[GRASS-SVN] r46605 - in grass/branches/develbranch_6/gui/wxpython:
	docs xml
    svn_grass at osgeo.org
    Wed Jun  8 05:00:09 EDT 2011
Author: martinl
Date: 2011-06-08 02:00:09 -0700 (Wed, 08 Jun 2011)
New Revision: 46605
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: change key shortcuts for adding new map layers (Ctrl+V is usually used for 'paste')
       (merge r46604 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-06-08 08:56:14 UTC (rev 46604)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-06-08 09:00:09 UTC (rev 46605)
@@ -304,12 +304,15 @@
   <dd>Load workspace from file</dd>
   <dt>Ctrl+S</dt>
   <dd>Close workspace</dd>
-  <dt>Ctrl+L</dt>
-  <dd>Load map layers</dd>
-  <dt>Ctrl+R</dt>
-  <dd>Add raster map layer</dd>
-  <dt>Ctrl+V</dt>
-  <dd>Add vector map layer</dd>
+</dl>
+<b>Map Layers</b>
+  <dt>Ctrl+Shift+L</dt>
+  <dd>Add multiple raster or vector map layers to current map display</dd>
+  <dt>Ctrl+Shift+R</dt>
+  <dd>Add raster map layer to current map display</dd>
+  <dt>Ctrl+Shift+V</dt>
+  <dd>Add vector map layer to current map display</dd>
   <dt>Ctrl+W</dt>
   <dd>Close current map display</dd>
 </dl>
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-06-08 08:56:14 UTC (rev 46604)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-06-08 09:00:09 UTC (rev 46605)
@@ -66,19 +66,19 @@
 	      <label>Add multiple rasters or vectors</label>
 	      <help>Add multiple raster or vector map layers to current display</help>
 	      <handler>OnAddMaps</handler>
-	      <shortcut>Ctrl+L</shortcut>
+	      <shortcut>Ctrl+Shift+L</shortcut>
 	    </menuitem>
 	    <menuitem>
 	      <label>Add raster</label>
 	      <help>Add raster map layer to current display</help>
 	      <handler>OnAddRaster</handler>
-	      <shortcut>Ctrl+R</shortcut>
+	      <shortcut>Ctrl+Shift+R</shortcut>
 	    </menuitem>
 	    <menuitem>
 	      <label>Add vector</label>
 	      <help>Add vector map layer to current display</help>
 	      <handler>OnAddVector</handler>
-	      <shortcut>Ctrl+V</shortcut>
+	      <shortcut>Ctrl+Shift+V</shortcut>
 	    </menuitem>
 	  </items>
 	</menu>
