[GRASS-SVN] r45576 - in grass/trunk: lib/init mswindows/osgeo4w
svn_grass at osgeo.org
Sat Mar 5 13:21:31 EST 2011
Author: martinl
Date: 2011-03-05 10:21:31 -0800 (Sat, 05 Mar 2011)
New Revision: 45576
Added:
grass/trunk/mswindows/osgeo4w/grass.bat.tmpl
grass/trunk/lib/init/grass.py
grass/trunk/mswindows/osgeo4w/package.sh
osgeo4w: grass.bat.tmpl added / grass.py updated for osgeo4w
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-03-05 16:40:43 UTC (rev 45575)
+++ grass/trunk/lib/init/grass.py 2011-03-05 18:21:31 UTC (rev 45576)
@@ -3,19 +3,18 @@
# MODULE: GRASS initialization (Python)
# AUTHOR(S): Original author unknown - probably CERL
-# Andreas Lange - Germany - andreas.lange at rhein-main.de
-# Huidae Cho - Korea - grass4u at gmail.com
-# Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
-# Markus Neteler - Germany/Italy - neteler at itc.it
-# Hamish Bowman - New Zealand - hamish_b at yahoo,com
+# Andreas Lange <andreas.lange rhein-main.de>
+# Huidae Cho <grass4u gmail.com>
+# Justin Hickey <jhickey hpcc.nectec.or.th>
+# Markus Neteler <neteler osgeo.org>
+# Hamish Bowman <hamish_b yahoo,com>
# Converted to Python (based on init.sh) by Glynn Clements
-# Martin Landa - Czech Republic - landa.martin at gmail.com
-# PURPOSE: Sets up some environment variables.
-# It also parses any remaining command line options for
-# setting the GISDBASE, LOCATION, and/or MAPSET.
-# Finally it starts GRASS with the appropriate user
+# Martin Landa <landa.martin gmail.com>
+# PURPOSE: Sets up environment variables, parses any remaining
+# command line options for setting the GISDBASE, LOCATION,
+# and/or MAPSET. Finally it starts GRASS with the appropriate user
# interface and cleans up after it is finished.
-# COPYRIGHT: (C) 2000-2010 by the GRASS Development Team
+# COPYRIGHT: (C) 2000-2011 by the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -32,17 +31,22 @@
import platform
# Variables substituted during build process
-# Set the GISBASE variable
-gisbase = "@GISBASE@"
+if os.environ.has_key('GISBASE'):
+ gisbase = os.environ['GISBASE']
+else:
+ gisbase = "@GISBASE@"
cmd_name = "@START_UP@"
grass_version = "@GRASS_VERSION_NUMBER@"
ld_library_path_var = '@LD_LIBRARY_PATH_VAR@'
-config_projshare = "@CONFIG_PROJSHARE@"
+if os.environ.has_key('GRASS_PROJSHARE'):
+ config_projshare = os.environ['GRASS_PROJSHARE']
+else:
+ config_projshare = "@CONFIG_PROJSHARE@"
grass_config_dirname = "@GRASS_CONFIG_DIR@"
gisbase = os.path.normpath(gisbase)
-### i18N
+# i18N
import gettext
gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode=True)
@@ -67,16 +71,16 @@
except:
pass
-def cleanup_dir(dir):
- if not dir:
+def cleanup_dir(path):
+ if not path:
return
- for root, dirs, files in os.walk(dir, topdown = False):
+ for root, dirs, files in os.walk(path, topdown = False):
for name in files:
- try_remove(os.path.join(root, name))
+ try_remove(os.path.join(root, name))
for name in dirs:
- try_rmdir(os.path.join(root, name))
+ try_rmdir(os.path.join(root, name))
def cleanup():
tmpdir, lockfile
# all exits after setting up $tmpdir should also tidy it up
@@ -90,7 +94,7 @@
def message(msg):
sys.stderr.write(msg + "\n")
sys.stderr.flush()
def readfile(path):
f = open(path, 'r')
s = f.read()
@@ -200,11 +204,11 @@
s = None
except:
s = None
# Copy the global grassrc file to the session grassrc file
if s:
writefile(gisrc, s)
def read_gisrc():
kv = {}
f = open(gisrc, 'r')
@@ -237,7 +241,7 @@
if not grass_gui:
grass_gui = default_gui
if grass_gui == 'gui':
@@ -276,14 +280,14 @@
path_prepend(addon_path, 'PATH')
path_prepend(gfile('scripts'), 'PATH')
path_prepend(gfile('bin'), 'PATH')
# Set PYTHONPATH to find GRASS Python modules
path_prepend(gfile('etc', 'python'), 'PYTHONPATH')
# Add .py (Python) to list of executable extensions to search for in MS-Windows PATH
if windows:
path_append('.PY', 'PATHEXT')
def find_exe(pgm):
for dir in os.getenv('PATH').split(os.pathsep):
path = os.path.join(dir, pgm)
@@ -303,26 +307,26 @@
else:
pager = "cat"
os.environ['GRASS_PAGER'] = pager
# GRASS_WISH
if not os.getenv('GRASS_WISH'):
os.environ['GRASS_WISH'] = "wish"
# GRASS_PYTHON
if not os.getenv('GRASS_PYTHON'):
if windows:
os.environ['GRASS_PYTHON'] = "python.exe"
else:
os.environ['GRASS_PYTHON'] = "python"
# GRASS_GNUPLOT
if not os.getenv('GRASS_GNUPLOT'):
os.environ['GRASS_GNUPLOT'] = "gnuplot -persist"
# GRASS_PROJSHARE
if not os.getenv('GRASS_PROJSHARE'):
os.environ['GRASS_PROJSHARE'] = config_projshare
def set_browser():
# GRASS_HTML_BROWSER
browser = os.getenv('GRASS_HTML_BROWSER')
@@ -331,7 +335,7 @@
# OSX doesn't execute browsers from the shell PATH - route thru a script
browser = gfile('etc', "html_browser_mac.sh")
os.environ['GRASS_HTML_BROWSER_MACOSX'] = "-b com.apple.helpviewer"
if windows or cygwin:
# MinGW startup moved to into init.bat
browser = "explorer"
@@ -348,7 +352,7 @@
os.environ['GRASS_HTML_BROWSER_MACOSX'] = "-b %s" % browser
if not browser:
warning(_("Searched for a web browser, but none found"))
# even so we set konqueror to make lib/gis/parser.c happy:
@@ -367,11 +371,11 @@
for line in f:
sys.stderr.write(line)
f.close()
sys.stderr.write("\n")
sys.stderr.write(_("Hit RETURN to continue"))
sys.stdin.readline()
#for convenience, define pwd as GISDBASE:
s = r"""GISDBASE: %s
LOCATION_NAME: <UNKNOWN>
@@ -405,7 +409,7 @@
"Hit RETURN to continue.\n"))
grass_gui = 'text'
else:
# Display a message if a graphical interface was expected
if grass_gui != 'text':
@@ -416,7 +420,7 @@
"Hit RETURN to continue"""))
grass_gui = 'text'
# Save the user interface variable in the grassrc file - choose a temporary
# file name that should not match another file
if os.access(gisrc, os.F_OK):
@@ -428,28 +432,28 @@
global gisdbase, location_name, mapset, location
# Try non-interactive startup
l = None
if arg == '-':
if location:
l = location
else:
l = arg
if l:
if l == '.':
l = os.getcwd()
elif not os.path.isabs(l):
l = os.path.abspath(l)
l, mapset = os.path.split(l)
if not mapset:
l, location_name = os.path.split(l)
gisdbase = l
if gisdbase and location_name and mapset:
location = os.path.join(gisdbase, location_name, mapset)
if not os.access(os.path.join(location, "WIND"), os.R_OK):
if location_name == "PERMANENT":
fatal(_("<%s> is not a valid GRASS location") % location)
@@ -466,12 +470,12 @@
message(_("Missing WIND file fixed"))
else:
if os.access(gisrc, os.R_OK):
kv = read_gisrc()
else:
kv = {}
kv['GISDBASE'] = gisdbase
kv['LOCATION_NAME'] = location_name
kv['MAPSET'] = mapset
@@ -479,7 +483,7 @@
else:
fatal(_("GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
"Interactive startup needed."))
def set_data():
# User selects LOCATION and MAPSET if not set
if not location:
@@ -493,7 +497,7 @@
# Shouldn't need this but you never know
fatal(_("Invalid user interface specified - <%s>.\n"
"Use the --help option to see valid interface names.") % grass_gui)
def gui_startup():
if grass_gui == 'wxpython':
thetest = call([os.getenv('GRASS_PYTHON'),
@@ -509,7 +513,7 @@
"Switching to text mode now.\n\n"
"Hit RETURN to continue..."))
os.execlp(cmd_name, "-text")
sys.exit(1)
elif thetest == 2:
@@ -519,7 +523,7 @@
else:
fatal(_("Invalid return code from GUI startup script.\n"
"Please advise GRASS developers of this error."))
def load_gisrc():
kv = read_gisrc()
@@ -553,7 +557,7 @@
{ 'user' : user, 'file' : lockfile })
else:
msg = _("Unable to properly access \"%s\"\nPlease notify system personel.") % lockfile
if msg:
if grass_gui == "wxpython":
thetest = call([os.getenv('GRASS_PYTHON'), os.path.join(wxpython_base, "gis_set_error.py"), msg])
@@ -565,7 +569,7 @@
if fc and not os.access(fc, os.R_OK):
message(_("Building user fontcap..."))
call(["g.mkfontcap"])
def check_shell():
global sh, shellname
# cygwin has many problems with the shell setup
@@ -589,11 +593,11 @@
shellname = "Bourne Shell"
else:
shellname = "shell"
# check for SHELL
if not os.getenv('SHELL'):
fatal(_("The SHELL variable is not set"))
def check_batch_job():
global batch_job
# hack to process batch jobs:
@@ -615,7 +619,7 @@
bj = Popen(shell,shell=True)
bj.wait()
message(_("Execution of '%s' finished.") % batch_job)
def start_gui():
# Start the chosen GUI but ignore text
if grass_debug:
@@ -634,7 +638,7 @@
else:
if not os.getenv('GRASS_BATCH_JOB') and not grass_debug:
call(["tput", "clear"])
def show_banner():
sys.stderr.write(r"""
__________ ___ __________ _______________
@@ -668,43 +672,43 @@
shellname, os.getenv('SHELL'),
_("Help is available with the command:"),
_("See the licence terms with:")))
message("%-41sg.gui wxpython" % _("If required, restart the GUI with:"))
else:
message("%-41sg.gui %s" % (_("Start the GUI with:"), default_gui))
message("%-41sexit" % _("When ready to quit enter:"))
message("")
def csh_startup():
global exit_val
userhome = os.getenv('HOME') # save original home
home = location
os.environ['HOME'] = home
cshrc = os.path.join(home, ".cshrc")
tcshrc = os.path.join(home, ".tcshrc")
try_remove(cshrc)
try_remove(tcshrc)
f = open(cshrc, 'w')
f.write("set home = %s" % userhome)
f.write("set history = 3000 savehist = 3000 noclobber ignoreeof")
f.write("set histfile = %s" % os.path.join(os.getenv('HOME'), ".history"))
f.write("set prompt = '\\")
f.write("Mapset <%s> in Location <%s> \\" % (mapset, location_name))
f.write("GRASS %s > '" % grass_version)
f.write("set BOGUS=``;unset BOGUS")
path = os.path.join(userhome, ".grass.cshrc")
if os.access(path, os.R_OK):
f.write(readfile(path))
mail_re = re.compile(r"^ *set *mail *= *")
for filename in [".cshrc", ".tcshrc", ".login"]:
path = os.path.join(userhome, filename)
@@ -713,17 +717,17 @@
for l in lines:
if mail_re.match(l):
f.write(l)
path = os.getenv('PATH').split(':')
f.write("set path = ( %s ) " % ' '.join(path))
f.close()
writefile(tcshrc, readfile(cshrc))
exit_val = call([gfile("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
def bash_startup():
global exit_val
@@ -775,7 +779,7 @@
else:
os.environ['PS1'] = "GRASS %s (%s):\w > " % (grass_version, location_name)
if exit_val != 0:
fatal(_("Failed to start shell '%s'") % os.getenv('SHELL'))
@@ -789,13 +793,13 @@
message("")
message(_("Goodbye from GRASS GIS"))
message("")
def clean_temp():
message(_("Cleaning up temporary files..."))
nul = open(os.devnull, 'w')
call([gfile("etc", "clean_temp")], stdout = nul, stderr = nul)
nul.close()
def get_username():
global user
if windows:
@@ -816,7 +820,7 @@
pass
if not user:
user = "user_%d" % os.getuid()
def parse_cmdline():
global args, grass_gui, create_new
args = []
@@ -946,7 +950,7 @@
check_gui()
# Parsing argument to get LOCATION
-if args == []:
+if not args:
# Try interactive startup
location = None
else:
@@ -992,7 +996,7 @@
show_info()
message(_("Launching '%s' GUI in the background, please wait...") % grass_gui)
if sh in ['csh', 'tcsh']:
csh_startup()
elif sh in ['bash', 'msh', 'cygwin']:
@@ -1014,6 +1018,6 @@
cleanup()
-#### after this point no more grass modules may be called ####
+# After this point no more grass modules may be called
done_message()
Added: grass/trunk/mswindows/osgeo4w/grass.bat.tmpl
--- grass/trunk/mswindows/osgeo4w/grass.bat.tmpl (rev 0)
+++ grass/trunk/mswindows/osgeo4w/grass.bat.tmpl 2011-03-05 18:21:31 UTC (rev 45576)
@@ -0,0 +1,4 @@
+ at echo off
+call @OSGEO4W_ROOT@\bin\o4w_env.bat
+call @OSGEO4W_ROOT@\apps\grass\grass- at VERSION@\etc\env.bat
+call %GRASS_PYTHON% @OSGEO4W_ROOT@\bin\grass at POSTFIX@.py
Modified: grass/trunk/mswindows/osgeo4w/package.sh
--- grass/trunk/mswindows/osgeo4w/package.sh 2011-03-05 16:40:43 UTC (rev 45575)
+++ grass/trunk/mswindows/osgeo4w/package.sh 2011-03-05 18:21:31 UTC (rev 45576)
@@ -64,8 +64,8 @@
export VERSION=$MAJOR.$MINOR.$PATCH
-export GRASS_PYTHON=/c/OSGeo4W/apps/Python25
-export PYTHONHOME=/c/OSGeo4W/apps/Python25
+export GRASS_PYTHON="/c/OSGeo4W/bin/python.exe"
+export PYTHONHOME="/c/OSGeo4W/apps/Python25"
if [ -f mswindows/osgeo4w/package.log ]; then
i=0
@@ -134,7 +134,9 @@
$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
cp mswindows/osgeo4w/config.h.switch $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
cp mswindows/osgeo4w/config.h.vc $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass
-sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT@#$OSGEO4W_ROOT#g" \
+sed -e "s#@OSGEO4W_ROOT_MSYS@#$OSGEO4W_ROOT_MSYS#g" -e "s#@VERSION@#$VERSION#g" -e "s#@POSTFIX@#$MAJOR$MINOR#g" \
+ mswindows/osgeo4w/grass.tmpl >$OSGEO4W_ROOT_MSYS/bin/grass$MAJOR$MINOR
+sed -e "s#@VERSION@#$VERSION#g" -e "s#@POSTFIX@#$MAJOR$MINOR#g" -e "s#@OSGEO4W_ROOT@#$OSGEO4W_ROOT#g" \
mswindows/osgeo4w/grass.bat.tmpl >$OSGEO4W_ROOT_MSYS/bin/grass$MAJOR$MINOR.bat
sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT_MSYS@#$OSGEO4W_ROOT#g" \
mswindows/osgeo4w/env.bat.tmpl >$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/env.bat
