[GRASS-SVN] r47296 - in grass/trunk/gui/wxpython: . xml
svn_grass at osgeo.org
Thu Jul 28 11:15:47 EDT 2011
Author: martinl
Date: 2011-07-28 08:15:47 -0700 (Thu, 28 Jul 2011)
New Revision: 47296
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: location wizard also accessible from Layer Manager
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-07-28 12:33:34 UTC (rev 47295)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-07-28 15:15:47 UTC (rev 47296)
@@ -302,6 +302,32 @@
if self.workspaceFile:
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.workspaceFile) + '*')
+ def OnLocationWizard(self, event):
+ """!Launch location wizard"""
+ from gui_modules import location_wizard
+ gisdbase = grass.gisenv()['GISDBASE']
+ gWizard = location_wizard.LocationWizard(parent = self,
+ grassdatabase = gisdbase)
+ if gWizard.location != None:
+ dlg = wx.MessageDialog(parent = self,
+ message = _('Location <%s> created.\n\n'
+ 'Do you want to switch to the '
+ 'new location?') % gWizard.location,
+ caption=_("Switch to new location?"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret == wx.ID_YES:
+ gcmd.RunCommand("g.gisenv",
+ set = "LOCATION_NAME=%s" % gWizard.location)
+ set = "MAPSET=PERMANENT")
+ dlg.Destroy()
def OnSettingsChanged(self, event):
"""!Here can be functions which have to be called after EVT_SETTINGS_CHANGED.
Now only set copying of selected text to clipboard (in goutput).
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2011-07-28 12:33:34 UTC (rev 47295)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2011-07-28 15:15:47 UTC (rev 47296)
@@ -831,6 +831,13 @@
</menuitem>
<separator />
<menuitem>
+ <label>Create new location</label>
+ <help>Launches location wizard to create new GRASS location.</help>
+ <keywords>location, wizard</keywords>
+ <handler>OnLocationWizard</handler>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>Version</label>
<help>Displays version and copyright information.</help>
<keywords>general,version</keywords>
