[GRASS-SVN] r46545 -
grass/branches/releasebranch_6_4/scripts/i.spectral
svn_grass at osgeo.org
Fri Jun 3 07:56:15 EDT 2011
Author: neteler
Date: 2011-06-03 04:56:15 -0700 (Fri, 03 Jun 2011)
New Revision: 46545
grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral
fix syntax
Modified: grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral
--- grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral 2011-06-03 11:33:01 UTC (rev 46544)
+++ grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral 2011-06-03 11:56:15 UTC (rev 46545)
@@ -245,10 +245,10 @@
## if more then 2 points we can draw an interpolated spline:
#if [ $PARAM_NUM -gt 2 ]
#then
-# echo "set data style linespoints" >> spectrum.gnuplot
+# echo "set style data linespoints" >> spectrum.gnuplot
# echo "plot 'data' with points pt 779, '' smooth csplines t 'spline interpolated'" >> spectrum.gnuplot
#else
- echo "set data style lines" >> spectrum.gnuplot
+ echo "set style data lines" >> spectrum.gnuplot
rm -f data.dum
