[GRASS-SVN] r46565 - grass/branches/develbranch_6/vector/v.in.ogr
svn_grass at osgeo.org
Sat Jun 4 03:31:29 EDT 2011
Author: mmetz
Date: 2011-06-04 00:31:29 -0700 (Sat, 04 Jun 2011)
New Revision: 46565
grass/branches/develbranch_6/vector/v.in.ogr/main.c
optimize topo cleaning
Modified: grass/branches/develbranch_6/vector/v.in.ogr/main.c
--- grass/branches/develbranch_6/vector/v.in.ogr/main.c 2011-06-04 07:28:05 UTC (rev 46564)
+++ grass/branches/develbranch_6/vector/v.in.ogr/main.c 2011-06-04 07:31:29 UTC (rev 46565)
@@ -1010,7 +1010,12 @@
Vect_clean_small_angles_at_nodes(&Tmp, GV_BOUNDARY, NULL);
} while (nmodif > 0);
+ /* merge boundaries */
G_message("%s", separator);
+ G_message(_("Merge boundaries:"));
+ Vect_merge_lines(&Tmp, GV_BOUNDARY, NULL, NULL);
+ G_message("%s", separator);
if (type & GV_BOUNDARY) { /* that means lines were converted boundaries */
G_message(_("Change boundary dangles to lines:"));
Vect_chtype_dangles(&Tmp, -1.0, NULL);
@@ -1030,11 +1035,6 @@
Vect_remove_bridges(&Tmp, NULL);
- /* merge boundaries */
- G_message("%s", separator);
- G_message(_("Merge boundaries:"));
- Vect_merge_lines(&Tmp, GV_BOUNDARY, NULL, NULL);
/* Boundaries are hopefully clean, build areas */
Vect_build_partial(&Tmp, GV_BUILD_ATTACH_ISLES);
