[GRASS-SVN] r46850 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Wed Jun 29 09:54:35 EDT 2011
Author: martinl
Date: 2011-06-29 06:54:35 -0700 (Wed, 29 Jun 2011)
New Revision: 46850
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.proj/output.c
g.proj: `-g` flag implemented
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2011-06-29 13:22:44 UTC (rev 46849)
+++ grass/trunk/general/g.proj/local_proto.h 2011-06-29 13:54:35 UTC (rev 46850)
@@ -13,7 +13,7 @@
#endif
/* output.c */
-void print_projinfo(void);
+void print_projinfo(int);
void print_datuminfo(void);
void print_proj4(int);
#ifdef HAVE_OGR
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2011-06-29 13:22:44 UTC (rev 46849)
+++ grass/trunk/general/g.proj/main.c 2011-06-29 13:54:35 UTC (rev 46850)
@@ -3,14 +3,15 @@
* MODULE: g.proj
* AUTHOR(S): Paul Kelly - paul-grass at stjohnspoint.co.uk
+ * Shell script style by Martin Landa <landa.martin gmail.com>
* PURPOSE: Provides a means of reporting the contents of GRASS
* projection information files and creating
* new projection information files.
- * COPYRIGHT: (C) 2003-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2007, 2011 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -28,27 +29,28 @@
int main(int argc, char *argv[])
struct Flag *printinfo, /* Print contents of PROJ_INFO & PROJ_UNITS */
- *printproj4, /* Print projection in PROJ.4 format */
- *datuminfo, /* Check if datum information is present */
- *create, /* Create new projection files */
+ *shellinfo, /* Print in shell script style */
+ *printproj4, /* Print projection in PROJ.4 format */
+ *datuminfo, /* Check if datum information is present */
+ *create, /* Create new projection files */
#ifdef HAVE_OGR
- *printwkt, /* Print projection in WKT format */
- *esristyle, /* Use ESRI-style WKT format */
+ *printwkt, /* Print projection in WKT format */
+ *esristyle, /* Use ESRI-style WKT format */
#endif
- *dontprettify, /* Print 'flat' output (no linebreaks) */
- *forcedatumtrans; /* Force override of datumtrans parameters */
+ *dontprettify, /* Print 'flat' output (no linebreaks) */
+ *forcedatumtrans; /* Force override of datumtrans parameters */
struct Option *location, /* Name of new location to create */
#ifdef HAVE_OGR
- *inepsg, /* EPSG projection code */
- *inwkt, /* Input file with projection in WKT format */
- *inproj4, /* Projection in PROJ.4 format */
- *ingeo, /* Input geo-referenced file readable by
+ *inepsg, /* EPSG projection code */
+ *inwkt, /* Input file with projection in WKT format */
+ *inproj4, /* Projection in PROJ.4 format */
+ *ingeo, /* Input geo-referenced file readable by
* GDAL or OGR */
#endif
- *dtrans; /* index to datum transform option */
+ *dtrans; /* index to datum transform option */
struct GModule *module;
int formats;
G_set_program_name(argv[0]);
@@ -74,8 +76,14 @@
printinfo->key = 'p';
printinfo->guisection = _("Print");
printinfo->description =
- _("Print projection information (in conventional GRASS format)");
+ _("Print projection information in conventional GRASS format");
+ shellinfo = G_define_flag();
+ shellinfo->key = 'g';
+ shellinfo->guisection = _("Print");
+ shellinfo->description =
+ _("Print projection information in shell script style");
datuminfo = G_define_flag();
datuminfo->key = 'd';
datuminfo->guisection = _("Print");
@@ -227,26 +235,27 @@
/* Output */
/* Only allow one output format at a time, to reduce confusion */
- formats = ((printinfo->answer ? 1 : 0) + (datuminfo->answer ? 1 : 0) +
+ formats = ((printinfo->answer ? 1 : 0) + (shellinfo->answer ? 1 : 0) +
(printproj4->answer ? 1 : 0) +
#ifdef HAVE_OGR
(printwkt->answer ? 1 : 0) +
#endif
(create->answer ? 1 : 0));
if (formats > 1)
- G_fatal_error(_("Only one of -%c, -%c, -%c"
+ G_fatal_error(_("Only one of -%c, -%c, -%c, -%c"
#ifdef HAVE_OGR
", -%c"
#endif
" or -%c flags may be specified"),
- printinfo->key, datuminfo->key, printproj4->key,
+ printinfo->key, shellinfo->key, datuminfo->key, printproj4->key,
#ifdef HAVE_OGR
printwkt->key,
#endif
create->key);
- if (printinfo->answer)
- print_projinfo();
+ if (printinfo->answer || shellinfo->answer)
+ print_projinfo(shellinfo->answer);
else if (datuminfo->answer)
print_datuminfo();
else if (printproj4->answer)
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2011-06-29 13:22:44 UTC (rev 46849)
+++ grass/trunk/general/g.proj/output.c 2011-06-29 13:54:35 UTC (rev 46850)
@@ -27,26 +27,37 @@
#include "local_proto.h"
-static int check_xy(void);
+static int check_xy(int shell);
+void print_projinfo(int shell)
int i;
- if (check_xy())
+ if (check_xy(shell))
return;
- fprintf(stdout,
- "-PROJ_INFO-------------------------------------------------\n");
- for (i = 0; i < projinfo->nitems; i++)
- fprintf(stdout, "%-11s: %s\n", projinfo->key[i], projinfo->value[i]);
- fprintf(stdout,
- "-PROJ_UNITS------------------------------------------------\n");
- for (i = 0; i < projunits->nitems; i++)
- projunits->key[i], projunits->value[i]);
+ if (!shell)
+ fprintf(stdout,
+ "-PROJ_INFO-------------------------------------------------\n");
+ for (i = 0; i < projinfo->nitems; i++) {
+ if (shell)
+ fprintf(stdout, "%s=%s\n", projinfo->key[i], projinfo->value[i]);
+ else
+ fprintf(stdout, "%-11s: %s\n", projinfo->key[i], projinfo->value[i]);
+ if (!shell)
+ fprintf(stdout,
+ "-PROJ_UNITS------------------------------------------------\n");
+ for (i = 0; i < projunits->nitems; i++) {
+ if (shell)
+ projunits->key[i], projunits->value[i]);
+ else
return;
@@ -56,7 +67,7 @@
struct gpj_datum dstruct;
int validdatum = 0;
- if (check_xy())
+ if (check_xy(FALSE))
return;
GPJ__get_datum_params(projinfo, &datum, ¶ms);
@@ -100,7 +111,7 @@
char *proj4, *proj4mod, *i;
const char *unfact;
- if (check_xy())
return;
pj_get_kv(&pjinfo, projinfo, projunits);
@@ -137,7 +148,7 @@
char *outwkt;
- if (check_xy())
return;
outwkt = GPJ_grass_to_wkt(projinfo, projunits, esristyle,
@@ -160,12 +171,12 @@
if (location) {
ret = G__make_location(location, &cellhd, projinfo, projunits, NULL);
if (ret == 0)
- G_message(_("Location %s created!"), location);
+ G_message(_("Location <%s> created"), location);
else if (ret == -1)
- G_fatal_error(_("Unable to create location: %s"),
- strerror(errno));
+ G_fatal_error(_("Unable to create location <%s>: %s"),
+ location, strerror(errno));
else if (ret == -2)
- G_fatal_error(_("Unable to create projection files: %s"),
+ G_fatal_error(_("Unable to create projection files: %s"),
strerror(errno));
else
/* Shouldn't happen */
@@ -176,7 +187,6 @@
* projection files for current location */
const char *mapset = G_mapset();
- struct Key_Value *old_projinfo = NULL, *old_projunits = NULL;
struct Cell_head old_cellhd;
if (strcmp(mapset, "PERMANENT") != 0)
@@ -186,46 +196,41 @@
/* Read projection information from current location first */
G_get_default_window(&old_cellhd);
- if (old_cellhd.proj != PROJECTION_XY) {
- old_projinfo = G_get_projinfo();
- old_projunits = G_get_projunits();
+ char path[GPATH_MAX];
+ /* Write out the PROJ_INFO, and PROJ_UNITS if available. */
+ if (projinfo != NULL) {
+ G_file_name(path, "", "PROJ_INFO", "PERMANENT");
+ G_write_key_value_file(path, projinfo);
- char path[GPATH_MAX];
- /* Write out the PROJ_INFO, and PROJ_UNITS if available. */
- if (projinfo != NULL) {
- G_file_name(path, "", "PROJ_INFO", "PERMANENT");
- G_write_key_value_file(path, projinfo);
- if (projunits != NULL) {
- G_file_name(path, "", "PROJ_UNITS", "PERMANENT");
- G_write_key_value_file(path, projunits);
- if ((old_cellhd.zone != cellhd.zone) ||
- (old_cellhd.proj != cellhd.proj)) {
- /* Recreate the default, and current window files if projection
- * number or zone have changed */
- G__put_window(&cellhd, "", "DEFAULT_WIND");
+ if (projunits != NULL) {
+ G_file_name(path, "", "PROJ_UNITS", "PERMANENT");
+ G_write_key_value_file(path, projunits);
+ if ((old_cellhd.zone != cellhd.zone) ||
+ (old_cellhd.proj != cellhd.proj)) {
+ /* Recreate the default, and current window files if projection
+ * number or zone have changed */
+ G__put_window(&cellhd, "", "DEFAULT_WIND");
G__put_window(&cellhd, "", "WIND");
G_message(_("N.B. The default region was updated to the new projection, but if you have "
- "multiple mapsets g.region -d should be run in each to update the region from "
- "the default."));
- G_message(_("Projection information updated!"));
+ "multiple mapsets g.region -d should be run in each to update the region from "
+ "the default."));
+ G_message(_("Projection information updated!"));
return;
if (cellhd.proj == PROJECTION_XY) {
+ if (shell)
+ fprintf(stdout, "name=");
fprintf(stdout, "XY location (unprojected)\n");
return 1;
