[GRASS-SVN] r46639 - grass/branches/releasebranch_6_4/raster/r.sun2
svn_grass at osgeo.org
Thu Jun 9 06:00:36 EDT 2011
Author: neteler
Date: 2011-06-09 03:00:36 -0700 (Thu, 09 Jun 2011)
New Revision: 46639
grass/branches/releasebranch_6_4/raster/r.sun2/description.html
grass/branches/releasebranch_6_4/raster/r.sun2/main.c
partial code layout/comments sync with 6.5
Modified: grass/branches/releasebranch_6_4/raster/r.sun2/description.html
--- grass/branches/releasebranch_6_4/raster/r.sun2/description.html 2011-06-09 09:57:13 UTC (rev 46638)
+++ grass/branches/releasebranch_6_4/raster/r.sun2/description.html 2011-06-09 10:00:36 UTC (rev 46639)
@@ -44,7 +44,8 @@
parameters are saved in the resultant maps' history files, which may be viewed
with the <a href="r.info.html">r.info</a> command.
</p>
-<p>The solar incidence angle raster map <i>incidout</i> is computed specifying
+<p>
+The solar incidence angle raster map <i>incidout</i> is computed specifying
elevation raster map <i>elevin</i>, aspect raster map <i>aspin</i>, slope
steepness raster map <i>slopin,</i> given the day <i>day</i> and local time
<i>time</i>. There is no need to define latitude for locations with known
@@ -52,8 +53,7 @@
g.proj</a>
command). If you have undefined projection, (x,y) system, etc. then the latitude
can be defined explicitely for large areas by input raster map <i>latin</i>
- with interpolated latitude values or, for smaller areas, a single region
-latitude value <i>lat</i> can be used instead. All input raster maps must
+ with interpolated latitude values. All input raster maps must
be floating point (FCELL) raster maps. Null data in maps are excluded from
the computation (and also speeding-up the computation), so each output raster
map will contain null data in cells according to all input raster maps. The
@@ -63,7 +63,8 @@
where January 1 is day no.1 and December 31 is 365. Time <i>time</i> must
be a local (solar) time (i.e. NOT a zone time, e.g. GMT, CET) in decimal system,
e.g. 7.5 (= 7h 30m A.M.), 16.1 = 4h 6m P.M.. </p>
-<p>Setting the solar declination <i>declin</i> by user is an option to override
+<p>
+Setting the solar declination <i>declin</i> by user is an option to override
the value computed by the internal routine for the day of the year. The value
of geographical latitude can be set as a constant for the whole computed
region or, as an option, a grid representing spatially distributed values
@@ -71,17 +72,19 @@
with positive values for northern hemisphere and negative for southern one.
In similar principle the Linke turbidity factor (<i>linkein</i>, <i>lin</i>
) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set. </p>
-<p>Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
+<p>
+Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
diffuse) using <i>coefbh</i> and <i>coefdh </i>input raster maps defining
the fraction of the respective clear-sky radiations reduced by atmospheric
factors (e.g. cloudiness). The value is between 0-1. Usually these
coefficients can be obtained from a long-terms meteorological measurements
provided as raster maps with spatial distribution of these coefficients separately
for beam and diffuse radiation (see Suri and Hofierka, 2004, section 3.2).</p>
-<p>The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>
-, <i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>lat
-(latin), </i>elevation <i>elevin</i>, slope <i>slopein</i> and aspect <i>
-aspin</i> raster maps. For convenience, the output raster given as <i>glob_rad</i>
+<p>
+The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>,
+<i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>latin</i>,
+elevation <i>elevin</i>, slope <i>slopein</i> and aspect <i>aspin</i> raster maps.
+For convenience, the output raster given as <i>glob_rad</i>
will output the sum of the three radiation components. The program uses
the Linke atmosphere turbidity factor and ground albedo coefficient.
A default, single value of Linke factor is <i>lin</i>=3.0 and
Modified: grass/branches/releasebranch_6_4/raster/r.sun2/main.c
--- grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2011-06-09 09:57:13 UTC (rev 46638)
+++ grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2011-06-09 10:00:36 UTC (rev 46639)
@@ -40,6 +40,7 @@
#include "local_proto.h"
#include "rsunglobals.h"
+/* default values */
#define NUM_PARTITIONS "1"
#define SKIP "1"
#define BIG 1.e20
@@ -179,6 +180,8 @@
int ll_correction = 0;
double coslatsq;
+/* why not use G_distance() here which switches to geodesic/great
+ circle distace as needed? */
double distance(double x1, double x2, double y1, double y2)
if (ll_correction) {
@@ -2076,6 +2079,9 @@
double d1, decl;
+ /* stretch day number in the following calculation for siderial effect? */
+ /* ? double siderial_day = no_of_day + ((no_of_day * 0.25) / 365.) ? */
+ /* or just change d1 to : d1 = pi2 * no_of_day / 365.0; ? */
d1 = pi2 * no_of_day / 365.25;
decl = asin(0.3978 * sin(d1 - 1.4 + 0.0355 * sin(d1 - 0.0489)));
decl = -decl;
