[GRASS-SVN] r46551 - grass/trunk/vector/v.net.alloc
svn_grass at osgeo.org
Fri Jun 3 12:16:53 EDT 2011
Author: mmetz
Date: 2011-06-03 09:16:53 -0700 (Fri, 03 Jun 2011)
New Revision: 46551
grass/trunk/vector/v.net.alloc/v.net.alloc.html
update manual
Modified: grass/trunk/vector/v.net.alloc/v.net.alloc.html
--- grass/trunk/vector/v.net.alloc/v.net.alloc.html 2011-06-03 16:16:31 UTC (rev 46550)
+++ grass/trunk/vector/v.net.alloc/v.net.alloc.html 2011-06-03 16:16:53 UTC (rev 46551)
@@ -3,8 +3,9 @@
<em>v.net.alloc</em> allocates subnets for nearest centres (direction from
centre). Centre node must be opened (costs >= 0). Costs of centre node are
used in calculation. Supported are cost assignments for both arcs and nodes,
-and also different in both directions of a vector line. For areas cost will
-be calculated along boundary lines.
+and also different in both directions of a vector line. For areas, costs will
+be calculated along boundary lines. The input vector map for
+<em>v.net.alloc</em> needs to be prepared with <em>v.net operation=connect</em>.
<h2>NOTES</h2>
