[GRASS-SVN] r46775 - in grass/trunk: gui/wxpython gui/wxpython/gui_modules include lib/nviz
Fri Jun 24 09:39:26 EDT 2011
Author: annakrat
Date: 2011-06-24 06:39:26 -0700 (Fri, 24 Jun 2011)
New Revision: 46775
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/include/nviz.h
   grass/trunk/lib/nviz/position.c
wxNviz: 3d mode in workspace
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -165,6 +165,7 @@
             cplane = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'cplane'))
             self.cplanes.append(cplane)
     def OnClose(self, event):
         # cleanup when window actually closes (on quit) and not just is hidden
         self.Reset()
@@ -215,7 +216,7 @@
                     elif layer.type ==  'vector':
                         self.lmgr.nviz.UpdatePage('vector')
-                ### self.lmgr.nviz.UpdateSettings()
+                self.lmgr.nviz.UpdateSettings()
                 # update widgets
                 win = self.lmgr.nviz.FindWindowById( \
@@ -264,7 +265,10 @@
                 pos = event.GetPosition()
                 size = self.GetClientSize()
                 self._display.LookHere(pos[0], size[1] - pos[1])
-                self.DoPaint()
+                self.Refresh(False)
+                focus = self._display.GetFocus()
+                for i, coord in enumerate(('x', 'y', 'z')):
+                    self.iview['focus'][coord] = focus[i]
                 toggle = self.lmgr.nviz.FindWindowByName('here')
                 toggle.SetValue(False)
                 self.mouse['use'] = 'default'
@@ -339,6 +343,7 @@
     def UpdateView(self, event):
         """!Change view settings"""
         data = self.view
+        print self.view
         self._display.SetView(data['position']['x'], data['position']['y'],
                               self.iview['height']['value'],
                               data['persp']['value'],
@@ -346,6 +351,9 @@
         if event and event.zExag and 'value' in data['z-exag']:
             self._display.SetZExag(data['z-exag']['value'])
+        if self.iview['focus']['x'] != -1:
+            self._display.SetFocus(self.iview['focus']['x'], self.iview['focus']['y'],
+                                   self.iview['focus']['z'])
         if event:
             event.Skip()
@@ -531,7 +539,16 @@
         stop = time.time()
         Debug.msg(3, "GLWindow.UnloadDataLayers(): time = %f" % (stop-start))
+    def SetVectorSurface(self, data):
+        """!Set reference surfaces of vector"""
+        data['mode']['surface'] = {}
+        data['mode']['surface']['value'] = list()
+        data['mode']['surface']['show'] = list()
+        for name in self.GetLayerNames('raster'):
+            data['mode']['surface']['value'].append(name)
+            data['mode']['surface']['show'].append(True)
     def SetVectorFromCmd(self, item, data):
         """!Set 3D view properties from cmd (d.vect)
@@ -582,6 +599,8 @@
                 # reset to default properties (lines/points)
                 data['vector'] = self.nvizDefault.SetVectorDefaultProp()
                 self.SetVectorFromCmd(item, data['vector'])
+                self.SetVectorSurface(data['vector']['points'])
+                self.SetVectorSurface(data['vector']['lines'])
             elif type ==  '3d-raster':
@@ -688,8 +707,8 @@
         return id
-    def AddConstant(self):
-        """!Add new constant"""
+    def NewConstant(self):
+        """!Create new constant"""
         index = len(self.constants)
         try:
             name = self.constants[-1]['constant']['object']['name'] + 1
@@ -698,13 +717,16 @@
         data = dict()
         self.constants.append(data)
         data = self.SetMapObjProperties(item = index, id = -1, nvizType = 'constant')
+        self.AddConstant(data, name)
+        return name
+    def AddConstant(self, data, name):
+        """!Add new constant"""
         id = self._display.AddConstant(value = data['constant']['value'], color = data['constant']['color'])
         self._display.SetSurfaceRes(id, data['constant']['resolution'], data['constant']['resolution'])
         data['constant']['object'] = { 'id' : id,
                                        'name': name,
                                        'init' : False }
-        return index, name
     def DeleteConstant(self, index):
         """!Delete constant layer"""
@@ -1134,7 +1156,7 @@
             if data['mode']['type'] ==  'flat':
                 flat = True
                 if 'surface' in data['mode']:
-                    data.pop('surface')
+                    data['mode'].pop('surface')
             else:
                 flat = False
@@ -1145,8 +1167,6 @@
                 data['color'].pop('update')
             if 'update' in data['width']:
                 data['width'].pop('update')
-            if 'update' in data['mode']:
-                data['mode'].pop('update')
         # height
         if 'update' in data['height']:
@@ -1155,20 +1175,20 @@
             data['height'].pop('update')
         # surface
-        if 'surface' in data['mode']:
-            if 'update' in data['mode']['surface']:
-                for item in range(len(data['mode']['surface']['value'])):
-                    for type in ('raster', 'constant'):
-                        sid = self.GetLayerId(type = type,
-                                              name = data['mode']['surface']['value'][item])
-                        if sid > -1:
-                            if data['mode']['surface']['show'][item]:
-                                self._display.SetVectorLineSurface(id, sid)
-                            else:
-                                self._display.UnsetVectorLineSurface(id, sid)
-                            break
+        if 'surface' in data['mode'] and 'update' in data['mode']:
+            for item in range(len(data['mode']['surface']['value'])):
+                for type in ('raster', 'constant'):
+                    sid = self.GetLayerId(type = type,
+                                          name = data['mode']['surface']['value'][item])
+                    if sid > -1:
+                        if data['mode']['surface']['show'][item]:
+                            self._display.SetVectorLineSurface(id, sid)
+                        else:
+                            self._display.UnsetVectorLineSurface(id, sid)
+                        break
-                data['mode']['surface'].pop('update')
+        if 'update' in data['mode']:
+                data['mode'].pop('update')
     def UpdateVectorPointsProperties(self, id, data):
         """!Update vector point map object properties"""
@@ -1200,19 +1220,18 @@
         # surface
-                        if sid > -1:
-                                self._display.SetVectorPointSurface(id, sid)
-                            else:
-                                self._display.UnsetVectorPointSurface(id, sid)
-                            break
+                    if sid > -1:
+                            self._display.SetVectorPointSurface(id, sid)
+                        else:
+                            self._display.UnsetVectorPointSurface(id, sid)
+                        break
     def GetLayerNames(self, type):
         """!Return list of map layer names of given type"""
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -131,7 +131,6 @@
         self.win  = {} # window ids
         self.page = {} # page ids
-        self.constantIndex = len(self.mapWindow.constants) # index of constant surface
         # view page
         self.AddPage(page = self._createViewPage(),
@@ -181,7 +180,17 @@
             self.FindWindowById(self.win['vector']['map']).SetValue(selectedVector)
         except IndexError:
             pass
+    def UpdateState(self, **kwargs):
+        if 'view' in kwargs:
+            self.mapWindow.view = kwargs['view']
+            self.FindWindowById(self.win['view']['position']).data = kwargs['view']
+        if 'iview' in kwargs:
+            self.mapWindow.iview = kwargs['iview']
+        if 'light' in kwargs:
+            self.mapWindow.light = kwargs['light']
+            self.FindWindowById(self.win['light']['position']).data = kwargs['light']
     def OnPageChanged(self, event):
         new = event.GetSelection()
         # self.ChangeSelection(new)
@@ -1716,7 +1725,7 @@
     def OnNewConstant(self, event):
         """!Create new surface with constant value"""
         #TODO settings
-        index, name = self.mapWindow.AddConstant()
+        name = self.mapWindow.NewConstant()
         win = self.FindWindowById(self.win['constant']['surface'])
         name = _("constant#") + str(name)
         win.Append(name)
@@ -1877,14 +1886,13 @@
                         'twist',
                         'z-exag'):
             for win in self.win['view'][control].itervalues():
-                if control == 'height':
-                    value = UserSettings.Get(group = 'nviz', key = 'view',
-                                             subkey = ['height', 'value'], internal = True)
-                else:
-                    try:
+                try:
+                    if control == 'height':
+                        value = self.mapWindow.iview[control]['value']
+                    else:
                         value = self.mapWindow.view[control]['value']
-                    except KeyError:
-                        value = -1
+                except KeyError:
+                    value = -1
                 self.FindWindowById(win).SetValue(value)
@@ -1894,6 +1902,8 @@
         viewWin.Draw(pos = (x, y), scale = True)
         viewWin.Refresh(False)
+        color = self._getColorString(self.mapWindow.view['background']['color'])
+        self._display.SetBgColor(str(color))
         self.Update()
@@ -1929,7 +1939,7 @@
     def OnLightColor(self, event):
         """!Color of the light changed"""
-        self.mapWindow.light['color'] = event.GetValue()
+        self.mapWindow.light['color'] = tuple(event.GetValue())
         event = wxUpdateLight(refresh = True)
         wx.PostEvent(self.mapWindow, event)
@@ -1948,7 +1958,7 @@
     def OnBgColor(self, event):
         """!Background color changed"""
         color = event.GetValue()
-        self.mapWindow.view['background']['color'] = color
+        self.mapWindow.view['background']['color'] = tuple(color)
         color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
@@ -2576,7 +2586,6 @@
             mode['surface']['value'] = value
             mode['surface']['show'] = checked
-            mode['surface']['update'] = None
         else:
             mode['type'] = 'flat'
@@ -2666,8 +2675,9 @@
         data = self.GetLayerData('vector')
         data['vector'][vtype]['mode']['surface'] = { 'value' : surfaces,
-                                                     'show'  : checked,
-                                                     'update': None }
+                                                     'show'  : checked}
+        data['vector'][vtype]['mode']['update'] = None
         # update properties
         event = wxUpdateProperties(data = data)
@@ -3088,7 +3098,15 @@
             self.FindWindowById(self.win['view']['background']['color']).SetColour(\
+            tval = self.mapWindow.view['twist']['value']
+            pval = self.mapWindow.view['persp']['value']
+            for control in ('slider','text'):
+                self.FindWindowById(self.win['view']['twist'][control]).SetValue(tval)
+                self.FindWindowById(self.win['view']['persp'][control]).SetValue(pval)
         elif pageId in ('surface', 'vector', 'volume'):
             name = self.FindWindowById(self.win[pageId]['map']).GetValue()
             data = self.GetLayerData(pageId)
@@ -3111,6 +3129,7 @@
                 self.FindWindowById(self.win['light']['bright'][control]).SetValue(bval)
                 self.FindWindowById(self.win['light']['ambient'][control]).SetValue(aval)
             self.FindWindowById(self.win['light']['color']).SetColour(self.mapWindow.light['color'])
+            self.FindWindowById(self.win['light']['position']).PostDraw()
         elif pageId == 'fringe':
             win = self.FindWindowById(self.win['fringe']['map'])
             win.SetValue(self.FindWindowById(self.win['surface']['map']).GetValue())
@@ -3118,7 +3137,7 @@
             if self.mapWindow.constants:
                 surface = self.FindWindowById(self.win['constant']['surface'])
                 for item in self.mapWindow.constants:
-                    surface.Append(_("constant") + str(item['constant']['object']['name']))
+                    surface.Append(_("constant#") + str(item['constant']['object']['name']))
                 surface.SetSelection(0)
                 self.OnConstantSelection(None)
                 self.EnablePage('constant', True)
@@ -3322,30 +3341,16 @@
                 else:
                     display.SetSelection(0)
             if data[vtype]['mode']['type'] == 'surface':
-                if npoints:
-                    vsubtyp = 'vpoint'
-                else:
-                    vsubtyp = 'vline'
-                vid = self.mapWindow.GetLayerId(type = 'vector', vsubtyp = vsubtyp, name = layer.name)
                 rasters = self.mapWindow.GetLayerNames('raster')
                 constants = self.mapWindow.GetLayerNames('constant')
                 surfaces = rasters + constants
                 surfaceWin = self.FindWindowById(self.win['vector'][vtype]['surface'])
                 surfaceWin.SetItems(surfaces)
                 for idx, surface in enumerate(surfaces):
-                    if vtype == 'lines':
-                        sid = self.mapWindow.GetLayerId(type = 'raster', name = surface)
-                        if sid == -1:
-                            sid = self.mapWindow.GetLayerId(type = 'constant', name = surface)
-                        if vid > -1 and sid > -1:
-                            selected = self._display.VectorSurfaceSelected(vid, sid)
-                        else:
-                            selected = False
-                    else: # points
-                        try:# TODO fix this mess
-                            selected = data[vtype]['mode']['surface']['show'][idx]
-                        except (TypeError, IndexError, KeyError):
-                            selected = False
+                    try:# TODO fix this mess
+                        selected = data[vtype]['mode']['surface']['show'][idx]
+                    except (TypeError, IndexError, KeyError):
+                        selected = False
                     surfaceWin.Check(idx, selected)
         for type in ('slider', 'text'):
@@ -3567,7 +3572,7 @@
     def TransformCoordinates(self, x, y, toLight = True):
         return x, y
     def OnMouse(self, event):
         PositionWindow.OnMouse(self, event)
         if event.LeftIsDown():
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -679,6 +679,10 @@
         self.internalSettings['nviz']['view']['persp']['max'] = 100
         self.internalSettings['nviz']['view']['height'] = {}
         self.internalSettings['nviz']['view']['height']['value'] = -1
+        self.internalSettings['nviz']['view']['focus'] = {}
+        self.internalSettings['nviz']['view']['focus']['x'] = -1
+        self.internalSettings['nviz']['view']['focus']['y'] = -1
+        self.internalSettings['nviz']['view']['focus']['z'] = -1
         self.internalSettings['nviz']['vector'] = {}
         self.internalSettings['nviz']['vector']['points'] = {}
         self.internalSettings['nviz']['vector']['points']['marker'] = ("x",
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -64,6 +64,10 @@
         # list of map layers
         self.layers = []
+        # nviz state
+        self.nviz_state = {}
         self.displayIndex = -1 # first display has index '0'
@@ -149,10 +153,13 @@
                     "size"           : size,
                     "extent"         : extent,
                     "constrainRes"   : bool(int(display.get('constrainRes', "0"))),
-                    "projection"     : projection, } )
+                    "projection"     : projection,
+                    "viewMode"       : display.get('viewMode', '2d')} )
             # process all layers/groups in the display
             self.__processLayers(display)
+            # process nviz_state
+            self.__processNvizState(display)
     def __processLayers(self, node, inGroup = -1):
         """!Process layers/groups of selected display
@@ -350,9 +357,17 @@
                 node_mode = node_vpoints.find('mode')
                 if node_mode is not None:
                     nviz['vector']['points']['mode'] = {}
-                    nviz['vector']['points']['mode']['type'] = str(node_mode.get('type', ''))
-                    nviz['vector']['points']['mode']['surface'] = \
-                        self.__processLayerNvizNode(node_mode, 'map', str)
+                    nviz['vector']['points']['mode']['type'] = str(node_mode.get('type', 'surface'))
+                    nviz['vector']['points']['mode']['surface'] = {}
+                    nviz['vector']['points']['mode']['surface']['value'] = []
+                    nviz['vector']['points']['mode']['surface']['show'] = []
+                    # map
+                    for node_map in node_mode.findall('map'):
+                        nviz['vector']['points']['mode']['surface']['value'].append(
+                            self.__processLayerNvizNode(node_map, 'name', str))
+                        nviz['vector']['points']['mode']['surface']['show'].append(bool(
+                            self.__processLayerNvizNode(node_map, 'checked', int)))
                 # color
                 self.__processLayerNvizNode(node_vpoints, 'color', str,
@@ -377,11 +392,16 @@
                     nviz['vector']['lines']['mode'] = {}
                     nviz['vector']['lines']['mode']['type'] = str(node_mode.get('type', ''))
-                    nviz['vector']['lines']['mode']['surface'] = ''
+                    nviz['vector']['lines']['mode']['surface'] = {}
+                    nviz['vector']['lines']['mode']['surface']['value'] = []
+                    nviz['vector']['lines']['mode']['surface']['show'] = []
                     # map
-                    nviz['vector']['lines']['mode']['surface'] = \
+                        nviz['vector']['lines']['mode']['surface']['value'].append(
+                        nviz['vector']['lines']['mode']['surface']['show'].append(bool(
                 # color
                 self.__processLayerNvizNode(node_vlines, 'color', str,
@@ -417,6 +437,92 @@
             else:
                 return value
+    def __processNvizState(self, node):
+        """!Process tag nviz_state"""
+        node_state = node.find('nviz_state')
+        if node_state is None:
+            return
+        self.nviz_state['display'] = self.displayIndex
+        # view
+        node_view = node_state.find('view')
+        view = {}
+        iview = {}
+        node_position = node_view.find('position')
+        view['position'] = {}
+        view['position']['x'] = float(self.__getNodeText(node_position, 'x'))
+        view['position']['y'] = float(self.__getNodeText(node_position, 'y'))
+        node_persp = node_view.find('persp')
+        view['persp'] = {}
+        iview['persp'] = {}
+        view['persp']['value'] = int(self.__getNodeText(node_persp, 'value'))
+        view['persp']['step'] = int(self.__getNodeText(node_persp, 'step'))
+        iview['persp']['min'] = int(self.__getNodeText(node_persp, 'min'))
+        iview['persp']['max'] = int(self.__getNodeText(node_persp, 'max'))
+        node_height = node_view.find('height')
+        view['height'] = {}
+        iview['height'] = {}
+        iview['height']['value'] = int(self.__getNodeText(node_height, 'value'))
+        view['height']['step'] = int(self.__getNodeText(node_height, 'step'))
+        iview['height']['min'] = int(self.__getNodeText(node_height, 'min'))
+        iview['height']['max'] = int(self.__getNodeText(node_height, 'max'))
+        node_twist = node_view.find('twist')
+        view['twist'] = {}
+        iview['twist'] = {}
+        view['twist']['value'] = int(self.__getNodeText(node_twist, 'value'))
+        view['twist']['step'] = int(self.__getNodeText(node_twist, 'step'))
+        iview['twist']['min'] = int(self.__getNodeText(node_twist, 'min'))
+        iview['twist']['max'] = int(self.__getNodeText(node_twist, 'max'))
+        node_zexag = node_view.find('z-exag')
+        view['z-exag'] = {}
+        view['z-exag']['step'] = int(self.__getNodeText(node_zexag, 'step'))
+        view['z-exag']['value'] = int(self.__getNodeText(node_zexag, 'value'))
+        view['z-exag']['min'] = int(self.__getNodeText(node_zexag, 'min'))
+        view['z-exag']['max'] = int(self.__getNodeText(node_zexag, 'max'))
+        node_focus = node_view.find('focus')
+        iview['focus'] = {}
+        iview['focus']['x'] = int(self.__getNodeText(node_focus, 'x'))
+        iview['focus']['y'] = int(self.__getNodeText(node_focus, 'y'))
+        iview['focus']['z'] = int(self.__getNodeText(node_focus, 'z'))
+        node_background = node_view.find('background')
+        view['background'] = {}
+        view['background']['color'] = tuple(map(int,self.__getNodeText(node_background, 'color').split(':')))
+        self.nviz_state['view'] = view
+        self.nviz_state['iview'] = iview
+        # light
+        node_light = node_state.find('light')
+        light = {}
+        node_position = node_light.find('position')
+        light['position'] = {}
+        light['position']['x'] = float(self.__getNodeText(node_position, 'x'))
+        light['position']['y'] = float(self.__getNodeText(node_position, 'y'))
+        light['position']['z'] = float(self.__getNodeText(node_position, 'z'))
+        light['bright'] = int(node_light.get('bright', '80'))
+        light['ambient'] = int(node_light.get('ambient', '20'))
+        light['color'] = tuple(map(int,(node_light.get('color', '255:255:255')).split(':')))
+        self.nviz_state['light'] = light
+        node_constants = node_state.find('constant_planes')
+        constants = []
+        for i, node_plane in enumerate(node_constants.findall('plane')):
+            plane = {}
+            plane['value'] = int(self.__getNodeText(node_plane, 'value'))
+            plane['resolution'] = int(self.__getNodeText(node_plane, 'resolution'))
+            plane['color'] = self.__getNodeText(node_plane, 'color')
+            plane['object'] = {}
+            constants.append({'constant': plane})
+        self.nviz_state['constants'] = constants
 class Nviz:
     def __init__(self):
         """Default 3D settings"""
@@ -590,8 +696,8 @@
         data['color'] = { 'value' : color }
         # mode
-        data['mode'] = { 'type' : 'surface',
-                         'surface' : '', }
+        data['mode'] = { 'type' : 'surface'}
+##                         'surface' : '', }
         # height
         data['height'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
@@ -701,12 +807,17 @@
             displayPos = mapTree.mapdisplay.GetPosition()
             displaySize = mapTree.mapdisplay.GetSize()
+            if mapTree.mapdisplay.toolbars['map'].combo.GetSelection() == 1:
+                viewmode = '3d'
+            else:
+                viewmode = '2d'
             file.write('%s<display render="%d" '
                        'mode="%d" showCompExtent="%d" '
                        'constrainRes="%d" '
                        'dim="%d,%d,%d,%d" '
-                       'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
+                       'extent="%f,%f,%f,%f" '
+                       'viewMode="%s" >\n' % (' ' * self.indent,
                                                     int(mapTree.mapdisplay.statusbarWin['render'].IsChecked()),
                                                     mapTree.mapdisplay.statusbarWin['toggle'].GetSelection(),
                                                     int(mapTree.mapdisplay.statusbarWin['region'].IsChecked()),
@@ -718,7 +829,8 @@
                                                     region['w'],
                                                     region['s'],
                                                     region['e'],
-                                                    region['n']
+                                                    region['n'],
+                                                    viewmode
             # projection statusbar info
             if mapTree.mapdisplay.statusbarWin['projection'].IsChecked() and \
@@ -739,6 +851,12 @@
             # list of layers
             item = mapTree.GetFirstChild(mapTree.root)[0]
             self.__writeLayer(mapTree, item)
+            if mapTree.mapdisplay.MapWindow3D is not None:
+                nvizDisp = mapTree.mapdisplay.MapWindow3D
+                self.__writeNvizState(view = nvizDisp.view, iview =  nvizDisp.iview,
+                                      light = nvizDisp.light, constants = nvizDisp.constants)
             file.write('%s</display>\n' % (' ' * self.indent))
         self.indent =- 4
@@ -944,8 +1062,14 @@
                                                           data[attrb][name]['type']))
                     if data[attrb][name]['type'] == 'surface':
                         self.indent += 4
-                        self.file.write('%s<map>%s</map>\n' % (' ' * self.indent,
-                                                               data[attrb][name]['surface']))
+                        for idx, surface in enumerate(data[attrb][name]['surface']['value']):
+                            checked = data[attrb][name]['surface']['show'][idx]
+                            self.file.write('%s<map>\n' % (' ' * self.indent))
+                            self.indent += 4
+                            self.file.write('%s<name>%s</name>\n' % (' ' * self.indent, surface))
+                            self.file.write('%s<checked>%s</checked>\n' % (' ' * self.indent, int(checked)))
+                            self.indent -= 4
+                            self.file.write('%s</map>\n' % (' ' * self.indent))
                         self.indent -= 4
                     self.file.write('%s</%s>\n' % ((' ' * self.indent, name)))
                 else:
@@ -959,6 +1083,130 @@
         self.indent -= 4
+    def __writeNvizState(self, view, iview, light, constants):
+        """"!Save Nviz properties (view, light) to workspace
+        @param view Nviz view properties
+        @param iview Nviz internal view properties
+        @param light Nviz light properties
+        self.indent += 4
+        self.file.write('%s<nviz_state>\n' % (' ' * self.indent))
+        # view
+        self.indent += 4
+        self.file.write('%s<view>\n' % (' ' * self.indent))
+        self.indent += 4
+        # position
+        self.file.write('%s<position>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('x', view['position'], format = '.2f')
+        self.__writePairTag('y', view['position'], format = '.2f')
+        self.indent -= 4
+        self.file.write('%s</position>\n' % (' ' * self.indent))
+        # perspective
+        self.file.write('%s<persp>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('value', view['persp'])
+        self.__writePairTag('step', view['persp'])
+        self.__writePairTag('max', iview['persp'])
+        self.__writePairTag('min', iview['persp'])
+        self.indent -= 4
+        self.file.write('%s</persp>\n' % (' ' * self.indent))
+        # height
+        self.file.write('%s<height>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('value', iview['height'])
+        self.__writePairTag('step', view['height'])
+        self.__writePairTag('max', iview['height'])
+        self.__writePairTag('min', iview['height'])
+        self.indent -= 4
+        self.file.write('%s</height>\n' % (' ' * self.indent))
+        # twist
+        self.file.write('%s<twist>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('step', view['twist'])
+        self.__writePairTag('value', view['twist'])
+        self.__writePairTag('max', iview['twist'])
+        self.__writePairTag('min', iview['twist'])
+        self.indent -= 4
+        self.file.write('%s</twist>\n' % (' ' * self.indent))
+        # z-exag
+        self.file.write('%s<z-exag>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('step', view['z-exag'])
+        self.__writePairTag('value', view['z-exag'])
+        self.__writePairTag('max', view['z-exag'])
+        self.__writePairTag('min', view['z-exag'])
+        self.indent -= 4
+        self.file.write('%s</z-exag>\n' % (' ' * self.indent))
+        # focus (look here)
+        self.file.write('%s<focus>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.__writePairTag('x', iview['focus'])
+        self.__writePairTag('y', iview['focus'])
+        self.__writePairTag('z', iview['focus'])
+        self.indent -= 4
+        self.file.write('%s</focus>\n' % (' ' * self.indent))
+        # background
+        self.file.write('%s<background>\n' % (' ' * self.indent))
+        self.indent += 4
+        self.file.write('%s<color>' % (' ' * self.indent))
+        self.file.write('%d:%d:%d</color>\n' % (view['background']['color']))
+        self.indent -= 4
+        self.file.write('%s</background>\n' % (' ' * self.indent))
+        self.indent -= 4
+        self.file.write('%s</view>\n' % (' ' * self.indent))
+        # light
+        self.file.write('%s<light bright="%d" ambient="%d" '
+                        % (' ' * self.indent, light['bright'], light['ambient']))
+        self.file.write('color="%d:%d:%d">\n' % (light['color']))
+        self.indent += 4
+        # position
+        self.indent += 4
+        self.__writePairTag('x', light['position'], format = '.2f')
+        self.__writePairTag('y', light['position'], format = '.2f')
+        self.__writePairTag('z', light['position'], format = '.2f')
+        self.indent -= 4
+        self.indent -= 4
+        self.file.write('%s</light>\n' % (' ' * self.indent))
+        # constant planes
+        self.file.write('%s<constant_planes>\n' % (' ' * self.indent))
+        self.indent += 4
+        for idx, plane in enumerate(constants):
+            self.file.write('%s<plane>\n' % (' ' * self.indent))
+            self.indent += 4
+            self.__writePairTag('value', constants[idx]['constant'])
+            self.__writePairTag('resolution', constants[idx]['constant'])
+            self.__writePairTag('color', constants[idx]['constant'], format = 's')
+            self.indent -= 4
+            self.file.write('%s</plane>\n' % (' ' * self.indent))
+        self.indent -= 4
+        self.file.write('%s</constant_planes>\n' % (' ' * self.indent))
+        self.indent -= 4
+        self.file.write('%s</nviz_state>\n' % (' ' * self.indent))
+        self.indent -= 4
+    def __writePairTag(self, tag, data, format = 'd'):
+        """!Helper function for writing pair tag
+        @param tag written tag
+        @param data written data
+        @param format conversion type
+        self.file.write(('%s<%s>%' + format + '</%s>\n') % \
+                        (' ' * self.indent, tag, data[tag], tag))
 class ProcessGrcFile(object):
     def __init__(self, filename):
         """!Process GRC file"""
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -151,7 +151,24 @@
         """!Center view at center of displayed surface"""
         Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1)
         Debug.msg(3, "Nviz::LookAtCenter()")
+    def GetFocus(self):
+        """!Get focus"""
+        Debug.msg(3, "Nviz::GetFocus()")
+        if Nviz_has_focus(self.data):
+            x = c_float()
+            y = c_float()
+            z = c_float()
+            Nviz_get_focus(self.data, byref(x), byref(y), byref(z))
+            return x.value, y.value, z.value
+        else:
+            return -1, -1, -1
+    def SetFocus(self, x, y, z):
+        """!Set focus"""
+        Debug.msg(3, "Nviz::SetFocus()")
+        Nviz_set_focus(self.data, x, y, z)
     def SetZExag(self, z_exag):
         """!Set z-exag value
@@ -365,7 +382,7 @@
         return 1
     def VectorSurfaceSelected(self, vid, sid):
-        """!Check if surface is selected
+        """!Check if surface is selected (currently unused)
         @param vid vector id
         @param sid surface id
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-06-24 13:39:26 UTC (rev 46775)
@@ -712,7 +712,7 @@
             return
         Debug.msg(4, "GMFrame.OnWorkspaceOpen(): filename=%s" % filename)
         # delete current layer tree content
         self.OnWorkspaceClose()
@@ -835,9 +835,30 @@
             # reverse list of map layers
             maptree.Map.ReverseListOfLayers()
-        for mdisp in mapdisplay:
+        for idx, mdisp in enumerate(mapdisplay):
             mdisp.MapWindow2D.UpdateMap()
+            #nviz
+            if gxwXml.displays[idx]['viewMode'] == '3d':
+                # check if nviz exist, if so, don't open workspace in 3D mode
+                # sofar only one nviz can exist
+                if self.existNviz:
+                    gcmd.GMessage(parent = self,
+                          message = _("3D view is not available. Please do not switch to 3D view "
+                                      "before opening workspace in 3D view mode."))
+                    continue
+                mdisp.AddToolbar(name = 'nviz')
+                self.nviz.UpdateState(view = gxwXml.nviz_state['view'],
+                                              iview = gxwXml.nviz_state['iview'],
+                                              light = gxwXml.nviz_state['light'])
+                mdisp.MapWindow3D.constants = gxwXml.nviz_state['constants']
+                for idx, constant in enumerate(mdisp.MapWindow3D.constants):
+                    mdisp.MapWindow3D.AddConstant(constant, idx + 1)
+                for page in ('view', 'light', 'fringe', 'constant', 'cplane'):
+                    self.nviz.UpdatePage(page)
+                self.nviz.UpdateSettings()
+                mapdisp.toolbars['map'].combo.SetSelection(1)
         return True
     def OnWorkspaceLoadGrcFile(self, event):
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/include/nviz.h	2011-06-24 13:39:26 UTC (rev 46775)
@@ -192,6 +192,9 @@
 void Nviz_init_view(nv_data *);
 int Nviz_set_focus_state(int);
 int Nviz_set_focus_map(int, int);
+int Nviz_has_focus(nv_data *);
+int Nviz_set_focus(nv_data *, float, float, float);
+int Nviz_get_focus(nv_data *, float *, float *, float *);
 float Nviz_get_xyrange(nv_data *);
 int Nviz_get_zrange(nv_data *, float *, float *);
Modified: grass/trunk/lib/nviz/position.c
--- grass/trunk/lib/nviz/position.c	2011-06-24 13:17:31 UTC (rev 46774)
+++ grass/trunk/lib/nviz/position.c	2011-06-24 13:39:26 UTC (rev 46775)
@@ -23,7 +23,7 @@
 void Nviz_init_view(nv_data *data)
     GS_init_view();
-    Nviz_set_focus_state(1);	/* center of view */
+    Nviz_set_focus_state(1);   /* center of view */
     /* set default lights (1 & 2) */
     Nviz_set_light_position(data, 1, 0.68, -0.68, 0.80, 0.0);
@@ -49,12 +49,12 @@
 int Nviz_set_focus_state(int state_flag)
     if (state_flag == 1)
-	GS_set_infocus();	/* return center of view */
+        GS_set_infocus();   /* return center of view */
     else if (state_flag == 0)
-	GS_set_nofocus();	/* no center of view -- use viewdir */
+        GS_set_nofocus();   /* no center of view -- use viewdir */
     else {
-	G_warning(_("Unable to set focus"));
-	return 0;
+        G_warning(_("Unable to set focus"));
+        return 0;
     return 1;
@@ -75,41 +75,95 @@
 int Nviz_set_focus_map(int type, int id)
     if (GS_num_surfs() < 0 && GVL_num_vols() < 0) {
-	GS_set_nofocus();
-	return 0;
+        GS_set_nofocus();
+        return 0;
     if (type == MAP_OBJ_UNDEFINED) {
-	int *surf_list, num_surfs, *vol_list;
+        int *surf_list, num_surfs, *vol_list;
-	if (GS_num_surfs() > 0) {
-	    surf_list = GS_get_surf_list(&num_surfs);
-	    id = surf_list[0];
-	    G_free(surf_list);
+        if (GS_num_surfs() > 0) {
+            surf_list = GS_get_surf_list(&num_surfs);
+            id = surf_list[0];
+            G_free(surf_list);
+            GS_set_focus_center_map(id);
-	    GS_set_focus_center_map(id);
-	if (GVL_num_vols() > 0) {
-	    vol_list = GVL_get_vol_list(&num_surfs);
-	    id = vol_list[0];
-	    G_free(vol_list);
-	    GVL_set_focus_center_map(id);
-	return id;
+        if (GVL_num_vols() > 0) {
+            vol_list = GVL_get_vol_list(&num_surfs);
+            id = vol_list[0];
+            G_free(vol_list);
+            GVL_set_focus_center_map(id);
+        return id;
     if (type == MAP_OBJ_SURF) {
     else if (type == MAP_OBJ_VOL) {
     return id;
+   \brief Get focus
+   \param data nviz data
+   \param x,y,z focus coordinates
+int Nviz_get_focus(nv_data * data, float * x, float * y, float * z)
+    float realto[3];
+    /* Get current center */
+    GS_get_focus(realto);
+    *x = realto[0];
+    *y = realto[1];
+    *z = realto[2];
+    // old nviz code is more complicated and it doesn't work properly,
+    // no idea why
+    return 1;
+   \brief Set focus
+   \param x, y, z focus coordinates
+int Nviz_set_focus(nv_data * data, float x, float y, float z)
+    float realto[3];
+    realto[0] = x;
+    realto[1] = y;
+    realto[2] = z;
+    GS_set_focus(realto);
+    // no idea why
+    return 1;
+   \brief Test focus
+int Nviz_has_focus(nv_data * data)
+    float realto[3];
+    if (GS_get_focus(realto))
+        return 1;
+    else
+        return 0;
    \brief Get xy range
@@ -126,6 +180,6 @@
 int Nviz_get_zrange(nv_data * data, float *min, float *max)
-	GS_get_zrange_nz(min, max);
-	return 1;
+    GS_get_zrange_nz(min, max);
+    return 1;
