[GRASS-SVN] r46567 -
	grass/branches/develbranch_6/scripts/r.fillnulls
    svn_grass at osgeo.org
    Sat Jun  4 23:44:01 EDT 2011
Author: neteler
Date: 2011-06-04 20:44:00 -0700 (Sat, 04 Jun 2011)
New Revision: 46567
   grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
modernized MASK management to fix white space in path support
Modified: grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
--- grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls	2011-06-05 03:38:46 UTC (rev 46566)
+++ grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls	2011-06-05 03:44:00 UTC (rev 46567)
@@ -80,10 +80,6 @@
 LC_NUMERIC=C
 export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
 # what to do in case of user break:
 exitprocedure()
@@ -92,8 +88,8 @@
    g.remove rast="$TMP1","$TMP1.buf","${TMP1}_filled" --quiet > /dev/null
    g.remove vect="$VECTTMP" --quiet > /dev/null
-   #restore user mask if present:
-   if test -f $LOCATION/cell/$USERMASK ; then
+   eval `g.findfile element=cell file=$USERMASK`
+   if [ "$file" ] ; then
       g.remove rast=MASK --quiet > /dev/null
       g.rename "$USERMASK",MASK --quiet > /dev/null
    fi
@@ -113,8 +109,8 @@
 fi
 #check if input file exists
-#if test -f $LOCATION/cell/$GIS_OPT_INPUT
-if [ -z `g.findfile elem=cell file="$GIS_OPT_INPUT" | grep ^file | cut -f2 -d=` ] ; then
+eval `g.findfile element=cell file="$GIS_OPT_INPUT"`
+if [ ! "$file" ] ; then
     g.message -e "<$GIS_OPT_INPUT> does not exist! Aborting."
     exit 1
 fi
@@ -122,8 +118,8 @@
 #check if a MASK is already present:
 MASKTMP=mask.$$
 USERMASK="usermask_$MASKTMP"
-if test -f "$LOCATION/cell/MASK"
-then
+eval `g.findfile element=cell file=MASK`
+if [ "$file" ] ; then
  g.message "A user raster mask (MASK) is present. Saving it..."
  g.rename MASK,"$USERMASK" --quiet > /dev/null
 fi
@@ -186,8 +182,8 @@
   g.remove MASK > /dev/null
   #restoring user's mask, if present:
-  if test -f "$LOCATION/cell/$USERMASK"
-  then
    g.message "Restoring user mask (MASK)..."
   fi
@@ -203,8 +199,8 @@
 #remove internal MASK first -- WHY???? MN 10/2005
-if test -f "$LOCATION/cell/$USERMASK"
-then
+eval `g.findfile element=cell file=$USERMASK`
   g.message "Using user mask while interpolating"
   RST_CMD="v.surf.rst zcol=value tension=$GIS_OPT_TENSION smooth=$GIS_OPT_SMOOTH maskmap=$USERMASK"
 else
@@ -224,8 +220,8 @@
 g.message "Note: Above warnings may be ignored."
-then
 fi
