[GRASS-SVN] r47321 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Sat Jul 30 15:16:27 EDT 2011
Author: sudeepsingh
Date: 2011-07-30 12:16:26 -0700 (Sat, 30 Jul 2011)
New Revision: 47321
Added:
grass-addons/grass7/gui/wxpython/wx.wms/passwordPopUp.py
grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
password popup frame added and integerated
Added: grass-addons/grass7/gui/wxpython/wx.wms/passwordPopUp.py
--- grass-addons/grass7/gui/wxpython/wx.wms/passwordPopUp.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.wms/passwordPopUp.py 2011-07-30 19:16:26 UTC (rev 47321)
@@ -0,0 +1,59 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# generated by wxGlade 0.6.3 on Sat Jul 30 22:23:14 2011
+import wx
+# begin wxGlade: extracode
+# end wxGlade
+class PopUpFrame(wx.Frame):
+ def __init__(self, *args, **kwds):
+ # begin wxGlade: PopUpFrame.__init__
+ kwds["style"] = wx.DEFAULT_FRAME_STYLE
+ wx.Frame.__init__(self, *args, **kwds)
+ self.passworddescription = wx.StaticText(self, -1, " Enter password")
+ self.text_ctrl_1 = wx.TextCtrl(self, -1, "", style=wx.TE_PASSWORD)
+ self.passwordEnter = wx.Button(self, -1, "Enter")
+ self.__set_properties()
+ self.__do_layout()
+ # end wxGlade
+ def __set_properties(self):
+ # begin wxGlade: PopUpFrame.__set_properties
+ self.SetTitle("EnterPassword")
+ self.text_ctrl_1.SetMinSize((200, 25))
+ # end wxGlade
+ def __do_layout(self):
+ # begin wxGlade: PopUpFrame.__do_layout
+ sizer_1 = wx.BoxSizer(wx.VERTICAL)
+ sizer_1.Add(self.passworddescription, 0, 0, 0)
+ sizer_1.Add(self.text_ctrl_1, 0, 0, 0)
+ sizer_1.Add(self.passwordEnter, 0, wx.ALIGN_CENTER_HORIZONTAL, 0)
+ self.SetSizer(sizer_1)
+ sizer_1.Fit(self)
+ self.Layout()
+ # end wxGlade
+# end of class PopUpFrame
+if __name__ == "__main__":
+ app = wx.PySimpleApp(0)
+ wx.InitAllImageHandlers()
+ frame_1 = PopUpFrame(None, -1, "")
+ app.SetTopWindow(frame_1)
+ frame_1.Show()
+ app.MainLoop()
+def PasswordPopUpFrame():
+ frame_1.Show()
+ app.MainLoop()
\ No newline at end of file
Property changes on: grass-addons/grass7/gui/wxpython/wx.wms/passwordPopUp.py
___________________________________________________________________
Added: svn:executable
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-07-30 17:19:35 UTC (rev 47320)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-07-30 19:16:26 UTC (rev 47321)
@@ -8,6 +8,7 @@
from parse import parsexml, isServiceException
from WMSMapDisplay import NewImageFrame
from addserver import AddServerFrame
+from passwordPopUp import PasswordPopUpFrame
# end wxGlade
@@ -41,7 +42,7 @@
#Sudeep's Code Starts
#self.urlInput.SetValue('http://www.gisnet.lv/cgi-bin/topo')
- self.__populate_Url_List(self.ServerList)
+ self.__populate_Url_List(self.ServerList)
self.selectedURL="No server selected"
self.layerTreeRoot = self.LayerTree.AddRoot("Layers")
#items = ["a", "b", "c"]
@@ -74,17 +75,17 @@
self.Layout()
# end wxGlade
def update_Url_List(self, name):
- ComboBox = self.ServerList
- ComboBox.Append(name)
+ ComboBox = self.ServerList
+ ComboBox.Append(name)
def __populate_Url_List(self, ComboBox):
- f = open('serverList.txt','r')
+ f = open('serverList.txt','r')
lines = f.readlines()
self.servers = {}
for line in lines:
row = line.split()
print row
if(len(row) == 4) :
- self.servers[row[0]] = row[1]
+ self.servers[row[0]] = row[1]
name = row[0]+" "+row[1][7:45]
f.close()
@@ -92,72 +93,75 @@
def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
#url = 'http://www.gisnet.lv/cgi-bin/topo?request=GetCapabilities&service=wms&version=1.1.1'
- self.LayerTree.CollapseAndReset(self.layerTreeRoot)
- #url = self.urlInput.GetValue()
- url = self.selectedURL
- url = url + '?request=GetCapabilities&service=wms&version=1.1.1'
- print url
- req = Request(url)
- try:
- response = urlopen(req)
- xml = response.read()
- #self.statusbar.SetStatusText(xml)
- reslist = parsexml(xml)
- st = ''
- for res in reslist:
- st = st + res + '\n'
- self.LayerTree.AppendItem(self.layerTreeRoot, res)
- #self.Layers.SetValue(st)
- #print xml
- self.LayerTree.Expand(self.layerTreeRoot)
- except HTTPError, e:
- print 'The server couldn\'t fulfill the request.'
- print 'Error code: ', e.code
- except URLError, e:
- print 'We failed to reach a server.'
- print 'Reason: ', e.reason
- else:
- print 'Successful'
- #Sudeep's Code Ends
+ self.LayerTree.CollapseAndReset(self.layerTreeRoot)
+ #url = self.urlInput.GetValue()
+ url = self.selectedURL
+ url = url + '?request=GetCapabilities&service=wms&version=1.1.1'
+ print url
+ req = Request(url)
+ try:
+ response = urlopen(req)
+ xml = response.read()
+ #self.statusbar.SetStatusText(xml)
+ reslist = parsexml(xml)
+ st = ''
+ for res in reslist:
+ st = st + res + '\n'
+ self.LayerTree.AppendItem(self.layerTreeRoot, res)
+ #self.Layers.SetValue(st)
+ #print xml
+ self.LayerTree.Expand(self.layerTreeRoot)
+ except HTTPError, e:
+ print 'The server couldn\'t fulfill the request.'
+ print 'Error code: ', e.code
+ except URLError, e:
+ print 'We failed to reach a server.'
+ print 'Reason: ', e.reason
+ else:
+ print 'Successful'
+ #Sudeep's Code Ends
event.Skip()
def OnGetMaps(self, event): # wxGlade: wmsFrame.<event_handler>
#self.layerName = self.layerSelected.GetValue()
- self.url_in = self.selectedURL
- getMap_request_url = self.url_in+'?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:3059&layers='+self.layerName+'&bbox=584344,397868,585500,398500'
+ PasswordPopUpFrame()
+ self.url_in = self.selectedURL
+ getMap_request_url = self.url_in
+ getMap_request_url += '?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:3059&layers='
+ getMap_request_url += self.layerName+'&bbox=584344,397868,585500,398500'
- print getMap_request_url
- req = Request(getMap_request_url)
- try:
- image = response.read()
- #print image
- if(isServiceException(image)):
- print 'Service Exception has occured'
- else:
- outfile = open('map.png','wb')
- outfile.write(image)
- outfile.close()
- NewImageFrame()
- else:
- event.Skip()
+ print getMap_request_url
+ req = Request(getMap_request_url)
+ try:
+ image = response.read()
+ #print image
+ if(isServiceException(image)):
+ print 'Service Exception has occured'
+ else:
+ outfile = open('map.png','wb')
+ outfile.write(image)
+ outfile.close()
+ NewImageFrame()
+ else:
+ event.Skip()
def OnServerListEnter(self, event): # wxGlade: wmsFrame.<event_handler>
print "Event handler `OnServerListEnter' not implemented"
@@ -218,7 +222,7 @@
event.Skip()
def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
- AddServerFrame()
+ AddServerFrame()
#print "Event handler `OnAddServer' not implemented"
event.Skip()
@@ -226,12 +230,12 @@
def DisplayWMSMenu():
- app = wx.PySimpleApp(0)
- wx.InitAllImageHandlers()
- wms_Frame = wmsFrame(None, -1, "")
+ wms_Frame = wmsFrame(None, -1, "")
app.SetTopWindow(wms_Frame)
- wms_Frame.Show()
- app.MainLoop()
+ wms_Frame.Show()
+ app.MainLoop()
#Sudeep's Code Ends
