[GRASS-SVN] r45544 - in grass/trunk: gui/wxpython
gui/wxpython/gui_modules lib/python
svn_grass at osgeo.org
Thu Mar 3 18:09:10 EST 2011
Author: martinl
Date: 2011-03-03 15:09:10 -0800 (Thu, 03 Mar 2011)
New Revision: 45544
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/lib/python/core.py
attempt to fix #1293 (Creating mapset with non-latin letter gives python ascii error)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2011-03-03 19:49:36 UTC (rev 45543)
+++ grass/trunk/gui/wxpython/gis_set.py 2011-03-03 23:09:10 UTC (rev 45544)
@@ -26,6 +26,7 @@
import shutil
import copy
import platform
+import codecs
### i18N
import gettext
@@ -46,6 +47,8 @@
import wx.lib.mixins.listctrl as listmix
import wx.lib.scrolledpanel as scrolled
+sys.stderr = codecs.getwriter('utf8')(sys.stderr)
class GRASSStartup(wx.Frame):
"""!GRASS start-up screen"""
def __init__(self, parent = None, id = wx.ID_ANY, style = wx.DEFAULT_FRAME_STYLE):
@@ -54,7 +57,7 @@
# GRASS variables
self.gisbase = os.getenv("GISBASE")
- self.grassrc = self._read_grassrc()
+ self.grassrc = self._readGisRC()
self.gisdbase = self.GetRCValue("GISDBASE")
@@ -376,32 +379,32 @@
self.Layout()
- def _read_grassrc(self):
+ def _readGisRC(self):
"""!Read variables from $HOME/.grass7/rc file
grassrc = {}
gisrc = os.getenv("GISRC")
if gisrc and os.path.isfile(gisrc):
try:
rc = open(gisrc, "r")
for line in rc.readlines():
key, val = line.split(":", 1)
- grassrc[key.strip()] = val.strip()
+ grassrc[key.strip()] = utils.DecodeString(val.strip())
finally:
rc.close()
return grassrc
def GetRCValue(self, value):
- "Return GRASS variable (read from GISRC)"""
+ """!Return GRASS variable (read from GISRC)
if self.grassrc.has_key(value):
return self.grassrc[value]
else:
return None
def OnWizard(self, event):
"""!Location wizard started"""
from gui_modules import location_wizard
@@ -583,10 +586,10 @@
def UpdateMapsets(self, location):
"""!Update list of mapsets"""
self.FormerMapsetSelection = wx.NOT_FOUND # for non-selectable item
self.listOfMapsetsSelectable = list()
self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase, location)
self.lbmapsets.Clear()
# disable mapset with denied permission
@@ -600,10 +603,10 @@
gisdbase = self.gisdbase)
if not ret:
- raise gcmd.CmdError("")
+ raise gcmd.GError(_("No mapsets available in location <%s>") % locationName)
for line in ret.splitlines():
- self.listOfMapsetsSelectable += line.split(' ')
+ self.listOfMapsetsSelectable += line.split(' ')
except:
gcmd.RunCommand("g.gisenv",
set = "GISDBASE = %s" % self.gisdbase)
@@ -639,7 +642,7 @@
self.listOfLocations[self.lblocations.GetSelection()]))
else:
self.listOfMapsets = []
disabled = []
idx = 0
try:
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2011-03-03 19:49:36 UTC (rev 45543)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2011-03-03 23:09:10 UTC (rev 45544)
@@ -600,8 +600,8 @@
ps.stdin.close()
ps.stdin = None
- stdout, stderr = ps.communicate()
+ stdout, stderr = map(lambda x: utils.DecodeString(x) if x and not 'None' else x, ps.communicate())
ret = ps.returncode
if ret != 0 and parent:
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-03-03 19:49:36 UTC (rev 45543)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-03-03 23:09:10 UTC (rev 45544)
@@ -325,9 +325,11 @@
first_dir = dir_node
self.seltree.SetItemTextColour(dir_node, wx.Colour(50, 50, 200))
+ if not filesdict.has_key(dir):
+ continue
try:
elem_list = filesdict[dir]
- elem_list.sort(key=str.lower)
+ elem_list.sort(key = unicode.lower)
for elem in elem_list:
if elem != '':
fullqElem = elem + '@' + dir
@@ -341,9 +343,10 @@
self.AddItem(elem, parent=dir_node)
else:
- except:
+ except StandardError, e:
+ sys.stderr.write(_("GSelect: invalid item: %s") % e)
continue
if self.seltree.ItemHasChildren(dir_node):
sel = UserSettings.Get(group='general', key='elementListExpand',
subkey='selection')
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2011-03-03 19:49:36 UTC (rev 45543)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2011-03-03 23:09:10 UTC (rev 45544)
@@ -619,16 +619,16 @@
if not ret:
return listOfMapsets
for line in ret.rstrip().splitlines():
listOfMapsets += line.split(' ')
else:
for mapset in glob.glob(os.path.join(dbase, location, "*")):
if os.path.isdir(mapset) and \
os.path.isfile(os.path.join(dbase, location, mapset, "WIND")):
- listOfMapsets.append(EncodeString(os.path.basename(mapset)))
+ listOfMapsets.append(os.path.basename(mapset))
- ListSortLower(listOfMapsets)
+ ListSortLower(listOfMapsets)
def GetColorTables():
@@ -641,11 +641,24 @@
return ret.splitlines()
+def DecodeString(string):
+ """!Return decoded string using system locales
+ @param string string to be decoded
+ @return decoded string
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ return string.decode(enc)
+ return string
def EncodeString(string):
- """!Return encoded string
+ """!Return encoded string using system locales
@param string string to be encoded
@return encoded string
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2011-03-03 19:49:36 UTC (rev 45543)
+++ grass/trunk/lib/python/core.py 2011-03-03 23:09:10 UTC (rev 45544)
@@ -30,6 +30,7 @@
import atexit
import subprocess
import shutil
+import locale
# i18N
import gettext
@@ -75,6 +76,13 @@
"preexec_fn", "close_fds", "cwd", "env",
"universal_newlines", "startupinfo", "creationflags"]
+def _decode(string):
+ if enc:
+ return string
def _make_val(val):
if isinstance(val, types.StringType) or \
isinstance(val, types.UnicodeType):
@@ -222,7 +230,7 @@
@return stdout
ps = pipe_command(*args, **kwargs)
- return ps.communicate()[0]
+ return _decode(ps.communicate()[0])
def parse_command(*args, **kwargs):
"""!Passes all arguments to read_command, then parses the output by
