[GRASS-SVN] r46701 - in grass/branches/releasebranch_6_4/general:
g.mlist manage/cmd
svn_grass at osgeo.org
Tue Jun 14 05:53:36 EDT 2011
Author: martinl
Date: 2011-06-14 02:53:36 -0700 (Tue, 14 Jun 2011)
New Revision: 46701
grass/branches/releasebranch_6_4/general/g.mlist/main.c
grass/branches/releasebranch_6_4/general/manage/cmd/list.c
g.mlist: more guisections, sync desc with g.list
(merge r46699 from trunk)
Modified: grass/branches/releasebranch_6_4/general/g.mlist/main.c
--- grass/branches/releasebranch_6_4/general/g.mlist/main.c 2011-06-14 09:17:46 UTC (rev 46700)
+++ grass/branches/releasebranch_6_4/general/g.mlist/main.c 2011-06-14 09:53:36 UTC (rev 46701)
@@ -9,7 +9,7 @@
* PURPOSE: Lists available GRASS data base files of the
* user-specified data type to standard output
- * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2008, 2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -65,7 +65,7 @@
module->keywords = _("general, map management");
module->description =
_("Lists available GRASS data base files "
- "of the user-specified data type to standard output.");
+ "of the user-specified data type optionally using the search pattern.");
read_list(0);
@@ -95,6 +95,7 @@
opt.pattern->required = NO;
opt.pattern->multiple = NO;
opt.pattern->description = _("Map name search pattern (default: all)");
+ opt.pattern->guisection = _("Pattern");
opt.exclude = G_define_option();
opt.exclude->key = "exclude";
@@ -102,6 +103,7 @@
opt.exclude->required = NO;
opt.exclude->multiple = NO;
opt.exclude->description = _("Map name exclusion pattern (default: none)");
+ opt.exclude->guisection = _("Pattern");
opt.separator = G_define_option();
opt.separator->key = "separator";
@@ -124,27 +126,33 @@
flag.regex->key = 'r';
flag.regex->description =
_("Use basic regular expressions instead of wildcards");
+ flag.regex->guisection = _("Pattern");
flag.extended = G_define_flag();
flag.extended->key = 'e';
flag.extended->description =
_("Use extended regular expressions instead of wildcards");
+ flag.extended->guisection = _("Pattern");
flag.type = G_define_flag();
flag.type->key = 't';
flag.type->description = _("Print data types");
+ flag.type->guisection = _("Print");
flag.mapset = G_define_flag();
flag.mapset->key = 'm';
- flag.mapset->description = _("Print mapset names");
+ flag.mapset->description = _("Print fully-qualified map names (including mapsets)");
+ flag.mapset->guisection = _("Print");
flag.pretty = G_define_flag();
flag.pretty->key = 'p';
flag.pretty->description = _("Pretty printing in human readable format");
+ flag.pretty->guisection = _("Print");
flag.full = G_define_flag();
flag.full->key = 'f';
flag.full->description = _("Verbose listing (also list map titles)");
+ flag.full->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/branches/releasebranch_6_4/general/manage/cmd/list.c
--- grass/branches/releasebranch_6_4/general/manage/cmd/list.c 2011-06-14 09:17:46 UTC (rev 46700)
+++ grass/branches/releasebranch_6_4/general/manage/cmd/list.c 2011-06-14 09:53:36 UTC (rev 46701)
@@ -41,8 +41,8 @@
+ "of the user-specified data type.");
element = G_define_option();
element->key = "type";
element->key_desc = "datatype";
