[GRASS-SVN] r46773 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Jun 23 18:30:34 EDT 2011
Author: martinl
Date: 2011-06-23 15:30:34 -0700 (Thu, 23 Jun 2011)
New Revision: 46773
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/workspace.py
wxGUI: attemt to fix #1330
(merge r46771 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2011-06-23 22:27:37 UTC (rev 46772)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2011-06-23 22:30:34 UTC (rev 46773)
@@ -869,7 +869,7 @@
elif ltype == 'command':
ctrl.SetValue(lname)
else:
- self.SetItemText(layer, self._getLayerName(layer))
+ self.SetItemText(layer, self._getLayerName(layer, lname))
# updated progress bar range (mapwindow statusbar)
if checked is True:
@@ -1336,21 +1336,27 @@
return newItem
- def _getLayerName(self, item):
- """!Get layer name string"""
+ def _getLayerName(self, item, lname = ''):
+ """!Get layer name string
+ @param lname optional layer name
mapLayer = self.GetPyData(item)[0]['maplayer']
- mapname = self.GetPyData(item)[0]['label']
+ if not lname:
+ lname = self.GetPyData(item)[0]['label']
opacity = int(mapLayer.GetOpacity(float = True) * 100)
- if not mapname:
+ if not lname:
dcmd = self.GetPyData(item)[0]['cmd']
- mapname, found = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
+ lname, found = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
fullyQualified = True)
- if not found:
- return None
+ if not found:
+ return None
- return mapname + ' (%s %d' % (_('opacity:'), opacity) + '%)'
+ if opacity < 100:
+ return lname + ' (%s %d' % (_('opacity:'), opacity) + '%)'
+ return lname
def GetOptData(self, dcmd, layer, params, propwin):
"""!Process layer data (when changes in propertiesdialog are applied)"""
# set layer text to map name
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/workspace.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/workspace.py 2011-06-23 22:27:37 UTC (rev 46772)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/workspace.py 2011-06-23 22:30:34 UTC (rev 46773)
@@ -764,7 +764,7 @@
elif type == 'group':
name = mapTree.GetItemText(item)
self.file.write('%s<group name="%s" checked="%d">\n' % \
- (' ' * self.indent, name, checked));
+ (' ' * self.indent, name.encode('utf8'), checked));
self.indent += 4
subItem = mapTree.GetFirstChild(item)[0]
self.__writeLayer(mapTree, subItem)
@@ -773,13 +773,13 @@
else:
cmd = mapTree.GetPyData(item)[0]['maplayer'].GetCmd(string=False)
+ opacity = maplayer.GetOpacity(float = True)
# remove 'opacity' part
- if '(opacity' in name:
+ if opacity < 1:
name = name.split('(', -1)[0].strip()
- opacity = maplayer.GetOpacity(float=True)
self.file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
- (' ' * self.indent, type, name, checked, opacity));
+ (' ' * self.indent, type, name.encode('utf8'), checked, opacity));
self.indent += 4
# selected ?
if item in itemSelected:
