[GRASS-SVN] r46879 - grass/branches/develbranch_6/include/vect
svn_grass at osgeo.org
Thu Jun 30 13:32:39 EDT 2011
Author: neteler
Date: 2011-06-30 10:32:39 -0700 (Thu, 30 Jun 2011)
New Revision: 46879
grass/branches/develbranch_6/include/vect/dig_structs.h
selected backport of r46858
Modified: grass/branches/develbranch_6/include/vect/dig_structs.h
--- grass/branches/develbranch_6/include/vect/dig_structs.h 2011-06-30 17:31:55 UTC (rev 46878)
+++ grass/branches/develbranch_6/include/vect/dig_structs.h 2011-06-30 17:32:39 UTC (rev 46879)
@@ -1,13 +1,18 @@
- ** Written by Dave Gerdes 5/1988
- ** US Army Construction Engineering Research Lab
+ \file include/vect/dig_structs.h
+ \brief Data structures for \ref vectorlib
+ \author Written by Dave Gerdes (CERL) 5/1988
+ \author Updated to GRASS 5.7 by Radim Blazek (2001)
+ \author Doxygenized by Martin Landa <landa.martin gmail.com> (2011)
#include <grass/config.h>
#ifndef DIG___STRUCTS___
#define DIG___STRUCTS___
-/* this file depends on <stdio.h> */
+/* this file depends on <stdio.h> */
#ifndef _STDIO_H
#include <stdio.h>
#endif
@@ -17,22 +22,18 @@
#include <grass/btree.h>
#include <grass/rtree.h>
#ifdef HAVE_OGR
#include "ogr_api.h"
#endif
-#define HEADSTR 50
+ \brief plus_t size
- ** NOTE: 3.10 changes plus_t to ints.
- ** This assumes that any reasonable machine will use 4 bytes to
- ** store an int. The mapdev code is not guaranteed to work if
- ** plus_t is changed to a type that is larger than an int.
- typedef short plus_t;
+ 3.10 changes plus_t to ints. This assumes that any reasonable
+ machine will use 4 bytes to store an int. The diglib code is not
+ guaranteed to work if plus_t is changed to a type that is larger
+ than an int.
typedef int plus_t;
typedef struct bound_box BOUND_BOX;
@@ -42,141 +43,372 @@
typedef struct P_line P_LINE;
typedef struct P_isle P_ISLE;
-/* Used by sites lib */
+ \brief Used by sites lib
struct site_att
- int cat; /* category */
- double *dbl; /* double attributes */
- char **str; /* string attributes */
+ \brief Category number
+ int cat;
+ \brief Array of double attributes
+ double *dbl;
+ \brief Array of string attributes
+ char **str;
typedef struct site_att SITE_ATT;
-struct bound_box /* Bounding Box */
+ \brief Bounding box
+struct bound_box
- double N; /* north */
- double S; /* south */
- double E; /* east */
- double W; /* west */
- double T; /* top */
- double B; /* bottom */
+ \brief North
+ double N;
+ \brief South
+ double S;
+ \brief East
+ double E;
+ \brief West
+ double W;
+ \brief Top
+ double T;
+ \brief Bottom
+ double B;
+ \brief File definition
struct gvfile
+ \brief File descriptor
FILE *file;
- char *start; /* pointer to beginnig of the file in the memory */
- char *current; /* current position set by dig_seek */
- char *end; /* end of file in the memory (pointer to first byte after) */
- long size; /* size of the file loaded to memory */
- long alloc; /* allocated space */
- int loaded; /* 0 - not loaded, 1 - loaded */
+ \brief Pointer to beginnig of the file in the memory
+ char *start;
+ \brief Current position set by dig_seek()
+ char *current;
+ \brief End of file in the memory (pointer to first byte after)
+ char *end;
+ \brief Size of the file loaded to memory
+ long size;
+ \brief Allocated space
+ long alloc;
+ \brief Is file loaded?
+ - 0 - not loaded
+ - 1 - loaded
+ int loaded;
typedef struct gvfile GVFILE;
/* category field information */
+ \brief Field (layer) information
struct field_info
- int number; /* field number */
- char *name; /* field name */
+ \brief Field number
+ int number;
+ \brief Field name (optional)
+ char *name;
+ \brief Name of DB driver ('sqlite', 'dbf', ...)
char *driver;
- char *database;
+ brief Name of database
+ char *database;
+ \brief Name of DB table
char *table;
+ \brief Name of key column (usually 'cat')
char *key;
+ \brief Database links
struct dblinks
- struct field_info *field;
- int alloc_fields, n_fields;
+ \brief Pointer to the first field_info structure
+ struct field_info *field;
+ \brief Number of allocated slots
+ int alloc_fields;
+ \brief Number of available fields (layers)
+ int n_fields;
-/* Portability info */
+ \brief Portability info
+ Set by V1_open_new() or V1_open_old()
struct Port_info
- /* portability stuff, set in V1_open_new/old() */
- /* file byte order */
+ \brief File byte order
int byte_order;
- /* conversion matrices between file and native byte order */
+ \brief Conversion matrices between file and native byte order (double)
unsigned char dbl_cnvrt[PORT_DOUBLE];
+ \brief Conversion matrices between file and native byte order (float)
unsigned char flt_cnvrt[PORT_FLOAT];
+ \brief Conversion matrices between file and native byte order (long)
unsigned char lng_cnvrt[PORT_LONG];
+ \brief Conversion matrices between file and native byte order (int)
unsigned char int_cnvrt[PORT_INT];
+ \brief Conversion matrices between file and native byte order (short)
unsigned char shrt_cnvrt[PORT_SHORT];
- /* *_quick specify if native byte order of that type
- * is the same as byte order of vector file (TRUE)
- * or not (FALSE);*/
+ \brief Byte order for dbl
+ Specify if native byte order of that type is the same
+ as byte order of vector file (TRUE) or not (FALSE)
int dbl_quick;
int flt_quick;
+ \brief Byte order for lng
int lng_quick;
+ \brief Byte order for int
int int_quick;
+ \brief Byte order for shrt
int shrt_quick;
-/* List of dead lines in the file, the space can be reused, not yet used */
+ \brief List of dead lines in the file
+ \todo Implement it
+ The space can be reused, not yet used
struct recycle
- /* TODO */
char dummy;
+ \brief Vector map header data
+ Holds header data of vector map (see \ref vlibMap_info)
struct dig_head
- /*** HEAD_ELEMENT ***/
+ \brief Organization name
char *organization;
+ \brief Map date
char *date;
+ \brief User name
char *your_name;
+ \brief Map name
char *map_name;
+ \brief Source date
char *source_date;
+ \brief Original scale
long orig_scale;
+ \brief Comments
char *line_3;
+ \brief Zone (UTM only)
int plani_zone;
- /* double W, E, S, N; */
+ \brief Threshold for digitization
double digit_thresh;
/* double map_thresh; *//* not used in g57 */
/* Programmers should NOT touch any thing below here */
/* Library takes care of everything for you */
- /*** COOR_ELEMENT ***/
+ /* coor elements */
+ \brief Backward compatibility info - major version
int Version_Major;
+ \brief Backward compatibility info - minor version
int Version_Minor;
+ \brief Backward compatibility info - back major version
int Back_Major;
+ \brief Backward compatibility info - back minor version
int Back_Minor;
+ \brief 2D/3D vector data
+ - zero for 2D data
+ - non-zero for 3D data
int with_z;
- long size; /* coor file size */
- long head_size; /* coor header size */
+ \brief Coor file size
+ long size;
+ \brief Coor header size
+ long head_size;
- struct Port_info port; /* Portability information */
+ \brief Portability information
+ struct Port_info port;
- long last_offset; /* offset of last read line */
+ \brief Offset of last read line
+ long last_offset;
+ \brief Recycle dead line
+ \todo Not implemented yet
struct recycle *recycle;
struct Map_info *Map; /* X-ref to Map_info struct ?? */
-/* Coor info */
+ \brief Coor file info
struct Coor_info
- long size; /* total size, in bytes */
- long mtime; /* time of last modification */
+ \brief Total size (in bytes)
+ long size;
+ \brief Time of last modification
+ long mtime;
-/* Non-native format inforamtion */
-/* TODO: structure size should not change depending on compilation I think, do it better */
-/* OGR */
+ \brief Non-native format info (OGR)
+ \todo Structure size should not change depending on compilation I
+ think, do it better
struct Format_info_ogr
+ \brief OGR datasource name
char *dsn;
+ \brief OGR layer name
char *layer_name;
#ifdef HAVE_OGR
+ \brief Pointer to OGRDataSource
OGRDataSourceH ds;
+ \brief Pointer to OGRLayer
OGRLayerH layer;
#else
void *ds;
@@ -184,234 +416,736 @@
#endif
/* Level 1 (used by V*_read_next_line_ogr) */
- struct line_pnts **lines; /* points cache */
+ \brief Points cache (level 1)
+ struct line_pnts **lines;
+ \brief List of line types (level 1)
int *lines_types;
+ \brief Number of allocated lines (level 1)
int lines_alloc;
- int lines_num; /* number of lines in cache */
- int lines_next; /* next line to be read from cache */
+ \brief Number of lines in cache (level 1)
+ int lines_num;
+ \brief Next line to be read from cache (level 1)
+ int lines_next;
/* Level 2 */
+ \brief Cache to avoid repeated reading (level 2)
+ NULL if no feature is in cache
#ifdef HAVE_OGR
- OGRFeatureH feature_cache; /* cache to avoid repeated reading, NULL if no feature is in cache */
+ OGRFeatureH feature_cache;
#else
void *feature_cache;
#endif
- int feature_cache_id; /* id of feature read in feature_cache */
+ \brief Feature id read in feature_cache (level 2)
+ int feature_cache_id;
- /* Array where OGR feature/part info is stored for each line in GRASS.
- * This is not used for GV_CENTROID.
- * Because one feature may contain more elements (geometry collection also recursively),
- * offset for one line may be stored in more records.
- * First record is FID, next records are part indexes if necessary.
- * Example:
- * 5. ring in 3. polygon in 7. feature (multipolygon) of geometry collection which has FID = 123
- * 123 (feature 123: geometry colletion)
- * 6 (7. feature in geometry collection: multiPolygon)
- * 2 (3. polygon)
- * 4 (5. ring in the polygon)
+ \brief Offset list
+ Array where OGR feature/part info is stored for each line in
+ GRASS. This is not used for GV_CENTROID. Because one feature
+ may contain more elements (geometry collection also
+ recursively), offset for one line may be stored in more
+ records. First record is FID, next records are part indexes if
+ necessary. Example: 5. ring in 3. polygon in 7. feature
+ (multipolygon) of geometry collection which has FID = 123 123
+ (feature 123: geometry colletion) 6 (7. feature in geometry
+ collection: multiPolygon) 2 (3. polygon) 4 (5. ring in the
+ polygon)
int *offset;
- int offset_num; /* number of items in offset */
- int offset_alloc; /* space allocated for offset */
+ \brief Number of items in offset
+ int offset_num;
+ \brief Space allocated for offset
+ int offset_alloc;
- int next_line; /* used by V2_read_next_line_ogr */
+ Used by V2_read_next_line_ogr()
+ int next_line;
+ \brief Non-native format info (currently only OGR is implemented)
struct Format_info
- int i;
+ \brief id?
+ int i;
+ \brief OGR info
struct Format_info_ogr ogr;
-/* Category index */
+ \brief Category index
struct Cat_index
- int field; /* field number */
- int n_cats; /* number of items in cat array */
- int a_cats; /* allocated space in cat array */
- int (*cat)[3]; /* array of cats (cat,type, lines/area) */
- int n_ucats; /* number of unique cats (not updated) */
- int n_types; /* number of types in type */
- int type[7][2]; /* number of elements for each type (point, line, boundary, centroid, area, face, kernel) */
- long offset; /* offset of the beginning of this index in cidx file */
+ \brief Field (layer) number
+ int field;
+ \brief Number of items in cat array
+ int n_cats;
+ \brief Allocated space in cat array
+ int a_cats;
+ \brief Array of cats (cat, type, lines/area)
+ int (*cat)[3];
+ \brief Number of unique cats (not updated)
+ int n_ucats;
+ \brief Number of types in type
+ int n_types;
+ \brief Number of elements for each type
+ - GV_POINT
+ - GV_LINE
+ - GV_BOUNDARY
+ - GV_CENTROID
+ - GV_FACE
+ - GV_KERNEL
+ - GV_AREA
+ int type[7][2];
+ \brief Offset of the beginning of this index in cidx file
+ long offset;
+ \brief Basic topology-related info
+ Holds basic topology-related information about vector map
struct Plus_head
- int Version_Major; /* version codes */
+ \brief Version info (major)
+ int Version_Major;
+ \brief Version info (minor)
int Version_Minor;
- int Back_Major; /* earliest version that can use this data format */
+ \brief Earliest version that can use this data format (major)
+ int Back_Major;
+ \brief Earliest version that can use this data format (minor)
int Back_Minor;
- int spidx_Version_Major; /* version codes for spatial index */
+ \brief Version codes for spatial index (major)
+ int spidx_Version_Major;
+ \brief Version codes for spatial index (minor)
int spidx_Version_Minor;
- int spidx_Back_Major; /* earliest version that can use this data format */
+ int spidx_Back_Major;
int spidx_Back_Minor;
- int cidx_Version_Major; /* version codes for category index */
+ \brief Version codes for category index (major)
+ int cidx_Version_Major;
+ \brief Version codes for category index (minor)
int cidx_Version_Minor;
- int cidx_Back_Major; /* earliest version that can use this data format */
+ int cidx_Back_Major;
int cidx_Back_Minor;
+ - WITH_Z
+ - WITHOUT_Z
int with_z;
+ \brief 2D/3D spatial index
+ - WITH_Z
+ - WITHOUT_Z
int spidx_with_z;
- long head_size; /* topo header size */
- long spidx_head_size; /* spatial index header size */
- long cidx_head_size; /* category index header size */
+ /*** file header size ***/
+ \brief Topo header size
+ long head_size;
+ \brief Spatial index header size
+ long spidx_head_size;
+ \brief Category index header size
+ long cidx_head_size;
- int release_support; /* release memory occupied by support (topo, spatial, category) */
+ \brief Release memory occupied by support
+ (topo, spatial, category)
+ int release_support;
- struct Port_info spidx_port; /* Portability information for spatial index */
- struct Port_info cidx_port; /* Portability information for category index */
- int mode; /* Read, Write, RW */
+ /*** portability info */
- int built; /* the highest level of topology currently available (GV_BUILD_*) */
+ \brief Portability information for spatial index
+ struct Port_info spidx_port;
+ category index
+ struct Port_info cidx_port;
+ \brief Access mode
+ - GV_MODE_READ
+ - GV_MODE_WRITE
+ - GV_MODE_RW
+ int mode;
- struct bound_box box; /* box */
+ \brief Highest level of topology currently available
- P_NODE **Node; /* P_NODE array of pointers *//* 1st item is 1 for */
- P_LINE **Line; /* P_LINE array of pointers *//* all these (not 0) */
+ - GV_BUILD_NONE
+ - GV_BUILD_BASE
+ - GV_BUILD_AREAS
+ - GV_BUILD_ATTACH_ISLES
+ - GV_BUILD_CENTROIDS
+ - GV_BUILD_ALL
+ int built;
+ \brief Bounding box of features
+ struct bound_box box;
+ /*** topology ***/
+ \brief Array topo nodes
+ struct P_node **Node;
+ \brief Array topo lines/edges
+ P_NODE **Node;
+ P_LINE **Line;
+ \brief Array topo areas
P_AREA **Area;
+ \brief Array topo isles
P_ISLE **Isle;
- plus_t n_nodes; /* Current Number of nodes */
- plus_t n_edges; /* Current Number of edges */
- plus_t n_lines; /* Current Number of lines */
- plus_t n_areas; /* Current Number of areas */
+ \brief Current number of nodes
+ plus_t n_nodes;
+ \brief Current number of edges
+ plus_t n_edges;
+ \brief Current number of lines
+ plus_t n_lines;
+ \brief Current number of areas
+ plus_t n_areas;
+ \brief Current number of isles
plus_t n_isles;
- plus_t n_volumes; /* Current Number of volumes */
- plus_t n_holes; /* Current Number of holes */
+ \brief Current number of faces
+ plus_t n_faces;
+ \brief Current number of volumes
+ plus_t n_volumes;
+ \brief Current number of holes
+ plus_t n_holes;
- plus_t n_plines; /* Current Number of point lines */
- plus_t n_llines; /* Current Number of line lines */
- plus_t n_blines; /* Current Number of boundary lines */
- plus_t n_clines; /* Current Number of centroid lines */
- plus_t n_flines; /* Current Number of face lines */
- plus_t n_klines; /* Current Number of kernel lines */
+ \brief Current number of points
+ plus_t n_plines;
+ plus_t n_llines;
+ \brief Current number of boundaries
+ plus_t n_blines;
+ \brief Current number of centroids
+ plus_t n_clines;
+ plus_t n_flines;
+ \brief Current number of kernels
+ plus_t n_klines;
- plus_t alloc_nodes; /* # of nodes we have alloc'ed space for
- i.e. array size - 1 */
+ \brief Number of allocated nodes
+ i.e. array size - 1
+ plus_t alloc_nodes;
+ \brief Number of allocated edges
plus_t alloc_edges;
- plus_t alloc_lines; /* # of lines we have alloc'ed space for */
- plus_t alloc_areas; /* # of areas we have alloc'ed space for */
- plus_t alloc_isles; /* # of isles we have alloc'ed space for */
+ plus_t alloc_lines;
+ \brief Number of allocated areas
+ plus_t alloc_areas;
+ \brief Number of allocated isles
+ plus_t alloc_isles;
plus_t alloc_volumes;
+ \brief Number of allocated holes
plus_t alloc_holes;
- long Node_offset; /* offset of array of nodes in topo file */
+ \brief Offset of array of nodes in topo file
+ long Node_offset;
+ \brief Offset of array of edges in topo file
long Edge_offset;
+ \brief Offset of array of lines in topo file
long Line_offset;
+ \brief Offset of array of areas in topo file
long Area_offset;
+ \brief Offset of array of isles in topo file
long Isle_offset;
+ \brief Offset of array of volumes in topo file
long Volume_offset;
+ \brief Offset of array of holes in topo file
long Hole_offset;
- /* Spatial index */
- /* Spatial index is never saved, it is built automaticaly for new and updated vectors.
- * It is not built for old vectors until it is needed, i.e. until Vect_select is called.
- * or until Vect_build is called */
+ /*** spatial index ***/
+ /* Spatial index is never saved, it is built automatically for new and updated vectors.
+ * It is not built for old vectors until it is needed, i.e. until Vect_select() is called.
+ * or until Vect_build() is called */
- int Spidx_built; /* set to 1 if spatial index is available and to 0 if it is not */
+ \brief Spatial index built?
- long Node_spidx_offset; /* offset of spindex */
+ Set to 1 if spatial index is available
+ int Spidx_built;
+ \brief Offset of nodes in sidx file
+ long Node_spidx_offset;
+ \brief Offset of edges in sidx file
long Edge_spidx_offset;
+ \brief Offset of lines in sidx file
long Line_spidx_offset;
+ \brief Offset of areas in sidx file
long Area_spidx_offset;
+ \brief Offset of isles in sidx file
long Isle_spidx_offset;
+ \brief Offset of volumes in sidx file
long Volume_spidx_offset;
+ \brief Offset of holes in sidx file
long Hole_spidx_offset;
+ \brief Node spatial index
struct Node *Node_spidx;
+ \brief Line spatial index
struct Node *Line_spidx;
+ \brief Area spatial index
struct Node *Area_spidx;
+ \brief Isles spatial index
struct Node *Isle_spidx;
- /* Category index */
- /* By default, category index is not updated */
- int update_cidx; /* update category index if vector is modified */
+ /*** category index ***/
+ \brief Update category index if vector is modified
- int n_cidx; /* number of cat indexes (one for each field) */
- int a_cidx; /* allocated space for cat indexes */
- struct Cat_index *cidx; /* Array of category indexes */
- int cidx_up_to_date; /* set to 1 when cidx is created and reset to 0 whenever any line is changed */
+ By default, category index is not updated
+ int update_cidx;
- long coor_size; /* size of coor file */
- long coor_mtime; /* time of last coor modification */
+ \brief Number of category indexes (one for each field/layer)
+ int n_cidx;
+ \brief Allocated space for category indexes
+ int a_cidx;
+ \brief Array of category indexes
+ struct Cat_index *cidx;
+ \brief Category index to be updated
+ Set to 1 when cidx is created
+ and reset to 0 whenever any line is changed
+ int cidx_up_to_date;
+ \brief Size of coor file
+ long coor_size;
+ \brief Time of last coor modification
+ long coor_mtime;
/* Level2 update: list of lines and nodes updated (topo info for the line was changed)
* by last write/rewrite/delete operation.
* Lines/nodes in the list may be deleted (e.g. delete boundary: first added for
* delete area and then delete */
- int do_uplist; /* used internaly in diglib to know if list is maintained */
+ int do_uplist;
- int *uplines; /* array of updated lines */
- int alloc_uplines; /* allocated array */
- int n_uplines; /* number of updated lines */
- int *upnodes; /* array of updated nodes */
- int alloc_upnodes; /* allocated array */
- int n_upnodes; /* number of updated nodes */
+ \brief Array of updated lines
+ List of lines and nodes updated (topo info for the line was
+ changed) by last write/rewrite/delete operation. Lines/nodes in
+ the list may be deleted (e.g. delete boundary: first added for
+ delete area and then delete
+ int *uplines;
+ \brief Allocated array (level 2)
+ int alloc_uplines;
+ \brief Number of updated lines (level 2)
+ int n_uplines;
+ \brief Array of updated nodes (level 2)
+ int *upnodes;
+ int alloc_upnodes;
+ \brief number of updated nodes (level 2)
+ int n_upnodes;
+/*! \brief
+ Vector map info
+ Maintains all information about an individual open vector map. The
+structure must be passed to the mosy vector library routines.
struct Map_info
- /* Common info for all formats */
- int format; /* format */
- int temporary; /* temporary file flag, not yet used */
+ /* common info for all formats */
+ \brief Format (native, ogr)
+ - GV_FORMAT_NATIVE
+ - GV_FORMAT_OGR
+ - GV_FORMAT_DIRECT
+ int format;
+ \brief Temporary file flag, not yet used
+ int temporary;
- struct dblinks *dblnk; /* info about tables */
+ \brief DB links
+ struct dblinks *dblnk;
- struct Plus_head plus; /* topo file *head; */
+ \brief Header info
+ struct Plus_head plus;
- int graph_line_type; /* line type used to build the graph */
- dglGraph_s graph; /* graph structure */
- dglSPCache_s spCache; /* Shortest path cache */
- double *edge_fcosts; /* costs used for graph, (dglGetEdge() is not supported for _DGL_V1) */
+ /* graph-related section */
+ \brief Graph-related section - line type used to build the graph
+ int graph_line_type;
+ \brief Graph-related section - graph structure
+ dglGraph_s graph;
+ \brief Graph-related section - shortest path cache
+ dglSPCache_s spCache;
+ \brief Graph-related section - forward costs used for graph
+ dglGetEdge() is not supported for _DGL_V1)
+ double *edge_fcosts;
+ \brief Graph-related section - backward costs used for graph
double *edge_bcosts;
- double *node_costs; /* node costs */
- int cost_multip; /* edge and node costs multiplicator */
+ \brief Graph-related section - node costs used for graph
+ double *node_costs;
+ \brief Graph-related section - edge and node costs multiplicator
+ int cost_multip;
- /* All of these apply only to runtime, and none get written out
- ** to the dig_plus file
- int open; /* should be 0x5522AA22 if opened correctly */
- /* or 0x22AA2255 if closed */
- /* anything else implies that structure has */
- /* never been initialized */
- int level; /* 1, 2, (3) */
- int head_only; /* Only header is opened */
- int support_updated; /* Support files were updated */
- plus_t next_line; /* for Level II sequential reads */
+ \brief Open indicator
- char *name; /* for 4.0 just name, and mapset */
+ Should be 0x5522AA22 (VECT_OPEN_CODE) if opened correctly
+ or 0x22AA2255 (VECT_CLOSED_CODE) if closed
+ anything else implies that structure has
+ never been initialized
+ int open;
+ /* Open mode
+ - read (GV_MODE_READ),
+ - write (GV_MODE_WRITE),
+ - rw (GV_MODE_RW)
+ int mode;
+ \brief Topology level
+ - 1 (without topo)
+ - 2 (with topo)
+ - 3 (with 3D topo) - not yet implemented
+ int level;
+ \brief Open only header
+ Non-zero code to open only header of vector map
+ int head_only;
+ \brief Support files were updated
+ Non-zero code to indicate that supoort file were updated
+ int support_updated;
+ \brief Sequential read (level 1)
+ plus_t next_line;
+ \brief Map name (for 4.0)
+ char *name;
+ \brief Mapset name
char *mapset;
/* location and gisdbase is usefull if changed (v.proj or external apps) */
- char *location; /* location name */
- char *gisdbase; /* gisdbase path */
+ \brief Location name
+ char *location;
+ \brief GISDBASE path
+ char *gisdbase;
- /* Constraints for reading in lines (not polys yet) */
+ /* constraints for reading in lines (not polys yet) */
+ \brief Constrainys for reading features (region)
+ Non-zero code to enable this constraint
int Constraint_region_flag;
+ \brief Constraints for reading features (type)
int Constraint_type_flag;
+ \brief Constraints for reading features (north)
double Constraint_N;
+ \brief Constraints for reading features (south)
double Constraint_S;
+ \brief Constraints for reading features (east)
double Constraint_E;
+ \brief Constraints for reading features (west)
double Constraint_W;
+ \brief Constraints for reading features (top)
double Constraint_T;
+ \brief Constraints for reading features (bottom)
double Constraint_B;
int Constraint_type;
+ \brief ???
int proj;
/* format specific */
- /* native */
- GVFILE dig_fp; /* Dig file pointer */
- struct dig_head head; /* coor file head */
+ \brief GV file pointer (native format only)
+ GVFILE dig_fp;
+ \brief Coor file header info (native format only)
+ struct dig_head head;
/* non native */
- struct Format_info fInfo; /* format information */
+ \brief Format info for non-native formats
+ struct Format_info fInfo;
- /* history file */
+ \brief History file
FILE *hist_fp;
/* Temporary solution for sites */
@@ -421,124 +1155,355 @@
int n_site_str; /* number of string attributes for one site */
+ \brief Topological primitive - node
struct P_node
+ \brief X coordinate
double x; /* X coordinate */
- double y; /* Y coordinate */
- double z; /* Z coordinate */
+ \brief Y coordinate
+ double y;
+ \brief Z coordinate (used only for 3D data)
+ double z;
+ \brief Allocated space for lines
plus_t alloc_lines;
- plus_t n_lines; /* Number of attached lines (size of lines, angle) */
- /* If 0, then is degenerate node, for snappingi ??? */
- plus_t *lines; /* Connected lines */
- float *angles; /* Respected angles. Angles for lines/boundaries are in radians between
- * -PI and PI. Value for points or lines with identical points (degenerated)
- * is set to -9. */
+ \brief Number of attached lines (size of
+ lines, angle)
+ If 0, then is degenerate node, for snappingi ???
+ plus_t n_lines;
+ \brief List of connected lines
+ plus_t *lines;
+ \brief List of respected angles
+ Angles for lines/boundaries are in radians between -PI and
+ PI. Value for points or lines with identical points
+ (degenerated) is set to -9.
+ float *angles;
+ \brief Topological primitive - line (edge)
struct P_line
- plus_t N1; /* start node */
- plus_t N2; /* end node */
- plus_t left; /* area/isle number to left, negative for isle */
- /* !!! area number for centroid, negative for */
- /* duplicate centroid */
- plus_t right; /* area/isle number to right, negative for isle */
+ \brief Start node
+ plus_t N1;
+ \brief End node
+ plus_t N2;
+ \brief Area/isle number to left
- double N; /* Bounding Box */
+ - negative for isle
+ - area number for centroid (negative for duplicate centroid)
+ plus_t left;
+ \brief Area/isle number to right
+ plus_t right;
+ \brief Line bounding box - north
+ double N;
+ \brief Line bounding box - south
double S;
+ \brief Line bounding box - east
double E;
+ \brief Line bounding box - west
double W;
+ \brief Line bounding box - top (3D data only)
+ double T;
+ \brief Line bounding box - bottom (3D data only)
+ double B;
- long offset; /* offset in coor file for line */
+ \brief Offset in coor file for line
+ long offset;
+ \brief Line type
+ - GV_POINT
+ - GV_LINE
+ - GV_BOUNDARY
+ - GV_CENTROID
+ - GV_FACE
+ - GV_KERNEL
+ - GV_AREA
+ - GV_VOLUME
int type;
+ \brief Topological primitive - area
struct P_area
+ \brief Area bounding box - north
+ double N;
+ \brief Area bounding box - south
double S;
+ \brief Area bounding box - east
double E;
+ \brief Area bounding box - west
double W;
- plus_t n_lines; /* Number of boundary lines */
+ \brief Area bounding box - top
+ double T;
+ \brief Area bounding box - bottom
+ double B;
+ \brief Number of boundary lines
+ plus_t n_lines;
plus_t alloc_lines;
- plus_t *lines; /* Boundary Lines, negative means direction N2 to N1,
- lines are in clockwise order */
+ \brief List of boundary lines
+ - negative means direction N2 to N1
+ - lines are in clockwise order
+ plus_t *lines;
/********* Above this line is compatible with P_isle **********/
- plus_t centroid; /* Number of first centroid within area */
- plus_t n_isles; /* Number of islands inside */
+ \brief Number of first centroid within area
+ plus_t centroid;
+ \brief Number of islands inside
+ plus_t n_isles;
+ \brief Allocated space for isles
plus_t alloc_isles;
- plus_t *isles; /* 1st generation interior islands */
+ \brief 1st generation interior islands
+ plus_t *isles;
+ \brief Topological primitive - isle
struct P_isle
+ \brief Isle bounding box - north
+ double N;
+ \brief Isle bounding box - south
double S;
+ \brief Isle bounding box - east
double E;
+ \brief Isle bounding box - west
double W;
+ \brief Isle bounding box - top
+ double T;
+ \brief Isle bounding box - bottom
+ double B;
+ plus_t n_lines;
plus_t alloc_lines;
- lines are in counter clockwise order */
+ - lines are in counter clockwise order
+ plus_t *lines;
/********* Above this line is compatible with P_area **********/
- plus_t area; /* area it exists w/in, if any */
+ \brief Area it exists w/in, if any
+ plus_t area;
+ \brief Feature geometry info
struct line_pnts
+ \brief Array of X coordinates
double *x;
+ \brief Array of Y coordinates
double *y;
+ \brief Array of Z coordinates
double *z;
+ \brief Number of points
int n_points;
+ \brief Allocated space for points
int alloc_points;
+ \brief Feature category info
struct line_cats
- int *field; /* pointer to array of fields */
- int *cat; /* pointer to array of categories */
- int n_cats; /* number of vector categories attached to element */
- int alloc_cats; /* allocated space */
+ \brief Array of fields (layers)
+ int *field;
+ \brief Array of categories
+ int *cat;
+ \brief Number of categories attached to element
+ int n_cats;
+ \brief Allocated space for categories
+ int alloc_cats;
+/*! \brief Category list */
struct cat_list
- int field; /* category field */
- int *min; /* pointer to array of minimun values */
- int *max; /* pointer to array of maximum values */
- int n_ranges; /* number ranges */
- int alloc_ranges; /* allocated space */
+ \brief Category field (layer)
+ int field;
+ \brief Array of minimun values
+ int *min;
+ \brief Array of maximum values
+ int *max;
+ \brie Number of ranges
+ int n_ranges;
+ \brief Allocated space for ranges
+ int alloc_ranges;
/* list of integers */
struct ilist
- int *value; /* items */
- int n_values; /* number of values */
- int alloc_values; /* allocated space */
+ \brief Array of values
+ int *value;
+ \brief Number of values in the array
+ int n_values;
+ \brief Allocated space for values
+ int alloc_values;
-/* Vector array. Space allocated is size + 1. */
+ \brief Vector array
+ Space allocated is size + 1
struct varray
- int size; /* array size */
- int *c; /* array where 'class' or new category or something like that is stored */
+ \brief Array size
+ int size;
+ \brief Array
+ Where 'class' or new category
+ or something like that is stored
+ int *c;
typedef struct varray VARRAY;
-/* Spatial index for use in modules. */
+ \brief Spatial index info
+ For use in modules
struct spatial_index
struct Node *root;
