[GRASS-SVN] r47143 - in grass/trunk: display display/d.mon lib/cairodriver lib/htmldriver lib/init lib/pngdriver lib/psdriver
Sun Jul 17 15:16:57 EDT 2011
Author: martinl
Date: 2011-07-17 12:16:57 -0700 (Sun, 17 Jul 2011)
New Revision: 47143
   grass/trunk/display/Makefile
   grass/trunk/display/d.mon/d.mon.html
   grass/trunk/lib/cairodriver/cairodriver.html
   grass/trunk/lib/htmldriver/htmldriver.html
   grass/trunk/lib/init/variables.html
   grass/trunk/lib/pngdriver/pngdriver.html
   grass/trunk/lib/psdriver/psdriver.html
update display driver manual pages
Modified: grass/trunk/display/Makefile
--- grass/trunk/display/Makefile	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/display/Makefile	2011-07-17 19:16:57 UTC (rev 47143)
@@ -41,7 +41,4 @@
 include $(MODULE_TOPDIR)/include/Make/Dir.make
-default: parsubdirs $(HTMLDIR)/displaydrivers.html
-$(HTMLDIR)/displaydrivers.html: displaydrivers.html
-	$(INSTALL_DATA) $< $@
+default: parsubdirs
Modified: grass/trunk/display/d.mon/d.mon.html
--- grass/trunk/display/d.mon/d.mon.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/display/d.mon/d.mon.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -12,7 +12,7 @@
 of running monitors by setting the <b>-l</b> flag on the command
 line. Note that some monitor drivers use environment
 <em><a href="variables.html">variables</a></em> or the specific
-<em><a href="displaydrivers.html">driver documentation</a></em>.
+<em><a href="variables.html#rendering">driver documentation</a></em>.
 <p>
 When a monitor is <em>started</em>, it is therefore also
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/lib/cairodriver/cairodriver.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -9,149 +9,171 @@
 <img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2>
-<EM><B>Cairo driver</B></EM> - driver for bitmap or vector output using
-the Cairo graphics library.
-<BR>
-<EM>(drivers)</EM>
+<h2>NAME</h2>
+<em><b>Cairo driver</b></em> - display driver for bitmap or vector
+output using the Cairo graphics library.
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-The Cairo driver generates PNG, BMP, PPM, PS, PDF or SVG images from GRASS
-display commands, using the
-<A HREF="http://www.cairographics.org/">Cairo graphics library</A>.
+The Cairo driver generates PNG, BMP, PPM, PS, PDF or SVG images by
+GRASS display commands, using the
+<a href="http://www.cairographics.org/">Cairo graphics library</a>.
 The image format is selected from the extension of the output file.
-<P>
-It is started as 'pseudo' monitor (output to an image file) and when
-stopped, all output from previously used display commands are written to
-the output file.
+The Cairo driver is used for GRASS display commands by default if
+available, otherwise <em><a href="pngdriver.html">PNG driver</a></em>
+is used.
-<H2>USAGE</H2>
+<h2>USAGE</h2>
-<H3>Environment variables</H3>
+<h3>Environment variables</h3>
+The Cairo driver can be enabled by
+setting <b>GRASS_RENDER_IMMEDIATE</b> variable, eg.
+<div class="code"><pre>
+export GRASS_RENDER_IMMEDIATE=cairo
+</pre></div>
 Several environment variables affect the operation of the Cairo driver:
-<UL>
-  <LI><B>GRASS_RENDER_IMMEDIATE=[FALSE|TRUE|PNG|PS|HTML|cairo]</B><BR>
-     tells the raster library which driver to use. If
-     <tt>TRUE</tt>, the cairo driver is used if it is enabled, otherwise the PNG driver is used.
-  <LI><B>GRASS_WIDTH=xxx</B><BR>
-     the width of the image.
-  </LI>
-  <LI><B>GRASS_HEIGHT=yyy</B><BR>
-    the height of the image.
-  </LI>
-  <LI><B>GRASS_PNGFILE=filename</B><BR>
+<ul>
+  <li><b>GRASS_WIDTH=xxx</b><br>
+    the width of the image map (default is 640).
+  </li>
+  <li><b>GRASS_HEIGHT=yyy</b><br>
+    the height of the image map (default is 480).
+  </li>
+  <li><b>GRASS_BACKGROUNDCOLOR=RRGGBB</b><br>
+    specifies the background color to use in RGB notation (hex or
+    R:G:B values). Named colors are also supported. Default
+    is <b>FFFFFF</b> (white).
+  </li>
+  <li><b>GRASS_TRANSPARENT=[TRUE|FALSE]</b><br>
+    sets transparent background on (TRUE) or off (FALSE, default).
+  </li>
+  <li><b>GRASS_ANTIALIAS</b><br> can be <em>default</em>,
+    <em>none</em>, <em>gray</em>, or <em>subpixel</em>, corresponding to
+    <a href="http://www.cairographics.org/manual/cairo-cairo-t.html#cairo-antialias-t">cairo_antialias_t</a>
+  </li>
+  <li><b>GRASS_PNGFILE=filename</b><br>
      the name and format of the resulting image file, default is
-     <tt>map.png</tt>.<BR>
-     The image format is determined from the file extension.<BR>
+     <tt>map.png</tt>.<br>
+     The image format is determined from the file extension.<br>
      Supported bitmap formats:
-     <UL>
-       <LI><B>.png</B> - Portable Network Graphics (PNG)</LI>
-       <LI><B>.bmp</B> - Windows Bitmap (BMP, 32-bpp)
-           (these are not readable by some older viewers)</LI>
-       <LI><B>.ppm</B> - Portable Pixmap (PPM + PGM for alpha channel)</LI>
-     </UL>
+     <ul>
+       <li><b>.png</b> - Portable Network Graphics (PNG)</li>
+       <li><b>.bmp</b> - Windows Bitmap (BMP, 32-bpp)
+           (these are not readable by some older viewers)</li>
+       <li><b>.ppm</b> - Portable Pixmap (PPM + PGM for alpha channel)</li>
+     </ul>
      Supported vector formats:
-     <UL>
-       <LI><B>.pdf</B> - Portable Document Format (PDF)</LI>
-       <LI><B>.ps</B> - PostScript (PS)</LI>
-       <LI><B>.svg</B> - Scalable Vector Graphics (SVG)</LI>
-     </UL>
+     <ul>
+       <li><b>.pdf</b> - Portable Document Format (PDF)</li>
+       <li><b>.ps</b> - PostScript (PS)</li>
+       <li><b>.svg</b> - Scalable Vector Graphics (SVG)</li>
+     </ul>
      (Note: Some formats may not be available, depending on your platform and
      the Cairo library that GRASS was built with.)
-  </LI>
-  <LI><B>GRASS_BACKGROUNDCOLOR=RRGGBB</B><BR>
-     specifies the background color to use in RGB
-    notation (hex values). Default is <b>FFFFFF</b> (white).
-  </LI>
-  <LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
-    sets transparent background on (TRUE) or off (FALSE, default).
-  </LI>
-  <LI><B>GRASS_PNG_READ</B><BR>
+  </li>
+  <li><b>GRASS_PNG_READ</b><br>
      if <tt>TRUE</tt>, the Cairo driver will initialize the image from
-    the contents of GRASS_PNGFILE.<BR>
-    (Note: This is only supported for bitmap formats)
-  </LI>
-  <LI><B>GRASS_PNG_MAPPED</B><BR>
+    the contents of GRASS_PNGFILE.<br>
+    (<em>Note: This is only supported for bitmap formats</em>)
+  </li>
+  <li><b>GRASS_PNG_MAPPED</b><br>
     if <tt>TRUE</tt>, the Cairo driver will map GRASS_PNGFILE as its framebuffer,
-    rather than using memory. This only works with BMP files.
-  </LI>
-  <LI><B>GRASS_ANTIALIAS</B><BR> can be <em>default</em>,
-    <em>none</em>, <em>gray</em>, or <em>subpixel</em>, corresponding to
-    <a href="http://www.cairographics.org/manual/cairo-cairo-t.html#cairo-antialias-t">cairo_antialias_t</a>
-  </LI>
-  <LI><B>GRASS_LINE_WIDTH</B><BR>
+    rather than using memory.<br>
+    (<em>Note: This only works with BMP files.</em>)
+  </li>
+<!-- used ?
+  <li><b>GRASS_LINE_WIDTH</b><br>
     the default line width.
-  </LI>
-  <LI><B>GRASS_TEXT_SIZE</B><BR>
+  </li>
+  <li><b>GRASS_TEXT_SIZE</b><br>
     the default text size.
-  </LI>
-  <LI><B>GRASS_FRAME</B><BR>
+  </li>
+  <li><b>GRASS_FRAME</b><br>
     contains 4 coordinates, <em>top,bottom,left,right</em>, defining the initial frame.
-  </LI>
-</UL>
+  </li>
+  <li><b>GRASS_CAIRO_SCREEN</b><br>
+    defines Cairo screen
+  </li>
+  <li><b>GRASS_CAIRO_VISUAL</b><br>
+    defines Cairo visual
+  </li>
+</ul>
-<H3>Examples</H3>
+<h3>Examples</h3>
 Example using the driver to generate a PNG file (bash-syntax):
-<div class="code"><PRE>
 export GRASS_WIDTH=800
 export GRASS_HEIGHT=800
-export GRASS_RENDER_IMMEDIATE=CAIRO
 export GRASS_PNG_READ=TRUE
-d.rast map=elevation.10m
+g.region rast=elevation
+d.rast map=elevation
 d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
-d.vect map=roads width=2
-</PRE></div>
+d.vect map=roadsmajor width=2
+</pre></div>
 Example using the driver to generate a PDF file (bash-syntax):
-export GRASS_PNGFILE=spearfish.pdf
+export GRASS_PNGFILE=nc_spm.pdf
-export GRASS_PNG_READ=TRUE
-d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
-</PRE></div>
+</pre></div>
-<H2>NOTES</H2>
+<h2>NOTES</h2>
 The driver is still in development. Enable it by specifying
-<CODE>--with-cairo</CODE> when configuring GRASS. This
+<code>--with-cairo</code> when configuring GRASS. This
 requires a reasonably recent version of the Cairo libraries
-and a working pkg-config.
+and a working <tt>pkg-config</tt>.
-<P>
+<p>
 Antialiasing is enabled by default for bitmap formats. There is
 currently no way of disabling this.
-<P>
+<p>
+The resolution of the output images is defined by current region
+extents. Use <tt>g.region -p</tt> to get the number of rows and cols
+and use the environment variables to set the image size. If you would
+like a larger image, multiply both rows and cols by the same whole
+number to preserve the aspect ratio.
+<p>
 Cairo supports true vector format output whenever possible. However,
 if the selected format doesn't support a necessary feature, Cairo may
 fall back on rendering a bitmap representation of the image wrapped in
 the selected vector format.
 <h2>SEE ALSO</h2>
-<EM>
-<a href="displaydrivers.html">Display drivers</a>
-<br>
-<A HREF="pngdriver.html">PNG driver</A>,
-<A HREF="psdriver.html">PostScript driver</A>,
-<BR>
-<A href="d.rast.html">d.rast</A>,
-<A href="d.vect.html">d.vect</A>
-</EM>
+<em>
+  <a href="pngdriver.html">PNG driver</a>,
+  <a href="psdriver.html">PS driver</a>,
+  <a href="htmldriver.html">HTML driver</a>,
+  <a href="variables.html">variables</a>
+  <br><br>
+  <a href="d.rast.html">d.rast</a>,
+  <a href="d.vect.html">d.vect</a>,
+  <a href="d.mon.html">d.mon</a>,
+  <a href="d.erase.html">d.erase</a>,
+  <a href="d.redraw.html">d.redraw</a>
+</em>
-<H2>AUTHOR</H2>
-Lars Ahlzen &lt;<I>lars (at) ahlzen.com</I>&gt;<BR>
+<h2>AUTHOR</h2>
+Lars Ahlzen &lt;<i>lars (at) ahlzen.com</i>&gt;<br>
 and the GRASS Development Team.
Modified: grass/trunk/lib/htmldriver/htmldriver.html
--- grass/trunk/lib/htmldriver/htmldriver.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/lib/htmldriver/htmldriver.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -1,7 +1,7 @@
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
 <HTML>
 <HEAD>
- <TITLE>HTMLMAP driver</TITLE>
+ <TITLE>HTML driver</TITLE>
  <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
  <link rel="stylesheet" href="grassdocs.css" type="text/css">
 </HEAD>
@@ -9,128 +9,144 @@
-<H2>NAME</H2>
+<h2>NAME</h2>
-<EM><B>HTMLMAP driver</B></EM> - driver to create HTML image maps.
-<BR><EM>(drivers)</EM>
+<em><b>HTML driver</b></em> - display driver to create HTML image maps.
-The HTMLMAP driver allows the generation of HTML image maps
-for area vector data. HTML image maps are used in conjunction with images to
-provide unique URL targets for different portions of an image. The HTMLMAP
-driver can create both client-side image maps embedded into HTML files, or
-server-side image maps used by web server software.
-<P>
-Note that GRASS display commands that require the MOUSE will not work
-correctly (or at all!)
-<P>
-Polygons can at most have 100 vertices (this limit imposed by HTML image map
-formats, see <B>GRASS_HTMLMAXPOINTS</B> below.) The driver will attempt to
-trim polygons that have more that 100
-vertices by removing vertices with the least amount of angle to the next
-vertice. Also, any polygon that is entirely bounded by another polygon will be
-discarded.
-<P>
-Text written to the driver before polygons are used as the HREF tag for all
-subsequent polygons written. All polygons that exist in a vector map will have
-the same HREF tag.
-<P>
-The only GRASS display commands that should be used with this driver are:
-<UL>
-  <LI><a href="d.text.html">d.text</A>
-  - pass href information for resulting image maps.</LI>
-  <LI><a href="d.vect.html">d.vect</A>
-  - draw polygons from a vector map.</LI>
-</UL>
+The HTML driver allows the generation of HTML image maps for area
+vector data. HTML image maps are used in conjunction with images to
+provide unique URL targets for different portions of an image. The
+HTML driver can create both client-side image maps embedded into HTML
+files, or server-side image maps used by web server software.
-<H2>USAGE</H2>
+<p>
+Polygons can at most have 100 vertices (this limit imposed by HTML
+image map formats, see <b>GRASS_HTMLMAXPOINTS</b> below.) The driver
+will attempt to trim polygons that have more that 100 vertices by
+removing vertices with the least amount of angle to the next
+vertice. Also, any polygon that is entirely bounded by another polygon
+will be discarded.
-<H3>Environment variables</H3>Several environment variables effect the operation
-of HTMLMAP.
+<p>
+Text written to the driver before polygons are used as the HREF tag
+for all subsequent polygons written. All polygons that exist in a
+vector map will have the same HREF tag.
-<UL>
-  <LI><B>GRASS_WIDTH=xxx</B><BR>the width of the image map (default is
-    640).
-  </LI>
-  <LI><B>GRASS_HEIGHT=yyy</B><BR>the height of the image map (default is
-    480).
-  </LI>
-  <LI><B>GRASS_HTMLTYPE=type</B><BR>the type of image mape to create (default is
-    CLIENT):
-    <DL>
-      <DD><TT><B>CLIENT</B></TT> &nbsp;&nbsp; Netscape/IE client-side image map.
-	(NAME="map")<BR>
-      <DD><TT><B>APACHE</B></TT> &nbsp;&nbsp; Apache/NCSA server-side image
-	map.<BR>
-      <DD><TT><B>RAW</B></TT> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Raw url
-	and polygon vertices ( <I>url&nbsp; x1&nbsp; y1&nbsp; x2&nbsp; y2&nbsp;
-	  ..... </I>), suitable for conversion to CERN server format, or any other
-	format with user supplied conversion program.</DD>
-    </DL>
-  </LI>
-  <LI><B>GRASS_HTMLFILE=filename</B><BR>
-    specifies the resulting file to store
-    the html image map, default is <tt>htmlmap</tt>. Files without absolute path
-    names are written in the current directory where the driver was started.
-    <BR>
-    <em>Any existing file of the same name is overwritten without
+<p>
+The only GRASS display commands that should be used with this driver
+are:
+<ul>
+  <li><em><a href="d.text.html">d.text</a></em> - pass href
+  information for resulting image maps.</li>
+  <li><em><a href="d.vect.html">d.vect</a></em> - draw polygons from a
+  vector map.</li>
+</ul>
+<h2>USAGE</h2>
+The HTML driver can be enabled by
+export GRASS_RENDER_IMMEDIATE=html
+</pre></div>
+Several environment variables effect the operation of the HTML driver:
+<ul>
+  </li>
+  </li>
+  <li><b>GRASS_HTMLTYPE=type</b><br> type of image mape to create
+    (default is CLIENT):
+    <dl>
+      <dd><tt><b>CLIENT</b></tt> &nbsp;&nbsp; Netscape/IE client-side
+	image map (NAME="map").</dd>
+      <dd><tt><b>APACHE</b></tt> &nbsp;&nbsp; Apache/NCSA server-side image
+	map.</dd>
+      <dd><tt><b>RAW</b></tt>
+	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Raw url and polygon
+	vertices (<i>url&nbsp; x1&nbsp; y1&nbsp; x2&nbsp; y2&nbsp;
+	.....</i>), suitable for conversion to CERN server format, or
+	any other format with user supplied conversion program.</dd>
+    </dl>
+  </li>
+  <li><b>GRASS_HTMLFILE=filename</b><br>
+    specifies the resulting file to store the html image map, default
+    is <tt>htmlmap</tt>. Files without absolute path names are written
+    in the current directory where the driver was started.
+    <br>
+    <em>Any existing file of the same name is overwritten without
       warning.</em>
-  </LI>
-  <LI><B>GRASS_HTMLMINDIST=n</B><BR>specifies the minimum distance in pixels
-  that a point must change from the previous point to keep in the list of
-  vertices for a polygon.  The default is <tt>2</tt>, which means that a
-  point's x and y difference from the previous point must change by a number
-  of pixels greater than this value.  This parameter helps to eliminate
-  closely spaced points.
-  </LI>
-  <LI><B>GRASS_HTMLMINBBOX=n</B><BR>specifies the minimum bounding box
-  dimensions to record a polygon as a clickable area.
-  The default is <tt>2</tt>, which means that a polygon with a bounding box
-  of less than this value is not included. This parameter helps to eliminate
-  polygons than are a point or line.
-  </LI>
-  <LI><B>GRASS_HTMLMAXPOINTS=n</B><BR>specifies the maximum number of
-  vertices included in a polygon's clickable area.
-  The default is <tt>99</tt>.  Some browsers can only accommodate polygons of
-  100 vertices or less.  The HTMLMAP driver automatically ensures that a
-  polygon is closed by making the last point the same as the first
-  point.</LI>
-</UL>
+  </li>
+  <li><b>GRASS_HTMLMINDIST=n</b><br>
+    specifies the minimum distance in pixels that a point must change
+    from the previous point to keep in the list of vertices for a
+    polygon.  The default is <tt>2</tt>, which means that a point's x
+    and y difference from the previous point must change by a number
+    of pixels greater than this value.  This parameter helps to
+    eliminate closely spaced points.
+  </li>
+  <li><b>GRASS_HTMLMINBBOX=n</b><br>
+    specifies the minimum bounding box dimensions to record a polygon
+    as a clickable area.  The default is <tt>2</tt>, which means that a
+    polygon with a bounding box of less than this value is not
+    included. This parameter helps to eliminate polygons than are a
+    point or line.
+  </li>
+  <li><b>GRASS_HTMLMAXPOINTS=n</b><br>
+    specifies the maximum number of vertices included in a polygon's
+    clickable area.  The default is <tt>99</tt>. Some browsers can only
+    accommodate polygons of 100 vertices or less. The HTMLMAP driver
+    automatically ensures that a polygon is closed by making the last
+    point the same as the first point.</li>
+</ul>
-<H3>Typical usage</H3>
-<UL>
-  <LI>Start up the driver
-<DIV class="code"><PRE>
-d.mon start=HTMLMAP
-</PRE></DIV>
-  </LI>
-  <LI>Display text strings (HREF's) and polygons
+<h3>Example</h3>
+Start up the driver
+d.mon start=html
+</pre></div>
+Display text strings (HREF's) and polygons
 echo "http://www.no-such-place.net/area51/" | d.text
 d.vect map=area51
 echo "http://www.roswell-nm.net/little/green/men.html" | d.text
 d.vect map=roswell
-</PRE></div>
-  <LI>Stop the driver when all polygon have been displayed. This will cause a file
-    named 'htmlmap' to be created in your current directory.
-d.mon stop=HTMLMAP
-</PRE></DIV>
-  <LI>You will also want to create an image for your image map. Use the PNG
-    driver and other utilities to create .gif or .jpg files.
-    <i>The following example is somewhat out of date and refers to options
-      available in GRASS 5.</i>
+</pre></div>
+Stop the driver when all polygon have been displayed. This will cause
+a file named 'htmlmap' to be created in your current directory.
+d.mon stop=html
+</pre></div>
+You will also want to create an image for your image map. Use the PNG
+driver and other utilities to create .gif or .jpg files.
+<i>The following example is somewhat out of date and refers to options
+  available in GRASS 5.</i>
 # using previous GRASS_WIDTH &amp; GRASS_HEIGHT
-d.mon start=PNG
-d.mon select=PNG
+d.mon start=png
 d.rast map=terrain
 d.vect map=area51  fillcolor=white  linecolor=blue
 d.vect map=roswell fillcolor=yellow linecolor=blue
 d.vect map=states  color=green
 d.vect map=roads   color=black
-d.mon stop=PNG
+d.mon stop=png
 <!-- ????  FIXME -->
 # make the region the same as the newly created cell for ppm export
 g.region save=saved.reg
@@ -150,41 +166,45 @@
 # take a look and test it out
 netscape file:`pwd`/alien.html &amp;
-</PRE></DIV>
-  </LI>
-</UL>
+</pre></div>
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-HTMLMAP was adapted from the CELL driver in GRASS 4.3.
-Point-in-polygon test code was lifted from Randolph Franklin's web page, see
-<UL>
-  <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/">http://www.ecse.rpi.edu/Homepages/wrf/</A></LI>
-  <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html">http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html</A></LI>
-</UL>
+HTML was adapted from the CELL driver in GRASS 4.3.
+Point-in-polygon test code was lifted from Randolph Franklin's web
+page, see
-<P>
-If you create an HTML file with two or more images and image maps, you will
-need to edit the map names. The HTMLMAP driver creates its map with the name
+<ul>
+  <li><a href="http://www.ecse.rpi.edu/Homepages/wrf/">http://www.ecse.rpi.edu/Homepages/wrf/</a>
+  </li>
+  <li><a href="http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html">http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html</a>
+  </li>
+</ul>
+<p>
+If you create an HTML file with two or more images and image maps, you
+will need to edit the map names. The HTML driver creates its map
+with the name
 <tt>map</tt>. A small sed script can easily change the map name:
-<PRE>
+<pre>
   sed -e 's/NAME="map"/NAME="foomap"/' &lt; htmlmap &gt; foomap.html
-</PRE>
+</pre>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM>
-  <a href="displaydrivers.html">Display drivers</a>
-  <br>
-  <a href="pngdriver.html">PNG driver</A>,
-  <a href="psdriver.html">PostScript driver</A>,
-  <a href="xdriver.html">XDRIVER</A>
-  <BR>
-  <A href="d.mon.html">d.mon</A>,
-  <a href="d.text.html">d.text</A>,
-  <a href="d.vect.html">d.vect</A>
-</EM>
+<em>
+  <a href="cairodriver.html">Cairo driver</a>,
+  <br><br>
+</em>
 <p>
 <i>Last changed: $Date$</i>
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/lib/init/variables.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -23,27 +23,17 @@
 There are a number of <i>shell</i> environment variable groups:
 <ul>
-<li><a href="#cairo">Cairo driver</a></li>
-<li><a href="#png">PNG driver</a></li>
-<li><a href="#ps">PS driver (PostScript)</a></li>
-<li><a href="#html">HTMLMAP driver</a></li>
-<li><a href="#dirrend">variables for direct rendering</a></li>
+<li><a href="#rendering">variables for rendering</a></li>
 <li><a href="#internal">variables for internal use</a></li>
 </ul>
-Any setting which needs to be modifiable by a GRASS program (e.g. MONITOR)
-has to be a GRASS <i>gisenv</i> variable.
+<i>Note:</i> Any setting which needs to be modifiable by a GRASS module
+(e.g. MONITOR by <em><a href="d.mon.html">d.mon</a></em>) has to be a GRASS
+gisenv variable.
+<h2>Setting shell environment variables</h2>
-<h2>GRASS-related Files</h2>
-GRASS maintains some settings in a number of files on the system. They are
-detailed <a href="#files">below</a>.
-<h2>Setting environment variables</h2>
-Setting environment variables depends on the shell being used:
+Setting shell environment variables depends on the shell being used:
 <br><br>
 Bash:
@@ -58,7 +48,7 @@
 set VARIABLE=value
 </pre></div>
-<h2>Setting environment variables permanently</h2>
+To set up shell environment variables permanently:
 <ul>
 <li>
@@ -72,7 +62,7 @@
 </ul>
-<h2>Setting GRASS variables</h2>
+<h2>Setting GRASS gisenv variables</h2>
 Use <em><a href="g.gisenv.html">g.gisenv</a></em> within GRASS. This permanently
 predefines GRASS variables in the <tt>.grass7/rc</tt> file.
@@ -88,12 +78,12 @@
 If the user just specifies a variable name, it defaults to <b>get</b> mode.
 For example:
-g.gisenv GRASS_GUI
-text
+g.gisenv MAPSET
+PERMANENT
 </pre></div>
 <a name="enviro"></a>
-<h2>List of selected (GRASS related) environment variables</h2>
+<h2>List of selected (GRASS related) shell environment variables</h2>
 <blockquote>
 [ To be set from the terminal shell or startup scripts ]
@@ -110,9 +100,9 @@
     while in a GRASS session.</dd>
   <dt>GRASS_ADDON_PATH</dt>
-  <dd>[grass startup script]<br>
-    allows to specify additional paths to local GRASS modules extra
-    to standard distribution. The default on GNU/Linux is $HOME/.grass7/addons</dd>
+  <dd>[grass startup script]<br> allows to specify additional paths to
+    local GRASS modules extra to standard distribution. The default on
+    GNU/Linux is <tt>$HOME/.grass7/addons</tt>.</dd>
   <dt>GRASS_ADDON_ETC</dt>
   <dd>[libgis, g.findetc]<br>
@@ -120,22 +110,35 @@
     standard distribution.</dd>
   <dt>GRASS_BATCH_JOB</dt>
-  <dd>defines the name (path) of a shell script to be processed as batch job.</dd>
+  <dd>defines the name (path) of a shell script to be processed as
+  batch job.</dd>
   <dt>GIS_ERROR_LOG</dt>
-  <dd>If set, $GIS_ERROR_LOG should be the absolute path to the log file (a
-   relative path will be interpreted relative to the process' cwd, not
-   the cwd at the point the user set the variable). If not set,
-   $HOME/GIS_ERROR_LOG is used instead. The file will only be used if
-   it already exists.</dd>
+  <dd>If set, GIS_ERROR_LOG should be the absolute path to the log
+   file (a relative path will be interpreted relative to the process'
+   cwd, not the cwd at the point the user set the variable). If not
+   set, <tt>$HOME/GIS_ERROR_LOG</tt> is used instead. The file will
+   only be used if it already exists.</dd>
   <dt>GRASS_ERROR_MAIL</dt>
   <dd>set to any value to send user mail on an error or warning that
     happens while stderr is being redirected.</dd>
+  <dt>GRASS_FONT</dt>
+  <dd>[display drivers]<br>
+    specifies the font as either the name of a font from
+    <tt>$GISBASE/etc/fontcap</tt> (or alternative fontcap file
+    specified by GRASS_FONT_CAP), or alternatively the full path to a
+    FreeType font file.</dd>
+  <dt>GRASS_ENCODING</dt>
+    the encoding to be assumed for text which is drawn using a
+    freetype font; may be any encoding know to <em>iconv</em>.</dd>
   <dt>GRASS_FONT_CAP</dt>
   <dd>[g.mkfontcap, d.font, display drivers]<br>
-    specifies an alternative location (to $GISBASE/etc/fontcap) for
+    specifies an alternative location (to <tt>$GISBASE/etc/fontcap</tt>) for
     the font configuration file.</dd>
   <dt>GRASS_GNUPLOT</dt>
@@ -144,44 +147,39 @@
   <dt>GRASS_GUI</dt>
   <dd>either <tt>text</tt> or <tt>gui</tt> to define non-/graphical startup.
-    <br><br>
-    Can also specify the name of the GUI to use, e.g. <tt>wxpython</tt>
+    <br><br> Can also specify the name of the GUI to use,
+    e.g. <tt>wxpython</tt>
     (<em><a href="wxGUI.html">wxGUI</a></em>). Also exists as a GRASS
-    gisenv variable (see below). If this shell variable exists at GRASS
-    startup, it will determine the GUI used. If it is not defined startup
-    will default to the last GUI used.</dd>
+    gisenv variable (see below). If this shell variable exists at
+    GRASS startup, it will determine the GUI used. If it is not
+    defined startup will default to the last GUI used.</dd>
-  <dt>GRASS_HEIGHT</dt>
-  <dd>[d.mon]<br>
-    defines the height of GRASS monitor, see also GRASS_WIDTH.</dd>
   <dt>GRASS_HTML_BROWSER</dt>
-  <dd>[init.sh, wxgui]<br>
-    defines name of HTML browser. For most platforms this should be
-    an executable in your PATH, or the full path to an executable.<br>
-    Mac OS X runs applications differently from the CLI.
-    Therefore, GRASS_HTML_BROWSER should be the application's signature,
-    which is a domain-like name, just reversed, i.e. com.apple.Safari. To
-    find an application's signature, type the following in a Terminal
-    (fill in the path to the application you are interested in, for
-    example: /Applications/Safari.app):<br> &nbsp; &nbsp; <code>grep -A 1
-      &quot;CFBundleIdentifier&quot;</code> <i>/path/to/application.app</i><code>/Contents/Info.plist</code><br>
-    &nbsp; The signature is the &lt;string&gt; following the &lt;key&gt;,
-    without the bracketing &lt;string&gt; tags.</dd>
+  <dd>[init.sh, wxgui]<br> defines name of HTML browser. For most
+    platforms this should be an executable in your PATH, or the full
+    path to an executable.<br>  Mac OS X runs applications differently
+    from the CLI.  Therefore, GRASS_HTML_BROWSER should be the
+    application's signature, which is a domain-like name, just
+    reversed, i.e. com.apple.Safari. To find an application's
+    signature, type the following in a Terminal (fill in the path to
+    the application you are interested in, for example:
+    /Applications/Safari.app):<br> &nbsp; &nbsp; <code>grep -A 1
+    &quot;CFBundleIdentifier&quot;</code> <i>/path/to/application.app</i><code>/Contents/Info.plist</code><br>
+    &nbsp; The signature is the &lt;string&gt; following the
+    &lt;key&gt;, without the bracketing &lt;string&gt; tags.</dd>
   <dt>GRASS_INT_ZLIB</dt>
-  <dd>[libgis]<br>
-    if the environment variable GRASS_INT_ZLIB exists, new compressed
-    rasters will be compressed using zlib instead of RLE
-    compression. Such rasters will have a <tt>compressed</tt> value of 2 in the
-    cellhd file.
+  <dd>[libgis]<br> if the environment variable GRASS_INT_ZLIB exists,
+    new compressed rasters will be compressed using zlib instead of
+    RLE compression. Such rasters will have a <tt>compressed</tt>
+    value of 2 in the cellhd file.
     <br><br>
     Obviously, decompression is controlled by the
     raster's <tt>compressed</tt> value, not the environment variable.</dd>
   <dt>GRASS_MESSAGE_FORMAT</dt>
-  <dd>[various modules, wxGUI]<br>
-    maybe set to either
+  <dd>[various modules, wxGUI]<br> maybe set to either
     <ul>
       <li><tt>standard</tt> - sets percentage output and message
 	formatting style to standard formatting,</li>
@@ -195,11 +193,12 @@
   </ul></dd>
   <dt>GRASS_MOUSE_BUTTON</dt>
-  <dd>[various modules]<br>
-    swaps mouse buttons for two-button or left-handed mice. Its value
-    has three digits 1, 2, and 3, which represent default left, middle, and right
-    buttons respectively. Setting to <tt>132</tt> will swap middle and right buttons. Note
-    that this variable should be set before a display driver is initialized (e.g.,
+  <dd>[various modules]<br> swaps mouse buttons for two-button or
+    left-handed mice. Its value has three digits 1, 2, and 3, which
+    represent default left, middle, and right buttons
+    respectively. Setting to <tt>132</tt> will swap middle and right
+    buttons. Note that this variable should be set before a display
+    driver is initialized (e.g.,
     <tt>d.mon x0</tt>).</dd>
   <dt>GRASS_PAGER</dt>
@@ -261,11 +260,7 @@
   <dt>GRASS_VERSION</dt>
   <dd>reports the current version number (used by R-stats interface etc);
     should not be changed by user.</dd>
-  <dt>GRASS_WIDTH</dt>
-  <dd>[d.mon]<br>
-    defines the width of GRASS monitor, see also GRASS_HEIGHT.</dd>
   <dt>GRASS_NO_GLX_PBUFFERS</dt>
   <dd>[nviz]<br>
     set to any value to disable the use of GLX Pbuffers.</dd>
@@ -275,72 +270,35 @@
     Set to any value to disable the use of GLX Pixmaps.</dd>
 </dl>
-<a name="cairo"></a>
-<h3>List of selected GRASS Cairo driver environment variables</h3>
+<a name="rendering"></a>
+<h3>List of selected GRASS environment variables for rendering</h3>
 <blockquote>
-[ These variables control the function of the Cairo driver. ]
+[ In addition to those which are understood by specific <em>GRASS display
+ drivers</em>, the following variables affect rendering. ]
 </blockquote>
-See <a href="cairodriver.html">Cairo driver</a> manual page for detailed
-list of the variables.
-<a name="png"></a>
-<h3>List of selected GRASS PNG driver environment variables</h3>
-<blockquote>
-[ These variables control the function of the PNG driver. ]
-</blockquote>
-See <a href="pngdriver.html">PNG driver</a> manual page for detailed
-<a name="ps"></a>
-<h3>List of selected GRASS PS driver environment variables</h3>
-<blockquote>
-[ These variables control the function of the PS driver. ]
-</blockquote>
-See <a href="psdriver.html">PS driver</a> manual page for detailed
-<a name="html"></a>
-<h3>List of selected HTMLMAP driver environment variables</h3>
-<blockquote>
-[ These variables control the function of the HTMLMAP driver. ]
-</blockquote>
-See <a href="htmldriver.html">HTMLMAP driver</a> manual page for
-detailed list of the variables.
-<a name="dirrend"></a>
-<h3>List of selected GRASS environment variables for direct rendering</h3>
-<blockquote>
-[ In addition to those which are understood by the
- <a href="pngdriver.html">PNG driver</a>, the following variables
- affect direct rendering. ]
-</blockquote>
 <dl>
   <dt>GRASS_RENDER_IMMEDIATE</dt>
-  <dd>tells the raster library to use its built-in PNG/PS driver rather
-    than connecting to an external monitor process using sockets. If
-    GRASS_RENDER_IMMEDIATE=TRUE is set, there is no need to run
-    <tt>d.mon&nbsp;start=PNG</tt>.</dd>
+  <dd>tells the display library which driver to use; possible
+  values: <em><a href="cairodriver.html">cairo</a></em>, <em><a href="pngdriver.html">png</a></em>, <em><a href="psdriver.html">ps</a></em>
+  or <em><a href="htmldriver.html">html</a></em></dd>
-  <dt>GRASS_FONT</dt>
-  <dd>specifies the font as either the name of a font from
-    $GISBASE/etc/fontcap (or alternative fontcap file specified by GRASS_FONT_CAP),
-    or alternatively the full path to a FreeType font file.</dd>
+  <dt>GRASS_WIDTH</dt>
+  <dd>defines the width of output image (default is 640).</dd>
-  <dt>GRASS_ENCODING</dt>
-  <dd>the encoding to be assumed for text which is drawn using a
-    freetype font; may be any encoding know to <em>iconv</em>.</dd>
+  <dt>GRASS_HEIGHT</dt>
+  <dd>defines the height of output image (default is 480).</dd>
 </dl>
+For specific driver-related variables see:
+<ul>
+  <li><em><a href="cairodriver.html">Cairo driver</a></em></li>
+  <li><em><a href="pngdriver.html">PNG driver</a></em></li>
+  <li><em><a href="psdriver.html">PS (Postscript) driver</a></em></li>
+  <li><em><a href="htmldriver.html">HTML driver</a></em></li>
+</ul>
 <a name="internal"></a>
 <h3>List of selected internal GRASS environment variables</h3>
 <blockquote>
@@ -460,30 +418,26 @@
     below will cause maps with identical names to be overwritten.</dd>
 </dl>
-<a name="files"></a>
 <dl>
-  <dt>$HOME/.grass7/rc</dt>
-  <dd>stores the GRASS variables (but not environment variables)</dd>
+  <dt><tt>$HOME/.grass7/rc</tt></dt>
+  <dd>stores the GRASS gisenv variables (not shell environment variables)</dd>
-  <dt>$HOME/.grasslogin7</dt>
+  <dt><tt>$HOME/.grass7/login</tt></dt>
   <dd>stores the DBMI passwords in this hidden file.
     Only the file owner can access this file.</dd>
-  <dt>$HOME/GIS_ERROR_LOG</dt>
+  <dt><tt>$HOME/GIS_ERROR_LOG</tt></dt>
   <dd>if this file exists then all GRASS error and warning messages are
     logged here. Applies to current user. To generate the file, use:
     <tt>touch $HOME/GIS_ERROR_LOG</tt><br>
    See also GIS_ERROR_LOG variable.</dd>
 </dl>
-<h3>SEE ALSO</h3>
+<h2>SEE ALSO</h2>
 <em>
-  <br>
   <a href="g.gisenv.html">g.gisenv</a>,
   <a href="g.parser.html">g.parser</a>
 </em>
@@ -496,7 +450,7 @@
 <p>
 <a href=index.html>Help Index</a>
 <p>
-&copy; 2008 <a href="http://grass.osgeo.org">GRASS Development Team</a>
+&copy; 2008-2011 <a href="http://grass.osgeo.org">GRASS Development Team</a>
 </body>
 </html>
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/lib/pngdriver/pngdriver.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -9,106 +9,131 @@
-<H2>NAME</H2>
-<EM><B> PNG driver</B></EM> - driver to create PNG and PPM images.
+<h2>NAME</h2>
+<em><b>PNG driver</b></em> - display driver to create PNG, PPM, or BMP images.
-The PNG driver generates PNG and PPM images from GRASS display commands.
-Per default PNG files are written with this driver. It is started as 'pseudo' monitor
-(image file instead) and when stopped, all output from previously used
-display commands are written to the PNG image file.
+The PNG driver generates PNG, PPM, or BMP images from GRASS display
+commands. Per default PNG files are written with this driver. This
+driver is used by default if <em><a href="cairodriver.html">Cairo
+driver</a></em> is not available.
-<H2>USAGE</H2>
+<h2>USAGE</h2>
-Several environment variables effect the operation
-of the PNG driver.
-<UL>
-     the width of the image map (default is 640).</LI>
-    the height of the image map (default is 480).</LI>
+The PNG driver can be enabled by setting <b>GRASS_RENDER_IMMEDIATE</b>
+variable, eg.
+export GRASS_RENDER_IMMEDIATE=png
+</pre></div>
+Several environment variables affect the operation of the PNG driver:
+<ul>
+  </li>
+  </li>
+  </li>
+  </li>
+  <li><b>GRASS_TRUECOLOR=[TRUE|FALSE]</b><br>
+    sets true-color support. Default is TRUE.
+  </li>
      the filename to put the resulting image in, default is <tt>map.png</tt>.
      If you set GRASS_PNGFILE to a filename which ends in ".ppm", a PPM
      file will be created (with alpha channel stored in a PGM image, if applicable).
      If you set GRASS_PNGFILE to a filename which ends in ".bmp", a 32-bpp
      BMP file will be created (these are not readable by some older viewers).
-     <br><br>
-     notation (hex values). Default is <b>000000</b> (black).<br><br>
-    sets transparent background on (TRUE) or off (FALSE, default).</LI>
-  <LI><B>GRASS_TRUECOLOR=[TRUE|FALSE]</B><BR>
-    sets true-color support. Default is TRUE</LI>
-  <LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
-    compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)</LI>
+  </li>
+  <li><b>GRASS_PNG_COMPRESSION=[0|1|9]</b><br>
+    compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)
+  </li>
      if <tt>TRUE</tt>, the PNG driver will initialize the image from
-     the contents of GRASS_PNGFILE.</LI>
-     if <tt>TRUE</tt>, the PNG driver will map GRASS_PNGFILE as its framebuffer,
-     rather than using memory. This only works with BMP files.</LI>
+  </li>
+    if <tt>TRUE</tt>, the PNG driver
+    will map GRASS_PNGFILE as its framebuffer, rather than using
+    memory. This only works with BMP files.
+  </li>
+  <!-- used ?
-  </LI>
+  </li>
-  </LI>
+  </li>
-  </LI>
-</UL>
+  </li>
+</ul>
-<H3>Example</H3>
+<h3>Example</h3>
-# Define driver settings (here: bash shell syntax)
-export GRASS_RENDER_IMMEDIATE=PNG
 export GRASS_TRUECOLOR=TRUE
-# Display raster map and vector polygons
-d.rast <i>somerastermap</i>
-d.vect <i>somevectormap</i> color=red
-</PRE></DIV>
+d.rast elevation
+d.vect roadsmajor color=red
+</pre></div>
 This writes a file named <tt>map.png</tt> in your current directory.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-The PNG driver uses the libpng (see the <a href="http://www.libpng.org/pub/png/">libpng</a>
-home page) and zlib (see the
+The PNG driver uses the libpng (see
+the <a href="http://www.libpng.org/pub/png/">libpng</a> home page) and
+zlib (see the
 <a href="http://www.zlib.net">zlib</a> home page), all which needs to
 be installed for the PNG driver to work (it's worth it).
 <p>
-The resolution of the <i>PNG</i> raster map is defined by the map
-extents. Use <em>g.region -p</em> to get the number of rows and cols and
-use the environment variables to set the PNG size. If you would like a
-larger image, multiply both rows and cols by the same whole number to
-preserve the aspect ratio.
 <p>
-Further PNG file processing (e.g. quantization to 1 bit for monochrome images)
-can be done with 'pnmquant' of the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
+Further PNG file processing (e.g. quantization to 1 bit for monochrome
+images) can be done with <tt>pnmquant</tt> of
+the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
 <h2>SEE ALSO</h2>
-<EM>
+<em>
+  <br><br>
+</em>
+<h2>AUTHOR</h2>
+Original version: Per Henrik Johansen &lt;<i>phj (at)
+norgit.no</i>&gt; <!-- broken link <I><a href="http://www.norgit.no">NORGIT AS</a></i> -->
 <br>
-<A HREF="cairodriver.html">CAIRO driver</A>,
-<BR>
-</EM>
-<H2>AUTHOR</H2>
-Original version: Per Henrik Johansen &lt;<I>phj (at) norgit.no</I>&gt; <I><a href="http://www.norgit.no">NORGIT AS</a></I>
-<BR>
 Rewritten by: Glynn Clements, 2003
 <p>
Modified: grass/trunk/lib/psdriver/psdriver.html
--- grass/trunk/lib/psdriver/psdriver.html	2011-07-17 16:36:10 UTC (rev 47142)
+++ grass/trunk/lib/psdriver/psdriver.html	2011-07-17 19:16:57 UTC (rev 47143)
@@ -9,99 +9,113 @@
-<H2>NAME</H2>
-<EM><B> PS driver</B></EM> - driver to create PostScript files.
+<h2>NAME</h2>
+<em><b>PS driver</b></em> - display driver to create PostScript files.
 The PS driver generates a PostScript file from GRASS display commands.
-The driver is started as 'pseudo' monitor (PS file instead) and when
-to the PostScript file.
-<H2>USAGE</H2>
-of the PS driver:
+<h2>USAGE</h2>
-<UL>
-  <LI><B>GRASS_PSFILE</B><BR>
+The PS driver can be enabled by setting <b>GRASS_RENDER_IMMEDIATE</b>
+variable, eg.
+export GRASS_RENDER_IMMEDIATE=ps
+</pre></div>
+Several environment variables effect the operation of the PS driver:
+<ul>
+  </li>
+  </li>
+    sets true-color support. Default is FALSE.
+  </li>
+  <li><b>GRASS_PSFILE</b><br>
     name of output file. If it ends with ".eps" an EPS file
-    will be created.</LI>
-  <LI><B>GRASS_PAPER</B><BR>
+    will be created.
+  </li>
+  <li><b>GRASS_PAPER</b><br>
     sets the screen dimensions and margins to
-    fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.</LI>
-  <LI><B>GRASS_WIDTH</B><BR>
-    defines the width of the screen, see also GRASS_HEIGHT</LI>
-  <LI><B>GRASS_HEIGHT</B><BR>
-    defines the height of the screen, see also GRASS_WIDTH</LI>
-  <LI><B>GRASS_TRUECOLOR</B><BR>
-    if <tt>TRUE</tt>, the PS driver generates color output, otherwise
-    monochrome.</LI>
-  <LI><B>GRASS_LANDSCAPE</B><BR>
+    fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.
+  </li>
+  <li><b>GRASS_LANDSCAPE</b><br>
     if <tt>TRUE</tt>, the screen is rotated 90 degrees
     counter-clockwise so that a "landscape" screen fits better on
-    "portrait" paper.</LI>
-  <LI><B>GRASS_PS_HEADER</B><BR>
+    "portrait" paper.
+  </li>
+  <li><b>GRASS_PS_HEADER</b><br>
     if <tt>FALSE</tt>, the output is appended to any existing file,
-    and no prolog or setup sections are generated.</LI>
-  <LI><B>GRASS_PS_TRAILER</B><BR>
-    if <tt>FALSE</tt>, no trailer section is generated.</LI>
+    and no prolog or setup sections are generated.
+  </li>
+  <li><b>GRASS_PS_TRAILER</b><br>
+    if <tt>FALSE</tt>, no trailer section is generated.
+  </li>
+  <!-- used ?
-  </LI>
+  </li>
-  </LI>
+  </li>
-  </LI>
-</UL>
+  </li>
+</ul>
-<H3>Example</H3>
+<h3>Example</h3>
-export GRASS_RENDER_IMMEDIATE=PS
-</PRE></DIV>
+d.rast elevation
+</pre></div>
 This writes a file named <tt>map.ps</tt> in your current directory.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
-The resolution of the <i>PS</i> raster map is defined by the map
-use the environment variables to set the PS size. If you would like a
-<P>
+The resolution of the output files is defined by current region
+<p>
 GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
-colorimage and setrgbcolor operators (this is the case for colour printers
-which pre-date level 2 PostScript).
+colorimage and setrgbcolor operators (this is the case for colour
+printers which pre-date level 2 PostScript).
 <p>
-Only masked images (<tt>d.rast -o</tt>, <tt>d.rgb -o</tt>, <tt>d.his
--n</tt>) require PostScript level 3.
+Masked images (<tt>d.rast</tt>, <tt>d.rgb</tt>, <tt>d.his -n</tt>)
+require PostScript level 3.
 <h2>SEE ALSO</h2>
-<EM>
-<br>
-<BR>
-</EM>
+<em>
+  <br><br>
+</em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
 Glynn Clements, 2007
