[GRASS-SVN] r46875 - grass/trunk/lib/vector
svn_grass at osgeo.org
Thu Jun 30 12:03:54 EDT 2011
Author: martinl
Date: 2011-06-30 09:03:54 -0700 (Thu, 30 Jun 2011)
New Revision: 46875
grass/trunk/lib/vector/vectorlib.dox
vlib: add some topo examples to the doxygen documentation
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2011-06-30 14:53:38 UTC (rev 46874)
+++ grass/trunk/lib/vector/vectorlib.dox 2011-06-30 16:03:54 UTC (rev 46875)
@@ -779,6 +779,216 @@
\subsection vlibTopoExamples Topology examples
+<b>Points</b>
+\verbatim
+One point (nodes: 1, lines: 1, areas: 0, isles: 0)
+ + N1/L1
+\endverbatim
+%Node N1 (see \ref P_Node)
+\verbatim
+node = 1, n_lines = 1, xyz = 631286.707172, 225105.223577, 0.000000
+ line = 1, type = 1, angle = -9.000000
+\endverbatim
+Line L1 (see \ref P_Line)
+\verbatim
+line = 1, type = 1, offset = 18 n1 = 1, n2 = 1, left/area = 0, right = 0
+N,S,E,W,T,B: 225105.223577, 225105.223577, 631286.707172, 631286.707172, 0.000000, 0.000000
+\endverbatim
+<b>Lines</b>
+\verbatim
+One line (nodes: 2, lines: 1, areas: 0, isles: 0)
+ +----L1----+
+ N1 N2
+\endverbatim
+\verbatim
+node = 1, n_lines = 1, xyz = 634624.746450, 223557.302231, 0.000000
+ line = 1, type = 2, angle = -0.436257
+\endverbatim
+%Node N2 (see \ref P_Node)
+\verbatim
+node = 2, n_lines = 1, xyz = 638677.484787, 221667.849899, 0.000000
+ line = -1, type = 2, angle = 2.705335
+\endverbatim
+\verbatim
+line = 1, type = 2, offset = 18 n1 = 1, n2 = 2, left/area = 0, right = 0
+N,S,E,W,T,B: 223557.302231, 221667.849899, 638677.484787, 634624.746450, 0.000000, 0.000000
+\endverbatim
+<b>Areas without holes</b>
+\verbatim
+One line (nodes: 2, lines: 2, areas: 1, isles: 1)
+ +N1
+ / +N2/L2 \
+ -------L1------
+\endverbatim
+\verbatim
+node = 1, n_lines = 2, xyz = 635720.081136, 225063.387424, 0.000000
+ line = 1, type = 4, angle = -2.245537
+ line = -1, type = 4, angle = -0.842926
+\endverbatim
+\verbatim
+node = 2, n_lines = 1, xyz = 635779.454021, 223100.127232, 0.000000
+ line = 2, type = 8, angle = -9.000000
+\endverbatim
+\verbatim
+line = 1, type = 4, offset = 18 n1 = 1, n2 = 1, left/area = 1, right = -1
+N,S,E,W,T,B: 225063.387424, 222188.133874, 638184.584178, 633419.878296, 0.000000, 0.000000
+\endverbatim
+Line L2 (see \ref P_Line)
+\verbatim
+line = 2, type = 8, offset = 87 n1 = 2, n2 = 2, left/area = 1, right = 0
+N,S,E,W,T,B: 223100.127232, 223100.127232, 635779.454021, 635779.454021, 0.000000, 0.000000
+\endverbatim
+Area A1 (see \ref P_Area)
+\verbatim
+area = 1, n_lines = 1, n_isles = 0 centroid = 2
+ line = -1
+\endverbatim
+Isle I1 (see \ref P_Isle)
+\verbatim
+isle = 1, n_lines = 1 area = 0
+ line = 1
+\endverbatim
+<b>Areas with holes</b>
+\verbatim
+One line (nodes: 3, lines: 3, areas: 2, isles: 2)
+ +N1
+ / +N2/L2 \
+ / +N3 \
+ / ---L3-- \
+------------L1-------------
+\endverbatim
+\verbatim
+\endverbatim
+\verbatim
+\endverbatim
+%Node N3 (see \ref P_Node)
+\verbatim
+node = 3, n_lines = 2, xyz = 636788.032454, 223173.935091, 0.000000
+ line = 3, type = 4, angle = -2.245537
+ line = -3, type = 4, angle = -0.866302
+\endverbatim
+\verbatim
+\endverbatim
+\verbatim
+\endverbatim
+Line L3 (see \ref P_Line)
+\verbatim
+line = 3, type = 4, offset = 197 n1 = 3, n2 = 3, left/area = 2, right = -2
+N,S,E,W,T,B: 223173.935091, 222626.267748, 637253.549696, 636349.898580, 0.000000, 0.000000
+\endverbatim
+\verbatim
+area = 1, n_lines = 1, n_isles = 1 centroid = 2
+ line = -1
+ isle = 2
+\endverbatim
+Area A2 (see \ref P_Area)
+\verbatim
+area = 2, n_lines = 1, n_isles = 0 centroid = 0
+ line = -3
+\endverbatim
+\verbatim
+ line = 1
+\endverbatim
+Isle I2 (see \ref P_Isle)
+\verbatim
+isle = 2, n_lines = 1 area = 1
+ line = 3
+\endverbatim
<b>Example 1</b>
A polygon may be formed by many boundaries (more primitives but connected).
