[GRASS-SVN] r47266 - grass/trunk/lib/python
svn_grass at osgeo.org
Wed Jul 27 10:47:23 EDT 2011
Author: mmetz
Date: 2011-07-27 07:47:23 -0700 (Wed, 27 Jul 2011)
New Revision: 47266
grass/trunk/lib/python/db.py
db_select: clean up afterwards
Modified: grass/trunk/lib/python/db.py
--- grass/trunk/lib/python/db.py 2011-07-27 14:06:32 UTC (rev 47265)
+++ grass/trunk/lib/python/db.py 2011-07-27 14:47:23 UTC (rev 47266)
@@ -92,21 +92,26 @@
@param file True if sql is filename
@param args see db.select arguments
- ofile = pytempfile.NamedTemporaryFile(mode = 'w+b')
+ fname = tempfile(create = False)
if not file:
ret = run_command('db.select', quiet = True,
flags = 'c',
table = table,
sql = sql,
- output = ofile.name)
+ output = fname)
else: # -> sql is file
flags = 'c',
table = table,
input = sql,
+ output = fname)
if ret != 0:
fatal(_("Fetching data from table <%s> failed") % table)
+ ofile = open(fname)
+ result = ofile.readlines()
+ ofile.close()
+ try_remove(fname)
- return ofile.readlines()
+ return result
