[GRASS-SVN] r46689 - grass/branches/develbranch_6/gui/scripts
Mon Jun 13 13:41:13 EDT 2011
Author: martinl
Date: 2011-06-13 10:41:13 -0700 (Mon, 13 Jun 2011)
New Revision: 46689
   grass/branches/develbranch_6/gui/scripts/g.extension.py
g.extension: update to install scripts
	     (merge r46686 from trunk)
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-06-13 17:35:24 UTC (rev 46688)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-06-13 17:41:13 UTC (rev 46689)
@@ -330,14 +330,16 @@
         html_dir = os.path.join(docs_dir, 'html')
         man_dir  = os.path.join(tmpdir, options['extension'], 'man')
         man1_dir = os.path.join(man_dir, 'man1')
-        for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir):
+        script_dir = os.path.join(tmpdir, options['extension'], 'scripts')
+        for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir, script_dir):
             os.mkdir(d)
         ret = grass.call(['make',
                           'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
                           'BIN=%s' % bin_dir,
                           'HTMLDIR=%s' % html_dir,
-                          'MANDIR=%s' % man1_dir],
+                          'MANDIR=%s' % man1_dir,
+                          'SCRIPTDIR=%s' % script_dir],
                          stdout = outdev)
     else:
@@ -392,6 +394,7 @@
     create_dir(os.path.join(options['prefix'], 'bin'))
     create_dir(os.path.join(options['prefix'], 'docs', 'html'))
     create_dir(os.path.join(options['prefix'], 'man', 'man1'))
+    create_dir(os.path.join(options['prefix'], 'scripts'))
 def main():
     # check dependecies
@@ -413,6 +416,8 @@
                 not os.environ['GRASS_ADDON_PATH']:
             grass.warning(_("GRASS_ADDON_PATH is not defined, installing to ~/.grass7/addons/"))
             options['prefix'] = os.path.join(os.environ['HOME'], '.grass7', 'addons')
+        else:
+            options['prefix'] = os.environ['GRASS_ADDON_PATH']
     # check dirs
     check_dirs()
