[GRASS-SVN] r46736 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Sat Jun 18 05:46:31 EDT 2011
Author: martinl
Date: 2011-06-18 02:46:30 -0700 (Sat, 18 Jun 2011)
New Revision: 46736
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: update menu items
add r.in.lidar and v.in.lidar
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2011-06-18 08:47:19 UTC (rev 46735)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2011-06-18 09:46:30 UTC (rev 46736)
@@ -165,6 +165,13 @@
<handler>OnMenuCmd</handler>
<command>r.in.aster</command>
</menuitem>
+ <menuitem>
+ <label>LAS LiDAR points import</label>
+ <help>Create a raster map from LAS LiDAR points using univariate statistics.</help>
+ <keywords>raster,import,LIDAR</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>r.in.lidar</command>
+ </menuitem>
<separator />
<menuitem>
<label>WMS import</label>
@@ -271,6 +278,13 @@
<command>v.in.mapgen</command>
</menuitem>
+ <menuitem>
+ <help>Converts LAS LiDAR point clouds to a GRASS vector map with libLAS.</help>
+ <keywords>vector,import</keywords>
+ <command>v.in.lidar</command>
+ </menuitem>
</items>
</menu>
<menu>
@@ -568,14 +582,14 @@
<separator />
<menuitem>
<label>List</label>
- <help>Lists available GIS elements of the user-specified data type.</help>
+ <help>Lists available GRASS data base files of the user-specified data type.</help>
<keywords>general,map management,list</keywords>
<command>g.list</command>
</menuitem>
<menuitem>
<label>List filtered</label>
- <help>Lists available GRASS data base files of the user-specified data type to standard output.</help>
+ <help>Lists available GRASS data base files of the user-specified data type optionally using the search pattern.</help>
<command>g.mlist</command>
@@ -662,7 +676,7 @@
<menuitem>
<label>Volume to raster series</label>
<help>Converts 3D raster maps to 2D raster maps</help>
- <keywords>raster3d,voxel</keywords>
+ <keywords>raster3d,raster,voxel</keywords>
<command>r3.to.rast</command>
</menuitem>
@@ -1278,7 +1292,7 @@
<items>
<menuitem>
<label>Carve stream channels</label>
- <help>Generates stream channels</help>
+ <help>Generates stream channels.</help>
<keywords>raster,hydrology</keywords>
<command>r.carve</command>
@@ -1307,7 +1321,7 @@
</menuitem>
<menuitem>
<label>Flow lines</label>
- <help>Constructs flow lines.</help>
+ <help>Constructs flowlines.</help>
<command>r.flow</command>
@@ -2435,7 +2449,7 @@
<menuitem>
<label>Basic vector metadata</label>
<help>Outputs basic information about a vector map.</help>
- <keywords>vector,metadata,history,attribute columns</keywords>
+ <keywords>vector,metadata,topology,extent,history,attribute columns</keywords>
<command>v.info</command>
</menuitem>
@@ -2828,7 +2842,7 @@
</menuitem>
<menuitem>
<label>Penman-Monteith Evapotranspiration</label>
- <help>Computes potontial evapotranspiration calculation with hourly Penman-Monteith.</help>
+ <help>Computes potential evapotranspiration calculation with hourly Penman-Monteith.</help>
<keywords>imagery,evapotranspiration</keywords>
<command>i.evapo.pm</command>
