[GRASS-SVN] r47223 - grass/trunk/gui/wxpython/gui_modules
Fri Jul 22 06:05:36 EDT 2011
Author: annakrat
Date: 2011-07-22 03:05:36 -0700 (Fri, 22 Jul 2011)
New Revision: 47223
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/render.py
wxNviz: add text overlays, little changes in 2D text overlays
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-07-22 07:56:40 UTC (rev 47222)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-07-22 10:05:36 UTC (rev 47223)
@@ -511,10 +511,10 @@
     def _CreateOverlay(self):
         if not self.parent.Map.GetOverlay(self.ovlId):
-            overlay = self.parent.Map.AddOverlay(id=self.ovlId, type=self.name,
+            self.newOverlay = self.parent.Map.AddOverlay(id=self.ovlId, type=self.name,
                                                  command=self.cmd,
                                                  l_active=False, l_render=False, l_hidden=True)
-            prop = { 'layer' : overlay,
+            prop = { 'layer' : self.newOverlay,
                      'params' : None,
                      'propwin' : None,
                      'cmd' : self.cmd,
@@ -551,7 +551,7 @@
     def OnCancel(self, event):
         """!Cancel dialog"""
         self.parent.dialogs['barscale'] = None
+        self.parent.Map.DeleteOverlay(self.newOverlay)
         self.Destroy()
     def OnOK(self, event):
@@ -613,12 +613,14 @@
             self.currClr  = self.parent.MapWindow.textdict[self.ovlId]['color']
             self.currRot  = self.parent.MapWindow.textdict[self.ovlId]['rotation']
             self.currCoords = self.parent.MapWindow.textdict[self.ovlId]['coords']
+            self.currBB = self.parent.MapWindow.textdict[self.ovlId]['bbox']
         else:
             self.currClr = wx.BLACK
             self.currText = ''
             self.currFont = self.GetFont()
             self.currRot = 0.0
-            self.currCoords = [10, 10, 10, 10]
+            self.currCoords = [10, 10]
+            self.currBB = wx.Rect()
         self.sizer = wx.BoxSizer(wx.VERTICAL)
         box = wx.GridBagSizer(vgap=5, hgap=5)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-22 07:56:40 UTC (rev 47222)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-22 10:05:36 UTC (rev 47223)
@@ -386,6 +386,7 @@
             self.MapWindow = self.MapWindow3D
             self.MapWindow.SetCursor(self.cursors["default"])
             self.MapWindow3D.overlays = self.MapWindow2D.overlays
+            self.MapWindow3D.textdict = self.MapWindow2D.textdict
             self.MapWindow3D.UpdateOverlays()
                 # add Nviz notebookpage
@@ -1679,6 +1680,13 @@
         AddScale.SetBitmap(icons["addBarscale"].GetBitmap(self.iconsize))
         decmenu.AppendItem(AddScale)
         self.Bind(wx.EVT_MENU, self.OnAddBarscale, AddScale)
+        # temporary
+        if self.toolbars['nviz']:
+            AddScale.Enable(False)
+            AddArrow = wx.MenuItem(decmenu, wx.ID_ANY, _("Add north arrow"))
+            AddArrow.SetBitmap(icons["addBarscale"].GetBitmap(self.iconsize))
+            decmenu.AppendItem(AddArrow)
+            self.Bind(wx.EVT_MENU, self.OnAddArrow, AddArrow)
         AddLegend = wx.MenuItem(decmenu, wx.ID_ANY, icons["addLegend"].GetLabel())
         AddLegend.SetBitmap(icons["addLegend"].GetBitmap(self.iconsize))
@@ -1689,14 +1697,6 @@
         AddText.SetBitmap(icons["addText"].GetBitmap(self.iconsize))
         decmenu.AppendItem(AddText)
         self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
-        # temporary
-        if self.toolbars['nviz']:
-            AddText.Enable(False)
-            AddScale.Enable(False)
-            AddArrow = wx.MenuItem(decmenu, wx.ID_ANY, _("Add north arrow"))
-            AddArrow.SetBitmap(icons["addBarscale"].GetBitmap(self.iconsize))
-            decmenu.AppendItem(AddArrow)
-            self.Bind(wx.EVT_MENU, self.OnAddArrow, AddArrow)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
@@ -1773,10 +1773,10 @@
         else:
             # index for overlay layer in render
             if len(self.MapWindow.textdict.keys()) > 0:
-                id = self.MapWindow.textdict.keys()[-1] + 1
+                id = max(self.MapWindow.textdict.keys()) + 1
             else:
                 id = 101
         self.dialogs['text'] = gdialogs.TextLayerDialog(parent = self, ovlId = id,
                                                         title = _('Add text layer'),
                                                         size = (400, 200))
@@ -1786,27 +1786,30 @@
         if self.dialogs['text'].ShowModal() == wx.ID_OK:
             text = self.dialogs['text'].GetValues()['text']
             active = self.dialogs['text'].GetValues()['active']
-            coords, w, h = self.MapWindow.TextBounds(self.dialogs['text'].GetValues())
             # delete object if it has no text or is not active
             if text == '' or active == False:
                 try:
-                    self.MapWindow.pdc.ClearId(id)
-                    self.MapWindow.pdc.RemoveId(id)
+                    self.MapWindow2D.pdc.ClearId(id)
+                    self.MapWindow2D.pdc.RemoveId(id)
                     del self.MapWindow.textdict[id]
+                    if self.MapWindow3D:
+                        self.MapWindow3D.UpdateOverlays()
                 except:
                     pass
                 return
-            self.MapWindow.pdc.SetId(id)
-            self.MapWindow.textdict[id] = self.dialogs['text'].GetValues()
+            self.MapWindow2D.pdc.SetId(id)
+            self.MapWindow2D.textdict[id] = self.dialogs['text'].GetValues()
+                self.MapWindow3D.textdict[id] = self.dialogs['text'].GetValues()
-            self.MapWindow.Draw(self.MapWindow.pdcDec, img = self.MapWindow.textdict[id],
-                                drawid = id, pdctype = 'text', coords = coords)
+            self.MapWindow2D.UpdateMap(render = False, renderVector = False)
-            self.MapWindow.UpdateMap(render = False, renderVector = False)
         self.MapWindow.mouse['use'] = 'pointer'
     def OnAddArrow(self, event):
@@ -1815,8 +1818,8 @@
         self._layerManager.nviz.SetPage('decoration')
+        self.MapWindow3D.SetDrawArrow((70, 70))
     def GetOptData(self, dcmd, type, params, propwin):
         """!Callback method for decoration overlay command generated by
         dialog created in menuform.py
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-22 07:56:40 UTC (rev 47222)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-22 10:05:36 UTC (rev 47223)
@@ -392,12 +392,12 @@
             w, h = self.GetFullTextExtent(img['text'])[0:2]
             pdc.SetFont(img['font'])
             pdc.SetTextForeground(img['color'])
-            coords, w, h = self.TextBounds(img)
+            coords, bbox = self.TextBounds(img)
             if rotation == 0:
                 pdc.DrawText(img['text'], coords[0], coords[1])
             else:
                 pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
-            pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
+            pdc.SetIdBounds(drawid, bbox)
         pdc.EndDrawing()
@@ -405,11 +405,15 @@
         return drawid
-    def TextBounds(self, textinfo):
+    def TextBounds(self, textinfo, relcoords = False):
         """!Return text boundary data
         @param textinfo text metadata (text, font, color, rotation)
         @param coords reference point
+        @return coords of nonrotated text bbox (TL corner)
+        @return bbox of rotated text bbox (wx.Rect)
+        @return relCoords are text coord inside bbox
         if 'rotation' in textinfo:
             rotation = float(textinfo['rotation'])
@@ -417,7 +421,8 @@
             rotation = 0.0
         coords = textinfo['coords']
+        bbox = wx.Rect(coords[0], coords[1], 0, 0)
+        relCoords = (0, 0)
         Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
                    (textinfo['text'], rotation))
@@ -428,15 +433,31 @@
         w, h = self.GetTextExtent(textinfo['text'])
         if rotation == 0:
-            coords[2], coords[3] = coords[0] + w, coords[1] + h
-            return coords, w, h
+            bbox[2], bbox[3] = w, h
+            if relcoords:
+                return coords, bbox, relCoords
+            else:
         boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
         boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
-        coords[2] = coords[0] + boxw
-        coords[3] = coords[1] + boxh
-        return coords, boxw, boxh
+        if rotation > 0 and rotation < 90:
+            bbox[1] -= boxh
+            relCoords = (0, boxh)
+        elif rotation >= 90 and rotation < 180:
+            bbox[0] -= boxw
+            bbox[1] -= boxh
+            relCoords = (boxw, boxh)
+        elif rotation >= 180 and rotation < 270:
+            bbox[0] -= boxw
+            relCoords = (boxw, 0)
+        bbox[2] = boxw
+        bbox[3] = boxh
+        bbox.Inflate(h,h)
+        if relcoords:
+        else:
     def OnPaint(self, event):
         """!Draw PseudoDC's to buffered paint DC
@@ -862,6 +883,7 @@
         dy = event.GetY() - y
         self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
         r = self.pdc.GetIdBounds(id)
         if type(r) is list:
             r = wx.Rect(r[0], r[1], r[2], r[3])
         if id > 100: # text dragging
@@ -875,7 +897,9 @@
         if type(r2) is list:
             r2 = wx.Rect(r[0], r[1], r[2], r[3])
         if id > 100: # text
-            self.textdict[id]['coords'] = r2
+            self.textdict[id]['bbox'] = r2
+            self.textdict[id]['coords'][0] += dx
+            self.textdict[id]['coords'][1] += dy
         r = r.Union(r2)
         r.Inflate(4,4)
         self.RefreshRect(r, False)
@@ -1265,7 +1289,7 @@
             if self.dragid < 99 and self.dragid in self.overlays:
                 self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
             elif self.dragid > 100 and self.dragid in self.textdict:
-                self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
+                self.textdict[self.dragid]['bbox'] = self.pdc.GetIdBounds(self.dragid)
             else:
                 pass
             self.dragid = None
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-22 07:56:40 UTC (rev 47222)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-22 10:05:36 UTC (rev 47223)
@@ -106,6 +106,8 @@
         self.shapes = []
         self.dragShape = None
         self.dragImage = None
+        self.textdict = {}
+        self.dragid = None
         # use display region instead of computational
@@ -268,10 +270,42 @@
             # draw any active and defined overlays
             if self.imagedict[img]['layer'].IsActive():
                 id = self.imagedict[img]['id']
+                if id == 0: # barscale
+                    continue
                 coords = self.overlays[id]['coords']
                 bitmap = wx.BitmapFromImage(img)
                 self.shapes.append(DragShape(bitmap, id))
                 self.shapes[-1].pos = coords[:2]
+        for textId in self.textdict.keys():
+            text = self.textdict[textId]['text']
+            color = self.textdict[textId]['color']
+            bgcolor = self.view['background']['color']
+            font = self.textdict[textId]['font']
+            rot = self.textdict[textId]['rotation']
+            coords, bbox, relCoords = self.TextBounds(self.textdict[textId])
+            # create a bitmap the same size as our text
+            bmp = wx.EmptyBitmap(bbox[2], bbox[3])
+            # 'draw' the text onto the bitmap
+            dc = wx.MemoryDC()
+            dc.SelectObject(bmp)
+            dc.SetBackground(wx.Brush(bgcolor, wx.SOLID))
+            dc.Clear()
+            dc.SetTextForeground(color)
+            dc.SetFont(font)
+            if rot == 0:
+                dc.DrawText(text, 0, 0)
+            else:
+                dc.DrawRotatedText(text, relCoords[0], relCoords[1], rot)
+            # setbackgroundMode(wx.TRANSPARENT) doesn't work
+            dc.SelectObject(wx.NullBitmap)
+            mask = wx.Mask(bmp, bgcolor)
+            bmp.SetMask(mask)
+            shape = DragShape(bmp, textId)
+            shape.pos = bbox[:2]
+            self.shapes.append(shape)
         self.Refresh(False)
     def OnMouseAction(self, event):
@@ -357,15 +391,7 @@
         if self.mouse['use'] == 'arrow':
             pos = event.GetPosition()
             size = self.GetClientSize()
-            if self._display.SetArrow(pos[0], size[1] - pos[1],
-                                     self.decoration['arrow']['size'],
-                                     self.decoration['arrow']['color']):
-                self._display.DrawArrow()
-                # update
-                self.decoration['arrow']['show'] = True
-                self.decoration['arrow']['position']['x'] = pos[0]
-                self.decoration['arrow']['position']['y'] = size[1] - pos[1]
-                self.Refresh(False)
+            self.SetDrawArrow((pos[0], size[1] - pos[1]))
         if self.mouse['use'] == 'pointer':
             shape = self.FindShape(event.GetPosition())
@@ -482,7 +508,12 @@
                 self.dragShape.pos[0] + event.GetPosition()[0] - self.dragStartPos[0],
                 self.dragShape.pos[1] + event.GetPosition()[1] - self.dragStartPos[1]
-            self.overlays[self.dragShape.id]['coords'] = tuple(self.dragShape.GetRect())
+            if self.dragShape.id in self.overlays:
+                self.overlays[self.dragShape.id]['coords'] = tuple(self.dragShape.GetRect())
+            else: # text
+                self.textdict[self.dragShape.id]['bbox'] = self.dragShape.GetRect()
+                self.textdict[self.dragShape.id]['coords'][0] += event.GetPosition()[0] - self.dragStartPos[0]
+                self.textdict[self.dragShape.id]['coords'][1] += event.GetPosition()[1] - self.dragStartPos[1]
             self.dragShape.shown = True
             self.RefreshRect(self.dragShape.GetRect())
@@ -491,7 +522,10 @@
     def OnDClick(self, event):
         if shape.id == 1:
-                self.parent.OnAddLegend(None)
+            self.parent.OnAddLegend(None)
+        elif shape.id > 100:
+            self.dragid = shape.id
+            self.parent.OnAddText(None)
     def OnQuerySurface(self, event):
         """!Query surface on given position"""
@@ -633,6 +667,18 @@
                 return shape
         return None
+    def SetDrawArrow(self, pos):
+        if self._display.SetArrow(pos[0], pos[1],
+                                 self.decoration['arrow']['size'],
+                                 self.decoration['arrow']['color']):
+            self._display.DrawArrow()
+            # update
+            self.decoration['arrow']['show'] = True
+            self.decoration['arrow']['position']['x'] = pos[0]
+            self.decoration['arrow']['position']['y'] = pos[1]
+            self.Refresh(False)
     def IsLoaded(self, item):
         """!Check if layer (item) is already loaded
@@ -1878,7 +1924,15 @@
         """!Reset view
         self.lmgr.nviz.OnResetView(None)
+    def TextBounds(self, textinfo):
+        """!Return text boundary data
+        @param textinfo text metadata (text, font, color, rotation)
+        return self.parent.MapWindow2D.TextBounds(textinfo, relcoords = True)
 class DragShape:
     """!Class for drawing overlays (based on wxpython demo)"""
     def __init__(self, bmp, id):
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-22 07:56:40 UTC (rev 47222)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-22 10:05:36 UTC (rev 47223)
@@ -1295,7 +1295,7 @@
     def DeleteOverlay(self, overlay):
         """!Delete overlay
-        @param id overlay id
+        @param overlay overlay layer
         @return removed overlay on success or None
