[GRASS-SVN] r46830 -
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Tue Jun 28 17:42:04 EDT 2011
Author: hamish
Date: 2011-06-28 14:42:04 -0700 (Tue, 28 Jun 2011)
New Revision: 46830
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
fix example (thanks Agustin; merge from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html 2011-06-28 21:38:55 UTC (rev 46829)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html 2011-06-28 21:42:04 UTC (rev 46830)
@@ -86,7 +86,7 @@
<h3>Basic interpolation</h3>
<div class="code"><pre>
-v.surf.bspline input=point_vector output=interpolate_surface type=bicubic
+v.surf.bspline input=point_vector output=interpolate_surface method=bicubic
</pre></div>
A bicubic spline interpolation will be done and a vector points map with estimated
