[GRASS-SVN] r46781 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Sun Jun 26 04:07:39 EDT 2011
Author: annakrat
Date: 2011-06-26 01:07:39 -0700 (Sun, 26 Jun 2011)
New Revision: 46781
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxNviz: workspace: update dtd file, fixed bugs
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-06-25 22:01:02 UTC (rev 46780)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-06-26 08:07:39 UTC (rev 46781)
@@ -343,7 +343,6 @@
def UpdateView(self, event):
"""!Change view settings"""
data = self.view
- print self.view
self._display.SetView(data['position']['x'], data['position']['y'],
self.iview['height']['value'],
data['persp']['value'],
@@ -610,9 +609,10 @@
data['constant'] = self.nvizDefault.SetConstantDefaultProp()
else:
- # complete data (use default values)
+ # complete data (use default values), not sure if this is necessary
if type == 'raster':
- data['surface'] = self.nvizDefault.SetSurfaceDefaultProp()
+ if not data['surface']:
+ data['surface'] = self.nvizDefault.SetSurfaceDefaultProp()
if type == 'vector':
if not data['vector']['lines']:
self.nvizDefault.SetVectorLinesDefaultProp(data['vector']['lines'])
@@ -622,10 +622,12 @@
# set updates
for sec in data.keys():
for sec1 in data[sec].keys():
+ if sec1 == 'position':
+ data[sec][sec1]['update'] = None
+ continue
for sec2 in data[sec][sec1].keys():
if sec2 != 'all':
data[sec][sec1][sec2]['update'] = None
event = wxUpdateProperties(data = data)
wx.PostEvent(self, event)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-06-25 22:01:02 UTC (rev 46780)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-06-26 08:07:39 UTC (rev 46781)
@@ -3208,7 +3208,7 @@
color = map(int, value.split(':'))
self.FindWindowById(self.win['surface']['color']['const']).SetColour(color)
self.SetMapObjUseMap(nvizType = 'surface',
- attrb = attr, map = data['attribute']['color']['map'])
+ attrb = 'color', map = data['attribute']['color']['map'])
attrb = 'shine', map = data['attribute']['shine']['map'])
@@ -3221,35 +3221,35 @@
# draw
- for control, data in data['draw'].iteritems():
+ for control, drawData in data['draw'].iteritems():
if control == 'all': # skip 'all' property
continue
if control == 'resolution':
- self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(data['coarse'])
- self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(data['fine'])
+ self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(drawData['coarse'])
+ self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(drawData['fine'])
continue
if control == 'mode':
- if data['desc']['mode'] == 'coarse':
+ if drawData['desc']['mode'] == 'coarse':
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(0)
- elif data['desc']['mode'] == 'fine':
+ elif drawData['desc']['mode'] == 'fine':
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(1)
else: # both
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(2)
- if data['desc']['style'] == 'wire':
+ if drawData['desc']['style'] == 'wire':
self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(0)
else: # surface
self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(1)
- if data['desc']['shading'] == 'flat':
+ if drawData['desc']['shading'] == 'flat':
self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(0)
else: # gouraud
self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(1)
continue
- value = data['value']
+ value = drawData['value']
win = self.FindWindowById(self.win['surface']['draw'][control])
name = win.GetName()
@@ -3261,6 +3261,14 @@
win.SetColour(color)
else:
win.SetValue(value)
+ # position
+ if 'x' in data['position']:
+ xval = data['position']['x']
+ self.FindWindowById(self.win['surface']['position']['axis']).SetSelection(0)
+ for control in ('slider','text'):
+ self.FindWindowById(self.win['surface']['position'][control]).SetValue(xval)
# enable/disable res widget + set draw mode
self.OnSurfaceMode(event = None)
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-06-25 22:01:02 UTC (rev 46780)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-06-26 08:07:39 UTC (rev 46781)
@@ -337,12 +337,12 @@
# position
node_pos = node_surface.find('position')
if node_pos is not None:
- dc = self.nviz['surface']['position'] = {}
+ dc = nviz['surface']['position'] = {}
for coor in ['x', 'y', 'z']:
node = node_pos.find(coor)
if node is None:
continue
- value = int(self.__getNodeText(node, 'value'))
+ value = int(self.__getNodeText(node_pos, coor))
dc[coor] = value
elif 'vector' in nviz:
@@ -450,45 +450,46 @@
view = {}
iview = {}
- node_position = node_view.find('position')
+ node_position = node_view.find('v_position')
view['position'] = {}
- view['position']['x'] = float(self.__getNodeText(node_position, 'x'))
- view['position']['y'] = float(self.__getNodeText(node_position, 'y'))
+ view['position']['x'] = self.__processLayerNvizNode(node_position, 'x', float)
+ view['position']['y'] = self.__processLayerNvizNode(node_position, 'y', float)
node_persp = node_view.find('persp')
view['persp'] = {}
iview['persp'] = {}
- view['persp']['value'] = int(self.__getNodeText(node_persp, 'value'))
- view['persp']['step'] = int(self.__getNodeText(node_persp, 'step'))
- iview['persp']['min'] = int(self.__getNodeText(node_persp, 'min'))
- iview['persp']['max'] = int(self.__getNodeText(node_persp, 'max'))
- node_height = node_view.find('height')
+ view['persp']['value'] = self.__processLayerNvizNode(node_persp, 'value', int)
+ view['persp']['step'] = self.__processLayerNvizNode(node_persp, 'step', int)
+ iview['persp']['min'] = self.__processLayerNvizNode(node_persp, 'min', int)
+ iview['persp']['max'] = self.__processLayerNvizNode(node_persp, 'max', int)
+ node_height = node_view.find('v_height')
view['height'] = {}
iview['height'] = {}
- iview['height']['value'] = int(self.__getNodeText(node_height, 'value'))
- view['height']['step'] = int(self.__getNodeText(node_height, 'step'))
- iview['height']['min'] = int(self.__getNodeText(node_height, 'min'))
- iview['height']['max'] = int(self.__getNodeText(node_height, 'max'))
+ iview['height']['value'] = self.__processLayerNvizNode(node_height, 'value', int)
+ view['height']['step'] = self.__processLayerNvizNode(node_height, 'step', int)
+ iview['height']['min'] = self.__processLayerNvizNode(node_height, 'min', int)
+ iview['height']['max'] = self.__processLayerNvizNode(node_height, 'max', int)
node_twist = node_view.find('twist')
view['twist'] = {}
iview['twist'] = {}
- view['twist']['value'] = int(self.__getNodeText(node_twist, 'value'))
- view['twist']['step'] = int(self.__getNodeText(node_twist, 'step'))
- iview['twist']['min'] = int(self.__getNodeText(node_twist, 'min'))
- iview['twist']['max'] = int(self.__getNodeText(node_twist, 'max'))
+ view['twist']['value'] = self.__processLayerNvizNode(node_twist, 'value', int)
+ view['twist']['step'] = self.__processLayerNvizNode(node_twist, 'step', int)
+ iview['twist']['min'] = self.__processLayerNvizNode(node_twist, 'min', int)
+ iview['twist']['max'] = self.__processLayerNvizNode(node_twist, 'max', int)
node_zexag = node_view.find('z-exag')
view['z-exag'] = {}
- view['z-exag']['step'] = int(self.__getNodeText(node_zexag, 'step'))
- view['z-exag']['value'] = int(self.__getNodeText(node_zexag, 'value'))
- view['z-exag']['min'] = int(self.__getNodeText(node_zexag, 'min'))
- view['z-exag']['max'] = int(self.__getNodeText(node_zexag, 'max'))
+ view['z-exag']['value'] = self.__processLayerNvizNode(node_zexag, 'value', int)
+ view['z-exag']['step'] = self.__processLayerNvizNode(node_zexag, 'step', int)
+ view['z-exag']['min'] = self.__processLayerNvizNode(node_zexag, 'min', int)
+ view['z-exag']['max'] = self.__processLayerNvizNode(node_zexag, 'max', int)
node_focus = node_view.find('focus')
iview['focus'] = {}
- iview['focus']['x'] = int(self.__getNodeText(node_focus, 'x'))
- iview['focus']['y'] = int(self.__getNodeText(node_focus, 'y'))
- iview['focus']['z'] = int(self.__getNodeText(node_focus, 'z'))
- node_background = node_view.find('background')
+ iview['focus']['x'] = self.__processLayerNvizNode(node_focus, 'x', int)
+ iview['focus']['y'] = self.__processLayerNvizNode(node_focus, 'y', int)
+ iview['focus']['z'] = self.__processLayerNvizNode(node_focus, 'z', int)
view['background'] = {}
- view['background']['color'] = tuple(map(int,self.__getNodeText(node_background, 'color').split(':')))
+ color = self.__processLayerNvizNode(node_view, 'background_color', str)
+ view['background']['color'] = tuple(map(int, color.split(':')))
self.nviz_state['view'] = view
self.nviz_state['iview'] = iview
@@ -498,28 +499,29 @@
node_light = node_state.find('light')
light = {}
- node_position = node_light.find('position')
+ node_position = node_light.find('l_position')
light['position'] = {}
- light['position']['x'] = float(self.__getNodeText(node_position, 'x'))
- light['position']['y'] = float(self.__getNodeText(node_position, 'y'))
- light['position']['z'] = float(self.__getNodeText(node_position, 'z'))
+ light['position']['x'] = self.__processLayerNvizNode(node_position, 'x', float)
+ light['position']['y'] = self.__processLayerNvizNode(node_position, 'y', float)
+ light['position']['z'] = self.__processLayerNvizNode(node_position, 'z', int)
+ light['bright'] = self.__processLayerNvizNode(node_light, 'bright', int)
+ light['ambient'] = self.__processLayerNvizNode(node_light, 'ambient', int)
+ color = self.__processLayerNvizNode(node_light, 'color', str)
+ light['color'] = tuple(map(int, color.split(':')))
- light['bright'] = int(node_light.get('bright', '80'))
- light['ambient'] = int(node_light.get('ambient', '20'))
- light['color'] = tuple(map(int,(node_light.get('color', '255:255:255')).split(':')))
self.nviz_state['light'] = light
node_constants = node_state.find('constant_planes')
constants = []
- for i, node_plane in enumerate(node_constants.findall('plane')):
- plane = {}
- plane['value'] = int(self.__getNodeText(node_plane, 'value'))
- plane['resolution'] = int(self.__getNodeText(node_plane, 'resolution'))
- plane['color'] = self.__getNodeText(node_plane, 'color')
- plane['object'] = {}
- constants.append({'constant': plane})
+ if node_constants:
+ for i, node_plane in enumerate(node_constants.findall('plane')):
+ plane = {}
+ plane['color'] = self.__processLayerNvizNode(node_plane, 'color', str)
+ plane['resolution'] = self.__processLayerNvizNode(node_plane, 'fine_resolution', int)
+ plane['value'] = self.__processLayerNvizNode(node_plane, 'height', int)
+ plane['object'] = {}
+ constants.append({'constant': plane})
self.nviz_state['constants'] = constants
@@ -584,7 +586,11 @@
data['draw']['mode'] = { 'value' : value,
'desc' : desc,
'update': None }
+ # position
+ for coord in ('x', 'y', 'z'):
+ data['position'][coord] = UserSettings.Get(group='nviz', key='surface', subkey=['position', coord])
+ data['position']['update'] = None
return data
def SetVolumeDefaultProp(self):
@@ -965,7 +971,6 @@
if 'object' not in data: # skip disabled
return
self.indent += 4
self.file.write('%s<surface>\n' % (' ' * self.indent))
self.indent += 4
@@ -1099,113 +1104,117 @@
self.file.write('%s<view>\n' % (' ' * self.indent))
self.indent += 4
# position
- self.file.write('%s<position>\n' % (' ' * self.indent))
+ self.file.write('%s<v_position>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('x', view['position'], format = '.2f')
- self.__writePairTag('y', view['position'], format = '.2f')
+ self.file.write('%s<x>%.2f</x>\n' % (' ' * self.indent, view['position']['x']))
+ self.file.write('%s<y>%.2f</y>\n' % (' ' * self.indent, view['position']['y']))
self.indent -= 4
- self.file.write('%s</position>\n' % (' ' * self.indent))
+ self.file.write('%s</v_position>\n' % (' ' * self.indent))
# perspective
self.file.write('%s<persp>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('value', view['persp'])
- self.__writePairTag('step', view['persp'])
- self.__writePairTag('max', iview['persp'])
- self.__writePairTag('min', iview['persp'])
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent, view['persp']['value']))
+ self.file.write('%s<step>%d</step>\n' % (' ' * self.indent, view['persp']['step']))
+ self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, iview['persp']['min']))
+ self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, iview['persp']['max']))
self.indent -= 4
self.file.write('%s</persp>\n' % (' ' * self.indent))
# height
- self.file.write('%s<height>\n' % (' ' * self.indent))
+ self.file.write('%s<v_height>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('value', iview['height'])
- self.__writePairTag('step', view['height'])
- self.__writePairTag('max', iview['height'])
- self.__writePairTag('min', iview['height'])
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent, iview['height']['value']))
+ self.file.write('%s<step>%d</step>\n' % (' ' * self.indent, view['height']['step']))
+ self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, iview['height']['min']))
+ self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, iview['height']['max']))
self.indent -= 4
- self.file.write('%s</height>\n' % (' ' * self.indent))
+ self.file.write('%s</v_height>\n' % (' ' * self.indent))
# twist
self.file.write('%s<twist>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('step', view['twist'])
- self.__writePairTag('value', view['twist'])
- self.__writePairTag('max', iview['twist'])
- self.__writePairTag('min', iview['twist'])
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent, view['twist']['value']))
+ self.file.write('%s<step>%d</step>\n' % (' ' * self.indent, view['twist']['step']))
+ self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, iview['twist']['min']))
+ self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, iview['twist']['max']))
self.indent -= 4
self.file.write('%s</twist>\n' % (' ' * self.indent))
# z-exag
self.file.write('%s<z-exag>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('step', view['z-exag'])
- self.__writePairTag('value', view['z-exag'])
- self.__writePairTag('max', view['z-exag'])
- self.__writePairTag('min', view['z-exag'])
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent, view['z-exag']['value']))
+ self.file.write('%s<step>%d</step>\n' % (' ' * self.indent, view['z-exag']['step']))
+ self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, view['z-exag']['min']))
+ self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, view['z-exag']['max']))
self.indent -= 4
self.file.write('%s</z-exag>\n' % (' ' * self.indent))
# focus (look here)
self.file.write('%s<focus>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('x', iview['focus'])
- self.__writePairTag('y', iview['focus'])
- self.__writePairTag('z', iview['focus'])
+ self.file.write('%s<x>%d</x>\n' % (' ' * self.indent, iview['focus']['x']))
+ self.file.write('%s<y>%d</y>\n' % (' ' * self.indent, iview['focus']['y']))
+ self.file.write('%s<z>%d</z>\n' % (' ' * self.indent, iview['focus']['z']))
self.indent -= 4
self.file.write('%s</focus>\n' % (' ' * self.indent))
# background
- self.file.write('%s<background>\n' % (' ' * self.indent))
- self.indent += 4
- self.file.write('%s<color>' % (' ' * self.indent))
- self.file.write('%d:%d:%d</color>\n' % (view['background']['color']))
- self.indent -= 4
- self.file.write('%s</background>\n' % (' ' * self.indent))
+ self.__writeTagWithValue('background_color', view['background']['color'], format = 'd:%d:%d')
self.indent -= 4
self.file.write('%s</view>\n' % (' ' * self.indent))
# light
- self.file.write('%s<light bright="%d" ambient="%d" '
- % (' ' * self.indent, light['bright'], light['ambient']))
- self.file.write('color="%d:%d:%d">\n' % (light['color']))
+ self.file.write('%s<light>\n' % (' ' * self.indent))
self.indent += 4
# position
+ self.file.write('%s<l_position>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('x', light['position'], format = '.2f')
- self.__writePairTag('y', light['position'], format = '.2f')
- self.__writePairTag('z', light['position'], format = '.2f')
+ self.file.write('%s<x>%.2f</x>\n' % (' ' * self.indent, light['position']['x']))
+ self.file.write('%s<y>%.2f</y>\n' % (' ' * self.indent, light['position']['y']))
+ self.file.write('%s<z>%d</z>\n' % (' ' * self.indent, light['position']['z']))
self.indent -= 4
+ self.file.write('%s</l_position>\n' % (' ' * self.indent))
+ # bright
+ self.__writeTagWithValue('bright', light['bright'])
+ # ambient
+ self.__writeTagWithValue('ambient', light['ambient'])
+ # color
+ self.__writeTagWithValue('color', light['color'], format = 'd:%d:%d')
self.indent -= 4
self.file.write('%s</light>\n' % (' ' * self.indent))
# constant planes
- self.file.write('%s<constant_planes>\n' % (' ' * self.indent))
- self.indent += 4
- for idx, plane in enumerate(constants):
- self.file.write('%s<plane>\n' % (' ' * self.indent))
+ if constants:
+ self.file.write('%s<constant_planes>\n' % (' ' * self.indent))
self.indent += 4
- self.__writePairTag('value', constants[idx]['constant'])
- self.__writePairTag('resolution', constants[idx]['constant'])
- self.__writePairTag('color', constants[idx]['constant'], format = 's')
+ for idx, plane in enumerate(constants):
+ self.file.write('%s<plane>\n' % (' ' * self.indent))
+ self.indent += 4
+ self.__writeTagWithValue('height', constants[idx]['constant']['value'])
+ self.__writeTagWithValue('fine_resolution', constants[idx]['constant']['resolution'])
+ self.__writeTagWithValue('color', constants[idx]['constant']['color'], format = 's')
+ self.indent -= 4
+ self.file.write('%s</plane>\n' % (' ' * self.indent))
self.indent -= 4
- self.file.write('%s</plane>\n' % (' ' * self.indent))
+ self.file.write('%s</constant_planes>\n' % (' ' * self.indent))
self.indent -= 4
- self.file.write('%s</constant_planes>\n' % (' ' * self.indent))
- self.indent -= 4
self.file.write('%s</nviz_state>\n' % (' ' * self.indent))
self.indent -= 4
- def __writePairTag(self, tag, data, format = 'd'):
+ def __writeTagWithValue(self, tag, data, format = 'd'):
"""!Helper function for writing pair tag
@param tag written tag
@param data written data
@param format conversion type
- self.file.write(('%s<%s>%' + format + '</%s>\n') % \
- (' ' * self.indent, tag, data[tag], tag))
+ self.file.write('%s<%s>\n' % (' ' * self.indent, tag))
+ self.indent += 4
+ self.file.write('%s' % (' ' * self.indent))
+ self.file.write(('<value>%' + format + '</value>\n') % data)
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, tag))
class ProcessGrcFile(object):
def __init__(self, filename):
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2011-06-25 22:01:02 UTC (rev 46780)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2011-06-26 08:07:39 UTC (rev 46781)
@@ -30,7 +30,7 @@
render, mode and showCompExtent (added 2004/08)
-<!ELEMENT display (projection?, (group|layer)*)>
+<!ELEMENT display (projection?, (group|layer)*, nviz_state?)>
<!ATTLIST display render (0 | 1) #IMPLIED>
<!ATTLIST display mode (0 | 1 | 2 | 3 | 4 | 5 | 6) #IMPLIED>
<!ATTLIST display showCompExtent (0 | 1) #IMPLIED>
@@ -38,6 +38,7 @@
<!-- window dimenstion (x, y (ur), width, heigth -->
<!ATTLIST display dim CDATA #IMPLIED>
<!ATTLIST display extent CDATA #IMPLIED>
+<!ATTLIST display viewMode (2d | 3d) #IMPLIED>
<!-- projection (statusbar coordinates)
@@ -121,6 +122,7 @@
<!-- nviz surface draw resolution
<!ELEMENT resolution (value)>
+<!ATTLIST resolution type (fine | coarse) #IMPLIED>
<!-- nviz surface wire color
@@ -150,6 +152,43 @@
<!ELEMENT color (value)>
<!ELEMENT width (value)>
<!ELEMENT height (value)>
-<!ELEMENT mode (map?)>
+<!ELEMENT mode (map*)>
+<!ELEMENT map (name, checked)>
+<!ELEMENT name (#PCDATA)>
+<!ELEMENT checked (0 | 1)>
<!ATTLIST mode type (flat | surface) #REQUIRED>
<!ELEMENT size (value)>
+<!-- nviz state properties
+<!ELEMENT nviz_state (view, light, constant_planes?)>
+<!-- nviz view position
+<!ELEMENT view (v_position, persp, v_height, twist, z-exag, focus, background_color)>
+<!ELEMENT v_position (x, y)>
+<!ELEMENT persp (value, step, min, max)>
+<!ELEMENT v_height (value, step, min, max)>
+<!ELEMENT twist (value, step, min, max)>
+<!ELEMENT z-exag (value, step, min, max)>
+<!ELEMENT focus (x, y, z)>
+<!ELEMENT background_color (value)>
+<!ELEMENT step (#PCDATA)>
+<!ELEMENT min (#PCDATA)>
+<!ELEMENT max (#PCDATA)>
+<!-- nviz light
+<!ELEMENT light (l_position, bright, ambient, color)>
+<!ELEMENT l_position (x, y, z)>
+<!ELEMENT bright (value)>
+<!ELEMENT ambien (value)>
+<!ELEMENT color (value)>
+<!-- nviz constant planes
+<!ELEMENT constant_planes (plane*)>
+<!ELEMENT plane (height, fine_resolution, color)>
+<!ELEMENT fine_resolution (#PCDATA)>
