[GRASS-SVN] r46871 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Jun 30 10:43:33 EDT 2011
Author: martinl
Date: 2011-06-30 07:43:33 -0700 (Thu, 30 Jun 2011)
New Revision: 46871
grass/trunk/scripts/g.extension/g.extension.py
g.extension: define also 'etc' dir
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-06-30 14:42:54 UTC (rev 46870)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-06-30 14:43:33 UTC (rev 46871)
@@ -287,7 +287,7 @@
if remove_tmpdir:
grass.try_rmdir(tmpdir)
else:
- grass.info(_("Path to the source code: '%s'") % tmpdir)
+ grass.info(_("Path to the source code: '%s'") % os.path.join(tmpdir, options['extension']))
def install_extension():
gisbase = os.getenv('GISBASE')
@@ -319,29 +319,45 @@
if grass.call(['svn', 'checkout',
url], stdout = outdev) != 0:
grass.fatal(_("GRASS Addons '%s' not found in repository") % options['extension'])
+ dirs = { 'bin' : os.path.join(tmpdir, options['extension'], 'bin'),
+ 'docs' : os.path.join(tmpdir, options['extension'], 'docs'),
+ 'html' : os.path.join(tmpdir, options['extension'], 'docs', 'html'),
+ 'man' : os.path.join(tmpdir, options['extension'], 'man'),
+ 'man1' : os.path.join(tmpdir, options['extension'], 'man', 'man1'),
+ 'scripts' : os.path.join(tmpdir, options['extension'], 'scripts'),
+ 'etc' : os.path.join(tmpdir, options['extension'], 'etc'),
+ makeCmd = ['make',
+ 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
+ 'BIN=%s' % dirs['bin'],
+ 'HTMLDIR=%s' % dirs['html'],
+ 'MANDIR=%s' % dirs['man1'],
+ 'SCRIPTDIR=%s' % dirs['scripts'],
+ 'ETC=%s' % dirs['etc']
+ installCmd = ['make',
+ 'MODULE_TOPDIR=%s' % gisbase,
+ 'ARCH_DISTDIR=%s' % os.path.join(tmpdir, options['extension']),
+ 'INST_DIR=%s' % options['prefix'],
+ 'install'
if flags['d']:
+ sys.stderr.write(' '.join(makeCmd) + '\n')
+ sys.stderr.write(' '.join(installCmd) + '\n')
return
os.chdir(os.path.join(tmpdir, options['extension']))
grass.message(_("Compiling '%s'...") % options['extension'])
if options['extension'] not in gui_list:
- bin_dir = os.path.join(tmpdir, options['extension'], 'bin')
- docs_dir = os.path.join(tmpdir, options['extension'], 'docs')
- html_dir = os.path.join(docs_dir, 'html')
- man_dir = os.path.join(tmpdir, options['extension'], 'man')
- man1_dir = os.path.join(man_dir, 'man1')
- script_dir = os.path.join(tmpdir, options['extension'], 'scripts')
- for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir, script_dir):
+ for d in dirs.itervalues():
os.mkdir(d)
- ret = grass.call(['make',
- 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
- 'BIN=%s' % bin_dir,
- 'HTMLDIR=%s' % html_dir,
- 'MANDIR=%s' % man1_dir,
- 'SCRIPTDIR=%s' % script_dir],
+ ret = grass.call(makeCmd,
stdout = outdev)
else:
@@ -356,11 +372,7 @@
grass.message(_("Installing '%s'...") % options['extension'])
- 'MODULE_TOPDIR=%s' % gisbase,
- 'ARCH_DISTDIR=%s' % os.path.join(tmpdir, options['extension']),
- 'INST_DIR=%s' % options['prefix'],
- 'install'],
+ ret = grass.call(installCmd,
stdout = outdev)
if ret != 0:
