[GRASS-SVN] r46777 - grass/trunk/lib/db/dbmi_client
svn_grass at osgeo.org
Sat Jun 25 09:52:47 EDT 2011
Author: martinl
Date: 2011-06-25 06:52:47 -0700 (Sat, 25 Jun 2011)
New Revision: 46777
grass/trunk/lib/db/dbmi_client/column.c
libdb: client/columns.c note supported type in dox documentation
Modified: grass/trunk/lib/db/dbmi_client/column.c
--- grass/trunk/lib/db/dbmi_client/column.c 2011-06-25 10:30:35 UTC (rev 46776)
+++ grass/trunk/lib/db/dbmi_client/column.c 2011-06-25 13:52:47 UTC (rev 46777)
@@ -1,18 +1,18 @@
- * \file db/dbmi_client/column.c
- * \brief DBMI Library (client) - column info
- * (C) 1999-2008 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author Joel Jones (CERL/UIUC), Radim Blazek
- * \author Update by Glynn Clement <glynn gclements.plus.com>
- * and Martin Landa <landa.martin gmail.com>
+ \file lib/db/dbmi_client/column.c
+ \brief DBMI Library (client) - column info
+ (C) 1999-2008, 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Joel Jones (CERL/UIUC), Radim Blazek
+ \author Update by Glynn Clement <glynn gclements.plus.com>
+ \author Martin Landa <landa.martin gmail.com>
#include <stdlib.h>
#include <string.h>
@@ -25,6 +25,22 @@
See db_sqltype_name().
+ Supported types:
+ - DB_SQL_TYPE_UNKNOWN
+ - DB_SQL_TYPE_CHARACTER
+ - DB_SQL_TYPE_SMALLINT
+ - DB_SQL_TYPE_INTEGER
+ - DB_SQL_TYPE_REAL
+ - DB_SQL_TYPE_DOUBLE_PRECISION
+ - DB_SQL_TYPE_DECIMAL
+ - DB_SQL_TYPE_NUMERIC
+ - DB_SQL_TYPE_DATE
+ - DB_SQL_TYPE_TIME
+ - DB_SQL_TYPE_TIMESTAMP
+ - DB_SQL_TYPE_INTERVAL
+ - DB_SQL_TYPE_TEXT
+ - DB_SQL_TYPE_SERIAL
\param driver DB driver
\param tab table name
\param col column name
@@ -63,6 +79,12 @@
See db_sqltype_to_Ctype().
+ Supported types:
+ - DB_C_TYPE_STRING
+ - DB_C_TYPE_INT
+ - DB_C_TYPE_DOUBLE
+ - DB_C_TYPE_DATETIME
