[GRASS-SVN] r46674 - grass/branches/releasebranch_6_4/lib/vector/vedit
Mon Jun 13 07:48:50 EDT 2011
Author: mmetz
Date: 2011-06-13 04:48:49 -0700 (Mon, 13 Jun 2011)
New Revision: 46674
   grass/branches/releasebranch_6_4/lib/vector/vedit/break.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/cats.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/chtype.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/copy.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/delete.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/distance.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/flip.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/merge.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/move.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/select.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/veditlib.dox
   grass/branches/releasebranch_6_4/lib/vector/vedit/vertex.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c
doxygenize (backport from devbr)
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/break.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/break.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/break.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,16 +1,14 @@
-   \file vector/vedit/break.c
+  \file lib/vector/vedit/break.c
-   \brief Vedit library - split, break, connect lines
-   (C) 2007-2008 by the GRASS Development Team
-   This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \author Martin Landa <landa.martin gmail.com>
-   \date 2007-2008
+  \brief Vedit library - split, break, connect lines
+  (C) 2007-2008 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2).  Read the file COPYING that comes with GRASS for details.
+  \author Martin Landa <landa.martin gmail.com>
 #include <math.h>
@@ -19,17 +17,17 @@
 static int connect_lines(struct Map_info *, int, int, int,
 			 double, struct ilist *);
-   \brief Split selected lines on given position
-   \param Map vector map
-   \param List list of selected lines
-   \param coord points location
-   \param[out] List_updated list of rewritten features (or NULL)
-   \return number of modified lines
-   \return -1 on error
+  \brief Split selected lines on given position
+  \param Map pointer to Map_info
+  \param List list of selected lines
+  \param coord points location
+  \param[out] List_updated list of rewritten features (or NULL)
+  \return number of modified lines
+  \return -1 on error
 int Vedit_split_lines(struct Map_info *Map, struct ilist *List,
 		      struct line_pnts *coord, double thresh,
 		      struct ilist *List_updated)
@@ -130,20 +128,20 @@
     return nlines_modified;
-   \brief Connect lines in given threshold
-   <pre>
+  \brief Connect lines in given threshold
+  \code
    id1   \           ->	      \
    id2 ---------           -----+---
-   </pre>
+   \endcode
    If two lines are selected and <i>thresh</i> is -1, no limit is
    applied.
    \param thresh threshold value
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/cats.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/cats.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/cats.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,34 +1,31 @@
+  \file lib/vector/vedit/cats.c
-   \file vector/vedit/cats.c
+  \brief Vedit library - category manipulation
+  (C) 2006-2008 by the GRASS Development Team
-   \brief Vedit library - category manipulation
-   (C) 2006-2008 by the GRASS Development Team
-   \author Jachym Cepicky <jachym.cepicky gmail.com>
-   \date 2006-2008
+  \author Jachym Cepicky <jachym.cepicky gmail.com>
 #include <grass/glocale.h>
 #include <grass/vedit.h>
-   \brief Add / remove categories
-   \param List list of selected primitives
-   \param layer layer number
-   \param del action (non-zero for delete otherwise add)
-   \param cats_list list of category numbers
-   \return number of modified primitives
+  \brief Add / remove categories
+  \param List list of selected primitives
+  \param layer layer number
+  \param del action (non-zero for delete otherwise add)
+  \param cats_list list of category numbers
+  \return number of modified primitives
 int Vedit_modify_cats(struct Map_info *Map, struct ilist *List,
 		      int layer, int del, struct cat_list *Clist)
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/chtype.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/chtype.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/chtype.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,33 +1,30 @@
-   \file vector/vedit/chtype.c
-   \brief Vedit library - change primitives type
-    (C) 2008 by the GRASS Development Team
-   \date 2008
+  \file vector/vedit/chtype.c
+  \brief Vedit library - change primitives type
+  (C) 2008 by the GRASS Development Team
-   \brief Change primitive type
+  \brief Change primitive type
+  Supported conversions:
+   - point <-> centroid
+   - line <-> boundary
-   Supported conversions:
-    - point <-> centroid
-    - line <-> boundary
 int Vedit_chtype_lines(struct Map_info *Map, struct ilist *List)
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/copy.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/copy.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/copy.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,32 +1,29 @@
+  \file lib/vector/vedit/copy.c
-   \file vector/vedit/copy.c
-   \brief Vedit library - copy primitives
-   \date 2007-2008
+  \brief Vedit library - copy primitives
-   \brief Copy selected primitives
-   \param Map vector map copy to
-   \param FromMap vector map copy from (if not given use Map)
-   \param List list of selected primitives (to be copied)
-   \return number of copied primitives
+  \brief Copy selected primitives
+  \param Map pointer to Map_info copy to
+  \param FromMap vector map copy from (if not given use Map)
+  \param List list of selected primitives (to be copied)
+  \return number of copied primitives
 int Vedit_copy_lines(struct Map_info *Map, struct Map_info *FromMap,
 		     struct ilist *List)
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/delete.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/delete.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/delete.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,30 +1,27 @@
+  \file lib/vector/vedit/delete.c
-   \file vector/vedit/delete.c
+  \brief Vedit library - delete primitives
-   \brief Vedit library - delete primitives
-   \date 2007-2008
-   \brief Delete selected primitives
-   \param List list of primitives to be deleted
-   \return number of deleted primitives
-   \return -1 on on error
+  \brief Delete selected primitives
+  \param List list of primitives to be deleted
+  \return number of deleted primitives
+  \return -1 on on error
 int Vedit_delete_lines(struct Map_info *Map, struct ilist *List)
     int i, line;
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/distance.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/distance.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/distance.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,31 +1,28 @@
+  \file lib/vector/vedit/distance.c
-   \file vector/vedit/distance.c
+  \brief Vedit library - distance calculation
-   \brief Vedit library - distance calculation
-   \date 2007-2008
-   \brief Calculate distances between two lines
-   \todo LL projection
-   \param Points1 first line geometry
-   \param Points2 second line geometry
-   \param[out] index of minimal distance
-   \return minimal distance betwen two lines (their nodes)
+  \brief Calculate distances between two lines
+  \todo LL projection
+  \param Points1 first line geometry
+  \param Points2 second line geometry
+  \param[out] index of minimal distance
+  \return minimal distance betwen two lines (their nodes)
 double Vedit_get_min_distance(struct line_pnts *Points1,
 			      struct line_pnts *Points2, int with_z,
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/flip.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/flip.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/flip.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,30 +1,27 @@
-   \file vector/vedit/flip.c
-   \brief Vedit library - flip lines
-   \date 2007-2008
+  \file lib/vector/vedit/flip.c
+  \brief Vedit library - flip lines
-   \brief Flip direction of selected lines
+  \brief Flip direction of selected lines
 int Vedit_flip_lines(struct Map_info *Map, struct ilist *List)
     struct line_cats *Cats;
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/merge.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/merge.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/merge.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,49 +1,46 @@
-   \file vector/vedit/merge.c
-   \brief Vedit library - merge lines
-   \date 2006-2008
+  \file lib/vector/vedit/merge.c
+  \brief Vedit library - merge lines
-   \brief Merge two given lines a, b
+  \brief Merge two given lines a, b
+  a : Points1/Cats1
+  b : Points2/Cats2
+  merged line : Points/Cats
-   a : Points1/Cats1
-   b : Points2/Cats2
-   merged line : Points/Cats
-   \param Points1,Cats1 first line
-   \param Points2,Cats2 second line
-   \param thresh threshold value
-   \param[out] Points result line
-   \return 1 on success
-   \return 0 on error
+  \param Points1,Cats1 first line
+  \param Points2,Cats2 second line
+  \param thresh threshold value
+  \param[out] Points result line
+  \return 1 on success
+  \return 0 on error
 static int merge_lines(struct line_pnts *Points1, struct line_cats *Cats1,
 		       struct line_pnts *Points2, struct line_cats *Cats2,
 		       double thresh, struct line_pnts **Points);
-   \brief Merge lines/boundaries
-   At least two lines need to be given.
+  \brief Merge lines/boundaries
+  At least two lines need to be given.
    \return number of merged lines
    \return -1 on error
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/move.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/move.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/move.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,33 +1,30 @@
-   \file vector/vedit/move.c
-   \brief Vedit library - move primitives
-   \date 2007-2008
+  \file lib/vector/vedit/move.c
+  \brief Vedit library - move primitives
-   \brief Move selected primitives
-   \param BgMap, nbgmaps list of background vector maps used for snapping
-   \param List list of primitives to be moved
-   \param move_x,move_y,move_z direction (move_z used only if map is 3D)
-   \param snap enable snapping (see globals.h)
+  \brief Move selected primitives
+  \param BgMap, nbgmaps list of background vector maps used for snapping
+  \param List list of primitives to be moved
+  \param move_x,move_y,move_z direction (move_z used only if map is 3D)
+  \param snap enable snapping (see globals.h)
 int Vedit_move_lines(struct Map_info *Map, struct Map_info **BgMap,
 		     int nbgmaps, struct ilist *List, double move_x,
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/select.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/select.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/select.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,17 +1,14 @@
+  \file lib/vector/vedit/select.c
-   \file vector/vedit/select.c
-   \brief Vedit library - select primitives by query
-   \date 2007-2008
+  \brief Vedit library - select primitives by query
@@ -22,24 +19,24 @@
 static int merge_lists(struct ilist *alist, struct ilist *blist);
-   \brief Select primitives by query (based on geometry properties)
+  \brief Select primitives by query (based on geometry properties)
+  Currently supported:
+   - QUERY_LENGTH, select all lines longer than threshold (or shorter if threshold is < 0)
+   - QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
-   Currently supported:
-    - QUERY_LENGTH, select all lines longer than threshold (or shorter if threshold is < 0)
-    - QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
+  Perform global query if <i>List</i> is empty otherwise query only
+  selected vector objects.
-   Perform global query if <i>List</i> is empty otherwise query only
-   selected vector objects.
-   \param type feature type
-   \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
-   \param query query (length, dangle, ...)
-   \param[in,out] List list of selected features
-   \return number of selected primitives
+  \param type feature type
+  \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
+  \param query query (length, dangle, ...)
+  \param[in,out] List list of selected features
+  \return number of selected primitives
 int Vedit_select_by_query(struct Map_info *Map,
 			  int type, int layer, double thresh, int query,
@@ -125,7 +122,7 @@
     return List->n_values;
    \brief Query selected primitive
    \return 1 line test positive
@@ -236,7 +233,7 @@
     return 0;
    \brief Merge two lists, i.e. store only duplicate items
    \param[in,out] alist list to be merged
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,32 +1,29 @@
+  \file lib/vector/vedit/snap.c
-   \file vector/vedit/snap.c
-   \brief Vedit library - snapping
-   \date 2007-2008
+  \brief Vedit library - snapping
-   \brief Snap given point to the nearest primitive
-   \param line line to be excluded (point on line)
-   \param x,y,z point on line to be snapped
-   \param thresh snapping threshold (>0)
-   \param vertex snap also to vertex (non-zero)
-   \return 1 snapped
-   \return 0 not snapped
+  \brief Snap given point to the nearest primitive
+  \param line line to be excluded (point on line)
+  \param x,y,z point on line to be snapped
+  \param thresh snapping threshold (>0)
+  \param vertex snap also to vertex (non-zero)
+  \return 1 snapped
+  \return 0 not snapped
 int Vedit_snap_point(struct Map_info *Map,
 		     int line, double *x, double *y, double *z, double thresh,
@@ -84,20 +81,20 @@
     return snapped;
-   \brief Snap selected primitive to its nearest primitive
-   \param BgMap,nbgmaps list of background maps used for snapping
-   \param line line id to be snapped (if already written, otherwise -1)
-   \param Points line geometry
-   \param thresh threshold value used for snapping (>0)
-   \param to_vertex allow snapping also to vertex
-   \return 1 line snapped
-   \return 0 line not snapped
-   \return -1 line is dead (if 'line' is > 0)
+  \brief Snap selected primitive to its nearest primitive
+  \param BgMap,nbgmaps list of background maps used for snapping
+  \param line line id to be snapped (if already written, otherwise -1)
+  \param Points line geometry
+  \param thresh threshold value used for snapping (>0)
+  \param to_vertex allow snapping also to vertex
+  \return 1 line snapped
+  \return 0 line not snapped
+  \return -1 line is dead (if 'line' is > 0)
 int Vedit_snap_line(struct Map_info *Map, struct Map_info **BgMap,
 		    int nbgmaps, int line, struct line_pnts *Points,
@@ -162,18 +159,18 @@
     return rewrite;
-   \brief Snap lines/boundaries
-   \param List list of lines to be snapped
-   \return number of snapped lines
+  \brief Snap lines/boundaries
+  \param List list of lines to be snapped
+  \return number of snapped lines
 int Vedit_snap_lines(struct Map_info *Map, struct Map_info **BgMap,
 		     int nbgmaps, struct ilist *List, double thresh,
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/veditlib.dox
--- grass/branches/releasebranch_6_4/lib/vector/vedit/veditlib.dox	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/veditlib.dox	2011-06-13 11:48:49 UTC (rev 46674)
@@ -65,15 +65,16 @@
  - Vedit_bulk_labeling()
-\section contacts Contacts
+ - Vedit_render_map()
- Martin Landa <landa.martin gmail.com>
 \section seealso See Also
  - \ref Vector_Library
  - \ref dbmilib
-Last change: $Date$
+\section authors Authors
+ Martin Landa <landa.martin gmail.com>
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/vertex.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/vertex.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/vertex.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,38 +1,35 @@
-   \file vector/vedit/vertex.c
-   \brief Vedit library - vertex manipulation
-   \date 2006-2008
+  \file lib/vector/vedit/vertex.c
+  \brief Vedit library - vertex manipulation
-   \brief Move all vertices in bounding box(es)
-   \param BgMap, nbgmaps list of background vector maps for snapping
-   \param thresh_coords threshold value for selecting lines
-   \param thresh_snap threshold value used for snapping
-   \param move_x,move_y,move_z direction (move_z is used when map is 3D)
-   \param move_first move only first vertex found in the bounding box
-   \param snap snapping mode (see vedit.h)
-   \return number of moved verteces
+  \brief Move all vertices in bounding box(es)
+  \param BgMap, nbgmaps list of background vector maps for snapping
+  \param thresh_coords threshold value for selecting lines
+  \param thresh_snap threshold value used for snapping
+  \param move_x,move_y,move_z direction (move_z is used when map is 3D)
+  \param move_first move only first vertex found in the bounding box
+  \param snap snapping mode (see vedit.h)
+  \return number of moved verteces
 int Vedit_move_vertex(struct Map_info *Map, struct Map_info **BgMap,
 		      struct line_pnts *coord, double thresh_coords,
@@ -179,20 +176,20 @@
     return nvertices_moved;
-   \brief Add new vertex to line
-   Shape of line is not changed.
-   \todo 3D
-   \param thresh find line in given threshold
-   \return number of add verteces
+  \brief Add new vertex to line
+  Shape of line is not changed.
+  \todo 3D
+  \param thresh find line in given threshold
+  \return number of add verteces
 int Vedit_add_vertex(struct Map_info *Map, struct ilist *List,
 		     struct line_pnts *coord, double thresh)
@@ -269,18 +266,18 @@
     return nvertices_added;
-   \brief Remove vertex from line
-   \todo 3D
-   \param thresh threshold value to find a line
-   \return number of removed vertices
+  \brief Remove vertex from line
+  \todo 3D
+  \param thresh threshold value to find a line
+  \return number of removed vertices
 int Vedit_remove_vertex(struct Map_info *Map, struct ilist *List,
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c	2011-06-13 11:41:57 UTC (rev 46673)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c	2011-06-13 11:48:49 UTC (rev 46674)
@@ -1,36 +1,33 @@
+  \file lib/vector/vedit/zbulk.c
-   \file vector/vedit/zbulk.c
-   \brief Vedit library - Bulk labeling (automated labeling of vector
-   features)
-   \date 2007-2008
+  \brief Vedit library - Bulk labeling (automated labeling of vector
+  features)
 #include <grass/dbmi.h>
-   \brief Lines z-bulk labeling
-   Automated labeling (z coordinate assignment) of vector lines (iso-lines).
-   \param point_start_end staring and ending point
-   \param start starting value
-   \param step step value
-   \return number of modified features
+  \brief Lines z-bulk labeling
+  Automated labeling (z coordinate assignment) of vector lines (iso-lines).
+  \param point_start_end staring and ending point
+  \param start starting value
+  \param step step value
+  \return number of modified features
 int Vedit_bulk_labeling(struct Map_info *Map, struct ilist *List,
 			double x1, double y1, double x2, double y2,
