[GRASS-SVN] r47181 - in grass/trunk/lib: cairodriver init pngdriver
psdriver
svn_grass at osgeo.org
Mon Jul 18 17:14:12 EDT 2011
Author: martinl
Date: 2011-07-18 14:14:12 -0700 (Mon, 18 Jul 2011)
New Revision: 47181
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/init/variables.html
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/psdriver/psdriver.html
displaydriver: note GRASS_LINE_WIDTH, GRASS_TEXT_SIZE
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2011-07-18 21:04:51 UTC (rev 47180)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2011-07-18 21:14:12 UTC (rev 47181)
@@ -86,14 +86,6 @@
rather than using memory.<br>
(<em>Note: This only works with BMP files.</em>)
</li>
-<!-- used ?
- <li><b>GRASS_LINE_WIDTH</b><br>
- the default line width.
- </li>
- <li><b>GRASS_TEXT_SIZE</b><br>
- the default text size.
- </li>
<li><b>GRASS_CAIRO_SCREEN</b><br>
defines Cairo screen
</li>
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2011-07-18 21:04:51 UTC (rev 47180)
+++ grass/trunk/lib/init/variables.html 2011-07-18 21:14:12 UTC (rev 47181)
@@ -291,6 +291,13 @@
<dt>GRASS_FRAME</dt>
<dd>contains 4 coordinates, <em>top,bottom,left,right</em>, defining the initial frame.</dd>
+ <dt>GRASS_LINE_WIDTH</dt>
+ <dd>defines default line width.</dd>
+ <dt>GRASS_TEXT_SIZE</dt>
+ <dd>defines default text size.</dd>
</dl>
For specific driver-related variables see:
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html 2011-07-18 21:04:51 UTC (rev 47180)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2011-07-18 21:14:12 UTC (rev 47181)
@@ -69,14 +69,6 @@
will map GRASS_PNGFILE as its framebuffer, rather than using
memory. This only works with BMP files.
</li>
- <!-- used ?
- </li>
- </li>
</ul>
<h3>Example</h3>
Modified: grass/trunk/lib/psdriver/psdriver.html
--- grass/trunk/lib/psdriver/psdriver.html 2011-07-18 21:04:51 UTC (rev 47180)
+++ grass/trunk/lib/psdriver/psdriver.html 2011-07-18 21:14:12 UTC (rev 47181)
@@ -59,14 +59,6 @@
<li><b>GRASS_PS_TRAILER</b><br>
if <tt>FALSE</tt>, no trailer section is generated.
</li>
- <!-- used ?
- </li>
- </li>
</ul>
<h3>Example</h3>
