[GRASS-SVN] r47262 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Wed Jul 27 09:23:55 EDT 2011
Author: neteler
Date: 2011-07-27 06:23:55 -0700 (Wed, 27 Jul 2011)
New Revision: 47262
grass/trunk/gui/wxpython/xml/menudata.xml
reorder map display entries
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2011-07-27 13:23:46 UTC (rev 47261)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2011-07-27 13:23:55 UTC (rev 47262)
@@ -46,40 +46,40 @@
<label>Map display</label>
<items>
<menuitem>
- <label>New</label>
- <help>Open new map display window</help>
- <handler>OnNewDisplay</handler>
+ <label>Add raster</label>
+ <help>Add raster map layer to current display</help>
+ <handler>OnAddRaster</handler>
+ <shortcut>Ctrl+Shift+R</shortcut>
</menuitem>
<menuitem>
- <label>Close current</label>
- <help>Close current map display window</help>
- <handler>OnDisplayClose</handler>
- <shortcut>Ctrl+W</shortcut>
+ <label>Add vector</label>
+ <help>Add vector map layer to current display</help>
+ <handler>OnAddVector</handler>
+ <shortcut>Ctrl+Shift+V</shortcut>
</menuitem>
<menuitem>
- <label>Close all</label>
- <help>Close all open map display windows</help>
- <handler>OnDisplayCloseAll</handler>
- </menuitem>
- <separator />
- <menuitem>
<label>Add multiple rasters or vectors</label>
<help>Add multiple raster or vector map layers to current display</help>
<handler>OnAddMaps</handler>
<shortcut>Ctrl+Shift+L</shortcut>
</menuitem>
+ <separator />
<menuitem>
- <label>Add raster</label>
- <help>Add raster map layer to current display</help>
- <handler>OnAddRaster</handler>
- <shortcut>Ctrl+Shift+R</shortcut>
+ <label>New map display window</label>
+ <help>Open new map display window</help>
+ <handler>OnNewDisplay</handler>
</menuitem>
<menuitem>
- <label>Add vector</label>
- <help>Add vector map layer to current display</help>
- <handler>OnAddVector</handler>
- <shortcut>Ctrl+Shift+V</shortcut>
+ <label>Close current map display window</label>
+ <help>Close current map display window</help>
+ <handler>OnDisplayClose</handler>
+ <shortcut>Ctrl+W</shortcut>
</menuitem>
+ <menuitem>
+ <label>Close all open map display windows</label>
+ <help>Close all open map display windows</help>
+ <handler>OnDisplayCloseAll</handler>
+ </menuitem>
</items>
</menu>
<separator />
