[GRASS-SVN] r46514 - in grass/trunk/gui/wxpython: . gui_modules
    svn_grass at osgeo.org
    Thu Jun  2 08:09:51 EDT 2011
Author: annakrat
Date: 2011-06-02 05:09:51 -0700 (Thu, 02 Jun 2011)
New Revision: 46514
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/gui_modules/layertree.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: selection of tabs in Layer Manager's notebook changed
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-06-02 09:37:36 UTC (rev 46513)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-06-02 12:09:51 UTC (rev 46514)
@@ -337,7 +337,7 @@
                 for elem in elem_list:
                     if elem != '':
                         fullqElem = elem + '@' + mapset
-                        if elements:
+                        if elements is not None:
                             if (exclude and fullqElem in elements) or \
                                     (not exclude and fullqElem not in elements):
                                 continue
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-06-02 09:37:36 UTC (rev 46513)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-06-02 12:09:51 UTC (rev 46514)
@@ -668,7 +668,7 @@
         @todo vector/volume
-        self.lmgr.notebook.SetSelection(3)
+        self.lmgr.SetNBPage('nviz')
         ltype = self.GetPyData(self.layer_selected)[0]['type']
         if ltype == 'raster':
             self.lmgr.nviz.SetPage('surface')
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-06-02 09:37:36 UTC (rev 46513)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-06-02 12:09:51 UTC (rev 46514)
@@ -1222,7 +1222,7 @@
         """!Internal method used by OnQuery*() methods"""
         if self.toolbars['map'].GetAction() == 'displayAttrb':
             # switch to output console to show query results
-            self._layerManager.notebook.SetSelection(1)
+            self._layerManager.SetNBPage('console')
         self.MapWindow.mouse['box'] = "point"
         self.MapWindow.zoomtype = 0
@@ -1617,7 +1617,7 @@
         self.totaldist = 0.0 # total measured distance
         # switch Layer Manager to output console to show measure results
         # change mouse to draw line for measurement
         self.MapWindow.mouse['use'] = "measure"
@@ -1658,8 +1658,8 @@
         """!Calculate map distance from screen distance
         and print to output window
-        if self._layerManager.notebook.GetSelection() != 1:
+        if self._layerManager.notebook.GetSelection() != self._layerManager.GetNBPageIndex('console'):
         dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-06-02 09:37:36 UTC (rev 46513)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-06-02 12:09:51 UTC (rev 46514)
@@ -1209,7 +1209,7 @@
             lmgr = self.parent.GetLayerManager()
             if lmgr:
                 lmgr.toolbars['tools'].Enable('vdigit', enable = True)
-                lmgr.notebook.SetSelection(1)
+                lmgr.SetNBPage('console')
             self.digit.CloseMap()
             if lmgr:
                 lmgr.GetLogWindow().GetProgressBar().SetValue(0)
@@ -1401,7 +1401,7 @@
             event.Skip()
             return
         eId = event.GetId()
         if eId == self.view:
             self.lmgr.nviz.SetPage('view')
@@ -1444,7 +1444,7 @@
         self.parent.MapWindow.polycoords = []
         # return to map layer page (gets rid of ugly exit bug)
-        self.lmgr.notebook.SetSelection(0)
+        self.lmgr.SetNBPage('layers')
         # disable the toolbar
         self.parent.RemoveToolbar("nviz")
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-06-02 09:37:36 UTC (rev 46513)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-06-02 12:09:51 UTC (rev 46514)
@@ -127,6 +127,7 @@
         # creating widgets
         self._createMenuBar()
         self.statusbar = self.CreateStatusBar(number=1)
+        self.notebookPages = {}
         self.notebook  = self._createNoteBook()
         self.toolbars = { 'main'  : LayerManagerToolbar(parent = self),
                           'tools' : ToolsToolbar(parent = self) }
@@ -163,7 +164,7 @@
         self._auimgr.Update()
-        wx.CallAfter(self.notebook.SetSelection, 0)
+        wx.CallAfter(self.SetNBPage, 'layers')
         # use default window layout ?
         if UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled'):
@@ -221,7 +222,6 @@
             self.notebook = FN.FlatNotebook(parent = self, id = wx.ID_ANY, agwStyle = globalvar.FNPageDStyle)
         else:
             self.notebook = FN.FlatNotebook(parent = self, id = wx.ID_ANY, style = globalvar.FNPageDStyle)
         # create displays notebook widget and add it to main notebook page
         cbStyle = globalvar.FNPageStyle
         if globalvar.hasAgw:
@@ -230,18 +230,22 @@
             self.gm_cb = FN.FlatNotebook(self, id = wx.ID_ANY, style = cbStyle)
         self.gm_cb.SetTabAreaColour(globalvar.FNPageColor)
         self.notebook.AddPage(self.gm_cb, text = _("Map layers"))
+        self.notebookPages['layers'] = self.gm_cb
         # create 'command output' text area
         self.goutput = goutput.GMConsole(self, pageid = 1)
         self.notebook.AddPage(self.goutput, text = _("Command console"))
+        self.notebookPages['console'] = self.goutput
         # create 'search module' notebook page
         self.search = MenuTreeWindow(parent = self)
         self.notebook.AddPage(self.search, text = _("Search module"))
+        self.notebookPages['search'] = self.search
         # create 'python shell' notebook page
         self.pyshell = PyShellWindow(parent = self)
         self.notebook.AddPage(self.pyshell, text = _("Python shell"))
+        self.notebookPages['pyshell'] = self.pyshell
         # bindings
         self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED,    self.OnCBPageChanged)
@@ -249,20 +253,29 @@
         self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING,    self.OnCBPageClosed)
         return self.notebook
+    def SetNBPage(self, page):
+        """!Set notebook page - 'layers', 'console', 'search', 'pyshell', 'nviz'"""
+        self.notebook.SetSelection(self.GetNBPageIndex(page))
+    def GetNBPageIndex(self, page):
+        """!Get notebook page index"""
+        return self.notebook.GetPageIndex(self.notebookPages[page])
     def AddNviz(self):
         """!Add nviz notebook page"""
         self.nviz = nviz_tools.NvizToolWindow(parent = self,
                                               display = self.curr_page.maptree.GetMapDisplay())
         self.notebook.AddPage(self.nviz, text = _("3D view"))
-        self.notebook.SetSelection(self.notebook.GetPageCount() - 1)
+        self.notebookPages['nviz'] = self.nviz
+        self.SetNBPage('nviz')
     def RemoveNviz(self):
         """!Remove nviz notebook page"""
         # print self.notebook.GetPage(1)
-        self.notebook.RemovePage(3)
+        self.notebook.RemovePage(self.GetNBPageIndex('nviz'))
         del self.nviz
-        self.notebook.SetSelection(0)
+        self.SetNBPage('layers')
     def WorkspaceChanged(self):
         """!Update window title"""
@@ -1243,7 +1256,7 @@
         if not self.curr_page:
             self.NewDisplay(show = True)
         self.curr_page.maptree.AddLayer('raster')
     def OnAddRaster3D(self, event):
@@ -1279,7 +1292,7 @@
         self.curr_page.maptree.AddLayer('vector')
     def OnAddVectorMisc(self, event):
@@ -1296,12 +1309,12 @@
     def OnAddVectorTheme(self, event):
         """!Add thematic vector map to the current layer tree"""
         self.curr_page.maptree.AddLayer('thememap')
     def OnAddVectorChart(self, event):
         """!Add chart vector map to the current layer tree"""
         self.curr_page.maptree.AddLayer('themechart')
     def OnAddOverlay(self, event):
@@ -1322,32 +1335,32 @@
         """!Add 3D raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('3d-raster')
     def OnAddRasterRGB(self, event):
         """!Add RGB raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('rgb')
     def OnAddRasterHIS(self, event):
         """!Add HIS raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('his')
     def OnAddRasterShaded(self, event):
         """!Add shaded relief raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('shaded')
     def OnAddRasterArrow(self, event):
         """!Add flow arrows raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('rastarrow')
     def OnAddRasterNum(self, event):
         """!Add cell number raster map to the current layer tree"""
         self.curr_page.maptree.AddLayer('rastnum')
     def OnAddCommand(self, event):
@@ -1356,7 +1369,7 @@
         self.curr_page.maptree.AddLayer('command')
         # show map display
@@ -1368,7 +1381,7 @@
         self.curr_page.maptree.AddLayer('group')
         # show map display
@@ -1376,17 +1389,17 @@
     def OnAddGrid(self, event):
         """!Add grid map layer to the current layer tree"""
         self.curr_page.maptree.AddLayer('grid')
     def OnAddGeodesic(self, event):
         """!Add geodesic line map layer to the current layer tree"""
         self.curr_page.maptree.AddLayer('geodesic')
     def OnAddRhumb(self, event):
         """!Add rhumb map layer to the current layer tree"""
         self.curr_page.maptree.AddLayer('rhumb')
     def OnAddLabels(self, event):
@@ -1395,7 +1408,7 @@
         self.curr_page.maptree.AddLayer('labels')
         # show map display
@@ -1448,10 +1461,10 @@
         if event.ControlDown():
             if kc == wx.WXK_TAB:
                 # switch layer list / command output
-                if self.notebook.GetSelection() == 0:
-                    self.notebook.SetSelection(1)
+                if self.notebook.GetSelection() == self.GetNBPageIndex('layers'):
+                    self.SetNBPage('console')
                 else:
         try:
             ckc = chr(kc)
