[GRASS-SVN] r46754 - in grass/trunk/raster: r.colors r.colors.out
svn_grass at osgeo.org
Wed Jun 22 09:33:54 EDT 2011
Author: huhabla
Date: 2011-06-22 06:33:54 -0700 (Wed, 22 Jun 2011)
New Revision: 46754
Added:
grass/trunk/raster/r.colors.out/local_proto.h
grass/trunk/raster/r.colors.out/r3.colors.out.html
grass/trunk/raster/r.colors.out/raster3d_main.c
grass/trunk/raster/r.colors.out/raster_main.c
grass/trunk/raster/r.colors.out/write_colors.c
Removed:
grass/trunk/raster/r.colors.out/main.c
grass/trunk/raster/r.colors.out/Makefile
grass/trunk/raster/r.colors/test.r.colors.sh
Do not use hacks while implementing r3.colors.out!
Modified: grass/trunk/raster/r.colors/test.r.colors.sh
--- grass/trunk/raster/r.colors/test.r.colors.sh 2011-06-22 12:36:41 UTC (rev 46753)
+++ grass/trunk/raster/r.colors/test.r.colors.sh 2011-06-22 13:33:54 UTC (rev 46754)
@@ -57,4 +57,4 @@
r3.colors -a map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3_logabs.txt
r3.colors map=volume_double_null rules=example4 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4.txt
r3.colors -n map=volume_double_null volume=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4_inv.txt
-r3.colors map=volume_double_null raster=test_elev_double && r3.colors.out --o map=volume_double_null rules=test_volume_double_example5.ref
\ No newline at end of file
+r3.colors map=volume_double_null raster=test_elev_double && r3.colors.out --o map=volume_double_null rules=test_volume_double_example5.txt
Modified: grass/trunk/raster/r.colors.out/Makefile
--- grass/trunk/raster/r.colors.out/Makefile 2011-06-22 12:36:41 UTC (rev 46753)
+++ grass/trunk/raster/r.colors.out/Makefile 2011-06-22 13:33:54 UTC (rev 46754)
@@ -1,11 +1,17 @@
MODULE_TOPDIR = ../..
-PGM = r.colors.out
+LIBES2 = $(RASTERLIB) $(GISLIB)
+LIBES3 = $(G3DLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(G3DDEP) $(GISDEP) $(RASTERDEP)
-LIBES = $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+PROGRAMS = r.colors.out r3.colors.out
-include $(MODULE_TOPDIR)/include/Make/Module.make
+r_colors_out_OBJS = raster_main.o write_colors.o
+r3_colors_out_OBJS = raster3d_main.o write_colors.o
-default: cmd
+include $(MODULE_TOPDIR)/include/Make/Multi.make
+default: multi
+$(BIN)/r.colors.out$(EXE): LIBES = $(LIBES2)
+$(BIN)/r3.colors.out$(EXE): LIBES = $(LIBES3)
Added: grass/trunk/raster/r.colors.out/local_proto.h
--- grass/trunk/raster/r.colors.out/local_proto.h (rev 0)
+++ grass/trunk/raster/r.colors.out/local_proto.h 2011-06-22 13:33:54 UTC (rev 46754)
@@ -0,0 +1,8 @@
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/G3d.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+void write_colors(struct Colors *, struct FPRange*, const char *, int);
Deleted: grass/trunk/raster/r.colors.out/main.c
--- grass/trunk/raster/r.colors.out/main.c 2011-06-22 12:36:41 UTC (rev 46753)
+++ grass/trunk/raster/r.colors.out/main.c 2011-06-22 13:33:54 UTC (rev 46754)
@@ -1,168 +0,0 @@
- * MODULE: r.colors.out
- * AUTHOR(S): Glynn Clements
- * PURPOSE: Allows export of the color table for a raster map layer.
- * COPYRIGHT: (C) 2008, 2010 Glynn Clements and the GRASS Development Team
- * This program is free software under the GNU General
- * Public License (>=v2). Read the file COPYING that
- * comes with GRASS for details.
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-#ifdef USE_RASTER3D
-#include <grass/G3d.h>
-#endif
-static FILE *fp;
-static int perc;
-static DCELL min, max;
-static void write_rule(DCELL *val, int r, int g, int b)
- static DCELL v0;
- static int r0 = -1, g0 = -1, b0 = -1;
- if (v0 == *val && r0 == r && g0 == g && b0 == b)
- return;
- v0 = *val, r0 = r, g0 = g, b0 = b;
- if (perc)
- fprintf(fp, "%g%% %d:%d:%d\n", 100 * (*val - min) / (max - min), r, g, b);
- else
- fprintf(fp, "%g %d:%d:%d\n", *val, r, g, b);
-int main(int argc, char **argv)
- struct GModule *module;
- struct
- struct Option *map, *file;
- } opt;
- struct
- struct Flag *p;
- } flag;
- const char *name, *file;
- struct Colors colors;
- struct FPRange range;
- int count;
- int i;
- G_gisinit(argv[0]);
- module = G_define_module();
- G_add_keyword(_("raster3d"));
-#else
- G_add_keyword(_("raster"));
-#endif
- G_add_keyword(_("export"));
- G_add_keyword(_("color table"));
- module->description =
- _("Exports the color table associated with a raster3d map layer.");
-#else
- _("Exports the color table associated with a raster map layer.");
-#endif
- opt.map = G_define_standard_option(G_OPT_R3_MAP);
-#else
- opt.map = G_define_standard_option(G_OPT_R_MAP);
-#endif
- opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
- opt.file->key = "rules";
- opt.file->label = _("Path to output rules file");
- opt.file->description = _("\"-\" to write to stdout");
- opt.file->answer = "-";
- flag.p = G_define_flag();
- flag.p->key = 'p';
- flag.p->description = _("Output values as percentages");
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- name = opt.map->answer;
- file = opt.file->answer;
- perc = flag.p->answer ? 1 : 0;
- if (G3d_readColors(name, "", &colors) < 0)
- G_fatal_error(_("Unable to read color table for raster3d map <%s>"), name);
- G3d_readRange(name, "", &range);
-#else
- if (Rast_read_colors(name, "", &colors) < 0)
- G_fatal_error(_("Unable to read color table for raster map <%s>"), name);
- Rast_read_fp_range(name, "", &range);
-#endif
- Rast_get_fp_range_min_max(&range, &min, &max);
- if (!file || strcmp(file, "-") == 0)
- fp = stdout;
- else {
- fp = fopen(file, "w");
- if (!fp)
- G_fatal_error(_("Unable to open output file <%s>"), file);
- if (colors.version < 0) {
- /* 3.0 format */
- CELL lo, hi;
- Rast_get_c_color_range(&lo, &hi, &colors);
- for (i = lo; i <= hi; i++) {
- unsigned char r, g, b, set;
- DCELL val = (DCELL) i;
- Rast_lookup_c_colors(&i, &r, &g, &b, &set, 1, &colors);
- write_rule(&val, r, g, b);
- else {
- count = Rast_colors_count(&colors);
- for (i = 0; i < count; i++) {
- DCELL val1, val2;
- unsigned char r1, g1, b1, r2, g2, b2;
- Rast_get_fp_color_rule(
- &val1, &r1, &g1, &b1,
- &val2, &r2, &g2, &b2,
- &colors, count - 1 - i);
- write_rule(&val1, r1, g1, b1);
- write_rule(&val2, r2, g2, b2);
- int r, g, b;
- Rast_get_null_value_color(&r, &g, &b, &colors);
- fprintf(fp, "nv %d:%d:%d\n", r, g, b);
- Rast_get_default_color(&r, &g, &b, &colors);
- fprintf(fp, "default %d:%d:%d\n", r, g, b);
- if (fp != stdout)
- fclose(fp);
- exit(EXIT_SUCCESS);
Added: grass/trunk/raster/r.colors.out/r3.colors.out.html
--- grass/trunk/raster/r.colors.out/r3.colors.out.html (rev 0)
+++ grass/trunk/raster/r.colors.out/r3.colors.out.html 2011-06-22 13:33:54 UTC (rev 46754)
@@ -0,0 +1,25 @@
+<h2>DESCRIPTION</h2>
+<em>r3.colors.out</em> allows the user to export the color table for a
+raster3d map to a file which is suitable as input
+to <em><a href="r3.colors.html">r3.colors</a></em>.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+r3.colors.out map=volume_1 rules=rules.txt
+r3.colors map=volume_2 rules=rules.txt
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="r3.colors.html">r3.colors</a>
+ <a href="r.colors.out.html">r.colors</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p>
+<i>Last changed: $Date: 2010-11-01 08:41:16 +0100 (Mo, 01. Nov 2010) $</i>
Added: grass/trunk/raster/r.colors.out/raster3d_main.c
--- grass/trunk/raster/r.colors.out/raster3d_main.c (rev 0)
+++ grass/trunk/raster/r.colors.out/raster3d_main.c 2011-06-22 13:33:54 UTC (rev 46754)
@@ -0,0 +1,65 @@
+ * MODULE: r.colors.out
+ * AUTHOR(S): Glynn Clements
+ * PURPOSE: Allows export of the color table for a raster map layer.
+ * COPYRIGHT: (C) 2008, 2010 Glynn Clements and the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
+#include "local_proto.h"
+/* Run in raster3d mode */
+int main(int argc, char **argv)
+ struct GModule *module;
+ struct
+ struct Option *map, *file;
+ } opt;
+ struct
+ struct Flag *p;
+ } flag;
+ struct Colors colors;
+ struct FPRange range;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("raster3d"));
+ G_add_keyword(_("color table"));
+ G_add_keyword(_("export"));
+ module->description =
+ _("Exports the color table associated with a raster3d map layer.");
+ opt.map = G_define_standard_option(G_OPT_R3_MAP);
+ opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.file->key = "rules";
+ opt.file->label = _("Path to output rules file");
+ opt.file->description = _("\"-\" to write to stdout");
+ opt.file->answer = "-";
+ flag.p = G_define_flag();
+ flag.p->key = 'p';
+ flag.p->description = _("Output values as percentages");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ if (G3d_readColors(opt.map->answer, "", &colors) < 0)
+ G_fatal_error(_("Unable to read color table for raster3d map <%s>"), opt.map->answer);
+ G3d_readRange(opt.map->answer, "", &range);
+ write_colors(&colors, &range, opt.file->answer, flag.p->answer ? 1 : 0);
+ exit(EXIT_SUCCESS);
Added: grass/trunk/raster/r.colors.out/raster_main.c
--- grass/trunk/raster/r.colors.out/raster_main.c (rev 0)
+++ grass/trunk/raster/r.colors.out/raster_main.c 2011-06-22 13:33:54 UTC (rev 46754)
@@ -0,0 +1,66 @@
+/* Run in raster mode */
+ struct
+ } opt;
+ struct
+ struct Flag *p;
+ } flag;
+ G_add_keyword(_("raster"));
+ _("Exports the color table associated with a raster map layer.");
+ opt.map = G_define_standard_option(G_OPT_R_MAP);
+ if (Rast_read_colors(opt.map->answer, "", &colors) < 0)
+ G_fatal_error(_("Unable to read color table for raster map <%s>"), opt.map->answer);
+ Rast_read_fp_range(opt.map->answer, "", &range);
Copied: grass/trunk/raster/r.colors.out/write_colors.c (from rev 46750, grass/trunk/raster/r.colors.out/main.c)
--- grass/trunk/raster/r.colors.out/write_colors.c (rev 0)
+++ grass/trunk/raster/r.colors.out/write_colors.c 2011-06-22 13:33:54 UTC (rev 46754)
@@ -0,0 +1,93 @@
+static FILE *fp;
+static DCELL min, max;
+static void write_rule(DCELL *val, int r, int g, int b, int perc)
+ static DCELL v0;
+ static int r0 = -1, g0 = -1, b0 = -1;
+ if (v0 == *val && r0 == r && g0 == g && b0 == b)
+ return;
+ v0 = *val, r0 = r, g0 = g, b0 = b;
+ if (perc)
+ fprintf(fp, "%g%% %d:%d:%d\n", 100 * (*val - min) / (max - min), r, g, b);
+ else
+ fprintf(fp, "%g %d:%d:%d\n", *val, r, g, b);
+void write_colors(struct Colors *colors, struct FPRange*range, const char *file,
+ int perc)
+ int i, count = 0;;
+ Rast_get_fp_range_min_max(range, &min, &max);
+ if (!file || strcmp(file, "-") == 0)
+ fp = stdout;
+ else {
+ fp = fopen(file, "w");
+ if (!fp)
+ G_fatal_error(_("Unable to open output file <%s>"), file);
+ if (colors->version < 0) {
+ /* 3.0 format */
+ CELL lo, hi;
+ Rast_get_c_color_range(&lo, &hi, colors);
+ for (i = lo; i <= hi; i++) {
+ unsigned char r, g, b, set;
+ DCELL val = (DCELL) i;
+ Rast_lookup_c_colors(&i, &r, &g, &b, &set, 1, colors);
+ write_rule(&val, r, g, b, perc);
+ else {
+ count = Rast_colors_count(colors);
+ for (i = 0; i < count; i++) {
+ DCELL val1, val2;
+ unsigned char r1, g1, b1, r2, g2, b2;
+ Rast_get_fp_color_rule(
+ &val1, &r1, &g1, &b1,
+ &val2, &r2, &g2, &b2,
+ colors, count - 1 - i);
+ write_rule(&val1, r1, g1, b1, perc);
+ write_rule(&val2, r2, g2, b2, perc);
+ int r, g, b;
+ Rast_get_null_value_color(&r, &g, &b, colors);
+ fprintf(fp, "nv %d:%d:%d\n", r, g, b);
+ Rast_get_default_color(&r, &g, &b, colors);
+ fprintf(fp, "default %d:%d:%d\n", r, g, b);
+ if (fp != stdout)
+ fclose(fp);
