[GRASS-SVN] r47201 - in grass/branches/releasebranch_6_4/gui: scripts wxpython/gui_modules wxpython/xml
Thu Jul 21 07:52:20 EDT 2011
Author: martinl
Date: 2011-07-21 04:52:20 -0700 (Thu, 21 Jul 2011)
New Revision: 47201
   grass/branches/releasebranch_6_4/gui/scripts/g.extension.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py
   grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI/extension: sync with grass65
Modified: grass/branches/releasebranch_6_4/gui/scripts/g.extension.py
--- grass/branches/releasebranch_6_4/gui/scripts/g.extension.py	2011-07-21 11:48:31 UTC (rev 47200)
+++ grass/branches/releasebranch_6_4/gui/scripts/g.extension.py	2011-07-21 11:52:20 UTC (rev 47201)
@@ -20,9 +20,7 @@
 #%module
 #% label: Tool to maintain the extensions in local GRASS installation.
 #% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
-#% keywords: general
-#% keywords: installation
-#% keywords: extensions
+#% keywords: general, installation, extensions
 #%end
 #%option
@@ -46,7 +44,7 @@
 #% key_desc: url
 #% description: SVN Addons repository URL
 #% required: yes
-#% answer: https://svn.osgeo.org/grass/grass-addons/grass7
+#% answer: https://svn.osgeo.org/grass/grass-addons
 #%end
 #%option
 #% key: prefix
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py	2011-07-21 11:48:31 UTC (rev 47200)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py	2011-07-21 11:52:20 UTC (rev 47201)
@@ -802,8 +802,7 @@
         self.treeBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
                                     label = " %s " % _("List of extensions"))
-        self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
-                                value = 'https://svn.osgeo.org/grass/grass-addons')
+        self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
         self.fullDesc = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
                                     label = _("Fetch full info including description and keywords (takes time)"))
         self.fullDesc.SetValue(False)
@@ -816,7 +815,7 @@
         self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
                                       label = " %s " % _("Options"))
-        task = gtask.parse_interface('g.extension.py')
+        task = gtask.parse_interface('g.extension')
         for f in task.get_options()['flags']:
             name = f.get('name', '')
@@ -829,6 +828,8 @@
                 continue
             self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
                                              label = desc)
+        self.repo.SetValue(task.get_param(value = 'svnurl').get('default',
+        'https://svn.osgeo.org/grass/grass-addons'))
         self.statusbar = self.CreateStatusBar(number = 1)
@@ -840,10 +841,14 @@
                                     label = _("&Install"))
         self.btnInstall.SetToolTipString(_("Install selected add-ons GRASS module"))
         self.btnInstall.Enable(False)
+        self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                label = _("Command dialog"))
+        self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension')
         self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
         self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
         self.btnInstall.Bind(wx.EVT_BUTTON, self.OnInstall)
+        self.btnCmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
         self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
         self.tree.Bind(wx.EVT_TREE_SEL_CHANGED,    self.OnItemSelected)
         self.search.Bind(wx.EVT_TEXT_ENTER,        self.OnShowItem)
@@ -877,6 +882,9 @@
             optionSizer.Add(item = self.options[key], proportion = 0)
         btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        btnSizer.Add(item = self.btnCmd, proportion = 0,
+                     flag = wx.RIGHT, border = 5)
+        btnSizer.AddSpacer(10)
         btnSizer.Add(item = self.btnClose, proportion = 0,
         btnSizer.Add(item = self.btnInstall, proportion = 0)
@@ -897,19 +905,23 @@
         self.Layout()
-    def _install(self, name):
+    def _getCmd(self):
+        item = self.tree.GetSelected()
+        if not item or not item.IsOk():
+            return ['g.extension']
+        name = self.tree.GetItemText(item)
         if not name:
+            gcmd.GError(_("Extension not defined"), parent = self)
             return
-        log = self.parent.GetLogWindow()
         flags = list()
         for key in self.options.keys():
             if self.options[key].IsChecked():
                 flags.append('-%s' % key)
-        log.RunCmd(['g.extension.py'] + flags + ['extension=' + name,
-                                                 'svnurl=' + self.repo.GetValue().strip()])
-        ### self.OnCloseWindow(None)
+        return ['g.extension'] + flags + ['extension=' + name,
+                                          'svnurl=' + self.repo.GetValue().strip()]
     def OnUpdateStatusBar(self, event):
         """!Update statusbar text"""
         element = self.search.GetSelection()
@@ -942,15 +954,15 @@
         item = event.GetItem()
         data = self.tree.GetPyData(item)
         if data and 'command' in data:
-            self._install(data['command'])
+            self.OnInstall(event = None)
     def OnInstall(self, event):
         """!Install selected extension"""
-        item = self.tree.GetSelected()
-        if not item.IsOk():
-            return
-        self._install(self.tree.GetItemText(item))
+        log = self.parent.GetLogWindow()
+        log.RunCmd(self._getCmd())
+        ### self.OnCloseWindow(None)
     def OnItemSelected(self, event):
         """!Item selected"""
@@ -970,6 +982,10 @@
             self.btnInstall.Enable()
         else:
+    def OnCmdDialog(self, event):
+        """!Shows command dialog"""
+        menuform.GUI(parent = self).ParseCommand(cmd = self._getCmd())
 class ExtensionTree(ItemTree):
     """!List of available extensions"""
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2011-07-21 11:48:31 UTC (rev 47200)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2011-07-21 11:52:20 UTC (rev 47201)
@@ -843,13 +843,8 @@
 	    <menuitem>
 	      <label>Install extension from add-ons</label>
 	      <help>Install new extension from GRASS AddOns SVN repository.</help>
-	      <handler>OnInstallExtension</handler>
-	    </menuitem>
-	    <menuitem>
-	      <label>Manage add-ons extensions</label>
-	      <help>Tool to maintain GRASS extensions in local GRASS installation.</help>
 	      <keywords>general,extensions</keywords>
-	      <handler>OnMenuCmd</handler>
+	      <handler>OnInstallExtension</handler>
 	      <command>g.extension</command>
 	    </menuitem>
 	<separator />
