[GRASS-SVN] r47292 - in grass/trunk: include lib/gis
svn_grass at osgeo.org
Thu Jul 28 06:56:29 EDT 2011
Author: martinl
Date: 2011-07-28 03:56:29 -0700 (Thu, 28 Jul 2011)
New Revision: 47292
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/get_window.c
grass/trunk/lib/gis/set_window.c
grass/trunk/lib/gis/window_map.c
gislib: define G_unset_window()
cosmetics doxygen messages
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2011-07-28 10:54:22 UTC (rev 47291)
+++ grass/trunk/include/gisdefs.h 2011-07-28 10:56:29 UTC (rev 47292)
@@ -562,6 +562,7 @@
/* set_window.c */
void G_get_set_window(struct Cell_head *);
void G_set_window(struct Cell_head *);
+void G_unset_window();
/* short_way.c */
void G_shortest_way(double *, double *);
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c 2011-07-28 10:54:22 UTC (rev 47291)
+++ grass/trunk/lib/gis/get_window.c 2011-07-28 10:56:29 UTC (rev 47292)
@@ -1,12 +1,12 @@
- \file gis/get_window.c
+ \file lib/gis/get_window.c
\brief GIS Library - Get window (i.e. GRASS region)
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2009, 2011 by the GRASS Development Team
This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author Original author CERL
@@ -26,24 +26,23 @@
static struct state *st = &state;
- * \brief Read the database region
- * Reads the database region as stored in the WIND file in the user's
- * current mapset into region.
- * 3D values are set to defaults if not available in WIND file.
- * An error message is printed and exit() is called if there is a problem reading
- * the region.
- * <b>Note:</b> GRASS applications that read or write raster maps
- * should not use this routine since its use implies that the active
- * module region will not be used. Programs that read or write raster
- * map data (or vector data) can query the active module region using
- * Rast_window_rows() and Rast_window_cols().
- * \param window pointer to Cell_head
+ \brief Read the database region
+ Reads the database region as stored in the WIND file in the user's
+ current mapset into region.
+ 3D values are set to defaults if not available in WIND file. An
+ error message is printed and exit() is called if there is a problem
+ reading the region.
+ <b>Note:</b> GRASS applications that read or write raster maps
+ should not use this routine since its use implies that the active
+ module region will not be used. Programs that read or write raster
+ map data (or vector data) can query the active module region using
+ Rast_window_rows() and Rast_window_cols().
+ \param[out] window pointer to Cell_head
void G_get_window(struct Cell_head *window)
const char *regvar;
@@ -80,32 +79,30 @@
- * \brief Read the default region
- * Reads the default region for the location into <i>region.</i> 3D
- * values are set to defaults if not available in WIND file.
- * problem reading the default region.
- * \param[out] window pointer to Cell_head
+ \brief Read the default region
+ Reads the default region for the location into <i>region.</i> 3D
+ values are set to defaults if not available in WIND file.
+ An error message is printed and exit() is called if there is a
+ problem reading the default region.
void G_get_default_window(struct Cell_head *window)
G__get_window(window, "", "DEFAULT_WIND", "PERMANENT");
- \brief Get cwindow (region) of selected map layer
+ \brief Get window (region) of selected map
- \param window pointer to Cell_head
- \param element element name
+ G_fatal_error() is called on error
+ \param window[out] pointer to Cell_head
+ \param element element type
\param name map name
\param mapset mapset name
- \return string on error
- \return NULL on success
void G__get_window(struct Cell_head *window,
const char *element, const char *name, const char *mapset)
@@ -123,3 +120,12 @@
G__read_Cell_head(fp, window, 0);
fclose(fp);
+ \brief Unset current window
+ st->initialized = 0;
+ G__.window_set = 0;
Modified: grass/trunk/lib/gis/set_window.c
--- grass/trunk/lib/gis/set_window.c 2011-07-28 10:54:22 UTC (rev 47291)
+++ grass/trunk/lib/gis/set_window.c 2011-07-28 10:56:29 UTC (rev 47292)
@@ -1,15 +1,15 @@
- * \file gis/set_window.c
- * \brief GIS Library - Set window (map region)
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
+ \file lib/gis/set_window.c
+ \brief GIS Library - Set window (map region)
+ This program is free software under the GNU General Public License
+ \author Original author CERL
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -17,13 +17,13 @@
#include "G.h"
- * \brief Get the current working window (region)
- * The current working window values are returned in the structure
- * <i>window</i>.
- * \param[in,out] window window structure to be set
+ \brief Get the current working window (region)
+ The current working window values are returned in the structure
+ <i>window</i>.
+ \param[out] window window structure to be set
void G_get_set_window(struct Cell_head *window)
G__init_window();
@@ -31,19 +31,15 @@
- * \brief Establishes 'window' as the current working window.
- * \param window window to become operative window
- * \return -1 on error
- * \return 1 on success
+ \brief Establishes 'window' as the current working window.
+ \param window window to become operative window
void G_set_window(struct Cell_head *window)
/* adjust window, check for valid window */
G_adjust_Cell_head(window, 0, 0);
/* copy the window to the current window */
G__.window = *window;
G__.window_set = 1;
Modified: grass/trunk/lib/gis/window_map.c
--- grass/trunk/lib/gis/window_map.c 2011-07-28 10:54:22 UTC (rev 47291)
+++ grass/trunk/lib/gis/window_map.c 2011-07-28 10:56:29 UTC (rev 47292)
@@ -1,36 +1,34 @@
- * \file window_map.c
- * \brief GIS Library - Window mapping functions.
+ \file lib/gis/window_map.c
+ \brief GIS Library - Window mapping functions.
#include "G.h"
- * \brief Adjust east longitude.
- * This routine returns an equivalent <i>east</i> that is
- * larger, but no more than 360 larger than the <i>west</i>
- * coordinate.
+ \brief Adjust east longitude.
+ This routine returns an equivalent <i>east</i> that is larger, but
+ no more than 360 larger than the <i>west</i> coordinate.
- * <b>Note:</b> This routine should be used only with
- * latitude-longitude coordinates.
- * \param east east coordinate
- * \param west west coordinate
- * \return east coordinate
+ <b>Note:</b> This routine should be used only with
+ latitude-longitude coordinates.
+ \param east east coordinate
+ \param west west coordinate
+ \return east coordinate
double G_adjust_east_longitude(double east, double west)
while (east > west + 360.0)
@@ -41,22 +39,20 @@
return east;
- * \brief Returns east larger than west.
- * If the region projection is <tt>PROJECTION_LL</tt>, then this routine
- * returns an equivalent <i>east</i> that is larger, but no more than
- * 360 degrees larger, than the coordinate for the western edge of the
- * region. Otherwise no adjustment is made and the original
- * <i>east</i> is returned.
+ \brief Returns east larger than west.
+ If the region projection is <tt>PROJECTION_LL</tt>, then this
+ routine returns an equivalent <i>east</i> that is larger, but no
+ more than 360 degrees larger, than the coordinate for the western
+ edge of the region. Otherwise no adjustment is made and the original
+ <i>east</i> is returned.
+ \param window pointer to Cell_head
double G_adjust_easting(double east, const struct Cell_head *window)
if (window->proj == PROJECTION_LL) {
@@ -69,14 +65,13 @@
- * \brief Initialize window.
+ \brief Initialize window (region).
void G__init_window(void)
if (G_is_initialized(&G__.window_set))
return;
G_get_window(&G__.window);
G_initialize_done(&G__.window_set);
