[GRASS-SVN] r46784 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Sun Jun 26 05:24:24 EDT 2011
Author: huhabla
Date: 2011-06-26 02:24:23 -0700 (Sun, 26 Jun 2011)
New Revision: 46784
grass/trunk/raster/r.colors/edit_colors.c
grass/trunk/raster/r.colors/local_proto.h
grass/trunk/raster/r.colors/r3.colors.html
grass/trunk/raster/r.colors/rules.c
grass/trunk/raster/r.colors/stats.c
grass/trunk/raster/r.colors/test.r.colors.sh
Enabled flag "-e" for volume maps
Modified: grass/trunk/raster/r.colors/edit_colors.c
--- grass/trunk/raster/r.colors/edit_colors.c 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/edit_colors.c 2011-06-26 09:24:23 UTC (rev 46784)
@@ -19,9 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
-#include <grass/glocale.h>
#include "local_proto.h"
-#include <grass/G3d.h>
static char **rules;
static int nrules;
@@ -38,7 +36,7 @@
char path[GPATH_MAX];
- sprintf(path, "%s/etc/colors", G_gisbase());
+ G_snprintf(path, GPATH_MAX, "%s/etc/colors", G_gisbase());
rules = G__ls(path, &nrules);
@@ -86,7 +84,7 @@
char *result = G_malloc(result_max);
int i;
- sprintf(path, "%s/etc/colors.desc", G_gisbase());
+ G_snprintf(path, GPATH_MAX, "%s/etc/colors.desc", G_gisbase());
kv = G_read_key_value_file(path);
if (!kv)
return NULL;
@@ -153,7 +151,7 @@
struct GModule *module;
struct {
- struct Flag *r, *w, *l, *g, *a, *n, *e; /* Flag e is not available in r3.colors*/
+ struct Flag *r, *w, *l, *g, *a, *n, *e;
} flag;
struct {
@@ -244,15 +242,10 @@
flag.a->description = _("Logarithmic-absolute scaling");
flag.a->guisection = _("Define");
- /* The histogram equalization is currently only available for
- * raster map. Therefor no flag is defined for r3.colors.
- if (type == RASTER_TYPE) {
- flag.e = G_define_flag();
- flag.e->key = 'e';
- flag.e->description = _("Histogram equalization");
- flag.e->guisection = _("Define");
+ flag.e = G_define_flag();
+ flag.e->key = 'e';
+ flag.e->description = _("Histogram equalization");
+ flag.e->guisection = _("Define");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -405,21 +398,17 @@
if (flag.n->answer)
Rast_invert_colors(&colors);
- /* This is not avilable for raster3d maps yet */
- if (flag.e->answer) {
- if (fp) {
- struct FP_stats fpstats;
- get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
- Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
- } else {
- if (!have_stats)
- have_stats = get_stats(name, mapset, &statf);
- Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
- colors = colors_tmp;
+ if (flag.e->answer) {
+ if (fp) {
+ struct FP_stats fpstats;
+ get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer, type);
+ Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
+ } else {
+ if (!have_stats)
+ have_stats = get_stats(name, mapset, &statf);
+ Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
+ colors = colors_tmp;
if (flag.g->answer) {
Modified: grass/trunk/raster/r.colors/local_proto.h
--- grass/trunk/raster/r.colors/local_proto.h 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/local_proto.h 2011-06-26 09:24:23 UTC (rev 46784)
@@ -22,6 +22,8 @@
#include <grass/gis.h>
#include <grass/raster.h>
+#include <grass/glocale.h>
+#include <grass/G3d.h>
#define RASTER_TYPE 1
#define RASTER3D_TYPE 2
@@ -30,7 +32,7 @@
int get_stats(const char *, const char *, struct Cell_stats *);
void get_fp_stats(const char *name, const char *mapset,
struct FP_stats *statf,
- DCELL min, DCELL max, int geometric, int geom_abs);
+ DCELL min, DCELL max, int geometric, int geom_abs, int);
/* edit_colors.c */
int edit_colors(int, char **, int, const char *, const char*);
Modified: grass/trunk/raster/r.colors/r3.colors.html
--- grass/trunk/raster/r.colors/r3.colors.html 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/r3.colors.html 2011-06-26 09:24:23 UTC (rev 46784)
@@ -1,8 +1,7 @@
<h2>DESCRIPTION</h2>
<i>r3.colors</i> has exactly the same functionality as <i>r.colors</i> but for volume maps.
-With the exception that the <b>-e</b> flag, which equalizes the original raster's color table,
-only works for raster maps. Please refer to <a href="r.colors.html">r.colors</a>.
+Please refer to <a href="r.colors.html">r.colors</a>.
<h2>SEE ALSO</h2>
Modified: grass/trunk/raster/r.colors/rules.c
--- grass/trunk/raster/r.colors/rules.c 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/rules.c 2011-06-26 09:24:23 UTC (rev 46784)
@@ -21,9 +21,6 @@
#include <stdio.h>
#include <unistd.h>
#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
/* color structure for default and null value */
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/stats.c 2011-06-26 09:24:23 UTC (rev 46784)
@@ -19,13 +19,9 @@
#include <math.h>
#include <stdlib.h>
-int get_stats(const char *name, const char *mapset, struct Cell_stats *statf)
+int get_stats(const char *name, const char *mapset, struct Cell_stats *statf) {
CELL *cell;
int row, nrows, ncols;
int fd;
@@ -38,11 +34,11 @@
Rast_init_cell_stats(statf);
G_verbose_message(_("Reading raster map <%s>..."),
- G_fully_qualified_name(name, mapset));
+ G_fully_qualified_name(name, mapset));
for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
- Rast_get_c_row(fd, cell, row);
- Rast_update_cell_stats(cell, ncols, statf);
+ G_percent(row, nrows, 2);
+ Rast_get_c_row(fd, cell, row);
+ Rast_update_cell_stats(cell, ncols, statf);
Rast_close(fd);
@@ -52,82 +48,109 @@
- struct FP_stats *statf,
+ struct FP_stats *statf,
+ DCELL min, DCELL max, int geometric, int geom_abs, int type) {
DCELL *dcell;
- int row, col, nrows, ncols;
+ int row, col, depth, nrows, ncols, ndepths = 1;
int fd;
+ G3D_Map *map3d = NULL;
- fd = Rast_open_old(name, mapset);
+ if (type == RASTER_TYPE) {
+ fd = Rast_open_old(name, mapset);
+ dcell = Rast_allocate_d_buf();
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ } else {
+ /* Initiate the default settings */
+ G3d_initDefaults();
- dcell = Rast_allocate_d_buf();
- nrows = Rast_window_rows();
- ncols = Rast_window_cols();
+ map3d = G3d_openCellOld(name, mapset, G3D_DEFAULT_WINDOW,
+ G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT);
+ if (map3d == NULL)
+ G3d_fatalError(_("Error opening 3d raster map"));
+ nrows = map3d->window.rows;
+ ncols = map3d->window.cols;
+ ndepths = map3d->window.depths;
statf->geometric = geometric;
statf->geom_abs = geom_abs;
statf->flip = 0;
if (statf->geometric) {
- if (min * max < 0)
- G_fatal_error(_("Unable to use logarithmic scaling if range includes zero"));
+ if (min * max < 0)
+ G_fatal_error(_("Unable to use logarithmic scaling if range includes zero"));
- if (min < 0) {
- statf->flip = 1;
- min = -min;
- max = -max;
+ if (min < 0) {
+ statf->flip = 1;
+ min = -min;
+ max = -max;
- min = log(min);
- max = log(max);
+ min = log(min);
+ max = log(max);
if (statf->geom_abs) {
- double a = log(fabs(min) + 1);
- double b = log(fabs(max) + 1);
- int has_zero = min * max < 0;
- min = a < b ? a : b;
- max = a > b ? a : b;
- if (has_zero)
- min = 0;
+ double a = log(fabs(min) + 1);
+ double b = log(fabs(max) + 1);
+ int has_zero = min * max < 0;
+ min = a < b ? a : b;
+ max = a > b ? a : b;
+ if (has_zero)
+ min = 0;
statf->count = 1000;
statf->min = min;
statf->max = max;
- statf->stats = G_calloc(statf->count + 1, sizeof(unsigned long));
+ statf->stats = G_calloc(statf->count + 1, sizeof (unsigned long));
statf->total = 0;
- G_verbose_message(_("Reading raster map <%s>..."),
- for (row = 0; row < nrows; row++) {
+ G_verbose_message(_("Reading map <%s>..."),
- Rast_get_d_row(fd, dcell, row);
- for (col = 0; col < ncols; col++) {
- DCELL x;
- int i;
+ for (depth = 0; depth < ndepths; depth++) {
+ for (row = 0; row < nrows; row++) {
- if (Rast_is_d_null_value(&dcell[col]))
- continue;
+ Rast_get_d_row(fd, dcell, row);
- x = dcell[col];
- if (statf->flip)
- x = -x;
- if (statf->geometric)
- x = log(x);
- if (statf->geom_abs)
- x = log(fabs(x) + 1);
+ for (col = 0; col < ncols; col++) {
+ DCELL x;
+ int i;
- i = (int) floor(statf->count * (x - statf->min) / (statf->max - statf->min));
- statf->stats[i]++;
- statf->total++;
+ x = dcell[col];
+ else
+ x = G3d_getDouble(map3d, col, row, depth);
+ if (Rast_is_d_null_value(&x))
+ continue;
+ if (statf->flip)
+ x = -x;
+ if (statf->geometric)
+ x = log(x);
+ if (statf->geom_abs)
+ x = log(fabs(x) + 1);
+ i = (int) floor(statf->count * (x - statf->min) / (statf->max - statf->min));
+ statf->stats[i]++;
+ statf->total++;
- Rast_close(fd);
+ Rast_close(fd);
+ else
+ G3d_closeCell(map3d);
G_free(dcell);
Modified: grass/trunk/raster/r.colors/test.r.colors.sh
--- grass/trunk/raster/r.colors/test.r.colors.sh 2011-06-26 08:46:09 UTC (rev 46783)
+++ grass/trunk/raster/r.colors/test.r.colors.sh 2011-06-26 09:24:23 UTC (rev 46784)
@@ -52,6 +52,7 @@
# The volume maps using r3.colors and r3.colors.out
r3.colors map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1.txt
+r3.colors -e map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1_hist.txt
r3.colors map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2.txt
r3.colors -g map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2_log.txt
r3.colors map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3.txt
@@ -64,4 +65,4 @@
# Test the removement the raster3d color table, a default color table will be created
r3.colors -r map=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_default.txt
# Test the removement the raster color table, a default color table will be created
-r.colors -r map=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_default.txt
\ No newline at end of file
+r.colors -r map=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_default.txt
