgstr ""
 #: ../imagery/i.smap/bouman/interp.c:237
-#, fuzzy
 msgid "Invalid parameter values"
 msgstr "Valori del parametro non validi"
 #: ../imagery/i.smap/bouman/segment.c:70
-#, fuzzy
 msgid "Number of classes must be < 256"
 msgstr "Il numero delle classi dev'essere < 256"
@@ -31219,9 +29773,7 @@
 msgstr ""
 #: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/shapiro/read_sig.c:13
@@ -31233,7 +29785,7 @@
 #: ../imagery/i.smap/shapiro/read_sig.c:17
 #: ../imagery/i.smap/shapiro/openfiles.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps"
 msgstr "Il sottogruppo <%s> nel gruppo <%s> non contiene mappe raster"
@@ -31292,7 +29844,6 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:69
-#, fuzzy
 msgid "Name of two or more input raster maps"
 msgstr "Nome di due o più mappe raster di input"
@@ -31317,12 +29868,10 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:100
-#, fuzzy
 msgid "Sorry, at least 2 input bands must be provided"
 msgstr "Spiacente, ma si devono fornire almeno due bande di input"
 #: ../imagery/i.pca/main.c:134
-#, fuzzy
 msgid "Calculating covariance matrix..."
 msgstr "Calcolo della matrice di covarianza in corso..."
@@ -31336,7 +29885,7 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:255
-#, fuzzy, c-format
+#, c-format
 msgid "Computing means for band %d..."
 msgstr "Calcolo delle medie per la banda %d in corso..."
@@ -31350,7 +29899,6 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:383
-#, fuzzy
 msgid "Unable to allocate memory for raster row"
 msgstr "Impossibile allocare memoria per la riga raster"
@@ -31382,34 +29930,11 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:100
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:111
-msgid ""
-"Name of QC type to extract:adjcorr;mod09: Adjacency Correction;atcorr;mod09: "
-"Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-"
-"Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different "
-"Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
-"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
-"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
-"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
-"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
-"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
-"StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA "
-"Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow "
-"Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: "
-"StateQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA "
-"Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;"
-"mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Mask"
+msgid "Name of QC type to extract:adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Sno
 w Maskcloud_state;mod09A1s: StateQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:142
@@ -31422,10 +29947,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:151
-msgid ""
-"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
-"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
-"mod09A1 Band 7: SWIR 3;"
+msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:162
@@ -31463,9 +29985,8 @@
 msgstr ""
 #: ../imagery/i.zc/main.c:57
-#, fuzzy
 msgid "imagery, edges"
-msgstr "raster, statistica, riclassificazione"
+msgstr ""
 #: ../imagery/i.zc/main.c:59
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
@@ -31525,16 +30046,13 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:92
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:106
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
-#, fuzzy
 msgid "Output raster map(s) suffix"
-msgstr "Suffisso per la mappa/e raster di output"
+msgstr "Suffisso per il/i raster di output"
 #: ../imagery/i.rectify/main.c:112
 msgid "Rectification polynom order (1-3)"
@@ -31552,8 +30070,7 @@
 #: ../imagery/i.rectify/main.c:141
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:145
@@ -31573,14 +30090,14 @@
 #: ../imagery/i.rectify/main.c:191
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:184
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
-msgstr "Il gruppo <%s> non contiene mappe raster; eseguire i.group"
+msgstr "Il gruppo <%s> non contiene raster; eseguire i.group"
 #: ../imagery/i.rectify/main.c:266
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:278
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "Extension <%s> is illegal"
 msgstr "L'estensione <%s> non è valida"
@@ -31613,15 +30130,15 @@
 #: ../imagery/i.rectify/main.c:306
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:316
-#, fuzzy, c-format
+#, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr "Si sta usando la regione: N=%f S=%f E=%f O=%f"
 #: ../imagery/i.rectify/main.c:321
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:383
-#, fuzzy, c-format
+#, c-format
 msgid "Input raster map <%s> does not exist in group <%s>."
-msgstr "La mappa raster di input <%s> non esiste nel gruppo <%s>"
+msgstr "Il raster di input <%s> non esiste nel gruppo <%s>"
 #: ../imagery/i.rectify/main.c:323
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:385
@@ -31630,22 +30147,21 @@
 #: ../imagery/i.rectify/main.c:328
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:390
-#, fuzzy
 msgid "Exit!"
 msgstr "Uscita!"
 #: ../imagery/i.rectify/get_wind.c:113
-#, fuzzy, c-format
+#, c-format
 msgid "Region N=%f S=%f E=%f W=%f"
 msgstr "Regione N=%f S=%f E=%f O=%f"
 #: ../imagery/i.rectify/get_wind.c:115
-#, fuzzy, c-format
+#, c-format
 msgid "Resolution EW=%f NS=%f"
 msgstr "Risoluzionen EW=%f NS=%f"
 #: ../imagery/i.rectify/cp.c:15
-#, fuzzy, c-format
+#, c-format
 msgid "Control Point file for group <%s@%s> - "
 msgstr "File dei punti di controllo per il gruppo <%s@%s> - "
@@ -31659,29 +30175,26 @@
 msgstr ""
 #: ../imagery/i.rectify/cp.c:26
-#, fuzzy
 msgid " Can not generate the transformation equation."
-msgstr "Impossibile generare l'equazione di trasformazione."
+msgstr " Impossibile generare l'equazione di trasformazione."
 #: ../imagery/i.rectify/cp.c:29
-#, fuzzy
 msgid "Not enough memory to solve for transformation equation"
 msgstr "Memoria insufficiente per risolvere l'equazione di trasformazione"
 #: ../imagery/i.rectify/cp.c:32
-#, fuzzy
 msgid "Invalid order"
 msgstr "Ordine non valido"
 #: ../imagery/i.rectify/target.c:14
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:13
-#, fuzzy, c-format
+#, c-format
 msgid "Target information for group <%s> missing"
 msgstr "Mancano le informazioni sulla destinazione per il gruppo <%s>"
 #: ../imagery/i.rectify/target.c:20
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Target location <%s> not found"
 msgstr "Location di destinazione <%s> non trovata"
@@ -31726,35 +30239,28 @@
 #: ../imagery/i.rectify/rectify.c:47
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:50
-#, fuzzy, c-format
+#, c-format
 msgid "into  <%s@%s> (location <%s>) ..."
 msgstr "in  <%s@%s> (location <%s>) ..."
 #: ../imagery/i.rectify/rectify.c:109
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-"Mappa raster <%s@%s>: la proiezione non corrisponde alle impostazioni "
-"correnti"
+msgstr "Raster <%s@%s>: la proiezione non corrisponde alle impostazioni correnti"
 #: ../imagery/i.rectify/rectify.c:115
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:137
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
-msgstr ""
-"Mappa raster <%s@%s>: la zona non corrisponde alle impostazioni correnti"
+msgstr "Raster <%s@%s>: la zona non corrisponde alle impostazioni correnti"
 #: ../imagery/i.landsat.toar/main.c:64
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:65
-msgid ""
-"imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric "
-"correction"
+msgid "imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:70
@@ -31790,9 +30296,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:95
-msgid ""
-"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;"
-"tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:109
@@ -31909,14 +30413,11 @@
 msgstr ""
 #: ../imagery/i.vpoints/main.c:94 ../imagery/i.points/main.c:96
-#, fuzzy
 msgid "imagery, geometry"
-msgstr "raster, geomorfologia"
+msgstr ""
 #: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
 msgstr ""
 #: ../imagery/i.vpoints/main.c:104 ../imagery/i.points/main.c:105
@@ -31959,86 +30460,70 @@
 msgstr ""
 #: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/r2hmain.c:53
-#, fuzzy
 msgid "Name of input raster map (red)"
-msgstr "Nome della mappe raster di input (rosso)"
+msgstr "Nome del raster di input (rosso)"
 #: ../imagery/i.rgb.his/r2hmain.c:57
-#, fuzzy
 msgid "Name of input raster map (green)"
-msgstr "Nome della mappe raster di input (verde)"
+msgstr "Nome del raster di input (verde)"
 #: ../imagery/i.rgb.his/r2hmain.c:61
-#, fuzzy
 msgid "Name of input raster map (blue)"
-msgstr "Nome della mappe raster di input (blu)"
+msgstr "Nome del raster di input (blu)"
 #: ../imagery/i.rgb.his/r2hmain.c:65
-#, fuzzy
 msgid "Name for output raster map (hue)"
-msgstr "Nome della mappe raster di output (tonalità)"
+msgstr "Nome del raster di output (tonalità)"
 #: ../imagery/i.rgb.his/r2hmain.c:69
-#, fuzzy
 msgid "Name for output raster map (intensity)"
-msgstr "Nome della mappe raster di output (intensità)"
+msgstr "Nome del raster di output (intensità)"
 #: ../imagery/i.rgb.his/r2hmain.c:73
-#, fuzzy
 msgid "Name for output raster map (saturation)"
-msgstr "Nome della mappe raster di output (saturazione)"
+msgstr "Nome del raster di output (saturazione)"
 #: ../imagery/i.rgb.his/r2hmain.c:93 ../imagery/i.his.rgb/h2rmain.c:95
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read raster map row %ld"
-msgstr "Impossibile leggere la riga %ld della mappa raster"
+msgstr "Impossibile leggere la riga %ld del raster"
 #: ../imagery/i.rgb.his/r2hmain.c:102 ../imagery/i.his.rgb/h2rmain.c:104
-#, fuzzy, c-format
+#, c-format
 msgid "Failed writing raster map row %ld"
-msgstr "Scrittura della riga %ld della mappa raster non riuscita"
+msgstr "Scrittura della riga %ld del raster non riuscita"
 #: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/h2rmain.c:53
-#, fuzzy
 msgid "Name of input raster map (hue)"
-msgstr "Nome della mappe raster in input (tonalità)"
+msgstr "Nome del raster in input (tonalità)"
 #: ../imagery/i.his.rgb/h2rmain.c:57
-#, fuzzy
 msgid "Name of input raster map (intensity)"
-msgstr "Nome della mappe raster in input (intensità)"
+msgstr "Nome del raster in input (intensità)"
 #: ../imagery/i.his.rgb/h2rmain.c:61
-#, fuzzy
 msgid "Name of input raster map (saturation)"
-msgstr "Nome della mappe raster in input (saturazione)"
+msgstr "Nome del raster in input (saturazione)"
 #: ../imagery/i.his.rgb/h2rmain.c:65
-#, fuzzy
 msgid "Name for output raster map (red)"
-msgstr "Nome della mappe raster di output (rosso)"
+msgstr "Nome del raster di output (rosso)"
 #: ../imagery/i.his.rgb/h2rmain.c:69
-#, fuzzy
 msgid "Name for output raster map (green)"
-msgstr "Nome della mappe raster di output (verde)"
+msgstr "Nome del raster di output (verde)"
 #: ../imagery/i.his.rgb/h2rmain.c:73
-#, fuzzy
 msgid "Name for output raster map (blue)"
-msgstr "Nome della mappe raster di output (blu)"
+msgstr "Nome del raster di output (blu)"
 #: ../imagery/i.gensigset/main.c:42
 msgid "Generates statistics for i.smap from raster map."
@@ -32050,12 +30535,12 @@
 msgstr ""
 #: ../imagery/i.gensigset/main.c:55
-#, fuzzy, c-format
+#, c-format
 msgid "Number of subclasses is %d"
 msgstr "Il numero di sottoclassi è %d"
 #: ../imagery/i.gensigset/subcluster.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "Not enough pixels in class %d"
 msgstr "Pixel insufficienti nella classe %d"
@@ -32065,7 +30550,7 @@
 msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:87
-#, fuzzy, c-format
+#, c-format
 msgid "Number of subclasses set to %d"
 msgstr "Numero di sottoclassi impostato a %d"
@@ -32102,12 +30587,11 @@
 msgstr ""
 #: ../imagery/i.gensigset/get_train.c:78 ../imagery/i.gensig/get_train.c:73
-#, fuzzy
 msgid "1 class found"
 msgstr "Trovata 1 classe"
 #: ../imagery/i.gensigset/get_train.c:80 ../imagery/i.gensig/get_train.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "%d classes found"
 msgstr "Trovate %d classi"
@@ -32130,15 +30614,14 @@
 msgstr ""
 #: ../imagery/i.gensigset/openfiles.c:19 ../imagery/i.gensig/openfiles.c:20
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps."
 msgstr "Il sottogruppo <%s> nel gruppo <%s> non contiene mappe raster."
 #: ../imagery/i.gensigset/read_data.c:19 ../imagery/i.ifft/ifftmain.c:144
 #: ../imagery/i.cluster/main.c:285
-#, fuzzy
 msgid "Reading raster maps..."
-msgstr "Lettura delle mappe raster in corso..."
+msgstr "Lettura dei raster in corso..."
 #: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
 #, c-format
@@ -32170,15 +30653,11 @@
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:101
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:111
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:134
@@ -32187,21 +30666,18 @@
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:151
-#, fuzzy
 msgid "Masking raster maps..."
-msgstr "Mascheramento delle mappe raster in corso..."
+msgstr "Mascheramento dei raster in corso..."
 #: ../imagery/i.ifft/ifftmain.c:172 ../imagery/i.fft/fftmain.c:201
-#, fuzzy
 msgid "Rotating data..."
-msgstr "Rotaizone dei dati in corso..."
+msgstr "Rotazione dei dati in corso..."
 #: ../imagery/i.ifft/ifftmain.c:211
 msgid "Starting Inverse FFT..."
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:225
-#, fuzzy
 msgid "Writing data..."
 msgstr "Scrittura dei dati in corso..."
@@ -32215,9 +30691,8 @@
 msgstr "Impossibile aprire il file temp"
 #: ../imagery/i.cca/main.c:84
-#, fuzzy
 msgid "imagery, statistics"
+msgstr "immagini, statistiche"
 #: ../imagery/i.cca/main.c:86
 msgid "Canonical components analysis (cca) program for image processing."
@@ -32228,14 +30703,12 @@
 msgstr ""
 #: ../imagery/i.cca/main.c:99
-#, fuzzy
 msgid "File containing spectral signatures"
-msgstr "File contenente i pesi"
+msgstr ""
 #: ../imagery/i.cca/main.c:102
-#, fuzzy
 msgid "Output raster map prefix name"
-msgstr "Nome del prefisso per la mappa raster di output"
+msgstr "Nome del prefisso per il raster di output"
 #: ../imagery/i.cca/main.c:108
 #, c-format
@@ -32274,9 +30747,7 @@
 #: ../imagery/i.cca/main.c:240
 #, c-format
-msgid ""
-"The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: "
-"%d"
+msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
 msgstr ""
 #: ../imagery/i.cca/transform.c:24
@@ -32311,9 +30782,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:52
@@ -32327,13 +30796,12 @@
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:64
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] not found"
 msgstr "Gruppo [%s] non trovato"
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
@@ -32376,14 +30844,11 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:51
 #: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:43
-#, fuzzy
 msgid "Could not open elevation raster"
-msgstr "Impossibile aprire il raster di elevazione"
+msgstr "Impossibile aprire il raster dell'elevazione"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
@@ -32391,7 +30856,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:181
-#, fuzzy, c-format
+#, c-format
 msgid "Could not read REF file for group <%s>"
 msgstr "Impossibile leggere il file REF per il gruppo <%s>"
@@ -32427,7 +30892,6 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:16
-#, fuzzy
 msgid "Computing equations..."
 msgstr "Calcolo delle equazioni in corso......"
@@ -32439,7 +30903,6 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:28
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:52
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:58
-#, fuzzy
 msgid "Can not generate the transformation equation.\n"
 msgstr "Impossibile generare l'equazione di trasformazione.\n"
@@ -32503,12 +30966,10 @@
 msgstr "Mapset [%s] nella location di destinazione [%s] - "
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:128
-#, fuzzy
 msgid "permission denied\n"
 msgstr "permesso negato\n"
-#, fuzzy
 msgid "not found\n"
 msgstr "non trovato\n"
@@ -32530,8 +30991,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
+msgid "Name of a map from target mapset which will be initially drawn on screen"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:125
@@ -32555,13 +31015,12 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:167
-#, fuzzy
 msgid "Computing equations ..."
 msgstr "Calcolo delle equazioni in corso..."
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:202
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:233
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read raster header of <%s>"
 msgstr "Impossibile leggere l'intestazione del raster di <%s>"
@@ -32591,7 +31050,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/menu.c:62
-#, fuzzy, c-format
+#, c-format
 msgid "Pre-selected group <%s> not found"
 msgstr "Il gruppo preselezionato <%s> non è stato trovato"
@@ -32600,12 +31059,12 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/menu.c:74
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] contains no files"
 msgstr "Il gruppo [%s] non contiene file"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:44
-#, fuzzy, c-format
+#, c-format
 msgid "Could not read REF file for group [%s]"
 msgstr "Impossibile leggere il file REF per il gruppo [%s]"
@@ -32621,7 +31080,6 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:61
-#, fuzzy
 msgid ""
 "\n"
 "Rectify all images in the group? "
@@ -32664,9 +31122,9 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:141
-#, fuzzy, c-format
+#, c-format
 msgid "Map name <%s> is illegal"
-msgstr "Il nome della mappa <%s> non è valido"
+msgstr "Nome della mappa <%s> non è valido"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:142
 msgid ""
@@ -32683,7 +31141,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:224
-#, fuzzy, c-format
+#, c-format
 msgid "Please select one of the following interpolation methods\n"
 msgstr "Selezionare uno dei seguenti metodi di interpolazione\n"
@@ -32752,18 +31210,17 @@
 msgstr ""
 #: ../imagery/i.fft/fftmain.c:166
-#, fuzzy, c-format
+#, c-format
 msgid "Reading the raster map <%s>..."
-msgstr "Lettura della mappa raster  <%s> in corso..."
+msgstr "Sto leggendo la mappa raster  <%s>..."
 #: ../imagery/i.fft/fftmain.c:182
 msgid "Starting FFT..."
 msgstr ""
 #: ../imagery/i.fft/fftmain.c:225
-#, fuzzy
 msgid "Writing transformed data..."
-msgstr "Scrittura dei dati trasformati in corso..."
+msgstr "Sto scrivendo i dati trasformati..."
 #: ../imagery/i.fft/fftmain.c:231
 msgid "Writing viewable versions of transformed data..."
@@ -32814,9 +31271,9 @@
 msgstr ""
 #: ../imagery/i.gensig/check.c:21
-#, fuzzy, c-format
+#, c-format
 msgid "Signature %d not invertible"
-msgstr "f"
+msgstr ""
 #: ../imagery/i.gensig/check.c:27
 #, c-format
@@ -32850,15 +31307,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:85
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:104
@@ -33001,7 +31454,7 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:266
-#, fuzzy, c-format
+#, c-format
 msgid " Number of initial classes:    %d"
 msgstr " Numero di classi iniziali:    %d"
@@ -33050,13 +31503,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:306
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:310
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:323
@@ -33157,7 +31608,7 @@
 msgstr ""
 #: ../imagery/i.cluster/open_files.c:21 ../imagery/i.maxlik/open.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> in group <%s> not found"
 msgstr "Sottogruppo <%s> non trovato nel gruppo <%s>"
@@ -33167,22 +31618,20 @@
 msgstr "La mappa raster <%s> non esiste nel sottogruppo <%s>"
 #: ../imagery/i.cluster/open_files.c:38
-#, fuzzy
 msgid "No raster maps found"
-msgstr "Nessun mappa raster trovata"
+msgstr "Nessun raster trovato"
 #: ../imagery/i.cluster/open_files.c:42
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> doesn't have any raster maps"
 msgstr "Il sottogruppo <%s> non ha nessuna mappa raster"
 #: ../imagery/i.cluster/open_files.c:45
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup <%s> only has 1 raster map"
 msgstr "Il sottogruppo <%s> ha solo 1 mappa raster"
 #: ../imagery/i.cluster/open_files.c:46
-#, fuzzy
 msgid "Subgroup must have at least 2 raster maps"
 msgstr "Il sottogruppo deve avere almeno 2 mappe raster"
@@ -33220,9 +31669,8 @@
 msgstr ""
 #: ../imagery/i.group/main.c:52 ../imagery/i.target/main.c:45
-#, fuzzy
 msgid "imagery, map management"
-msgstr "Nessun mappa raster rimossa"
+msgstr ""
 #: ../imagery/i.group/main.c:54
 msgid "Creates, edits, and lists groups and subgroups of imagery files."
@@ -33233,9 +31681,8 @@
 msgstr ""
 #: ../imagery/i.group/main.c:68
-#, fuzzy
 msgid "Name of raster map(s) to include in group"
-msgstr "Nome della mappa/e raster da includere nel gruppo"
+msgstr "Nome del/i raster da includere nel gruppo"
 #: ../imagery/i.group/main.c:72
 msgid "Remove selected files from specified group"
@@ -33250,18 +31697,15 @@
 msgstr ""
 #: ../imagery/i.group/main.c:102
-#, fuzzy
 msgid "No input raster map(s) specified"
-msgstr "Nessuna mappa raster di input specificata"
+msgstr "Nessun raster di input specificato"
 #: ../imagery/i.group/main.c:110 ../imagery/i.target/main.c:79
 #: ../imagery/i.class/main.c:103
-#, fuzzy
 msgid "Group must exist in the current mapset"
 msgstr "Il gruppo deve esistere nel mapset corrente"
 #: ../imagery/i.group/main.c:120 ../imagery/i.group/main.c:141
-#, fuzzy
 msgid "Specified group does not exist in current mapset"
 msgstr "Il gruppo specificato non esiste nel mapset corrente"
@@ -33333,9 +31777,8 @@
 msgstr ""
 #: ../imagery/i.target/main.c:62
-#, fuzzy
 msgid "Name of target mapset"
-msgstr "Nome del mapset di destinazione"
+msgstr "Nome del mapset d'origine"
 #: ../imagery/i.target/main.c:67
 msgid "Set current location and mapset as target for of imagery group"
@@ -33360,28 +31803,24 @@
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:83
-#, fuzzy
 msgid "Computes topografic correction of reflectance."
-msgstr "Metodo di interpolazione"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:85
 msgid "imagery, topographic correction, Cosine, Minnaert, C-Factor, Percent"
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:93
-#, fuzzy
 msgid "Name of reflectance raster maps to correct topographically"
-msgstr "Nome di una mappa raster esistente da interrogare sui colori"
+msgstr ""
 #: ../imagery/i.topo.corr/main.c:97
-#, fuzzy
 msgid "Name (flag -i) or prefix for output raster maps"
-msgstr "Prefisso per la mappa/e raster di output"
+msgstr "Nome (flag -i) o prefisso per il raster di output"
 #: ../imagery/i.topo.corr/main.c:101
-#, fuzzy
 msgid "Name of input base raster map (elevation or ilumination)"
+msgstr "Nome del raster in input (elevazione o illuminazione)"
 #: ../imagery/i.topo.corr/main.c:107
 msgid "Solar zenith in degrees"
@@ -33408,18 +31847,17 @@
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:166
-#, fuzzy
 msgid "Elevation raster map of unknown type"
-msgstr "Coordinate dell'altezza di un punto nel piano"
+msgstr "Raster dell'elavazione di tipologia sconosciuta"
 #: ../imagery/i.topo.corr/main.c:200
 msgid "Illumination model is of CELL type"
 msgstr ""
 #: ../imagery/i.topo.corr/main.c:207
-#, fuzzy, c-format
+#, c-format
 msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-msgstr "Tavola dei colori <%s> non trovata"
+msgstr "Raster della riflettanza <%s> non è DCELL - ignorato"
 #: ../imagery/i.topo.corr/correction.c:100
 #, c-format
@@ -33440,9 +31878,7 @@
 msgstr "Classifica la riflettanza spettrale nei dati dell'immagine"
 #: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:80
@@ -33459,16 +31895,12 @@
 #: ../imagery/i.maxlik/open.c:26
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:29
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:48
@@ -33487,20 +31919,15 @@
 msgstr ""
 #: ../imagery/i.class/main.c:53
-#, fuzzy
 msgid "imagery, classification"
-msgstr "Algoritmo da usare per la classificazione"
+msgstr "immagini, classificazione"
 #: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
 msgstr ""
 #: ../imagery/i.class/main.c:58
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
 msgstr ""
 #: ../imagery/i.class/main.c:77
@@ -33675,2535 +32102,2494 @@
 msgstr ""
 #, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgid "input,cell,raster"
+msgstr "Nome del driver in input"
 #, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
+msgid "output,cell,raster"
+msgstr "campo separatore in output"
-#, fuzzy
-#~ msgid "input"
-#~ msgstr "Input"
+msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
+msgstr "Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset corrente nel formato corrente"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "Nome del driver in input"
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr "Importa vettori Mapgen o Matlab in GRASS"
 #, fuzzy
-#~ msgid "output"
-#~ msgstr "Output"
+msgid "raster, projection"
+msgstr "Nome del raster"
 #, fuzzy
-#~ msgid "output,cell,raster"
-#~ msgstr "campo separatore in output"
+msgid "Create an integer map"
+msgstr "Mappa raster risultante"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "Rimuove le mappe di base"
+msgid "Empty east coordinate specified!"
+msgstr "Sono state specificate delle coordinate ovest vuote."
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Metodo sconosciuto"
+msgid "Empty north coordinate specified!"
+msgstr "Sono state specificate delle coordinate nord vuote."
-#~ msgid ""
-#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-#~ "format"
-#~ msgstr ""
-#~ "Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset "
-#~ "corrente nel formato corrente"
+msgid "Either define sun position or location/date/time parameters."
+msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importa vettori Mapgen o Matlab in GRASS"
 #, fuzzy
-#~ msgid "raster, projection"
-#~ msgstr "Nome del raster"
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
+msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
-#, fuzzy
-#~ msgid "Create an integer map"
-#~ msgstr "Mappa raster risultante"
+msgid "Change current mapset."
+msgstr "Cambia il mapset corrente."
-#~ msgid "Empty east coordinate specified!"
-#~ msgstr "Sono state specificate delle coordinate ovest vuote."
-#~ msgid "Empty north coordinate specified!"
-#~ msgstr "Sono state specificate delle coordinate nord vuote."
-#~ msgid "Either define sun position or location/date/time parameters."
-#~ msgstr ""
-#~ "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
 #, fuzzy
-#~ msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
-#~ msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
+msgid "Modifies the user's current mapset search path, affecting the user's access to data existing under the other GRASS mapsets in the current location."
+msgstr "Copia i file disponibili nell'attuale percorso di ricerca del mapset e della location in uso dall'utente nelle appropriate cartelle del mapset corrente"
-#~ msgid "Change current mapset."
-#~ msgstr "Cambia il mapset corrente."
 #, fuzzy
-#~ msgid ""
-#~ "Modifies the user's current mapset search path, affecting the user's "
-#~ "access to data existing under the other GRASS mapsets in the current "
-#~ "location."
-#~ msgstr ""
-#~ "Copia i file disponibili nell'attuale percorso di ricerca del mapset e "
-#~ "della location in uso dall'utente nelle appropriate cartelle del mapset "
-#~ "corrente"
+msgid "Name(s) of existing mapset(s) to add to search list"
+msgstr "Nome di una mappa raster esistente"
 #, fuzzy
-#~ msgid "Name(s) of existing mapset(s) to add to search list"
-#~ msgstr "Nome di una mappa raster esistente"
+msgid "Name(s) of existing mapset(s) to remove from search list"
 #, fuzzy
-#~ msgid "Name(s) of existing mapset(s) to remove from search list"
+msgid "Unhandled vector feature type <%s>"
+msgstr "Nome della mappa raster risultante"
 #, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "Nome della mappa raster risultante"
+msgid "No areas found, skipping type=area"
+msgstr "Utilizza la regione corrente"
 #, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "Utilizza la regione corrente"
+msgid "No points found, skipping%s%s"
 #, fuzzy
-#~ msgid "No points found, skipping%s%s"
+msgid "No lines found, skipping%s%s"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
+msgid "Total area: %e (%d areas)"
+msgstr "Area totale: %e (%d areas)"
-#~ msgid "Total area: %e (%d areas)"
-#~ msgstr "Area totale: %e (%d areas)"
+msgid "Area without category: %e (%d areas)"
+msgstr "Aree senza categoria: %e (%d areas)"
-#~ msgid "Area without category: %e (%d areas)"
-#~ msgstr "Aree senza categoria: %e (%d areas)"
+msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+msgstr "Converte vettore binario GRASS in raster GRASS"
-#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-#~ msgstr "Converte vettore binario GRASS in raster GRASS"
+msgid "Name of column for attr parameter (data type must be numeric)"
+msgstr "Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
-#~ msgid "Name of column for attr parameter (data type must be numeric)"
-#~ msgstr ""
-#~ "Nome della colonna per il parametro attr (tipo di dato dovrà essere "
-#~ "numerico)"
+msgid "Duplicate area centroids"
+msgstr "Centroidi dell'area duplicati"
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Centroidi dell'area duplicati"
 #, fuzzy
-#~ msgid "installation"
-#~ msgstr "visualizzazione"
+msgid "installation"
+msgstr "visualizzazione"
 #, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "ERRORE: <%s> esiste già\n"
+msgid "GDAL datatype: %s, range: %f - %f"
+msgstr "ERRORE: <%s> esiste già\n"
 #, fuzzy
-#~ msgid "The hight of the river bed in [m]"
-#~ msgstr "Nome del driver in output"
+msgid "The hight of the river bed in [m]"
+msgstr "Nome del driver in output"
 #, fuzzy
-#~ msgid "The hight of the drainage bed in [m]"
+msgid "The hight of the drainage bed in [m]"
 #, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Password"
+msgid "Pass %d:"
+msgstr "Password"
 #, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgid "The '-q' flag is superseded and will be removed "
+msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
 #, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#~ msgstr "Impossibile aprire il database <%s>"
+msgid "Unable to create table <%s_edge_Interpolation>"
+msgstr "Impossibile aprire il database <%s>"
 #, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
+msgid "Rescale output raster map [0,255]"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Usa db.select per i comandi SELECT SQL"
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Usa db.select per i comandi SELECT SQL"
 #, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Can't find %d,%d:%f"
+msgstr "Non riesco a mostrare i database"
-#~ msgid "Nothing to show"
-#~ msgstr "Niente da mostrare"
+msgid "Nothing to show"
+msgstr "Niente da mostrare"
-#~ msgid "Starting points raster map"
-#~ msgstr "Punti di partenza del file raster"
+msgid "Starting points raster map"
+msgstr "Punti di partenza del file raster"
 #, fuzzy
-#~ msgid "Reading %s"
+msgid "Reading %s"
 #, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "Sto disegnando ..."
+msgid "Writing %s"
+msgstr "Sto disegnando ..."
-#~ msgid "Please choose only one print style"
-#~ msgstr "Per favore scegli un solo stile di output"
+msgid "Please choose only one print style"
+msgstr "Per favore scegli un solo stile di output"
 #, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Mostra il titolo del file raster"
+msgid "Output more comments (default=quiet)"
+msgstr "Mostra il titolo del file raster"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Mappa(e) raster da leggere"
+msgid "Vector map to display thematically"
+msgstr "Mappa(e) raster da leggere"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "File di input"
+msgid "Vector map type"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgid "Layer to use for thematic display"
+msgstr "Nome della mappa raster da utilizzare per <%s>"
 #, fuzzy
-#~ msgid "Data type"
-#~ msgstr "Tipo di grafico"
+msgid "Data type"
+msgstr "Tipo di grafico"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Carattere di separatore in output (predefinito: tab)"
+msgid "Output separator (default: newline)"
+msgstr "Carattere di separatore in output (predefinito: tab)"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Raster to remove"
+msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
+msgid "Vector to remove"
 #, fuzzy
-#~ msgid "Region to remove"
+msgid "Region to remove"
 #, fuzzy
-#~ msgid "Label to remove"
+msgid "Label to remove"
 #, fuzzy
-#~ msgid "3dview to remove"
+msgid "3dview to remove"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "Group to remove"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "sensore: LANDSAT"
+msgid "sensor: LANDSAT"
+msgstr "sensore: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "sensore: QuickBird"
+msgid "sensor: QuickBird"
+msgstr "sensore: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "sensore: SPOT"
+msgid "sensor: SPOT"
+msgstr "sensore: SPOT"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "Mappa raster in input"
+msgid "raster input maps"
+msgstr "Mappa raster in input"
 #, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "Nome della mappa di output"
+msgid "reclass raster output map"
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Campo separatore in output"
+msgid "Output field seperator"
+msgstr "Campo separatore in output"
-#~ msgid "Steps=%d"
-#~ msgstr "Scala=%d"
+msgid "Steps=%d"
+msgstr "Scala=%d"
 #, fuzzy
-#~ msgid "ERROR: Problem opening output file."
+msgid "ERROR: Problem opening output file."
 #, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Crea separatamente un file bitmap 3D di valori nulli"
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr "Crea separatamente un file bitmap 3D di valori nulli"
 #, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#~ msgstr "Nome della mappa di input"
+msgid "Name of the sampling locations vector points map"
+msgstr "Nome della mappa di input"
 #, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nome del file in output"
+msgid "Density of output walkers"
+msgstr "Nome del file in output"
 #, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "raster <%s> non trovato"
+msgid "File [%s] not found"
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Unable to open file [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
 #, fuzzy
-#~ msgid "Reading sites map (%s) ..."
+msgid "Reading sites map (%s) ..."
 #, fuzzy
-#~ msgid "Name of the output walkers vector points map"
+msgid "Name of the output walkers vector points map"
 #, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "You are not outputting any raster or vector points maps"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "Nome del raster map in output"
+msgid "%s=%s - illegal value"
+msgstr "Nome del raster map in output"
 #, fuzzy
-#~ msgid "Unable to read current region parameters"
+msgid "Unable to read current region parameters"
 #, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile [%s]"
+msgid "Cannot open cover raster map <%s>"
+msgstr "Non riesco ad aprire il cellfile [%s]"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Non riesco ad eseguire il driver '%s'"
+msgid "Cannot open database <%s> by driver <%s>"
+msgstr "Non riesco ad eseguire il driver '%s'"
 #, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "Nessuna mappa in input specificata"
+msgid "No map specified"
+msgstr "Nessuna mappa in input specificata"
 #, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "Valore da scrivere per null"
+msgid "%s - unable to remove color table"
+msgstr "Valore da scrivere per null"
 #, fuzzy
-#~ msgid "%s - color table not found"
+msgid "%s - color table not found"
 #, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Unable to properly read input raster map"
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Nome del raster in output"
+msgid "Unable to properly write output raster map"
+msgstr "Nome del raster in output"
 #, fuzzy
-#~ msgid "Unable to read f_range for map %s"
+msgid "Unable to read f_range for map %s"
-#~ msgid "Name of raster map layer to be used for <%s>"
+msgid "Name of raster map layer to be used for <%s>"
 #, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "Punti di blocco della mappa vettoriale"
+msgid "%d points converted to centroids"
+msgstr "Punti di blocco della mappa vettoriale"
 #, fuzzy
-#~ msgid "%d centroids converted to points"
+msgid "%d centroids converted to points"
 #, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%d linee / confini rimossi"
+msgid "%d lines converted to boundaries"
+msgstr "%d linee / confini rimossi"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
+msgid "CrossCorrelation: %d points read in region.\n"
 #, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#~ msgstr "Non riesco ad aprire il database %s col driver %s"
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgstr "Non riesco ad aprire il database %s col driver %s"
 #, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Tipo di colonna non supportata"
+msgid "CrossCorrelation: Column type not supported"
+msgstr "Tipo di colonna non supportata"
 #, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Non riesco a selezionare dati dalla tabella"
+msgid "CrossCorrelation: Cannot select data from table"
+msgstr "Non riesco a selezionare dati dalla tabella"
 #, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Nessun record per la cat = %d"
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "Nessun record per la cat = %d"
 #, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "vector, attribute table"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "Cannot fetch data"
+msgid "Cannot fetch data"
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Colore di evidenziazione del testo"
+msgid "Hilight color for text"
+msgstr "Colore di evidenziazione del testo"
-#~ msgid "Reading data from the map..."
-#~ msgstr "Sto leggendo dati dalla mappa"
+msgid "Reading data from the map..."
+msgstr "Sto leggendo dati dalla mappa"
 #, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
+msgid "Query layer (used by 'query' option)"
-#~ msgid "%d categories read from map"
-#~ msgstr "%d categorie caricate dalla mappa"
+msgid "%d categories read from map"
+msgstr "%d categorie caricate dalla mappa"
-#~ msgid "Writing attributes ..."
-#~ msgstr "Sto scrivendo gli attributi ..."
+msgid "Writing attributes ..."
+msgstr "Sto scrivendo gli attributi ..."
 #, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
+msgid "Current region does not include the entire input vector map <%s>"
 #, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
+msgid "Output inverse raster map after IFFT"
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Leggendo la mappa raster"
+msgid "Reading the raster maps..."
+msgstr "Leggendo la mappa raster"
-#~ msgid "Unable to open output file."
-#~ msgstr "Impossibile aprire il file di output"
+msgid "Unable to open output file."
+msgstr "Impossibile aprire il file di output"
 #, fuzzy
-#~ msgid "Hue map name"
+msgid "Hue map name"
 #, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Nome mappa raster"
+msgid "Intensity map name"
+msgstr "Nome mappa raster"
 #, fuzzy
-#~ msgid "Saturation map name"
+msgid "Saturation map name"
 #, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "strighe che rappresentano le celle prive di valori"
+msgid "Output map representing the red"
+msgstr "strighe che rappresentano le celle prive di valori"
 #, fuzzy
-#~ msgid "Output map representing the green"
+msgid "Output map representing the green"
 #, fuzzy
-#~ msgid "Output map representing the blue"
+msgid "Output map representing the blue"
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Non posso leggere la riga dalla mappa raster"
+msgid "Cannot read row from raster map"
+msgstr "Non posso leggere la riga dalla mappa raster"
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "Non posso scrivere la riga alla mappa raster"
+msgid "Cannot write row to raster map"
+msgstr "Non posso scrivere la riga alla mappa raster"
 #, fuzzy
-#~ msgid "Red input raster map"
+msgid "Red input raster map"
 #, fuzzy
-#~ msgid "Green input raster map"
+msgid "Green input raster map"
 #, fuzzy
-#~ msgid "Blue input raster map"
+msgid "Blue input raster map"
 #, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "Nome della tabella in output"
+msgid "Output intensity raster map"
+msgstr "Nome della tabella in output"
 #, fuzzy
-#~ msgid "Output saturation raster map"
-#~ msgstr "Visualizza il raster della direzione"
+msgid "Output saturation raster map"
+msgstr "Visualizza il raster della direzione"
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Sto scrivendo [%s] ..."
+msgid "Writing [%s] ..."
+msgstr "Sto scrivendo [%s] ..."
 #, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Nome della mappa raster"
+msgid "Name of imagery signaturefile"
+msgstr "Nome della mappa raster"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Sottogruppo <%s> non trovato"
+msgid "Subgroup [%s] not found."
+msgstr "Sottogruppo <%s> non trovato"
 #, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
+msgid "Cannot write color table of raster map <%s>"
-#~ msgid "Imagery group"
-#~ msgstr "Gruppo di immagini"
+msgid "Imagery group"
+msgstr "Gruppo di immagini"
 #, fuzzy
-#~ msgid "Subgroup containing image files"
+msgid "Subgroup containing image files"
 #, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "mappa raster con il risultato"
+msgid "Resultant signature file"
+msgstr "mappa raster con il risultato"
 #, fuzzy
-#~ msgid "Input raster map being fft"
+msgid "Input raster map being fft"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Illegal file name for real part: %s"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "Reading the raster map..."
+msgid "Reading the raster map..."
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "sottogruppo <%s> non trovato"
+msgid "subgroup <%s> not found"
+msgstr "sottogruppo <%s> non trovato"
 #, fuzzy
-#~ msgid "Unable to proceed"
+msgid "Unable to proceed"
 #, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Non riesco ad aprire il file header di [%s]"
+msgid "Unable to read head of %s"
+msgstr "Non riesco ad aprire il file header di [%s]"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "gruppo=[%s] - non trovato"
+msgid "group=[%s] - not found."
+msgstr "gruppo=[%s] - non trovato"
 #, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
+msgid "subgroup=[%s] (of group [%s]) - not found."
 #, fuzzy
-#~ msgid "Can't read signature file [%s]."
+msgid "Can't read signature file [%s]."
 #, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
+msgid "Unable to create reject layer [%s]."
 #, fuzzy
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Nome del file con il risultato della classificazione"
+msgid "Signatures to use for classification"
+msgstr "Nome del file con il risultato della classificazione"
 #, fuzzy
-#~ msgid "Raster map to hold classification results"
+msgid "Raster map to hold classification results"
 #, fuzzy
-#~ msgid "Cannot select attributes: %s"
+msgid "Cannot select attributes: %s"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Usa i numeri delle bande invece che i nomi dei colori"
+msgid "Keep band numbers instead of using band color names."
+msgstr "Usa i numeri delle bande invece che i nomi dei colori"
 #, fuzzy
-#~ msgid "Saving new map"
+msgid "Saving new map"
 #, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Output raster map with lake"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Cannot write lake raster map <%s>!"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
+msgid "Terrain raster map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "Seed map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
+msgid "Failure to allocate memory for row pointers"
 #, fuzzy
-#~ msgid "Loading maps: "
+msgid "Loading maps: "
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
+msgid "Error reading terrain raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Errore nella lettura del file dbmscap\n"
 #, fuzzy
-#~ msgid "All done."
-#~ msgstr "Fatto.\n"
+msgid "All done."
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
+msgid "Name of the vector points map with x,y locations"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Numero di passi attraverso il dataset"
+msgid "Number of time iterations (sec.)"
+msgstr "Numero di passi attraverso il dataset"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "locazione del database"
+msgid "Multiscale simulation"
+msgstr "locazione del database"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nome del file raster in input"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "Nome del file raster in input"
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mappe raster in input"
+msgid "Raster input maps(s)"
+msgstr "Mappe raster in input"
 #, fuzzy
-#~ msgid "Output file name"
-#~ msgstr "Nome del file di output"
+msgid "Output file name"
+msgstr "Nome del file di output"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
 #, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Error reading '%s' map"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unità della distanza"
+msgid "Threshold distance"
+msgstr "Unità della distanza"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Cannot execute: %s"
+msgstr "Non riesco ad impostare user/password"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "Cannot link table: %s"
+msgstr "Non posso scrivere i collegamenti del database"
 #, fuzzy
-#~ msgid "DXF input file"
+msgid "DXF input file"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "Cannot open new vector map <%s>"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
+msgid "Conversion of <%s> to vector map:"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "file raster per la Vista%d"
+msgid "Raster file(s) for Elevation"
+msgstr "file raster per la Vista%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
+msgid "Raster map to zoom into"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Salva le impostazione della region corrente in un file di definizione "
-#~ "della region"
+msgid "Save the current region to region definition file"
+msgstr "Salva le impostazione della region corrente in un file di definizione della region"
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not open input file <%s>."
 #, fuzzy
-#~ msgid "Name of the resultant map"
-#~ msgstr "Nome della mappa con il risultato"
+msgid "Name of the resultant map"
+msgstr "Nome della mappa con il risultato"
 #, fuzzy
-#~ msgid "Raster map not found."
+msgid "Raster map not found."
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "It was not possible writing in <%s>."
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Non riesco a leggere da <%s>"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Non riesco a leggere da <%s>"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Unknown query tool '%s'"
 #, fuzzy
-#~ msgid "No layer database connection"
+msgid "No layer database connection"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "Estrae dati dal database."
+msgid "%d categories loaded from the database"
+msgstr "Estrae dati dal database."
 #, fuzzy
-#~ msgid "Cannot create layer"
+msgid "Cannot create layer"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Impossibile trovare il vettoriale [%s]"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Impossibile trovare il vettoriale [%s]"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
+msgid "Column type [%d] not supported"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "Cannot read map header for <%s>"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "Impossibile salvare la region <%s>"
+msgid "Cannot read category file for <%s>"
+msgstr "Impossibile salvare la region <%s>"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Stampa; script per la shell"
+msgid "Print;Shell Script"
+msgstr "Stampa; script per la shell"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
+msgid "%s: <%s> raster map not found"
 #, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
+msgid "%s: <%s> raster map exists already"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 #, fuzzy
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
 #, fuzzy
-#~ msgid "Could not access %s layer"
+msgid "Could not access %s layer"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Mappa raster che contiene i valori delle altezze"
+msgid "Raster map containing elevation data"
+msgstr "Mappa raster che contiene i valori delle altezze"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Mappa raster con il nome dei risultati archiviati"
+msgid "Raster map name for storing results"
+msgstr "Mappa raster con il nome dei risultati archiviati"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altezza della locazione visualizzata"
+msgid "Height of the viewing location"
+msgstr "Altezza della locazione visualizzata"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
 #, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
+msgid "Unable to read category file for raster map <%s>"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
 #, fuzzy
-#~ msgid "Reading %s ... "
+msgid "Reading %s ... "
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s ha dato un numero non valido di sites [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s ha dato un numero non valido di sites [%d]"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Unable to open database %s by driver %s"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nessuna impostazione definita per il database. Fallo usando db.connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Nessuna impostazione definita per il database. Fallo usando db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Non riesco a trovare l'input %s"
+msgid "Could not find input %s"
+msgstr "Non riesco a trovare l'input %s"
-#~ msgid "Could not open input"
-#~ msgstr "Non riesco ad aprire l'input"
+msgid "Could not open input"
+msgstr "Non riesco ad aprire l'input"
-#~ msgid "Could not open output"
-#~ msgstr "Non riesco ad aprire l'output"
+msgid "Could not open output"
+msgstr "Non riesco ad aprire l'output"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s in %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s in %s: %s"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Can't write region <%s>"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** input non valido **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** input non valido **"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Nessun device grafico selezionato"
+msgid "No graphics device selected."
+msgstr "Nessun device grafico selezionato"
 #, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Unable to read raster row."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
-#~ msgid "cannot read head of %s"
+msgid "cannot read head of %s"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "Nome file non valido [%s]."
+msgid "Illegal file name: %s"
+msgstr "Nome file non valido [%s]."
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgid "Cannot get layer info for vector map"
+msgstr "Impossibile ottenere informazioni sul layer vettoriale"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
+msgid "Cannot open raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
+msgid "%s: %s - raster map not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "%s: %s - illegal name"
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "%s: ERROR reading category file for %s"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "%s: %s - illegal units"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
+msgid "Reading input map (%s)    ... "
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "%s - ERROR reading %s"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Reading raster map... "
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "Nome del raster map esistente"
+msgid "Writing raster map... "
+msgstr "Nome del raster map esistente"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Categoria lista: es. 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Categoria lista: es. 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
+msgid "Output separator character (default: tab)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Cannot create vector map %s"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nume di righe da tenere in memoria"
+msgid "Number of raster rows to hold in memory"
+msgstr "Nume di righe da tenere in memoria"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
+msgid "Print raster map title only"
+msgstr "Stampa solo il tipo di mappa raster"
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Tipo sconosciuto"
+msgid "unknown type: %d"
+msgstr "Tipo sconosciuto"
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Cannot read GRASS raster."
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Couldn't set geo transform."
 #, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "Couldn't set projection."
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
 #, fuzzy
-#~ msgid "Cannot open output map."
+msgid "Cannot open output map."
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
+msgid "memory allocation failure"
 #, fuzzy
-#~ msgid "Can't find data map."
+msgid "Can't find data map."
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
-#~ msgid "No record for cat = %d"
+msgid "No record for cat = %d"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
+msgid "Attaching islands ..."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
+msgid "Vector map <%s> not found in current mapset"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Nome di  2-%d mappe raster in input"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Nome di  2-%d mappe raster in input"
 #, fuzzy
-#~ msgid "The number of polylines in the output vector map is [%d]"
+msgid "The number of polylines in the output vector map is [%d]"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "Connessione al database non definita\n"
+msgid "Database connection not defined for layer <%d>"
+msgstr "Connessione al database non definita\n"
 #, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "Cannot get layer info"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossibile creare l'indice"
+msgid "Cannot rewrite line %d"
+msgstr "Impossibile creare l'indice"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Esistente"
+msgid "Editing tool"
+msgstr "Esistente"
 #, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "Non riesco a copiare la tabella"
+msgid "Close boundaries"
+msgstr "Non riesco a copiare la tabella"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%d categorie duplicate nel vettoriale"
+msgid "%d lines modified"
+msgstr "%d categorie duplicate nel vettoriale"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
 #, fuzzy
-#~ msgid "Print vector map region only"
+msgid "Print vector map region only"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot get layer info for vector map <%s>"
 #, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Cannot select attribute."
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Could not find vector map <%s> in current mapset"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 #, fuzzy
-#~ msgid "Output map where segments will be written"
+msgid "Output map where segments will be written"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
 #, fuzzy
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nome driver"
+msgid "driver name"
+msgstr "nome driver"
-#~ msgid "database name"
-#~ msgstr "nome database"
+msgid "database name"
+msgstr "nome database"
 #, fuzzy
-#~ msgid "Driver name"
+msgid "Driver name"
-#~ msgid "Cannot list databases."
+msgid "Cannot list databases."
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nome tabella, seleziona tutto da questa tabella"
+msgid "Table name, select all from this table"
+msgstr "Nome tabella, seleziona tutto da questa tabella"
-#~ msgid "output vertical record separator"
-#~ msgstr "output verticale del separatore di record "
+msgid "output vertical record separator"
+msgstr "output verticale del separatore di record "
-#~ msgid "null value indicator"
-#~ msgstr "indicatore di valore nullo"
+msgid "null value indicator"
+msgstr "indicatore di valore nullo"
-#~ msgid "do not include column names in output"
-#~ msgstr "non includere i nomi delle colonne nell'output"
+msgid "do not include column names in output"
+msgstr "non includere i nomi delle colonne nell'output"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "output verticale (invece che orizzontale)"
+msgid "vertical output (instead of horizontal)"
+msgstr "output verticale (invece che orizzontale)"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "Cannot find mapset for %s"
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
+msgid "Unable to open cellfile for <%s>"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "Unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
+msgid "Input file [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr ""
+msgid "No db connection for driver <%s> defined. Run db.connect."
 #, fuzzy
-#~ msgid "Table name"
-#~ msgstr "nome tabella"
+msgid "Table name"
+msgstr "nome tabella"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr ""
+"Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
 #, fuzzy
-#~ msgid "x column name"
+msgid "x column name"
 #, fuzzy
-#~ msgid "z column name"
+msgid "z column name"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
+msgid "Cannot fetch data from table"
 #, fuzzy
-#~ msgid "Cannot open file [%s]"
+msgid "Cannot open file [%s]"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Querying input '%s' ... "
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
+msgid "Copying %s input lines ... "
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
+msgid "Cannot find line of cat %d"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Esporta un raster grass come array binario"
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Esporta un raster grass come array binario"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
+msgid "Cannot start driver '%s'."
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Non riesco ad eseguire il driver <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "Non riesco ad eseguire il driver <%s>."
-#~ msgid "Could not open <%s>"
-#~ msgstr "Impossibile aprire <%s>"
+msgid "Could not open <%s>"
+msgstr "Impossibile aprire <%s>"
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Non riesco a scrivere su <%s>"
+msgid "Cannot write to <%s>"
+msgstr "Non riesco a scrivere su <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
+msgid "Raster file [%s] not available"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Memoria esaurita!\n"
+msgid "Out of Memory!\n"
+msgstr "Memoria esaurita!\n"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Open raster map %s in %s = %d"
 #, fuzzy
-#~ msgid "Closing raster map"
+msgid "Closing raster map"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "Checking location %s, mapset %s:"
 #, fuzzy
-#~ msgid "Error writing output map"
+msgid "Error writing output map"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
-#~ msgstr "[%s] è un nome illegale"
+msgid "<%s> is illegal file name"
+msgstr "[%s] è un nome illegale"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
+msgid "no rules specified"
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Can't open temp file [%s]"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
 #, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "Normalizzata"
+msgid "Normalized"
+msgstr "Normalizzata"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
+msgid "Requested 3d raster map not found <%s>"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "unable to close output map"
+msgid "unable to close output map"
 #, fuzzy
-#~ msgid "Could not close the 3d raster map"
+msgid "Could not close the 3d raster map"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "Database's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
+msgid "Cannot open vector points map <%s>"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgstr ""
+msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Nome di mappa(e) raster esistente(i)"
+msgid "error opening raster map [%s]."
+msgstr "Nome di mappa(e) raster esistente(i)"
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "Patching file <%s@%s>"
 #, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "%d records aggiornati"
+msgid "[%d] files patched"
+msgstr "%d records aggiornati"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
+msgid "Could not open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
 #, fuzzy
-#~ msgid "Could not close new 3d raster map"
+msgid "Could not close new 3d raster map"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "Unable to open the temporary file."
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "Nome di un nuovo file raster"
+msgid "name for new raster map"
+msgstr "Nome di un nuovo file raster"
 #, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Output GRASS image file"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
 #, fuzzy
-#~ msgid "Input vector map"
+msgid "Input vector map"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid "%s: ERROR can't open tempfile"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
+msgid "<%s> raster map not found"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
+msgid "Can't get row %d from raster map %s"
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
+msgid "string representing no data cell value"
-#~ msgid "quiet"
-#~ msgstr "silenzioso"
+msgid "quiet"
+msgstr "silenzioso"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "<%s> - illegal output file name"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
-#~ msgid "Base raster map"
-#~ msgstr "Mappa raster di base"
+msgid "Base raster map"
+msgstr "Mappa raster di base"
-#~ msgid "Resultant raster map"
+msgid "Resultant raster map"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
 #, fuzzy
-#~ msgid "Output verbosely"
+msgid "Output verbosely"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Input vector map <%s> not found."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
 #, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "Visualizza i formati supportati ed esci"
+msgid "List available formats and exit"
+msgstr "Visualizza i formati supportati ed esci"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
+msgid "SVG output file"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "Could not find vector '%s'"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
-#~ msgid "Input file"
+msgid "Input file"
-#~ msgid "Raster output file"
-#~ msgstr "File raster in output"
+msgid "Raster output file"
+msgstr "File raster in output"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "Mantieni la tabella colore esistente"
+msgid "Keep existing color table"
+msgstr "Mantieni la tabella colore esistente"
-#~ msgid "List rules"
-#~ msgstr "Mostra regole"
+msgid "List rules"
+msgstr "Mostra regole"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d raster%s, %d vettoriale%s\n"
+msgid " %d rows, %d cols."
+msgstr "%d raster%s, %d vettoriale%s\n"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
+msgid "Vector map with points for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nome della mappa vettoriale di punti della quale editare la tabella "
-#~ "attributi"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #, fuzzy
-#~ msgid "Path to the input file"
-#~ msgstr "Nome del filtro file"
+msgid "Path to the input file"
+msgstr "Nome del filtro file"
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
+msgid "Name of existing raster map to be displayed"
-#~ msgid "driver name:"
-#~ msgstr "nome del driver:"
+msgid "driver name:"
+msgstr "nome del driver:"
-#~ msgid "Database name:"
-#~ msgstr "Nome del database:"
+msgid "Database name:"
+msgstr "Nome del database:"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgid "column type not supported"
+msgstr "driver pg: colonna '%s', di tipo %d non supportata"
 #, fuzzy
-#~ msgid "cannot select data from table"
+msgid "cannot select data from table"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "cannot grant privileges on table %s"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
+msgid "Cannot find vector map"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Errore nella scrittura della grid. Disco pieno?"
+msgid "Error while writing new cell map."
+msgstr "Errore nella scrittura della grid. Disco pieno?"
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Error in opening input file <%s>"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "Unable to open cell man <%s> for input.\n"
 #, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "Unable to open cell map <%s> for output.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "Unable to read map raster row %d"
+msgstr "Nome del raster"
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nome del file con le regole predefinite"
+msgid "Name of predefined rules file"
+msgstr "Nome del file con le regole predefinite"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%"
-#~ "d:%d **\n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%d:%d **\n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %"
-#~ "d %d **\n"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %d %d **\n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attenzione: non trovo il valore **\n"
+msgid "no such value"
+msgstr "** attenzione: non trovo il valore **\n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:linea %d:%s\n"
+msgid "%s:line %d:%s"
+msgstr "%s:linea %d:%s\n"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** definizione errata del colore **\n"
+msgid "bad color specification"
+msgstr "** definizione errata del colore **\n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - colore sconosciuto\n"
+msgid "%s - unknown color"
+msgstr "%s - colore sconosciuto\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "I colori validi sono:\n"
+msgid "Valid colors are:\n"
+msgstr "I colori validi sono:\n"
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "Unable to find base map <%s>"
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "%s: unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#~ msgstr "Nome del raster"
+msgid "%s: Failed to read raster row %d"
 #, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid "Unable to find [%s]."
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Could not open raster <%s>"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nome del tipo carattere (non supportato in maniera interattiva, in tal "
-#~ "caso vedi il flag -l) oppure percorso del font TrueType (completo del "
-#~ "nome del file)"
+msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
+msgstr "Nome del tipo carattere (non supportato in maniera interattiva, in tal caso vedi il flag -l) oppure percorso del font TrueType (completo del nome del file)"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+msgid "%s: o_open_file: raster map %s not found"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "No record for category for [%d]"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "Error reading ASCII file <%s>"
 #, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error reading categories: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "Layer: %d\n"
-#~ "categoria: %d\n"
+msgid "category [%d]"
+msgstr ""
+"Layer: %d\n"
+"categoria: %d\n"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Could not find input vector '%s'"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Failed opening output vector map '%s'"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
+msgid "%s: <%s> vector map not found"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
+msgid "Vector <%s> could not be open"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Raster <%s> could not be open."
 #, fuzzy
-#~ msgid "Interpolation()"
+msgid "Interpolation()"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "Interpolation was a success!"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "Utilizza la regione corrente"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "Utilizza la regione corrente"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "%s -- illegal output file name"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Sorry, with method '%s' you have to define an output map."
 #, fuzzy
-#~ msgid "Writing "
+msgid "Writing "
 #, fuzzy
-#~ msgid "Existing raster map name"
+msgid "Existing raster map name"
 #, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "%s - can't read raster cellhd"
 #, fuzzy
-#~ msgid "error reading cell data"
+msgid "error reading cell data"
 #, fuzzy
-#~ msgid "Done!"
+msgid "Done!"
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Non ho trovato nulla.\n"
+msgid "No line found."
+msgstr "Non ho trovato nulla.\n"
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgstr "file vettoriale da creare"
+msgid "vector map to be created"
+msgstr "file vettoriale da creare"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "Mappa raster risultante"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "Mappa raster risultante"
 #, fuzzy
-#~ msgid "EPSG code of projection to be created"
+msgid "EPSG code of projection to be created"
-#~ msgid "must be even number of names"
-#~ msgstr "deve essere un numero pari di nomi"
+msgid "must be even number of names"
+msgstr "deve essere un numero pari di nomi"
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERRORE: <%s> non trovato\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "ERRORE: <%s> non trovato\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERRORE: <%s> nome illegale\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "ERRORE: <%s> nome illegale\n"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Cannot open toolbox: %s"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "Cannot open toolbox."
 #, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "File di input"
+msgid "Vector map(s) -- source for composite"
+msgstr "File di input"
 #, fuzzy
-#~ msgid ""
-#~ "Name of output vector points map (if not specified, the program writes to "
-#~ "standard output)"
-#~ msgstr ""
-#~ "attributi"
+msgid "Name of output vector points map (if not specified, the program writes to standard output)"
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
+msgid "Vector map '%s' not found"
 #, fuzzy
-#~ msgid "vector, segment, curvature"
-#~ msgstr "vettore da rimuovere"
+msgid "vector, segment, curvature"
+msgstr "vettore da rimuovere"
 #, fuzzy
-#~ msgid "More lines with category %d found"
+msgid "More lines with category %d found"
 #, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s Sposta\n"
+msgid "%s\n"
+msgstr "%s Sposta\n"
 #, fuzzy
-#~ msgid "Raster '%s' not found"
+msgid "Raster '%s' not found"
 #, fuzzy
-#~ msgid "Cold not get raster row"
+msgid "Cold not get raster row"
 #, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Risoluzione"
+msgid "ILLEGAL Resolution!"
+msgstr "Risoluzione"
 #, fuzzy
-#~ msgid "Error opening raster map %s"
+msgid "Error opening raster map %s"
 #, fuzzy
-#~ msgid "Copy raster map <%s> into the memory"
+msgid "Copy raster map <%s> into the memory"
 #, fuzzy
-#~ msgid "Query layer"
+msgid "Query layer"
 #, fuzzy
-#~ msgid "Query column name"
+msgid "Query column name"
 #, fuzzy
-#~ msgid "Enter imagery group to be registered"
+msgid "Enter imagery group to be registered"
 #, fuzzy
-#~ msgid "output layer name"
+msgid "output layer name"
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: da  M: a R: esci\n"
+msgid "L: from  M: to R: quit\n"
+msgstr "L: da  M: a R: esci\n"
-#~ msgid "Prints and manipulates GRASS projection information files."
-#~ msgstr "Stampa e modifica i file di proiezione di GRASS"
+msgid "Prints and manipulates GRASS projection information files."
+msgstr "Stampa e modifica i file di proiezione di GRASS"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Dove %s è uno di:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Dove %s è uno di:\n"
 #, fuzzy
-#~ msgid "%s: - no such database %s\n"
+msgid "%s: - no such database %s\n"
 #, fuzzy
-#~ msgid "Input aspect file"
+msgid "Input aspect file"
 #, fuzzy
-#~ msgid "Input barrier file"
+msgid "Input barrier file"
 #, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "%s Esce dal menu\n"
+msgid "Quiet operation"
+msgstr "%s Esce dal menu\n"
 #, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "nessuno"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "nessuno"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "Fatto\n"
+msgid ""
+"\n"
+"Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
 #, fuzzy
-#~ msgid "Vector import complete"
+msgid "Vector import complete"
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Unable to create raster map for [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
-#~ msgid "Done\n"
+msgid "Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
+msgid "Open Raster file %s in Mapset %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "Open 3d raster map %s\n"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
+msgid "Open elev raster map %s\n"
 #, fuzzy
-#~ msgid "Could not open map %s\n"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Could not open map %s\n"
+msgstr "impossibile aprire <%s>"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Il file raster bin è stato importato"
+msgid "Bin raster map to be imported"
+msgstr "Il file raster bin è stato importato"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è inferiore rispetto al valore di minreg, non "
-#~ "verrà visualizzato nulla.\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla.\n"
 #, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "Livello massimo di contorno"
+msgid "Maximum distance"
+msgstr "Livello massimo di contorno"
 #, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "Makes 3D trees from input point vector map"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "Name of the column with tree crown width"
+msgid "Name of the column with tree crown width"
 #, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Cannot select attributes for point #%d"
+msgstr "Non riesco a mostrare i database"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Esce\n"
+msgid "%s Quit\n"
+msgstr "%s Esce\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Disegna griglia geografica"
+msgid "Draw geographic grid"
+msgstr "Disegna griglia geografica"
 #, fuzzy
-#~ msgid "Quiet mode"
+msgid "Quiet mode"
 #, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "raster <%s> non trovato"
+msgid "%s[%d]: No raster map specified."
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "done."
+msgid "done."
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Name for G3d raster map"
+msgid "Name for G3d raster map"
 #, fuzzy
-#~ msgid "No output maps"
-#~ msgstr "Nome della mappa di output"
+msgid "No output maps"
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e "
-#~ "255!\n"
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
 #, fuzzy
-#~ msgid "unable to open new L map layer."
+msgid "unable to open new L map layer."
 #, fuzzy
-#~ msgid "unable to open new S map layer."
+msgid "unable to open new S map layer."
 #, fuzzy
-#~ msgid "Do not export long colortable"
+msgid "Do not export long colortable"
 #, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "Vector map for which to edit attribute table"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "Cannot make stat of %s configuration file"
+msgid "Cannot make stat of %s configuration file"
 #, fuzzy
-#~ msgid "Illegal configuration file"
+msgid "Illegal configuration file"
 #, fuzzy
-#~ msgid "vector, query"
+msgid "vector, query"
 #, fuzzy
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Computing row %d of covariance matrix..."
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Converting %s..."
+msgid "Converting %s..."
-#~ msgid "New LOCATION name (not location path)"
-#~ msgstr "Nome della nuova LOCATION (non il percorso della location)"
+msgid "New LOCATION name (not location path)"
+msgstr "Nome della nuova LOCATION (non il percorso della location)"
-#~ msgid "New GISDBASE (full path to the directory where the new location is)"
-#~ msgstr ""
-#~ "Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
-#~ "situata)"
+msgid "New GISDBASE (full path to the directory where the new location is)"
+msgstr "Nuovo GISDBASE (percorso intero della directory dove la nuova location è situata)"
 #, fuzzy
-#~ msgid "Name for output file (do not add extension)"
+msgid "Name for output file (do not add extension)"
 #, fuzzy
-#~ msgid "Width and height of output image"
-#~ msgstr "Spessore dell'evidenziazione"
+msgid "Width and height of output image"
+msgstr "Spessore dell'evidenziazione"
-#~ msgid "Surface"
-#~ msgstr "Superficie"
+msgid "Surface"
+msgstr "Superficie"
 #, fuzzy
-#~ msgid "Volume"
-#~ msgstr "colonne: %d"
+msgid "Volume"
+msgstr "colonne: %d"
 #, fuzzy
-#~ msgid "Layer where to add column"
+msgid "Layer where to add column"
 #, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
+msgid "Unable to read symbol, unable todisplay points"
-#~ msgid "Raster value"
-#~ msgstr "Valore del raster"
+msgid "Raster value"
+msgstr "Valore del raster"
-#~ msgid "Exporting %i points/lines..."
-#~ msgstr "Esportando %i punti/linee..."
+msgid "Exporting %i points/lines..."
+msgstr "Esportando %i punti/linee..."
 #, fuzzy
-#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "Importa mappe vettoriali Mapgen o Matlab-ASCII in GRASS"
+msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr "Importa mappe vettoriali Mapgen o Matlab-ASCII in GRASS"
-#~ msgid "Raster File Series to MPEG Conversion Program."
-#~ msgstr "Programma di conversione per serie di file raster in MPEG"
+msgid "Raster File Series to MPEG Conversion Program."
+msgstr "Programma di conversione per serie di file raster in MPEG"
-#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
-#~ msgstr "Calcola la regressione lineare per due raster: y = a + b*x"
+msgid "Calculates linear regression from two raster maps: y = a + b*x"
+msgstr "Calcola la regressione lineare per due raster: y = a + b*x"
-#~ msgid ""
-#~ "Sediment transport and erosion/deposition simulation using path sampling "
-#~ "method (SIMWE)"
-#~ msgstr ""
-#~ "Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando "
-#~ "il metodo path sampling (SIMWE)"
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
+msgstr "Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il metodo path sampling (SIMWE)"
-#~ msgid ""
-#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-#~ msgstr ""
-#~ "Simulazione del ruscellamento superficiale usando il metodo path sampling "
-#~ "(SIMWE)"
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr "Simulazione del ruscellamento superficiale usando il metodo path sampling (SIMWE)"
 #, fuzzy
+msgid ""
+"\n"
+"ERROR: Required parameter <%s> not set:\n"
+"    (%s).\n"
+msgstr ""
+"\n"
+"ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
+"    (%s).\n"
+#, fuzzy
+msgid "Band to select"
+msgstr "Nessun monitor selezionato"
+#, fuzzy
+#~ msgid "Cannot open file [%s] in mapset [%s]"
+#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+#, fuzzy
+#~ msgid "Cannot create file <%s> in mapset <%s>"
+#, fuzzy
+#~ msgid "input"
+#~ msgstr "Input"
+#, fuzzy
+#~ msgid "output"
+#~ msgstr "Output"
+#, fuzzy
+#~ msgid "basemap"
+#~ msgstr "Rimuove le mappe di base"
+#, fuzzy
+#~ msgid "method"
+#~ msgstr "Metodo sconosciuto"
+#, fuzzy
 #~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr ""
-#~ "Esportazione in corso del raster come valori a precisione doppia (double) "
-#~ "(bytes=%d)"
+#~ msgstr "Esportazione in corso del raster come valori a precisione doppia (double) (bytes=%d)"
 #, fuzzy
 #~ msgid "Reading map"
 #~ msgstr "Lettura della mappa"
 #~ msgid "Signed data (high bit means negative value)"
-#~ msgstr ""
-#~ "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
+#~ msgstr "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
 #~ msgid "Number of bytes per cell (1, 2, 4)"
 #~ msgstr "Numero di byte per cella (1, 2, 4)"
@@ -36242,23 +34628,10 @@
 #~ msgid "Unable to calculate centroid for area %d"
 #~ msgstr "Non è possibile calcolare il centroide per l'area %d"
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "    (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
-#~ "    (%s).\n"
-#, fuzzy
 #~ msgid "Cannot set GRASS_VERBOSE variable."
 #~ msgstr "Impossibile impostare la variabile GRASS_VERBOSE."
@@ -36266,11 +34639,9 @@
 #~ msgid "Reading raster map <%s in %s> ..."
 #~ msgstr "Lettura della mappa raster <%s in %s> in corso ..."
-#, fuzzy
 #~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "La mappa raster di input rettificata <%s> verrà salvata come <%s>"
+#~ msgstr "Il raster di input rettificata <%s> verrà salvata come <%s>"
-#, fuzzy
 #~ msgid "Target location <%s> not found\n"
 #~ msgstr "Location di destinazione <%s> non trovata\n"
@@ -36303,12 +34674,8 @@
 #, fuzzy
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-#~ "nel monitor grafico dell'utente."
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
 #, fuzzy
 #~ msgid "Raster map to be displayed"
@@ -36316,9 +34683,7 @@
 #, fuzzy
 #~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr ""
 #, fuzzy
 #~ msgid "vector, projection"
@@ -36367,14 +34732,8 @@
 #~ msgid "Failed in attempt to open %s"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Genera raster della pendenza, esposizione, curvature e le derivate "
-#~ "parziali da un raster con valori dell'elevazione. Esposizione è calcolata "
-#~ "in senso antiorario partendo dall'est."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione. Esposizione è calcolata in senso antiorario partendo dall'est."
 #, fuzzy
 #~ msgid "Output slope filename"
@@ -36436,9 +34795,7 @@
 #~ msgstr "                Nessuna topologia presente"
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Usa un vettoriale di punti per produrre un vettoriale di poligoni "
-#~ "convessi."
+#~ msgstr "Usa un vettoriale di punti per produrre un vettoriale di poligoni convessi."
 #, fuzzy
 #~ msgid "Name of input vector points map"
@@ -36494,7 +34851,6 @@
 #~ msgid "Cannot allocate %d bytes of memory"
 #~ msgstr "Impossibile allocare % byte di memoria"
-#, fuzzy
 #~ msgid "Raster map to use as MASK"
 #~ msgstr "Mappa raster da usare come MASK"
@@ -36518,13 +34874,11 @@
 #, fuzzy
 #~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr ""
-#~ "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
 #, fuzzy
 #~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr ""
-#~ "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
 #, fuzzy
 #~ msgid "Name of the Mannings n raster map"
@@ -36540,8 +34894,7 @@
 #, fuzzy
 #~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr ""
-#~ "Mappa raster di output della concentrazione di sedimenti [parcicelle/m3]"
+#~ msgstr "Mappa raster di output della concentrazione di sedimenti [parcicelle/m3]"
 #, fuzzy
 #~ msgid "Output sediment flux raster map [kg/ms]"
@@ -36553,21 +34906,15 @@
 #, fuzzy
 #~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr ""
-#~ "Nome della mappa raster del tasso di pioggia eccedente (intensità di "
-#~ "pioggia - velocità di infiltrazione) [mm/h]"
+#~ msgstr "Nome della mappa raster del tasso di pioggia eccedente (intensità di pioggia - velocità di infiltrazione) [mm/h]"
 #, fuzzy
 #~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr ""
-#~ "Nome della mappa raster della velocità di infiltrazione del deflusso "
-#~ "superficiale [mm/h]"
+#~ msgstr "Nome della mappa raster della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #, fuzzy
 #~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr ""
-#~ "Nome della mappa raster delle strutture per il controllo del flusso "
-#~ "(coeff. di permeabilità 0-1)"
+#~ msgstr "Nome della mappa raster delle strutture per il controllo del flusso (coeff. di permeabilità 0-1)"
 #, fuzzy
 #~ msgid "Output water discharge raster map [m3/s]"
@@ -36592,12 +34939,8 @@
 #~ msgid "Name of elevation raster map"
 #~ msgstr "Nome della mappa raster dell'elevazione"
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Crea un nuovo layer dove i valori delle categorie sono basati sulla "
-#~ "riclassificazione delle categorie esistenti in un altro raster"
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Crea un nuovo layer dove i valori delle categorie sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #~ msgid "Converts a raster map into a vector map layer."
 #~ msgstr "Converte un raster in un vettore"
@@ -36609,20 +34952,14 @@
 #~ msgid "raster, terrain analysis"
 #~ msgstr "Nome della mappa raster da utilizzare per <%s>"
-#~ msgid ""
-#~ "Threshold water depth [m] (diffusion increases after this water depth is "
-#~ "reached)"
-#~ msgstr ""
-#~ "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta "
-#~ "raggiuntaquesta altezza)"
+#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+#~ msgstr "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta raggiuntaquesta altezza)"
 #~ msgid "Watershed basin analysis program."
 #~ msgstr "Programma per l'analisi dei bacini idrografici."
 #~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr ""
-#~ "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza "
-#~ "della cella del raster"
+#~ msgstr "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza della cella del raster"
 #, fuzzy
 #~ msgid ""
@@ -36644,16 +34981,12 @@
 #~ msgstr "fp: l'intervallo di dati è da %.25f a %.25f\n"
 #, fuzzy
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
 #~ msgstr "Converte in uno dei formati vettoriali supportati da OGR"
 #, fuzzy
-#~ msgid ""
-#~ "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr ""
-#~ "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra "
-#~ "destra alto basso[margine])"
+#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
 #, fuzzy
 #~ msgid "PostScript output file"
@@ -36664,5 +34997,10 @@
 #~ msgstr "Lettura della mappa raster nel gruppo <%s> in corso ..."
 #, fuzzy
-#~ msgid "Band to select"
-#~ msgstr "Nessun monitor selezionato"
+#~ msgid ""
+#~ "ERROR: Required parameter <%s> not set:\n"
+#~ "\t(%s)\n"
+#~ msgstr ""
+#~ "\n"
+#~ "ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
+#~ "    (%s).\n"
