[GRASS-SVN] r46809 - grass-addons/grass7/raster/r.modis
svn_grass at osgeo.org
Mon Jun 27 16:44:04 EDT 2011
Author: neteler
Date: 2011-06-27 13:44:04 -0700 (Mon, 27 Jun 2011)
New Revision: 46809
grass-addons/grass7/raster/r.modis/r.modis.html
long lines broken
Modified: grass-addons/grass7/raster/r.modis/r.modis.html
--- grass-addons/grass7/raster/r.modis/r.modis.html 2011-06-27 20:41:11 UTC (rev 46808)
+++ grass-addons/grass7/raster/r.modis/r.modis.html 2011-06-27 20:44:04 UTC (rev 46809)
@@ -19,18 +19,27 @@
<h4>Products</h4>
The products already supported:
<ul>
- <li>Land Surface Temperature daily (Terra): product provides per-pixel temperature and emissivity values in a sequence of swath-based to grid-based global products. The MODIS/Terra LST/E Daily L3 Global 1 km Grid product (MOD11A1), is tile-based and gridded in the Sinusoidal projection, and produced daily at 1 km spatial resolution. </li>
- <li>Land Surface Temperature daily (Aqua): product provides per-pixel temperature and emissivity values in a sequence of swath-based to grid-based global products. The MODIS/Aqua LST/E Daily L3 Global 1 Km Grid product (MYD11A1), is tile-based and gridded in the Sinusoidal projection, and produced daily at 1 Km spatial resolution.</li>
- <li>NDVI sixteen days (Terra): MODIS Normalized Difference Vegetation Index (NDVI) complements NOAA's Advanced Very High Resolution Radiometer (AVHRR) NDVI products and provides continuity for time series historical applications. data are provided every 16 days at 250-meter spatial resolution as a gridded level-3 product (MOD13Q1) in the Sinusoidal projection.</li>
+ <li>Land Surface Temperature daily (Terra): product provides per-pixel temperature
+ and emissivity values in a sequence of swath-based to grid-based global products.
+ The MODIS/Terra LST/E Daily L3 Global 1 km Grid product (MOD11A1), is tile-based
+ and gridded in the Sinusoidal projection, and produced daily at 1 km spatial resolution. </li>
+ <li>Land Surface Temperature daily (Aqua): product provides per-pixel temperature and
+ emissivity values in a sequence of swath-based to grid-based global products.
+ The MODIS/Aqua LST/E Daily L3 Global 1 km Grid product (MYD11A1), is tile-based
+ and gridded in the Sinusoidal projection, and produced daily at 1 km spatial resolution.</li>
+ <li>NDVI sixteen days (Terra): MODIS Normalized Difference Vegetation Index (NDVI)
+ complements NOAA's Advanced Very High Resolution Radiometer (AVHRR) NDVI products
+ and provides continuity for time series historical applications. data are provided
+ every 16 days at 250-meter spatial resolution as a gridded level-3 product (MOD13Q1)
+ in the Sinusoidal projection.</li>
<li>Snow eight days: </li>
</ul>
<h2>SEE ALSO</h2>
<ul>
- <li> <a href="r.modis.download.html">r.modis.download</a>: Download MODIS
-products</li>
-<!-- <li> <a href="r.modis.import.html">r.modis.import</a>: Import into GRASS
-GIS 3 Level MODIS products as single image or daily mosaik</li> -->
+ <li> <a href="r.modis.download.html">r.modis.download</a>: Download MODIS HDF products from NASA FTP</li>
+<!-- <li> <a href="r.modis.import.html">r.modis.import</a>: Import Level 3 MODIS products as
+single image or daily mosaik into GRASS GIS</li> -->
<!-- <li> <a href="r.modis.process.html">r.modis.process</a>: Calculates range
of patch area size on a raster map</li>-->
</ul>
