[GRASS-SVN] r46624 - grass/branches/releasebranch_6_4/vector/v.digit
svn_grass at osgeo.org
Wed Jun 8 20:26:23 EDT 2011
Author: neteler
Date: 2011-06-08 17:26:23 -0700 (Wed, 08 Jun 2011)
New Revision: 46624
grass/branches/releasebranch_6_4/vector/v.digit/attr.c
grass/branches/releasebranch_6_4/vector/v.digit/c_face.c
grass/branches/releasebranch_6_4/vector/v.digit/centre.c
grass/branches/releasebranch_6_4/vector/v.digit/display.c
grass/branches/releasebranch_6_4/vector/v.digit/form.c
grass/branches/releasebranch_6_4/vector/v.digit/generate.c
grass/branches/releasebranch_6_4/vector/v.digit/line.c
grass/branches/releasebranch_6_4/vector/v.digit/main.c
grass/branches/releasebranch_6_4/vector/v.digit/var.c
grass/branches/releasebranch_6_4/vector/v.digit/vertex.c
grass/branches/releasebranch_6_4/vector/v.digit/zoom.c
i18N; error trap (backport from 6.5)
Modified: grass/branches/releasebranch_6_4/vector/v.digit/attr.c
--- grass/branches/releasebranch_6_4/vector/v.digit/attr.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/attr.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -10,6 +10,7 @@
#include <grass/display.h>
#include <grass/colors.h>
#include <grass/form.h>
+#include <grass/glocale.h>
#include "global.h"
#include "proto.h"
@@ -90,7 +91,7 @@
G_debug(2, "Record already existed.");
else if (ret == -1) {
- G_warning("Cannot create new record.");
+ G_warning("%s", _("Cannot create new record."));
@@ -123,7 +124,7 @@
Fi = Vect_get_field(&Map, field);
if (Fi == NULL) {
i_message(MSG_OK, MSGI_ERROR,
- "Database table for this layer is not defined");
+ _("Database table for this layer is not defined"));
return -1;
@@ -133,7 +134,7 @@
/* First check if already exists */
driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (driver == NULL) {
- sprintf(buf, "Cannot open database %s by driver %s", Fi->database,
+ sprintf(buf, _("Cannot open database %s by driver %s"), Fi->database,
Fi->driver);
i_message(MSG_OK, MSGI_ERROR, buf);
return -1;
@@ -141,7 +142,7 @@
ret = db_select_value(driver, Fi->table, Fi->key, cat, Fi->key, &value);
if (ret == -1) {
db_close_database_shutdown_driver(driver);
- sprintf(buf, "Cannot select record from table %s", Fi->table);
+ sprintf(buf, _("Cannot select record from table %s"), Fi->table);
return -1;
@@ -149,11 +150,11 @@
sprintf(buf, "insert into %s (%s) values (%d)", Fi->table, Fi->key,
cat);
db_set_string(&sql, buf);
- G_debug(2, db_get_string(&sql));
+ G_debug(2, "%s", db_get_string(&sql));
ret = db_execute_immediate(driver, &sql);
if (ret != DB_OK) {
- sprintf(buf, "Cannot insert new record: %s", db_get_string(&sql));
+ sprintf(buf, _("Cannot insert new record: %s"), db_get_string(&sql));
return -1;
@@ -187,8 +188,8 @@
dc->Points = Vect_new_line_struct();
dc->Cats = Vect_new_cats_struct();
- i_prompt("Display categories:");
- i_prompt_buttons("Select line", "", "Quit tool");
+ i_prompt(_("Display categories:"));
+ i_prompt_buttons(_("Select line"), "", _("Quit tool"));
dc->thresh = get_thresh();
G_debug(2, "thresh = %f", dc->thresh);
@@ -297,8 +298,8 @@
cc->Src_Cats = Vect_new_cats_struct();
cc->Dest_Cats = Vect_new_cats_struct();
- i_prompt("Copy attributes:");
- i_prompt_buttons("Select source object", "", "Quit tool");
+ i_prompt(_("Copy attributes:"));
+ i_prompt_buttons(_("Select source object"), "", _("Quit tool"));
cc->thresh = get_thresh();
G_debug(2, "thresh = %f", cc->thresh);
@@ -392,18 +393,18 @@
if (cc->dest_line > 0) {
display_line(cc->dest_line, SYMB_HIGHLIGHT, 1);
display_line(cc->src_line, SYMB_HIGHLIGHT, 1);
- i_prompt("Select the target object");
- i_prompt_buttons("Conform and select next", "Deselect Target",
- "Quit tool");
+ i_prompt(_("Select the target object"));
+ i_prompt_buttons(_("Conform and select next"), _("Deselect Target"),
+ _("Quit tool"));
else if (cc->src_line > 0) {
- i_prompt_buttons("Select", "Deselect Source", "Quit tool");
+ i_prompt_buttons(_("Select"), _("Deselect Source"), _("Quit tool"));
else {
return 0;
@@ -458,8 +459,8 @@
da->Points = Vect_new_line_struct();
da->Cats = Vect_new_cats_struct();
- i_prompt("Display attributes:");
+ i_prompt(_("Display attributes:"));
da->thresh = get_thresh();
G_debug(2, "thresh = %f", da->thresh);
@@ -532,23 +533,24 @@
G_debug(3, "field = %d category = %d", da->Cats->field[j],
da->Cats->cat[j]);
- sprintf(title, "Layer %d", da->Cats->field[j]);
+ sprintf(title, _("Layer %d"), da->Cats->field[j]);
db_set_string(&da->html, "");
- db_append_string(&da->html,
- "<HTML><HEAD><TITLE>Attributes</TITLE><BODY>");
+ db_append_string(&da->html, "<HTML><HEAD><TITLE>");
+ db_append_string(&da->html, _("Attributes"));
+ db_append_string(&da->html, "</TITLE><BODY>");
- sprintf(buf, "layer: %d<BR>category: %d<BR>",
+ sprintf(buf, _("layer: %d<BR>category: %d<BR>"),
da->Cats->field[j], da->Cats->cat[j]);
db_append_string(&da->html, buf);
Fi = Vect_get_field(&Map, da->Cats->field[j]);
if (Fi == NULL) {
- "Database connection not defined<BR>");
+ _("Database connection not defined<BR>"));
else {
sprintf(buf,
- "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>",
+ _("driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"),
Fi->driver, Fi->database, Fi->table, Fi->key);
@@ -561,19 +563,20 @@
G_free(Fi);
db_append_string(&da->html, "</BODY></HTML>");
- G_debug(3, db_get_string(&da->html));
+ G_debug(3, "%s", db_get_string(&da->html));
F_open(title, db_get_string(&da->html));
else {
- sprintf(title, "Line %d", line);
+ sprintf(title, _("Line %d"), line);
db_init_string(&da->html);
- db_append_string(&da->html, "No categories");
+ db_append_string(&da->html, _("No categories"));
@@ -644,7 +647,7 @@
/* Does record exist ? */
Fi->driver);
return -1;
@@ -653,7 +656,7 @@
G_debug(3, "n records = %d", ret);
if (ret == -1) {
return -1;
@@ -662,8 +665,7 @@
return 0;
sprintf(buf,
- "There are no more features with category %d (layer %d) in the map, but there is "
- "record in the table. Delete this record?", cat, field);
+ _("There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"), cat, field);
ret = i_message(MSG_YESNO, MSGI_QUESTION, buf);
if (ret == 1)
@@ -671,11 +673,11 @@
sprintf(buf, "delete from %s where %s = %d", Fi->table, Fi->key, cat);
if (ret != DB_OK) {
- sprintf(buf, "Cannot delete record: %s", db_get_string(&sql));
+ sprintf(buf, _("Cannot delete record: %s"), db_get_string(&sql));
return -1;
Modified: grass/branches/releasebranch_6_4/vector/v.digit/c_face.c
--- grass/branches/releasebranch_6_4/vector/v.digit/c_face.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/c_face.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -8,6 +8,7 @@
#include <grass/Vect.h>
#include <grass/dbmi.h>
#include <grass/raster.h>
#include "global.h"
#include "proto.h"
@@ -179,13 +180,13 @@
driver = db_start_driver(Fi->driver);
- G_warning("Cannot open driver %s", Fi->driver);
+ G_warning(_("Cannot open driver %s"), Fi->driver);
return TCL_OK;
db_init_handle(&handle);
db_set_handle(&handle, Vect_subst_var(Fi->database, &Map), NULL);
if (db_open_database(driver, &handle) != DB_OK) {
- G_warning("Cannot open database %s", Fi->database);
+ G_warning(_("Cannot open database %s"), Fi->database);
db_shutdown_driver(driver);
return TCL_OK;
@@ -222,6 +223,7 @@
dbString sql, err;
dbDriver *driver;
dbHandle handle;
+ char buf[1000];
G_debug(2, "c_create_table() field = %s key = %s cols = %s", argv[1],
argv[3], argv[4]);
@@ -236,8 +238,8 @@
- db_set_string(&err, "Cannot open driver ");
+ db_set_string(&err, _("Cannot open driver "));
db_append_string(&err, Fi->driver);
Tcl_SetVar(Toolbox, "create_table_msg", db_get_string(&err),
TCL_GLOBAL_ONLY);
@@ -246,11 +248,9 @@
- db_set_string(&err, "Cannot open database ");
- db_append_string(&err, Fi->database);
- db_append_string(&err, " by driver ");
- db_append_string(&err, Fi->driver);
+ sprintf(buf, _("Cannot open database %s by driver %s"), Fi->database, Fi->driver);
+ db_set_string(&err, buf);
db_append_string(&err, db_get_error_msg());
@@ -263,11 +263,11 @@
db_append_string(&sql, " ( ");
db_append_string(&sql, argv[4]);
db_append_string(&sql, " ) ");
if (db_execute_immediate(driver, &sql) != DB_OK) {
- G_warning("Cannot create table: %s", db_get_string(&sql));
- db_set_string(&err, "Cannot create table: ");
+ G_warning(_("Cannot create table: %s"), db_get_string(&sql));
+ db_set_string(&err, _("Cannot create table: "));
db_append_string(&err, db_get_string(&sql));
db_append_string(&err, "\n");
@@ -279,8 +279,8 @@
if (db_create_index2(driver, Fi->table, argv[3]) != DB_OK) {
- G_warning("Cannot create index");
- db_set_string(&err, "Cannot create index:\n");
+ G_warning("%s", _("Cannot create index"));
+ db_set_string(&err, _("Cannot create index:\n"));
db_close_database(driver);
@@ -291,8 +291,8 @@
if (db_grant_on_table
(driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
- G_warning("Cannot grant privileges on table %s", Fi->table);
- db_set_string(&err, "Cannot grant privileges on table:\n");
+ G_warning(_("Cannot grant privileges on table %s"), Fi->table);
+ db_set_string(&err, _("Cannot grant privileges on table:\n"));
@@ -309,8 +309,7 @@
if (ret == -1) {
db_set_string(&err,
- "Cannot add database link to vector, link for given field probably "
- "already exists.");
+ _("Cannot add database link to vector, link for given field probably already exists."));
TCL_GLOBAL_ONLY);
return TCL_OK;
Modified: grass/branches/releasebranch_6_4/vector/v.digit/centre.c
--- grass/branches/releasebranch_6_4/vector/v.digit/centre.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/centre.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -53,7 +53,7 @@
driver_close();
symb_init_gui();
- i_prompt("Select tool");
+ i_prompt(_("Select tool"));
void next_tool(void)
@@ -175,7 +175,7 @@
Vect_close(&Map);
if (1 == G_put_window(&GRegion))
- G_message(_("Region restored to original extent."));
+ G_message("%s", _("Region restored to original extent."));
/* clear the screen */
Tcl_Eval(Toolbox, ".screen.canvas delete all");
Modified: grass/branches/releasebranch_6_4/vector/v.digit/display.c
--- grass/branches/releasebranch_6_4/vector/v.digit/display.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/display.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -234,8 +234,11 @@
for (i = 0; i < nbgcmd; i++) {
putenv((i > 0) ? "GRASS_PNG_READ=TRUE" : "GRASS_PNG_READ=FALSE");
- if (Bgcmd[i].on)
- system(Bgcmd[i].cmd);
+ if (Bgcmd[i].on) {
+ if (system(Bgcmd[i].cmd) == -1) {
+ G_warning("System call has failed");
sprintf(cmd_buf, "image create photo bgimage -file {%s.ppm}", ppmfile);
Modified: grass/branches/releasebranch_6_4/vector/v.digit/form.c
--- grass/branches/releasebranch_6_4/vector/v.digit/form.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/form.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -14,6 +14,7 @@
#include "proto.h"
/* Structure to store column names and values */
@@ -93,7 +94,7 @@
/* Check if all internal values are set */
if (Drvname == NULL || Dbname == NULL || Tblname == NULL || Key == NULL) {
- G_warning("db connection was not set by form\n");
+ G_warning("%s", _("db connection was not set by form\n"));
sprintf(buf, "set submit_msg \"db connection was not set by form.\"");
Tcl_Eval(interp, buf);
Tcl_Eval(interp, "set submit_result 0");
@@ -104,7 +105,7 @@
G_debug(2, "Open driver");
driver = db_start_driver(Drvname);
- G_warning("Cannot open driver\n");
+ G_warning("%s", _("Cannot open driver\n"));
sprintf(buf, "set submit_msg \"Cannot open driver '%s'\"", Drvname);
@@ -116,7 +117,7 @@
db_set_handle(&handle, Dbname, NULL);
G_debug(2, "Open database");
- G_warning("Cannot open database\n");
+ G_warning("%s", _("Cannot open database\n"));
sprintf(buf,
"set submit_msg \"Cannot open database '%s' by driver '%s'\"",
@@ -129,7 +130,7 @@
db_set_string(&table_name, Tblname);
if (db_describe_table(driver, &table_name, &table) != DB_OK) {
- G_warning("Cannot describe table\n");
+ G_warning("%s", _("Cannot describe table\n"));
sprintf(buf, "set submit_msg \"Cannot describe table '%s'\"",
@@ -158,7 +159,7 @@
if (!found && (G_strcasecmp(Columns[i].name, F_ENCODING) != 0)) {
- G_warning("Cannot find column type");
+ G_warning("%s", _("Cannot find column type"));
sprintf(buf, "set submit_msg \"Cannot find column type\"");
@@ -195,7 +196,7 @@
if (Tcl_SetSystemEncoding(interp, Columns[i].value) ==
TCL_ERROR) {
G_warning
- ("Could not set Tcl system encoding to '%s' (%s)",
+ (_("Could not set Tcl system encoding to '%s' (%s)"),
Columns[i].value, Tcl_GetStringResult(interp));
@@ -224,7 +225,7 @@
buf, 2000, NULL, NULL, NULL);
if (ret != TCL_OK) {
- G_warning("Could not convert UTF to external.");
+ G_warning("%s", _("Could not convert UTF to external."));
db_set_string(&strval, Columns[i].value);
else {
@@ -252,7 +253,7 @@
if (ret != DB_OK) {
- G_warning("Cannot update table");
+ G_warning("%s", _("Cannot update table"));
Tcl_VarEval(interp, "set submit_msg \"Cannot update table:\n",
db_get_error_msg(), "\"", NULL);
Modified: grass/branches/releasebranch_6_4/vector/v.digit/generate.c
--- grass/branches/releasebranch_6_4/vector/v.digit/generate.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/generate.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -3,6 +3,7 @@
#include <grass/gis.h>
/* Escape string for use in TCL */
char *escape_tcl_string(char *input)
@@ -73,8 +74,8 @@
driver = db_start_driver(drvname);
- G_warning("Cannot open driver");
- sprintf(buf, "Cannot open driver '%s'<BR>",
+ G_warning("%s", _("Cannot open driver"));
+ sprintf(buf, _("Cannot open driver '%s'<BR>"),
escape_tcl_string(drvname));
*form = G_store(buf);
return -1;
@@ -85,9 +86,9 @@
db_set_handle(&handle, dbname, NULL);
- G_warning("Cannot open database");
+ G_warning("%s", _("Cannot open database"));
- sprintf(buf, "Cannot open database '%s' by driver '%s'<BR>",
+ sprintf(buf, _("Cannot open database '%s' by driver '%s'<BR>"),
escape_tcl_string(dbname), escape_tcl_string(drvname));
return -1;
@@ -102,11 +103,11 @@
G_debug(2, "%s", buf);
if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
- G_warning("Cannot open select cursor");
+ G_warning("%s", _("Cannot open select cursor"));
sprintf(buf,
- "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>",
+ _("Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"),
escape_tcl_string(db_get_string(&sql)),
@@ -117,7 +118,7 @@
table = db_get_cursor_table(&cursor);
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
- G_warning("Cannot fetch next record");
+ G_warning("%s", _("Cannot fetch next record"));
db_close_cursor(&cursor);
@@ -126,7 +127,7 @@
if (!more) {
- G_warning("No database record");
+ G_warning("%s", _("No database record"));
if (format == F_HTML) {
*form = G_store("No record selected.<BR>");
@@ -219,7 +220,7 @@
if (edit_mode == F_EDIT) {
sprintf(buf,
- "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>",
+ _("<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"),
F_ENCODING);
db_append_string(&html, buf);
Modified: grass/branches/releasebranch_6_4/vector/v.digit/line.c
--- grass/branches/releasebranch_6_4/vector/v.digit/line.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/line.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -8,6 +8,7 @@
#include "global.h"
#include "proto.h"
@@ -50,7 +51,9 @@
if (var_geti(VAR_CAT_MODE) != CAT_MODE_NO && var_geti(VAR_INSERT) &&
cat > 0) {
G_debug(2, "Insert new record");
- db_set_string(&html, "<HTML><HEAD><TITLE>Form</TITLE><BODY>");
+ db_set_string(&html, "<HTML><HEAD><TITLE>");
+ db_append_string(&html, _("Form"));
+ db_append_string(&html, "</TITLE><BODY>");
field = var_geti(VAR_FIELD);
ret = new_record(field, cat);
@@ -58,11 +61,11 @@
return -1;
else if (ret == 0) {
- db_append_string(&html, "New record was created.<BR>");
+ db_append_string(&html, _("New record was created.<BR>"));
else { /* record already existed */
- "Record for this category already existed.<BR>");
+ _("Record for this category already existed.<BR>"));
/* Open form */
@@ -80,7 +83,7 @@
if (first_form)
driver_close();
F_clear();
- F_open("Attributes", db_get_string(&html));
+ F_open(_("Attributes"), db_get_string(&html));
if (first_form) {
driver_open();
first_form = 0;
@@ -132,9 +135,9 @@
nl->Points = Vect_new_line_struct();
nl->Cats = Vect_new_cats_struct();
- sprintf(buf, "Digitize new %s:", get_line_type_name(nl->type));
+ sprintf(buf, _("Digitize new %s:"), get_line_type_name(nl->type));
i_prompt(buf);
- i_prompt_buttons("New point", "", "Quit tool");
+ i_prompt_buttons(_("New point"), "", _("Quit tool"));
i_new_line_options(1);
@@ -159,8 +162,8 @@
return 1;
- if (button > 3) /* Do nothing on mouse scroll */
- return 0;
+ if (button > 3) /* Do nothing on mouse scroll */
+ return 0;
if (nl->type & GV_POINTS && (button == 1 || button == 2)) {
snap(&x, &y);
@@ -185,7 +188,7 @@
if (Vect_append_point(nl->Points, x, y, 0) == -1) {
- G_warning("Out of memory! Point not added.");
+ G_warning("%s", _("Out of memory! Point not added."));
return 0;
@@ -218,7 +221,7 @@
if (nl->Points->n_points == 0) {
nl->first = 1;
set_mode(MOUSE_POINT);
@@ -240,14 +243,14 @@
updated_lines_and_nodes_erase_refresh_display();
else
- G_warning("Less than 2 points for line -> nothing written");
+ G_warning("%s", _("Less than 2 points for line -> nothing written"));
return 1;
G_debug(2, "n_points = %d", nl->Points->n_points);
- i_prompt_buttons("New point", "Undo last point", "Close line");
+ i_prompt_buttons(_("New point"), _("Undo last point"), _("Close line"));
return 0;
@@ -331,7 +334,7 @@
display_node(node1, SYMB_BACKGROUND, 1);
display_node(node2, SYMB_BACKGROUND, 1);
- i_prompt_buttons("New Point", "Undo Last Point", "Close line");
+ i_prompt_buttons(_("New Point"), _("Undo Last Point"), _("Close line"));
set_location(D_u_to_d_col(el->Points->x[el->Points->n_points - 1]),
D_u_to_d_row(el->Points->y[el->Points->n_points - 1])
@@ -380,7 +383,7 @@
display_points(el->Points, 1);
set_location(sxn, syn);
else if (button == 2) { /* Undo last point */
if (el->Points->n_points > 1) {
@@ -401,7 +404,7 @@
if (el->Points->n_points == 1)
- i_prompt_buttons("New Point", "", "Delete line and exit");
+ i_prompt_buttons(_("New Point"), "", _("Delete line and exit"));
break;
@@ -474,8 +477,8 @@
dl->Points = Vect_new_line_struct();
dl->Cats = Vect_new_cats_struct();
- i_prompt("Delete point, line, boundary, or centroid:");
- i_prompt_buttons("Select", "Unselect", "Quit tool");
+ i_prompt(_("Delete point, line, boundary, or centroid:"));
+ i_prompt_buttons(_("Select"), _("Unselect"), _("Quit tool"));
dl->thresh = get_thresh();
G_debug(2, "thresh = %f", dl->thresh);
@@ -558,9 +561,9 @@
if (dl->line > 0)
- i_prompt_buttons("Confirm and select next", "Unselect", "Quit tool");
+ i_prompt_buttons(_("Confirm and select next"), _("Unselect"), _("Quit tool"));
else
dl->last_line = dl->line;
dl->first = 0;
@@ -613,8 +616,8 @@
ml->Points = Vect_new_line_struct();
ml->Cats = Vect_new_cats_struct();
- i_prompt("Move point, line, boundary, or centroid:");
- i_prompt_buttons("Select", "", "Quit tool");
+ i_prompt(_("Move point, line, boundary, or centroid:"));
+ i_prompt_buttons(_("Select"), "", _("Quit tool"));
ml->thresh = get_thresh();
G_debug(2, "thresh = %f", ml->thresh);
@@ -665,7 +668,7 @@
NULL, NULL, NULL, NULL);
set_location(D_u_to_d_col(ml->xo), D_u_to_d_row(ml->yo));
- i_prompt_buttons("New location", "Unselect", "Quit tool");
+ i_prompt_buttons(_("New location"), _("Unselect"), _("Quit tool"));
ml->last_line = ml->line;
@@ -699,7 +702,7 @@
if (ml->last_line == 0) {
else
Modified: grass/branches/releasebranch_6_4/vector/v.digit/main.c
--- grass/branches/releasebranch_6_4/vector/v.digit/main.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/main.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -147,7 +147,7 @@
mapset = G_find_vector2(map_opt->answer, G_mapset());
if (mapset == NULL) {
if (new_f->answer) {
- G_message(_("New empty map created."));
+ G_message("%s", _("New empty map created."));
Vect_open_new(&Map, map_opt->answer, 0);
Vect_build(&Map);
Vect_close(&Map);
Modified: grass/branches/releasebranch_6_4/vector/v.digit/var.c
--- grass/branches/releasebranch_6_4/vector/v.digit/var.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/var.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -21,6 +21,7 @@
#include "global.h"
#include "proto.h"
@@ -76,7 +77,7 @@
i++;
- G_warning("Cannot set variable code = %d", code);
+ G_warning(_("Cannot set variable code = %d"), code);
return -1;
@@ -97,7 +98,7 @@
i++;
return -1;
@@ -118,7 +119,7 @@
i++;
return -1;
@@ -139,7 +140,7 @@
i++;
- G_warning("Cannot get type of variable %s", name);
+ G_warning(_("Cannot get type of variable %s"), name);
return -1;
@@ -160,7 +161,7 @@
i++;
- G_warning("Cannot get code of variable %s", name);
+ G_warning(_("Cannot get code of variable %s"), name);
return -1;
@@ -180,7 +181,7 @@
i++;
- G_warning("Cannot get name of variable %d", code);
+ G_warning(_("Cannot get name of variable %d"), code);
return NULL;
@@ -195,7 +196,7 @@
i++;
- G_warning("Cannot get value of variable code = %d", code);
+ G_warning(_("Cannot get value of variable code = %d"), code);
return 0;
@@ -211,7 +212,7 @@
i++;
return 0;
@@ -227,6 +228,6 @@
i++;
return NULL;
Modified: grass/branches/releasebranch_6_4/vector/v.digit/vertex.c
--- grass/branches/releasebranch_6_4/vector/v.digit/vertex.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/vertex.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -8,6 +8,7 @@
#include "global.h"
#include "proto.h"
@@ -31,8 +32,8 @@
sl->NPoints = Vect_new_line_struct();
sl->Cats = Vect_new_cats_struct();
- i_prompt("Split line:");
+ i_prompt(_("Split line:"));
sl->thresh = get_thresh();
G_debug(2, "thresh = %f", sl->thresh);
@@ -52,7 +53,7 @@
double y = D_d_to_u_row(syn);
if (sl->last_line == 0) {
if (sl->last_line > 0) {
@@ -126,8 +127,8 @@
symb_set_driver_color(SYMB_HIGHLIGHT);
display_icon(sl->xo, sl->yo, G_ICON_CROSS, 0, 10, 1);
- "Quit tool");
+ _("Quit tool"));
sl->last_line = line;
sl->last_seg = seg;
@@ -148,7 +149,7 @@
struct split_line *sl = closure;
@@ -195,8 +196,8 @@
rv->Points = Vect_new_line_struct();
rv->Cats = Vect_new_cats_struct();
- i_prompt("Remove vertex:");
- i_prompt_buttons("Select vertex", "", "Quit tool");
+ i_prompt(_("Remove vertex:"));
+ i_prompt_buttons(_("Select vertex"), "", _("Quit tool"));
rv->thresh = get_thresh();
G_debug(2, "thresh = %f", rv->thresh);
@@ -216,7 +217,7 @@
if (rv->last_line == 0) {
if (rv->last_line > 0) {
@@ -299,8 +300,8 @@
display_icon(rv->xo, rv->yo, G_ICON_BOX, 0, 10, 1);
- "Quit tool");
+ _("Quit tool"));
rv->last_line = line;
rv->last_seg = seg;
@@ -321,7 +322,7 @@
struct rm_vertex *rv = closure;
@@ -368,8 +369,8 @@
av->Points = Vect_new_line_struct();
av->Cats = Vect_new_cats_struct();
- i_prompt("Add vertex:");
+ i_prompt(_("Add vertex:"));
av->thresh = get_thresh();
G_debug(2, "thresh = %f", av->thresh);
@@ -467,7 +468,7 @@
set_location(D_u_to_d_col(xo), D_u_to_d_row(yo));
- i_prompt_buttons("New vertex", "Unselect", "Quit tool");
+ i_prompt_buttons(_("New vertex"), _("Unselect"), _("Quit tool"));
av->last_line = line;
av->last_seg = seg;
@@ -512,7 +513,7 @@
if (av->last_line == 0) {
else
@@ -565,8 +566,8 @@
mv->Points = Vect_new_line_struct();
mv->Cats = Vect_new_cats_struct();
- i_prompt("Move vertex:");
+ i_prompt(_("Move vertex:"));
mv->thresh = get_thresh();
G_debug(2, "thresh = %f", mv->thresh);
@@ -629,7 +630,7 @@
set_location(D_u_to_d_col(mv->xo), D_u_to_d_row(mv->yo));
mv->last_line = line;
mv->last_seg = seg;
@@ -665,7 +666,7 @@
if (mv->last_line == 0) {
else
Modified: grass/branches/releasebranch_6_4/vector/v.digit/zoom.c
--- grass/branches/releasebranch_6_4/vector/v.digit/zoom.c 2011-06-09 00:19:56 UTC (rev 46623)
+++ grass/branches/releasebranch_6_4/vector/v.digit/zoom.c 2011-06-09 00:26:23 UTC (rev 46624)
@@ -5,6 +5,7 @@
#include "global.h"
#include "proto.h"
@@ -22,8 +23,8 @@
G_debug(2, "zoom_window()");
- i_prompt("Zoom by window");
- i_prompt_buttons("1. corner", "1. corner", "Quit");
+ i_prompt(_("Zoom by window"));
+ i_prompt_buttons(_("1. corner"), _("1. corner"), _("Quit"));
zw->mode = 1;
zw->next_mode = 1;
@@ -40,7 +41,7 @@
struct zoom_window *zw = closure;
if (zw->mode == 1) {
- i_prompt_buttons("1. corner", "2. corner", "Quit");
+ i_prompt_buttons(_("1. corner"), _("2. corner"), _("Quit"));
zw->next_mode = 2;
@@ -71,7 +72,7 @@
display_redraw();
zw->next_mode = 1;
@@ -153,8 +154,8 @@
G_debug(2, "zoom_pan()");
- i_prompt("Pan");
- i_prompt_buttons("New center", "", "Quit");
+ i_prompt(_("Pan"));
+ i_prompt_buttons(_("New center"), "", _("Quit"));
@@ -243,7 +244,7 @@
mapset = G_find_file2("windows", var_getc(VAR_ZOOM_REGION), NULL);
- G_warning("Cannot find window '%s'", var_getc(VAR_ZOOM_REGION));
+ G_warning(_("Cannot find window '%s'"), var_getc(VAR_ZOOM_REGION));
return 0;
G__get_window(&win, "windows", var_getc(VAR_ZOOM_REGION), mapset);
