[GRASS-SVN] r47252 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jul 26 15:44:09 EDT 2011
Author: martinl
Date: 2011-07-26 12:44:09 -0700 (Tue, 26 Jul 2011)
New Revision: 47252
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: attempt to fix #1409
(merge r47251 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2011-07-26 19:37:29 UTC (rev 47251)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2011-07-26 19:44:09 UTC (rev 47252)
@@ -470,7 +470,8 @@
# send GRASS command without arguments to GUI command interface
# except display commands (they are handled differently)
if self.parent.GetName() == "LayerManager" and \
- command[0][0:2] == "d.":
+ command[0][0:2] == "d." and \
+ (len(command) > 1 and 'help' not in ' '.join(command[1:])):
# display GRASS commands
try:
layertype = {'d.rast' : 'raster',
@@ -507,7 +508,7 @@
self.parent.curr_page.maptree.AddLayer(ltype = layertype,
lname = lname,
lcmd = command)
else:
# other GRASS commands (r|v|g|...)
# switch to 'Command output' if required
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-07-26 19:37:29 UTC (rev 47251)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-07-26 19:44:09 UTC (rev 47252)
@@ -807,7 +807,7 @@
render = False
name = None
if ctrl:
ctrlId = ctrl.GetId()
else:
@@ -1348,7 +1348,7 @@
if not lname:
dcmd = self.GetPyData(item)[0]['cmd']
lname, found = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
- fullyQualified = True)
+ fullyQualified = True)
if not found:
return None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2011-07-26 19:37:29 UTC (rev 47251)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2011-07-26 19:44:09 UTC (rev 47252)
@@ -184,23 +184,11 @@
quiet = True,
**self.cmd[1])
- # if len(msg):
- # sys.stderr.write(_("Running") + " '" + utils.GetCmdString(self.cmd) + "'")
- # sys.stderr.write(msg)
if ret != 0:
- # clean up after problem
- try:
- os.remove(self.mapfile)
- os.remove(self.maskfile)
- os.remove(self.gtemp)
- except (OSError, TypeError):
- pass
- self.mapfile = None
- self.maskfile = None
+ raise gcmd.GException(value = _("'%s' failed. Details: %s") % (self.cmd[0], msg))
except gcmd.GException, e:
- # sys.stderr.write(e.value)
+ print >> sys.stderr, e.value
# clean up after problems
try:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2011-07-26 19:37:29 UTC (rev 47251)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2011-07-26 19:44:09 UTC (rev 47252)
@@ -24,6 +24,7 @@
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
from grass.script import core as grass
+from grass.script import task as gtask
import gcmd
from debug import Debug
@@ -75,6 +76,9 @@
layerType = None):
"""!Get map name from GRASS command
+ Parameter dcmd can be modified when first parameter is not
+ defined.
@param dcmd GRASS command (given as list)
@param fullyQualified change map name to be fully qualified
@param param params directory
@@ -116,7 +120,9 @@
if len(params) < 1:
if len(dcmd) > 1 and '=' not in dcmd[1]:
- params.append((1, None, dcmd[1]))
+ task = gtask.parse_interface(dcmd[0])
+ p = task.get_options()['params'][0].get('name', '')
+ params.append((1, p, dcmd[1]))
else:
return mapname, False
