[GRASS-SVN] r46563 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Sat Jun 4 03:21:18 EDT 2011
Author: mmetz
Date: 2011-06-04 00:21:18 -0700 (Sat, 04 Jun 2011)
New Revision: 46563
grass/trunk/vector/v.in.lidar/main.c
add option filter by return type
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2011-06-04 07:18:33 UTC (rev 46562)
+++ grass/trunk/vector/v.in.lidar/main.c 2011-06-04 07:21:18 UTC (rev 46563)
@@ -33,6 +33,11 @@
# define MAX(a,b) ((a>b) ? a : b)
#endif
+#define LAS_ALL 0
+#define LAS_FIRST 1
+#define LAS_LAST 2
+#define LAS_MID 3
* ASPRS Standard LIDAR Point Classes
* Classification Value (bits 0:4) : Meaning
@@ -105,7 +110,7 @@
int i;
float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
struct GModule *module;
- struct Option *in_opt, *out_opt, *spat_opt;
+ struct Option *in_opt, *out_opt, *spat_opt, *filter_opt;
struct Option *outloc_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
@@ -133,12 +138,13 @@
double scale_x, scale_y, scale_z, offset_x, offset_y, offset_z;
int las_point_format;
int have_time, have_color;
+ int return_filter;
unsigned int not_valid;
struct line_pnts *Points;
struct line_cats *Cats;
- unsigned int n_features, feature_count, n_outside;
+ unsigned int n_features, feature_count, n_outside, n_filtered;
int overwrite;
G_gisinit(argv[0]);
@@ -172,6 +178,14 @@
outloc_opt->description = _("Name for new location to create");
outloc_opt->key_desc = "name";
+ filter_opt = G_define_option();
+ filter_opt->key = "filter";
+ filter_opt->type = TYPE_STRING;
+ filter_opt->required = NO;
+ filter_opt->label = _("Only import points of selected return type");
+ filter_opt->description = _("If not specified, all points are imported");
+ filter_opt->options = "first,last,mid";
print_flag = G_define_flag();
print_flag->key = 'p';
print_flag->description =
@@ -263,6 +277,17 @@
+ return_filter = LAS_ALL;
+ if (filter_opt->answer) {
+ if (strcmp(filter_opt->answer, "first") == 0)
+ return_filter = LAS_FIRST;
+ else if (strcmp(filter_opt->answer, "last") == 0)
+ return_filter = LAS_LAST;
+ else if (strcmp(filter_opt->answer, "mid") == 0)
+ return_filter = LAS_MID;
+ else
+ G_fatal_error(_("Unknown filter option <%s>"), filter_opt->answer);
if (region_flag->answer) {
if (spat_opt->answer)
@@ -590,6 +615,7 @@
not_valid = 0;
feature_count = 0;
n_outside = 0;
+ n_filtered = 0;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -618,7 +644,34 @@
continue;
+ if (return_filter != LAS_ALL) {
+ int return_no = LASPoint_GetReturnNumber(LAS_point);
+ int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
+ int skipme = 1;
+ if (n_returns > 1) {
+ switch (return_filter) {
+ case LAS_FIRST:
+ if (return_no == 1)
+ skipme = 0;
+ break;
+ case LAS_LAST:
+ if (return_no == n_returns)
+ skipme = 0;
+ break;
+ case LAS_MID:
+ if (return_no > 1 && return_no < n_returns)
+ skipme = 0;
+ break;
+ if (skipme) {
+ n_filtered++;
+ continue;
Vect_append_point(Points, x, y, z);
Vect_cat_set(Cats, 1, cat);
Vect_write_line(&Map, GV_POINT, Points, Cats);
@@ -722,11 +775,13 @@
Vect_build(&Map);
Vect_close(&Map);
- G_message(_("%d points imported"), n_features - not_valid - n_outside);
+ G_message(_("%d points imported"), n_features - not_valid - n_outside - n_filtered);
if (not_valid)
G_message(_("%d input points were not valid"), not_valid);
if (n_outside)
G_message(_("%d input points were outside of the selected area"), n_outside);
+ if (n_filtered)
+ G_message(_("%d input points were filtered by return number"), n_filtered);
/* Extend current window based on dataset. */
