[GRASS-SVN] r46569 -
grass/branches/releasebranch_6_4/scripts/r.fillnulls
svn_grass at osgeo.org
Sat Jun 4 23:52:06 EDT 2011
Author: neteler
Date: 2011-06-04 20:52:06 -0700 (Sat, 04 Jun 2011)
New Revision: 46569
grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls
backported quoting fixes from 6.5; backported less chatty
Modified: grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls
--- grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls 2011-06-05 03:49:12 UTC (rev 46568)
+++ grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls 2011-06-05 03:52:06 UTC (rev 46569)
@@ -83,32 +83,30 @@
# what to do in case of user break:
exitprocedure()
- g.message -e 'User break!'
- #delete internal mask and any TMP files:
- g.remove rast=$TMP1,$TMP1.buf,${TMP1}_filled > /dev/null
- g.remove vect=${VECTTMP} > /dev/null
- #restore user mask if present:
- eval `g.findfile element=cell file=$USERMASK`
- if [ "$file" ] ; then
- g.remove rast=MASK > /dev/null
- g.rename $USERMASK,MASK > /dev/null
- fi
- exit 1
+ g.message -e 'User break!'
+ #delete internal mask and any TMP files:
+ g.remove rast="$TMP1","$TMP1.buf","${TMP1}_filled" --quiet > /dev/null
+ g.remove vect="$VECTTMP" --quiet > /dev/null
+ #restore user mask if present:
+ eval `g.findfile element=cell file=$USERMASK`
+ if [ "$file" ] ; then
+ g.remove rast=MASK --quiet > /dev/null
+ g.rename "$USERMASK",MASK --quiet > /dev/null
+ fi
+ exit 1
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
#test:
-if [ ! $GIS_OPT_INPUT ]
-then
- g.message "Please provide an input map name."
- exit 1
+if [ -z "$GIS_OPT_INPUT" ] ; then
+ g.message "Please provide an input map name."
+ exit 1
fi
-if [ ! $GIS_OPT_OUTPUT ]
-then
- g.message "Please provide an output name."
- exit 1
+if [ -z "$GIS_OPT_OUTPUT" ] ; then
+ g.message "Please provide an output name."
+ exit 1
fi
#check if input file exists
@@ -120,11 +118,11 @@
#check if a MASK is already present:
MASKTMP=mask.$$
-USERMASK=usermask_${MASKTMP}
+USERMASK="usermask_$MASKTMP"
eval `g.findfile element=cell file=MASK`
g.message "A user raster mask (MASK) is present. Saving it..."
- g.rename MASK,$USERMASK > /dev/null
+ g.rename MASK,"$USERMASK" --quiet > /dev/null
fi
#make a mask of NULL cells
@@ -136,7 +134,7 @@
g.message "Locating and isolating NULL areas..."
#creating 0/1 map:
-r.mapcalc $TMP1="if(isnull($GIS_OPT_INPUT),1,null())"
+r.mapcalc "$TMP1 = if(isnull($GIS_OPT_INPUT),1,null())"
#generate a ring:
# the buffer is set to three times the map resolution so you get nominally
@@ -146,38 +144,40 @@
# around the edges when distance > mean (.5 of the time? diagonals? worse
# when ewres!=nsres).
eval `g.region -gm | grep res`
+# check-me: quoting ok?
RES="`echo $nsres $ewres | awk '{printf "%f", ($1+$2) * 3. / 2.}'`" # avg*3
-r.buffer input=$TMP1 dist=$RES out=$TMP1.buf
+r.buffer input="$TMP1" dist="$RES" out="$TMP1.buf"
if [ $? -ne 0 ] ; then
g.message -e "$0 abandoned. Removing temporary map, restoring user mask if needed:"
- g.remove rast=MASK,$TMP1,$TMP1.buf,${TMP1}_filled > /dev/null
+ g.remove rast=MASK,"$TMP1","$TMP1.buf","${TMP1}_filled" --quiet > /dev/null
exit 1
fi
-r.mapcalc "MASK=if($TMP1.buf==2,1,null())"
+r.mapcalc "MASK = if($TMP1.buf==2,1,null())"
# now we only see the outlines of the NULL areas if looking at INPUT.
# Use this outline (raster border) for interpolating the fill data:
VECTTMP=vecttmp_fillnulls_$$
g.message "Creating interpolation points..."
-r.to.vect input=$GIS_OPT_INPUT output=${VECTTMP} feature=point
+r.to.vect input="$GIS_OPT_INPUT" output="$VECTTMP" feature=point
g.message -e "$0 abandoned. Removing temporary maps, restoring user mask if needed:"
exit 1
fi
#count number of points to control segmax parameter for interpolation:
-POINTSNUMBER="`v.info -t map=${VECTTMP} | grep points | cut -d'=' -f2`"
+# check-me: quoting?
+POINTSNUMBER="`v.info -t map="$VECTTMP" | grep points | cut -d'=' -f2`"
g.message "Interpolating $POINTSNUMBER points"
-if [ $POINTSNUMBER -lt 2 ] ; then
+if [ "$POINTSNUMBER" -lt 2 ] ; then
g.message -w "Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?"
#remove internal MASK first
g.remove MASK > /dev/null
@@ -186,12 +186,12 @@
g.message "Restoring user mask (MASK)..."
fi
#cleanup
exit 1
fi
@@ -209,13 +209,13 @@
fi
SEGMAX=600
-if [ $POINTSNUMBER -ge $SEGMAX ] ; then
+if [ "$POINTSNUMBER" -ge "$SEGMAX" ] ; then
g.message "Using segmentation for interpolation..."
- $RST_CMD input=${VECTTMP} elev=${TMP1}_filled #2> /dev/null
+ $RST_CMD input="$VECTTMP" elev="${TMP1}_filled" #2> /dev/null
else
#if less than $SEGMAX points, use no segmentation for speedup:
g.message "Using no segmentation for interpolation as not needed..."
- $RST_CMD input=${VECTTMP} elev=${TMP1}_filled segmax=$SEGMAX #2> /dev/null
+ $RST_CMD input="$VECTTMP" elev="${TMP1}_filled" segmax="$SEGMAX" #2> /dev/null
fi
g.message "Note: Above warnings may be ignored."
@@ -223,22 +223,22 @@
#restoring user's mask, if present:
- g.message "Restoring user mask (MASK)..."
+ g.message "Restoring user mask (MASK)..."
fi
#patch orig and fill map
g.message "Patching fill data into NULL areas..."
# we can use --o here as g.parser already checks on startup
-r.patch in=$GIS_OPT_INPUT,${TMP1}_filled out=$GIS_OPT_OUTPUT --o
+r.patch in="$GIS_OPT_INPUT","${TMP1}_filled" out="$GIS_OPT_OUTPUT" --o
#cleanup
-g.remove rast=$TMP1,$TMP1.buf,${TMP1}_filled > /dev/null
-g.remove vect=${VECTTMP} > /dev/null
+g.remove rast="$TMP1","$TMP1.buf","${TMP1}_filled" --quiet > /dev/null
+g.remove vect="$VECTTMP" --quiet > /dev/null
g.message "Filled raster map is: $GIS_OPT_OUTPUT"
# write cmd history:
-r.support $GIS_OPT_OUTPUT history="${CMDLINE}"
+r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
g.message "Done."
