[GRASS-SVN] r46827 - grass/trunk/visualization/nviz2/cmd
svn_grass at osgeo.org
Tue Jun 28 12:11:40 EDT 2011
Author: annakrat
Date: 2011-06-28 09:11:40 -0700 (Tue, 28 Jun 2011)
New Revision: 46827
grass/trunk/visualization/nviz2/cmd/args.c
grass/trunk/visualization/nviz2/cmd/local_proto.h
grass/trunk/visualization/nviz2/cmd/main.c
grass/trunk/visualization/nviz2/cmd/surface.c
nviz_cmd: cutting planes added
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c 2011-06-28 16:09:23 UTC (rev 46826)
+++ grass/trunk/visualization/nviz2/cmd/args.c 2011-06-28 16:11:40 UTC (rev 46827)
@@ -31,6 +31,7 @@
static void args_volume(struct GParams *);
static void args_lighting(struct GParams *);
static void args_fringe(struct GParams *);
+static void args_cplane(struct GParams *);
\brief Parse command
@@ -73,6 +74,9 @@
/*** fringe ***/
args_fringe(params);
+ /*** cutting plane ***/
+ args_cplane(params);
/*** output image ***/
/* output */
@@ -630,6 +634,64 @@
params->light_ambient->options="0-100";
+void args_cplane(struct GParams *params)
+ params->cplane = G_define_option();
+ params->cplane->key = "cplane";
+ params->cplane->key_desc = "value";
+ params->cplane->type = TYPE_INTEGER;
+ params->cplane->required = NO;
+ params->cplane->multiple = YES;
+ params->cplane->description = _("Cutting plane index (0-5)");
+ params->cplane->guisection = _("Cutting planes");
+ params->cplane_pos = G_define_option();
+ params->cplane_pos->key = "cplane_position";
+ params->cplane_pos->key_desc = "x,y,z";
+ params->cplane_pos->type = TYPE_DOUBLE;
+ params->cplane_pos->required = NO;
+ params->cplane_pos->multiple = YES;
+ params->cplane_pos->description = _("Cutting plane x,y coordinates");
+ params->cplane_pos->guisection = _("Cutting planes");
+ params->cplane_pos->answer = "0,0,0";
+ params->cplane_rot = G_define_option();
+ params->cplane_rot->key = "cplane_rotation";
+ params->cplane_rot->key_desc = "value";
+ params->cplane_rot->type = TYPE_DOUBLE;
+ params->cplane_rot->multiple = YES;
+ params->cplane_rot->required = NO;
+ params->cplane_rot->label = _("Cutting plane rotation along the vertical axis");
+ params->cplane_rot->guisection = _("Cutting planes");
+ params->cplane_rot->description = _("Cutting plane rotation along the vertical axis");
+ params->cplane_rot->answer = "0";
+ params->cplane_rot->options="0-360";
+ params->cplane_tilt = G_define_option();
+ params->cplane_tilt->key = "cplane_tilt";
+ params->cplane_tilt->key_desc = "value";
+ params->cplane_tilt->type = TYPE_DOUBLE;
+ params->cplane_tilt->multiple = YES;
+ params->cplane_tilt->required = NO;
+ params->cplane_tilt->label = _("Cutting plane tilt");
+ params->cplane_tilt->guisection = _("Cutting planes");
+ params->cplane_tilt->description = _("Cutting plane tilt");
+ params->cplane_tilt->answer = "0";
+ params->cplane_tilt->options="0-360";
+ params->cplane_shading = G_define_option();
+ params->cplane_shading->key = "cplane_shading";
+ params->cplane_shading->key_desc = "string";
+ params->cplane_shading->type = TYPE_STRING;
+ params->cplane_shading->multiple = NO;
+ params->cplane_shading->required = NO;
+ params->cplane_shading->label = _("Cutting plane color (between two surfaces)");
+ params->cplane_shading->guisection = _("Cutting planes");
+ params->cplane_shading->description = _("Cutting plane color (between two surfaces)");
+ params->cplane_shading->answer = "clear";
+ params->cplane_shading->options= "clear,top,bottom,blend,shaded";
void args_fringe(struct GParams *params)
params->fringe = G_define_option();
@@ -690,7 +752,7 @@
void check_parameters(const struct GParams *params)
int nelev_map, nelev_const, nelevs;
- int nmaps, nconsts, ncoords;
+ int nmaps, nconsts, ncoords, ncplanes;
int nvlines;
@@ -779,15 +841,26 @@
G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
params->elev_map->key, params->elev_const->key,
nelevs, params->wire_color->key, nconsts);
- /* position */
- ncoords = opt_get_num_answers(params->surface_pos);
- if (ncoords > 0 && 3 * nelevs != ncoords)
- G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
- params->elev_map->key, params->elev_const->key, nelevs,
- params->surface_pos->key, ncoords);
+ * Cutting planes
+ ncplanes = opt_get_num_answers(params->cplane);
+ ncoords = opt_get_num_answers(params->cplane_pos);
+ if (ncplanes > 0 && ncplanes * 3 != ncoords)
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"),
+ params->cplane->key, ncplanes, params->cplane_pos->key, ncoords/3);
+ nconsts = opt_get_num_answers(params->cplane_rot);
+ if (ncplanes > 0 && ncplanes != nconsts)
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+ params->cplane->key, ncplanes, params->cplane_rot->key, nconsts);
+ nconsts = opt_get_num_answers(params->cplane_tilt);
+ params->cplane->key, ncplanes, params->cplane_tilt->key, nconsts);
* vector lines
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h 2011-06-28 16:09:23 UTC (rev 46826)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h 2011-06-28 16:11:40 UTC (rev 46827)
@@ -24,6 +24,8 @@
*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
/* misc */
*exag, *bgcolor,
+ /* cutting planes */
+ *cplane, *cplane_pos, *cplane_rot, *cplane_tilt, *cplane_shading,
/* viewpoint */
*pos, *height, *persp, *twist,
/* output */
@@ -55,6 +57,9 @@
int load_rasters3d(const struct GParams *, nv_data *);
int add_isosurfs(const struct GParams *, nv_data *);
+/* cutting planes */
+void draw_cplane(const struct GParams *, nv_data *);
/* write_img.c */
int write_img(const char *, int);
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c 2011-06-28 16:09:23 UTC (rev 46826)
+++ grass/trunk/visualization/nviz2/cmd/main.c 2011-06-28 16:11:40 UTC (rev 46827)
@@ -189,8 +189,10 @@
GS_clear(data.bgcolor);
+ if(params->cplane->answer)
+ draw_cplane(params, &data);
/* draw */
- Nviz_draw_cplane(&data, -1, -1);
Nviz_draw_all(&data);
/* write to image */
Modified: grass/trunk/visualization/nviz2/cmd/surface.c
--- grass/trunk/visualization/nviz2/cmd/surface.c 2011-06-28 16:09:23 UTC (rev 46826)
+++ grass/trunk/visualization/nviz2/cmd/surface.c 2011-06-28 16:11:40 UTC (rev 46827)
@@ -74,9 +74,16 @@
/* set position */
- x = atof(params->surface_pos->answers[i*3+0]);
- y = atof(params->surface_pos->answers[i*3+1]);
- z = atof(params->surface_pos->answers[i*3+2]);
+ if (opt_get_num_answers(params->surface_pos) != 3 * nelevs){
+ x = atof(params->surface_pos->answers[0]);
+ y = atof(params->surface_pos->answers[1]);
+ z = atof(params->surface_pos->answers[2]);
+ else{
+ x = atof(params->surface_pos->answers[i*3+0]);
+ y = atof(params->surface_pos->answers[i*3+1]);
+ z = atof(params->surface_pos->answers[i*3+2]);
GS_set_trans(id, x, y, z);
