[GRASS-SVN] r46685 - grass-addons/grass7/raster/r.threshold
Mon Jun 13 12:46:01 EDT 2011
Author: martinl
Date: 2011-06-13 09:46:01 -0700 (Mon, 13 Jun 2011)
New Revision: 46685
Added:
   grass-addons/grass7/raster/r.threshold/r.threshold.html
Removed:
   grass-addons/grass7/raster/r.threshold/description.html
   grass-addons/grass7/raster/r.threshold/Makefile
   grass-addons/grass7/raster/r.threshold/r.threshold.py
r.threshold: rename html file to follow grass7 naming convention
	     update svn props
Property changes on: grass-addons/grass7/raster/r.threshold/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Deleted: grass-addons/grass7/raster/r.threshold/description.html
--- grass-addons/grass7/raster/r.threshold/description.html	2011-06-13 16:43:00 UTC (rev 46684)
+++ grass-addons/grass7/raster/r.threshold/description.html	2011-06-13 16:46:01 UTC (rev 46685)
@@ -1,21 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.threshold</em> It finds optimal threshold for stream extraction.
-<h2>NOTES</h2>
-<p>It allows to find the optimal value of upslope area in order to extract the river network using r.stream.extract or r.watershed. Real streams depend on rainfall and infiltration rate, i.e. the same topography in different parts of the world yields different real stream networks. This approach provides a best guess about what makes sense when looking only at the DEM.
-<h2>EXAMPLE</h2>
-<p>r.threshold.py acc=accumulation_map
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.stream.extract.html">r.stream.extract</a>, <a href="r.watershed.html">r.watershed</a>
-</em>
-<h2>AUTHOR</h2>
-<p>Margherita Di Leo (dileomargherita AT gmail DOT com)
-<p><i>Last changed: (Tue May 24 2011)</i>
Copied: grass-addons/grass7/raster/r.threshold/r.threshold.html (from rev 46683, grass-addons/grass7/raster/r.threshold/description.html)
--- grass-addons/grass7/raster/r.threshold/r.threshold.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.threshold/r.threshold.html	2011-06-13 16:46:01 UTC (rev 46685)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>r.threshold</em> It finds optimal threshold for stream extraction.
+<h2>NOTES</h2>
+<p>It allows to find the optimal value of upslope area in order to extract the river network using r.stream.extract or r.watershed. Real streams depend on rainfall and infiltration rate, i.e. the same topography in different parts of the world yields different real stream networks. This approach provides a best guess about what makes sense when looking only at the DEM.
+<h2>EXAMPLE</h2>
+<p>r.threshold.py acc=accumulation_map
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.stream.extract.html">r.stream.extract</a>, <a href="r.watershed.html">r.watershed</a>
+</em>
+<h2>AUTHOR</h2>
+<p>Margherita Di Leo (dileomargherita AT gmail DOT com)
+<p><i>Last changed: (Tue May 24 2011)</i>
Property changes on: grass-addons/grass7/raster/r.threshold/r.threshold.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.threshold/r.threshold.py
Deleted: svn:executable
   + text/x-python
   + native
