[GRASS-SVN] r45549 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Mar 4 11:05:06 EST 2011
Author: martinl
Date: 2011-03-04 08:05:06 -0800 (Fri, 04 Mar 2011)
New Revision: 45549
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/prompt.py
wxGUI: read/write history file with encoding 'utf-8' (see #1293)
(merge r45548 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-03-04 16:02:06 UTC (rev 45548)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-03-04 16:05:06 UTC (rev 45549)
@@ -24,6 +24,7 @@
import time
import threading
import Queue
+import codecs
import wx
import wx.stc
@@ -412,7 +413,7 @@
def WriteError(self, line):
"""!Write message in error style"""
- self.WriteLog(line, style=self.cmd_output.StyleError, switchPage = True)
+ self.WriteLog(line, style = self.cmd_output.StyleError, switchPage = True)
def RunCmd(self, command, compReg = True, switchPage = False,
onDone = None):
@@ -435,10 +436,13 @@
# update history file
env = grass.gisenv()
try:
- fileHistory = open(os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'],
- '.bash_history'), 'a')
+ fileHistory = codecs.open(os.path.join(env['GISDBASE'],
+ env['LOCATION_NAME'],
+ env['MAPSET'],
+ '.bash_history'),
+ encoding = 'utf-8', mode = 'a')
except IOError, e:
- self.WriteError(str(e))
+ self.WriteError(e)
fileHistory = None
if fileHistory:
@@ -1068,8 +1072,8 @@
elif os.environ.has_key('GRASS_DB_ENCODING'):
txt = unicode(txt, os.environ['GRASS_DB_ENCODING'])
else:
- txt = _('Unable to encode text. Please set encoding in GUI preferences.') + '\n'
+ txt = utils.EncodeString(txt)
self.AddText(txt)
# reset output window to read only
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2011-03-04 16:02:06 UTC (rev 45548)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2011-03-04 16:05:06 UTC (rev 45549)
@@ -24,6 +24,7 @@
import shlex
import copy
import difflib
+import codecs
import wx
import wx.stc
@@ -505,10 +506,11 @@
hist = list()
try:
- env['LOCATION_NAME'],
- env['MAPSET'],
- '.bash_history'), 'r')
+ env['MAPSET'],
+ '.bash_history'),
+ encoding = 'utf-8', mode = 'r')
except IOError:
return hist
@@ -1059,6 +1061,7 @@
cmd = utils.split(str(line))
except UnicodeError:
cmd = utils.split(utils.EncodeString((line)))
+ cmd = map(utils.DecodeString, cmd)
# send the command list to the processor
if cmd[0] in ('r.mapcalc', 'r3.mapcalc') and len(cmd) == 1:
