[GRASS-SVN] r47151 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Jul 18 04:04:28 EDT 2011
Author: martinl
Date: 2011-07-18 01:04:27 -0700 (Mon, 18 Jul 2011)
New Revision: 47151
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
wxGUI: clean up mapdisp::OnQuery()
(merge r47145 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2011-07-18 07:38:18 UTC (rev 47150)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2011-07-18 08:04:27 UTC (rev 47151)
@@ -1219,7 +1219,8 @@
def _OnQuery(self):
"""!Internal method used by OnQuery*() methods"""
- if self.toolbars['map'].GetAction() == 'displayAttrb':
+ if not self.IsStandalone() and \
+ self.toolbars['map'].GetAction() == 'displayAttrb':
# switch to output console to show query results
self._layerManager.notebook.SetSelectionByName('output')
@@ -1278,94 +1279,95 @@
self._OnQuery()
def QueryMap(self, x, y):
- """!Query map layer features
+ """!Query raster or vector map layers by r/v.what
- Currently only raster and vector map layers are supported.
@param x,y coordinates
- #set query snap distance for v.what at mapunit equivalent of 10 pixels
+ # set query snap distance for v.what at map unit equivalent of 10 pixels
qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
east, north = self.MapWindow.Pixel2Cell((x, y))
- num = 0
- for layer in self.tree.GetSelections():
- type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
- if type in ('raster', 'rgb', 'his',
- 'vector', 'thememap', 'themechart'):
- num += 1
+ if not self.IsStandalone():
+ num = 0
+ for layer in self.tree.GetSelections():
+ ltype = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
+ if ltype in ('raster', 'rgb', 'his',
+ 'vector', 'thememap', 'themechart'):
+ num += 1
+ if num < 1:
+ gcmd.GMessage(parent = self,
+ message = _('No raster or vector map layer selected for querying.'))
+ return
- if num < 1:
- dlg = wx.MessageDialog(parent = self,
- message = _('No raster or vector map layer selected for querying.'),
- caption = _('No map layer selected'),
- style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- dlg.ShowModal()
- dlg.Destroy()
- return
- mapname = None
- raststr = ''
- vectstr = ''
+ rast = list()
+ vect = list()
rcmd = ['r.what', '--v']
vcmd = ['v.what', '--v']
- dcmd = self.tree.GetPyData(layer)[0]['cmd']
- name, found = utils.GetLayerNameFromCmd(dcmd)
- if not found:
- continue
- if type in ('raster', 'rgb', 'his'):
- raststr += "%s," % name
- elif type in ('vector', 'thememap', 'themechart'):
- vectstr += "%s," % name
+ if self.IsStandalone():
+ pass
+ else:
+ dcmd = self.tree.GetPyData(layer)[0]['cmd']
+ name, found = utils.GetLayerNameFromCmd(dcmd)
+ if not found:
+ continue
+ if ltype is 'raster':
+ rast.append(name)
+ elif ltype in ('rgb', 'his'):
+ for iname in name.split('\n'):
+ rast.append(iname)
+ elif ltype in ('vector', 'thememap', 'themechart'):
+ vect.append(name)
# use display region settings instead of computation region settings
self.tmpreg = os.getenv("GRASS_REGION")
os.environ["GRASS_REGION"] = self.Map.SetRegion(windres = False)
# build query commands for any selected rasters and vectors
- if raststr != '':
+ if rast:
rcmd.append('-f')
- rcmd.append('input=%s' % raststr.rstrip(','))
+ rcmd.append('-n')
+ rcmd.append('input=%s' % ','.join(rast))
rcmd.append('east_north=%f,%f' % (float(east), float(north)))
- if vectstr != '':
+ if vect:
# check for vector maps open to be edited
digitToolbar = self.toolbars['vdigit']
if digitToolbar:
- map = digitToolbar.GetLayer().GetName()
- vect = []
- for vector in vectstr.split(','):
- if map == vector:
- self._layerManager.goutput.WriteWarning("Vector map <%s> "
- "opened for editing - skipped." % map)
- continue
- vect.append(vector)
- vectstr = ','.join(vect)
+ lmap = digitToolbar.GetLayer().GetName()
+ for name in vect:
+ if lmap == name:
+ self._layerManager.goutput.WriteWarning(_("Vector map <%s> "
+ "opened for editing - skipped.") % map)
+ vect.remove(name)
- if len(vectstr) <= 1:
- self._layerManager.goutput.WriteCmdLog("Nothing to query.")
+ if len(vect) < 1:
+ self._layerManager.goutput.WriteCmdLog(_("Nothing to query."))
return
vcmd.append('-a')
- vcmd.append('map=%s' % vectstr.rstrip(','))
+ vcmd.append('map=%s' % ','.join(vect))
vcmd.append('east_north=%f,%f' % (float(east), float(north)))
vcmd.append('distance=%f' % float(qdist))
+ Debug.msg(1, "QueryMap(): raster=%s vector=%s" % (','.join(rast),
+ ','.join(vect)))
# parse query command(s)
- if self._layerManager:
- if raststr:
+ if rast:
self._layerManager.goutput.RunCmd(rcmd,
compReg = False,
onDone = self._QueryMapDone)
- if vectstr:
+ if vect:
self._layerManager.goutput.RunCmd(vcmd,
else:
- if raststr:
+ if rast:
gcmd.RunCommand(rcmd)
- if vectstr:
+ if vect:
gcmd.RunCommand(vcmd)
def _QueryMapDone(self, cmd, returncode):
@@ -1469,7 +1471,7 @@
point = wx.GetMousePosition()
toolsmenu = wx.Menu()
# add items to the menu
if self.toolbars['nviz']:
raster = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
@@ -1493,12 +1495,13 @@
toolsmenu.AppendItem(display)
self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
numLayers = 0
- numLayers += 1
- if numLayers < 1:
+ if self.tree:
+ numLayers += 1
+ if not self.IsStandalone() and numLayers < 1:
display.Enable(False)
if action == "displayAttrb":
display.Check(True)
@@ -1513,7 +1516,7 @@
modify.Check(True)
- if self.tree.layer_selected:
+ if self.tree and self.tree.layer_selected:
mapLayer = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
if mapLayer.GetType() == 'vector' and \
mapLayer.GetMapset() == grass.gisenv()['MAPSET'] and \
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2011-07-18 07:38:18 UTC (rev 47150)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2011-07-18 08:04:27 UTC (rev 47151)
@@ -32,6 +32,7 @@
sys.path.append(compatPath)
import subprocess
import tempfile
+import types
import wx
from wx.lib.newevent import NewEvent
@@ -774,18 +775,18 @@
selected = []
- if type(l_type) == type(''):
+ if type(l_type) == types.StringType:
one_type = True
else:
one_type = False
if one_type and l_type == 'overlay':
- list = self.overlays
+ llist = self.overlays
else:
- list = self.layers
+ llist = self.layers
# ["raster", "vector", "wms", ... ]
- for layer in list:
+ for layer in llist:
# specified type only
if l_type != None:
if one_type and layer.type != l_type:
@@ -794,7 +795,7 @@
continue
# mapset
- if (l_mapset != None and type != 'overlay') and \
+ if (l_mapset != None and l_type != 'overlay') and \
layer.GetMapset() != l_mapset:
continue
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-07-18 07:38:18 UTC (rev 47150)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-07-18 08:04:27 UTC (rev 47151)
@@ -3,7 +3,7 @@
@brief Misc utilities for wxGUI
-(C) 2007-2009 by the GRASS Development Team
+(C) 2007-2009, 2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
